    Duet 6HC randomly crasing (again)
    902
    • chrishammundefined
      chrishamm administrators @agmeadows
      @agmeadows Consider upgrading to v3.4.6, v3.4.5 is no longer supported. I've seen similar error messages before and they were all caused by electrostatic discharge. Make sure you have all the machine parts properly grounded including the hotend.
      Duet software engineer
      agmeadowsundefined 1 Reply Last reply Reply Quote 0
      • agmeadowsundefined
        agmeadows @chrishamm
        @chrishamm I verified continuity between the hotend and Duet ground. Are there any other methods to check to make sure it is properly grounded? I have another thermistor on the way just in case that is causing a problem.
          agmeadows
          So I've done the following:
          Upgraded to firmware and web control to 3.5
          Replaced the thermistor
          Verified ground from the heatblock to ground on the Duet (Continuity check between Power In GND and metal of the heat block)
          Printed without filament to verify its not a general issue with the board
          I cannot reliably recreate the issue. It does seem ESD related, but I am not sure what would be causing it. Are there any steps I can take to narrow it down ? What else could be affected by ESD that would crash the board?
          M122:
          RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.01 (standalone mode)
          Board ID: 08DJM-956BA-NA3TJ-6JTD8-3SJ6J-1UA2U
          Used output buffers: 1 of 40 (37 max)
          Error in macro line 97 while starting up: Accelerometer not found on specified port
          Static ram: 154852
          Dynamic ram: 122208 of which 168 recycled
          Never used RAM 65428, free system stack 143 words
          Tasks: NETWORK(1,ready,511.4%,147) ETHERNET(5,nWait,1.1%,317) HEAT(3,nWait,0.4%,323) Move(4,nWait,0.0%,225) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.1%,343) TMC(4,nWait,108.8%,59) MAIN(1,running,687.7%,137) IDLE(0,ready,0.0%,30), total 1309.6%
          Owned mutexes:
          Last reset 01:43:20 ago, cause: software
          Last software reset at 2023-12-01 11:04, reason: MemoryProtectionFault mmarValid daccViol, Gcodes spinning, available RAM 65236, slot 0
          Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x00000008 SP 0x20421720 Task Move Freestk 357 ok
          Stack: 204322a4 00000000 00000001 00000001 ffffffff 00448f75 004469a4 01000000 00446983 00000000 00000000 00000000 00000001 00000000 204322a4 00000000 20432418 00000000 00000001 00000002 00448f75 204332a0 2043258c 20433a54 204341d8 a5a5a5a5 42ba9810
          Error status: 0x00
          MCU temperature: min 28.2, current 28.5, max 34.6
          Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
          Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/884/728, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 328, reads 61679, writes 29 timeouts 0
          Driver 1: standstill, SG min 0, mspos 552, reads 61679, writes 29 timeouts 0
          Driver 2: standstill, SG min 0, mspos 696, reads 61679, writes 29 timeouts 0
          Driver 3: standstill, SG min 0, mspos 424, reads 61680, writes 29 timeouts 0
          Driver 4: standstill, SG min 0, mspos 216, reads 61680, writes 29 timeouts 0
          Driver 5: standstill, SG min n/a, mspos 936, reads 61693, writes 16 timeouts 0
          Date/time: 2023-12-01 12:47:22
          Slowest loop: 8.37ms; fastest: 0.07ms
          === Storage ===
          Free file entries: 20
          SD card longest read time 4.1ms, write time 0.0ms, max retries 0
          DMs created 125, segments created 20, maxWait 5142791ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
          no step interrupt scheduled
          Moves shaped first try 31, on retry 0, too short 0, wrong shape 0, maybepossible 0
          === DDARing 0 ===
          Scheduled moves 89, completed 89, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
          === DDARing 1 ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
          Heater 0 is on, I-accum = 0.3
          Heater 1 is on, I-accum = 0.0
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x80000007
          Code queue 0 is empty
          Code queue 1 is empty
          === Filament sensors ===
          Extruder 0: pos -8.44, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
          === CAN ===
          Messages queued 55800, received 0, lost 0, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 31001/0/0
          Tx timeouts 0,0,31000,0,0,24798 last cancelled message type 30 dest 127
          === Network ===
          Slowest loop: 36.19ms; fastest: 0.03ms
          Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 2 of 8
          = Ethernet =
          Interface state: active
          Error counts: 0 0 0 1 0 0
          === Multicast handler ===
          Responder is inactive, messages received 0, responses 0
            agmeadows
            Another crash...
