    4 Axis Z - Setup
    437
    • fcwiltundefined
      fcwilt @Snyggis 0
      @Snyggis-0
      I don't understand the following:
      "drive all 4 Z steppers up to their top ends" - normally you would move the bed down to get it away from the nozzle so you could do homing.
      Since you have installed 4 Z endstops why don't you simply home Z using G1 H1 commands and when Z is homed you can move it to a safe location (say Z=10) for homing X and Y?
      How does the "home to hard stop" feature enter into this? Is it something that has to be done before you can use the servos for normal G1 movments?
        droftarts administrators @fcwilt
        @fcwilt I'm guessing the bed doesn't move, but the X and Y axes are lifted by Z, like a Voron 2.4. Is that correct @Snyggis-0 ?
        • fcwiltundefined
          fcwilt @droftarts
          @droftarts
          Moving the XY gantry instead of the bed????
          That's almost as bad as setting 0,0 at the left front corner! 😀
          Snyggis 0undefined 1 Reply Last reply Reply Quote 0
          • Snyggis 0undefined
            Snyggis 0 @fcwilt
            @fcwilt
            Ha! Well.. looks like I could use some advice here. Please have a look at the pictures for perspective. This is my first experience with Duet and I'm learning.
            1800mm cubic volume, the gantry moves with the light weight print head. The glass plate is fixed at the bottom. You can see the 4 stepper motors in each corner, there is a lead screw which raises and lowers each side. I was imagining a homing program where they all move up in z until they hit the switches. If there is a better way to do this I am WIDE open to suggestions?? Struggling to think of how to get each corner level.
            I am using ClearPath servos for the X and Y Axis.
            https://teknic.com/model-info/CPM-SDHP-2310S-ELN/?model_voltage=75VDC
            They have a nice feature where they move at a reduced torque into a hard stop. I was thinking of bumping the X/Y into stops and setting the position at -900mm for both X and Y. Is there a better way of doing this?
            Thanks for your advice!
            -Snyggis
            • fcwiltundefined
              fcwilt @Snyggis 0
              @Snyggis-0
              You certainly can use the 4 Z steppers when you have "matching" 4 Z endstops to level the bed BUT it depends on getting the Z endstops into the exact positions to obtain a level bed.
              It is easier to just get the positions of the Z endstops close so the bed, after homing, is more or less level and THEN use Auto Bed Leveling (the G32 command which runs your bed.g file) which probes the bed in 4 locations (in your case) and adjusts the Z steppers to achieve a perfectly level bed.
              Here is an example of a bed.g file to do Auto Bed Leveling:
              ; --- example of bed.g to do auto bed leveling with 4 Z steppers ---
              M290 R0 S0 ; clear baby stepping
              G29 S2     ; cancel mesh bed compensation
              ; --- specify where Z leadscrews are ---
              ; M671: Define positions of Z leadscrews
              ; Xnn:nn:nn:nn... list of 4 X coordinates of the pivot points of the gantry where it connects to the Z axis
              ; Ynn:nn:nn:nn.   list of 4 Y coordinates of the pivot points of the gantry where it connects to the Z axis
              ; Snn          maximum correction allowed for each leadscrew in mm (optional, default 1.0)
              ; Fnn          fudge factor, default 1.0
              ; *** important ***
              ; Xaaa and Yeee are for the 1st Z stepper in your M584 command
              ; Xbbb and Yfff are for the 2nd Z stepper in your M584 command
              ; Xccc and Yggg are for the 3rd Z stepper in your M584 command
              ; Xddd and Yhhh are for the 4th Z stepper in your M584 command
              M671 Xaaa:bbb:ccc:ddd Yeee:fff:ggg:hhh ; replace the letters with the actual values for your machine
              ; --- level bed ---
              while true
                ; run leveling pass
                ; --- probe near bed corners --- again replace the letters with the actual values for your bed
                G30 P0 Xaaa  Ybbb  Z-99999    ; probe near LF corner
                G30 P1 Xccc  Yddd  Z-99999    ; probe near LR corner
                G30 P2 Xeee  Yfff  Z-99999    ; probe near RR corner
                G30 P2 Xggg  Yhhh  Z-99999 S4 ; probe near RF corner
                ; check results - exit loop if results are good
                if move.calibration.initial.deviation < 0.02
                  set var.success = true
                  break
                ; check pass limit - exit loop if pass limit reached
                if iterations = 5
                  set var.success = false
                  break
              ; --- end of while loop ---
              ; --- set the Z=0 Datum ---
              G90
              G1 Xaaa Ybbb F6000 ; move probe to bed center
              G30
                Snyggis 0 @fcwilt
                @fcwilt Makes sense. In the case of an error where the part is stopped mid print, you have to remove the part. I suppose this is inevitable if you want to re-zero the bed.
                Questions:
                Endstop positions - should be slightly above the bed?
                Z Probe - Do you have any suggestions for a machine like this?
                I
                • fcwiltundefined
                  fcwilt @Snyggis 0
                  @Snyggis-0 said in 4 Axis Z - Setup:
                  Yes 10 mm should be adequate. You just don't want to damage anything by colliding with the bed.
                  What is the bed made out of? What type of surface are you going to print on?
                    Snyggis 0 @fcwilt
                    @fcwilt I am planning on a large tempered glass surface.
                    fcwiltundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    • fcwiltundefined
                      fcwilt @Snyggis 0
                      @Snyggis-0
                      I think you are pretty much limited to a BLTouch-like device or a removable micro-switch like a Euclid.
                      You might find a inductive that would have enough range to "reach" through the glass to the metal below - assuming there is metal below.
                      Capacitive units would work with the glass but all the ones I have seen and tested had a slow response time meaning a rather low probing speed to obtain reasonable accuracy.
                        droftarts administrators @Snyggis 0
                        @Snyggis-0 I'm going to disagree with @fcwilt here. I think you should have your Z endstops at the opposite end of Z from the bed. Reason? You have a very big printer. Big prints take a long time. Power failures are more likely. You don't want the only way of re-levelling the XY gantry to be close to the bed.
                        I'd have adjustable endstops at the high end of Z. Initially home Z to them, then run a four-point bed calibration (G32 - see https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_auto_levelling). Adjust the endstops so that subsequent G32s cause no change. You will also have to accurately set the Z height. That should allow you to restart a print job following a power failure. Repeat every so often to check accuracy. You could do this with Z stalling, but it's often less accurate on screw driven axes, and harder to dial in.
                        You don't always need to use these endstops for regular Z homing; whatever probe you use should be sufficient, and will save lifting the gantry up and down a lot.
                        • fcwiltundefined
                          fcwilt @droftarts
                          @droftarts
                          I absolutely agree with your thoughts if your concern is power failures.
                          I don't like power failures for variety of reasons.
                          So my approach was to install a propane powered generator with automatic transfer plus dual-conversion UPS units with enough runtime to power the printers until the generator kicks in, which is typically 30 seconds.
                          Overkill? Probably but its nice to have power that doesn't go away because a storm rolls in. I will admit that I only have enough propane in the tank for 10 days, so a serious power outage due to say, storm damage, may mean I will lose power.
                          Moving the endstops is a much cheaper solution. 😁