            Used output buffers: 3 of 40 (38 max)
            Static ram: 154852
            Dynamic ram: 121344 of which 640 recycled
            Never used RAM 66300, free system stack 204 words
            Tasks: NETWORK(1,ready,39.1%,182) ETHERNET(5,nWait,0.1%,317) HEAT(3,nWait,0.0%,323) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,343) TMC(4,nWait,8.3%,59) MAIN(1,running,52.5%,137) IDLE(0,ready,0.0%,30), total 100.0%
            Owned mutexes:
            Last reset 00:35:24 ago, cause: software
            Last software reset at 2023-12-01 15:03, reason: MemoryProtectionFault mmarValid daccViol, Gcodes spinning, available RAM 65236, slot 1
            Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400004 BFAR 0x0000bbb1 SP 0x2045ff48 Task NETW Freestk 65426 ok
            Stack: 0000bba9 2045f0b4 0000bba9 00008103 00000000 00445189 00446808 210f0027 00446809 4000c000 00000000 2042194c 204322b8 00000000 0044aa39 40000000 00000000 2042b730 810343b1 2042b740 ffffffed 00000000 00f00000 e000e000 c0000000 00000000 00497f6b
            Error status: 0x00
            MCU temperature: min 28.2, current 28.4, max 32.0
            Supply voltage: min 23.8, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/156/0, gc cycles 0
            Driver 0: standstill, SG min n/a, mspos 488, reads 17047, writes 16 timeouts 0
            Driver 1: standstill, SG min n/a, mspos 936, reads 17048, writes 16 timeouts 0
            Driver 2: standstill, SG min n/a, mspos 888, reads 17048, writes 16 timeouts 0
            Driver 3: standstill, SG min n/a, mspos 616, reads 17048, writes 16 timeouts 0
            Driver 4: standstill, SG min n/a, mspos 408, reads 17048, writes 16 timeouts 0
            Driver 5: standstill, SG min n/a, mspos 56, reads 17048, writes 16 timeouts 0
            Date/time: 2023-12-01 15:38:26
            Slowest loop: 6.91ms; fastest: 0.07ms
            === Storage ===
            SD card longest read time 4.0ms, write time 0.0ms, max retries 0
            DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
            Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
            === DDARing 0 ===
            === DDARing 1 ===
            Q0 segments left 0, axes/extruders owned 0x80000003
            Extruder 0: pos -3.10, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
            === CAN ===
            Messages queued 19121, received 0, lost 0, boc 0
            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 10624/0/0
            Tx timeouts 0,0,10623,0,0,8496 last cancelled message type 30 dest 127
            === Network ===
            Slowest loop: 34.18ms; fastest: 0.03ms
            = Ethernet =
              Thanks for the M122 reports.
              Can you share your config.g and some details about your printer?
                Can you try this test firmware?
                https://www.dropbox.com/scl/fo/9hum0skl7rew21go56q7z/h?rlkey=mh1wx7mi72oz0dmk86c7uf4un&dl=0
                  agmeadows
                  Here is the config.g
                  ;Initialize variables
                  if !exists(global.materialtype)
                  	global materialtype = ""
                  if !exists(global.materialprint)
                  	global materialprint = ""
                  if !exists(global.materialstandby)
                  	global materialstandby = ""
                  if !exists(global.materialbed)
                  	global materialbed = ""
                  if !exists(global.machineheater)
                  	global machineheater = 0
                  if !exists(global.inFilamentError)
                  	global inFilamentError = false
                  ;General Setup - RailCore RRF Duet3
                  M552 P0.0.0.0 S1
                  G21								;Work in millimetres
                  G90								;Send absolute coordinates...
                  M83								;...but relative extruder moves
                  ; Stepper configuration
                  M569 P0 S0 D3					;Drive 0 X / Rear
                  M569 P1 S1 D3					;Drive 1 Y / Front
                  M569 P2 S1 D3					;Drive 2 Z Front Left
                  M569 P3 S1 D3					;Drive 3 Z Rear Left
                  M569 P4 S1 D3					;Drive 4 Z Right
                  M569 P5 S1 D3					;Drive 5 Extruder
                  ;Axis configuration
                  M669 K1							;CoreXY mode
                  M584 X0 Y1 Z2:3:4 E5			;Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5
                  ;Leadscrew locations
                  M671 X-13.6:-13.3:340 Y22:278:149 S7.5
                  M350 X16 Y16 Z16 E16 I1				;Set 16x microstepping for axes with interpolation
                  M906 X1500 Y1500 Z1200 E1200 I10	;Set motor currents (mA)
                  ; Fully commissioned speeds.
                  M201 X3000 Y8000 Z100 E1500       ; Accelerations (mm/s^2)
                  M203 X24000 Y24000 Z800 E3600     ; Maximum speeds (mm/min)
                  M566 X1000 Y1000 Z100 E600 P1     ; Maximum jerk speeds mm/minute
                  M208 X290 Y290 Z275				;Set axis maxima and high homing switch positions (adjust to suit your machine)
                  M208 X0 Y0 Z0 S1				;Set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
                  M92 X200 Y200 Z1600 E696		;Orbiter
                  ;M92 X200 Y201 Z1600 E835    	;Bowden
                  ;Mesh leveling parameters
                  M557 X1:300 Y38:290 P21:21
                  ; End Stops
                  M574 X1 S1 P"io1.in"				;Map the X endstop to io1.in
                  M574 Y1 S1 P"io2.in"				;May the Y endstop to io2.in
                  ; Filament Sensor
                  M591 D0 P5 C"io5.in" R60:215 E3.0 S0 A1 L0.406 ;Duet3D laser sensor for extruder drive 0, connected to IO 5, tolerance 60 to 215%, 3mm comparison length, disabled
                  ; Thermistors
                  M308 S2 P"temp3" Y"thermistor" A"chamber_temp" T100000 B3950 H0 L0			;Chamber thermistor
                  M308 S0 P"temp2" Y"thermistor" A"plate_heat" T100000 B3960 H0 L0			;Plate thermistor
                  M308 S1 P"temp1" Y"thermistor" A"e0_heat" T100000 B4725 C7.06e-8 H0 L0		;E3D thermistor
                  ;Define Heaters
                  M950 H0 C"out0" T0				;Bed heater is on out0
                  M950 H1 C"out1" T1				;Hotend heater is on out1
                  M950 H2 C"out2" T2				;Chamber heater is on out2
                  ;Define Bed
                  M140 H0
                  ;Define Chamber
                  M141 H2
                  M307 H0 R0.394 K0.158:0.000 D13.55 E1.35 S1.00 B0		;Bed Duet 3 configuration
                  M307 H1 R2.812 K0.374:0.000 D4.13 E1.35 S1.00 B0 V23.8  ;Phaetus Hotend Duet 3 configuration
                  M307 H2 R0.048 K0.134:0.000 D16.81 E1.35 S1.00 B0		;Chamber calibration
                  ;M307 H2 R0.425 K0.744:0.000 D14.76 E1.35 S1.00 B0
                  ;old hotend value M307 H1 A310.1 C144.7 D2.6 S1.00 B0
                  ;old bed value M307 H0 A90.0 C700.0 D10.0 S1.00 B0
                  M570 H0 T15							;Set hot end fault behaviour. 15C excursion before error
                  M143 H1 S300						;Set max hotend temperature
                  M143 H0 S150						;Set max bed temp
                  M950 F0 C"out6"	Q100				;Layer fan on  "out6" connector
                  M106 P0 S0 H-1 C"Part Fan"			;Layer fan
                  M950 F1 C"out8"                     ;Hotend fan on "out8" connector without PWM
                  M106 P1 C"Hotend Fan" 	            ;M106 P1 S255 H1 T50 "Hotend Fan"	;enable thermostatic mode for hotend fan
                  M950 F2 C"out7" Q2500				;Heater cooling fan on  "out7" connector
                  M106 P2 S0 C"Cooling Fan"			;Heater cooling fan
                  M950 F3 C"out4"     		    	;Extruder fan on "out4" connector
                  M106 P3 T40 H2 C"Extruder Fan"		;Extruder fan
                  ; Accelerometer
                  M955 P0 C"spi.cs3+spi.cs2" ; all wires connected to temp DB connector
                  ; Input Shaping
                  M593 P"mzv" F70
                  ; Tool definitions
                  M563 P0 D0 H1 F0	                        ;Define tool 0 uses extruder 1, heater 1 and fan 1
                  G10 P0 S0 R0                        		;Set tool 0 operating and standby temperatures
                  ; Pressure Advance
                  ; M572 D0 S0.01 ; set extruder 0 pressure advance to 0.01 seconds
                  ; Euclid
                  M558 P5 C"^io7.in" H3 F500:100 T24000 A6 S0.02
                  ;Tip: A larger trigger height in G31 moves you CLOSER to the bed
                  G31 X1 Y37.5 Z3.20 P25 			;Nozzle-X set the probe offsets
                  ;G31 X0 Y40 Z2.8 P25 			;0.25mm nozzle set the probe offsets
                  T0						;Select first hot end
                  As for the printer, it is a Railcore II 300ZL corexy. The hotend is a Phaetus Dragon with an Orbiter II extruder. LDO steppers all around with a 750w heat pad on a magnetic bed kinematically mounted. The Z probe is a Euclid.
                  Another thing I did today was verify the bed has ground to the frame. The firmware looks like it is for the Mini+. I have a 6HC will that firmware work on the 6HC as well?
                  Its so strange because everything worked fine for months after the initial problem of random reboots. Absolutely nothing has changed except the weather.
                    droftarts administrators @agmeadows
                    @agmeadows said in Duet 6HC randomly crasing (again):
                    That's actually significant. Humidity has a big effect on electrostatic buildup. I don't have any greater insights into how to further ground your machine, unfortunately.
                      agmeadows @droftarts
                      @droftarts The long road to troubleshooting an intermittent problem is a long one. I am wondering if my chamber temp thermistor is collecting static. It is unshielded and very close to the hotend. I am not even sure if that is possible.
                      I have moved it away from the hotend for now to see if that helps.
                        dc42 administrators @agmeadows
                        @agmeadows this is just to let you know that I am tracking this and other reports of crashes on 6HC and Duet 3 Mini when running firmware 3.5.0-rc.1. The reports you posted may indicate a firmware problem. You could try reverting to 3.4.6 to see if the resets stop.
                          agmeadows @dc42
                          @dc42 Thank you for the heads up. I will continue to post crash logs as I receive them. I suspect mine is related to a hardware issue and static. I was on 3.4.5 and it was crashing with the same type of error.
                          Initial testing after moving the chamber thermistor is promising. I was able to do 2 successful prints that were 3 hours long.
                          Is there a way to ground the thermistors on the Duet side in order to protect the board? I'd rather wire something in if it all possible to eliminate that as an issue. the hotend thermistor has a metal enclosure and is grounded by the hotend. The other thermistor is bare with just the two leads going to it. I am not sure if it is acting as an antenna for static when it is near parts interacting with filament or what. I am really just shooting in the dark as this point.
                            @agmeadows to avoid static discharge to the thermistor input, it's only necessary to ensure that any parts close to the thermistor that might accumulate charge are connected to Duet ground one way or another. If the metal parts of the machine are connected to mains ground then it should only be necessary to connect the Duet VIN ground terminal to mains ground also.
                            If there is any risk of creating a ground loop, then instead of a direct connection to ground, connecting metal parts to Duet ground via a 100K resistor is sufficient to prevent static charge building up.
                            If no other source of Duet ground is available close to the thermistor, then a 100K resistor between the metal parts of the machine and the VSSA wire of the thermistor may be used instead. Be sure to use the thermistor wire that is connected to the VSSA pin on the TEMPx connector, because if you connect to the other one then the temperature reading could be affected.
                              agmeadows @dc42
                              Well, another crash. This is after 2 or 3 multi-hour prints finish successfully. The most recent print went for a little over an hour and then crashed. I am nearing my wits end and not sure what to do.
                              Used output buffers: 1 of 40 (36 max)
                              Static ram: 154852
                              Dynamic ram: 121320 of which 664 recycled
                              Never used RAM 66300, free system stack 210 words
                              Tasks: NETWORK(1,ready,39.0%,182) ETHERNET(5,nWait,0.1%,317) HEAT(3,nWait,0.0%,325) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,8.3%,59) MAIN(1,running,52.6%,137) IDLE(0,ready,0.0%,30), total 100.0%
                              Owned mutexes:
                              Last reset 00:19:41 ago, cause: software
                              Last software reset at 2023-12-07 18:35, reason: MemoryProtectionFault mmarValid daccViol, Gcodes spinning, available RAM 65092, slot 0
                              Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400004 BFAR 0x0000198d SP 0x2045ff48 Task Move Freestk 64367 ok
                              Stack: 00001989 83b6454d 00001a88 00001989 00000000 0044684d 0044ab5c 61000027 00446809 4000c000 00000000 2042194c 204322b8 00000000 0044aa39 20459300 204322a4 00000007 00000000 2045f840 ffffffed 00000000 00f00000 e000e000 c0000000 00000000 00497f6b
                              Error status: 0x00
                              MCU temperature: min 29.1, current 29.2, max 32.6
                              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                              Driver 0: standstill, SG min n/a, mspos 904, reads 41806, writes 16 timeouts 0
                              Driver 1: standstill, SG min n/a, mspos 56, reads 41806, writes 16 timeouts 0
                              Driver 2: standstill, SG min n/a, mspos 664, reads 41806, writes 16 timeouts 0
                              Driver 3: standstill, SG min n/a, mspos 296, reads 41806, writes 16 timeouts 0
                              Driver 4: standstill, SG min n/a, mspos 504, reads 41807, writes 16 timeouts 0
                              Driver 5: standstill, SG min n/a, mspos 600, reads 41807, writes 16 timeouts 0
                              Date/time: 2023-12-07 18:55:04
                              Slowest loop: 6.27ms; fastest: 0.07ms
                              === Storage ===
                              SD card longest read time 4.2ms, write time 0.0ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              Extruder 0: no data received
                              === CAN ===
                              Messages queued 10629, received 0, lost 0, boc 0
                              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 5906/0/0
                              Tx timeouts 0,0,5905,0,0,4722 last cancelled message type 30 dest 127
                              === Network ===
                              Slowest loop: 34.90ms; fastest: 0.03ms
                              = Ethernet =
                              I unplugged the filaments sensor to see if that was causing issues. It still crashed. I have now removed everything not essential to printing.
                                agmeadows
                                Yet another crash
                                Used output buffers: 1 of 40 (18 max)
                                Static ram: 154852
                                Dynamic ram: 120916 of which 240 recycled
                                Never used RAM 67128, free system stack 210 words
                                Tasks: NETWORK(1,ready,38.8%,157) ETHERNET(5,nWait,0.1%,321) HEAT(3,nWait,0.0%,325) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,8.4%,59) MAIN(1,running,52.6%,137) IDLE(0,ready,0.1%,30), total 100.0%
                                Owned mutexes:
                                Last reset 00:01:20 ago, cause: software
                                Last software reset at 2023-12-22 23:00, reason: MemoryProtectionFault mmarValid daccViol, Gcodes spinning, available RAM 65648, slot 0
                                Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00427804 BFAR 0x00000001 SP 0x2041bc20 Task MAIN Freestk 2212 ok
                                Stack: 20419934 20419934 00000001 00000000 00000000 00498559 00497de8 610f0000 004984df 20430030 ffffffff 20430140 2043019c 20419934 2042e0dc ffffffff 00000000 204309d8 0049866b 2041bccc 00000003 2042bb28 00495b6f 2042e0d8 0046db83 2042bb28 2042e0dc
                                Error status: 0x00
                                MCU temperature: min 31.8, current 32.1, max 32.3
                                Driver 0: standstill, SG min n/a, mspos 872, reads 48401, writes 16 timeouts 0
                                Driver 1: standstill, SG min n/a, mspos 72, reads 48401, writes 16 timeouts 0
                                Driver 2: standstill, SG min n/a, mspos 792, reads 48401, writes 16 timeouts 0
                                Driver 3: standstill, SG min n/a, mspos 856, reads 48401, writes 16 timeouts 0
                                Driver 4: standstill, SG min n/a, mspos 600, reads 48401, writes 16 timeouts 0
                                Driver 5: standstill, SG min n/a, mspos 888, reads 48401, writes 16 timeouts 0
                                Date/time: 2023-12-22 23:01:31
                                Slowest loop: 5.98ms; fastest: 0.07ms
                                === Storage ===
                                SD card longest read time 3.9ms, write time 0.0ms, max retries 0
                                === DDARing 0 ===
                                === DDARing 1 ===
                                === CAN ===
                                Messages queued 720, received 0, lost 0, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 401/0/0
                                Tx timeouts 0,0,400,0,0,318 last cancelled message type 30 dest 127
                                === Network ===
                                Slowest loop: 8.77ms; fastest: 0.03ms
                                HTTP sessions: 1 of 8
                                = Ethernet =
                                I am tempted to ditch the Duet 6HC at this point. It is crashing constantly and I am wasting filament. I took the entire carriage apart and reassembled it being sure to check everything over. I have verified ground on the hotend and disconnected the chamber thermistor in case that was causing issues.
                                What else can I do short of replacing the entire board?
                                shaunpplundefined 1 Reply Last reply Reply Quote 0
                                • T3P3Tonyundefined T3P3Tony referenced this topic
                                • shaunpplundefined
                                  shaunppl @agmeadows
                                  @agmeadows have you double checked the power supply feed and or the power supply output, where is the printer situated ?.
                                  power spikes are another source of electrical interference that could be effecting the boards as a fluctuating input or ground can trip the boards to reset.
                                    3.5 final has released now, there has been a lot of fixes since rc1. Can you please update using the full release zip file?
                                    https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0
