    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    9.5k
      dc42 administrators @Exerqtor
      @Exerqtor interesting, that one is a different sort of reset but in the same function. Please send M122 P500 S0, then wait for it to reset again and send the M122 report as usual.
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Exerqtorundefined
        Exerqtor @dc42
        @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
        Here you go ( i did a print or two after sending M122 P500 S0, hope that don't mess anything up):
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
        Used output buffers: 6 of 40 (40 max)
        Static ram: 102844
        Dynamic ram: 123360 of which 0 recycled
        Never used RAM 12356, free system stack 196 words
        Tasks: NETWORK(1,ready,19.1%,239) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.0%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 01:09:12 ago, cause: software
        Last software reset at 2023-12-06 08:16, reason: AssertionFailed, Gcodes spinning, available RAM 5824, slot 2
        Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
        Stack: 0000090f 000af3c8 0002de29 2002bed4 2002be01 000001b0 2002c100 20031550 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 2003155c 00000800 20035a68 2002c100 20018678 2002bf9d 20018678 2001e888 000300af 00000000 00000000
        Error status: 0x04
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 4152839, completed 4152837, timed out 0, errs 0
        MCU temperature: min 33.8, current 34.0, max 36.9
        Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1248/812, gc cycles 193
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 89, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 248, read errors 0, write errors 1, ifcnt 88, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 52, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 50, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: not present
        Driver 6: not present
        Date/time: 2023-12-06 09:25:54
        Slowest loop: 12.98ms; fastest: 0.13ms
        === Storage ===
        Free file entries: 18
        SD card longest read time 6.9ms, write time 4.8ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
        === DDARing 0 ===
        === DDARing 1 ===
        Heater 1 is on, I-accum = 0.0
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is doing "G4 S1" in state(s) 0 0, running macro
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0000803
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        in 0 notIn 0
        Extruder 0 sensor: no filament
        === CAN ===
        Messages queued 37382, received 85164, lost 0, errs 1, boc 0
        Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 20763/20762/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 5.88ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 2 of 8
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1beta4
        MAC address c4:5b:be:ce:91:93
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968
        WiFi IP address 192.168.10.x
        Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002001
          @Exerqtor thanks, that's back to normal. Please install the firmware from https://www.dropbox.com/scl/fo/pj3pphcoi373dtlcbsrao/h?rlkey=w3hwi2n2l51bywl0773j9uo6a&dl=0 (ignore all the other files there, you only need the .uf2 file) and again send M122 P500 S0 after it starts up. That command will persist until the next reset, so no problem if you do several prints.
          Exerqtorundefined 2 Replies Last reply Reply Quote 0
          • Exerqtorundefined
            Exerqtor @dc42
            "Normal" lol. Ok i'll install it once the current print finishes, and add M122 P500 S0 at the bottom of config.g.
            • Exerqtorundefined
              Exerqtor @dc42
              Here we have one:
              M122
              RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-06 12:09:26) running on Duet 3 Mini5plus WiFi (standalone mode)
              Used output buffers: 1 of 40 (40 max)
              Static ram: 102844
              Never used RAM 12356, free system stack 194 words
              Tasks: NETWORK(2,nWait,18.3%,228) HEAT(3,nWait,0.0%,355) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.9%,264), total 100.0%
              Last reset 00:05:36 ago, cause: software
              Last software reset at 2023-12-07 02:46, reason: AssertionFailed, Gcodes spinning, available RAM 5440, slot 0
              Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001b0 2002c100 20031598 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 200315a4 00000800 20035ab0 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 336854, completed 336854, timed out 0, errs 0
              MCU temperature: min 35.1, current 35.7, max 38.4
              Supply voltage: min 22.4, current 24.1, max 26.6, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/640/204, gc cycles 16
              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 207, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 206, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 111, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 112, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 109, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0
              Date/time: 2023-12-07 02:51:52
              Cache data hit count 560391083
              Slowest loop: 12.95ms; fastest: 0.14ms
              === Storage ===
              SD card longest read time 6.9ms, write time 4.6ms, max retries 0
              === DDARing 0 ===
              === DDARing 1 ===
              in 0 notIn 0
              === CAN ===
              Messages queued 3040, received 6936, lost 0, errs 1, boc 0
              Longest wait 2ms for reply type 6031, peak Tx sync delay 253, free buffers 26 (min 25), ts 1684/1683/0
              === Network ===
              Slowest loop: 8.87ms; fastest: 0.00ms
              HTTP sessions: 3 of 8
              === WiFi ===
              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948
              Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @Exerqtor
                And another:
                M122
                Static ram: 102844
                Dynamic ram: 122128 of which 0 recycled
                Never used RAM 13588, free system stack 198 words
                Tasks: NETWORK(1,ready,18.3%,203) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,116) MAIN(1,running,79.7%,670) IDLE(0,ready,0.4%,29) AIN(4,delaying,0.8%,264), total 100.0%
                Last reset 00:03:15 ago, cause: software
                Last software reset at 2023-12-07 06:59, reason: AssertionFailed, Gcodes spinning, available RAM 13540, slot 0
                Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001a8 2002c100 20031d28 2002c118 2001e888 a5a5a5a5 a5a5a5a5 362e303d 00000000 00000000 00000000 20031d34 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                Error status: 0x04
                Aux0 errors 0,0,0
                MCU revision 3, ADC conversions started 195496, completed 195496, timed out 0, errs 0
                MCU temperature: min 34.2, current 34.8, max 37.3
                Supply voltage: min 22.6, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1524/1128, gc cycles 8
                Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 249, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 248, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 153, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 154, reads 10256, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 151, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Date/time: 2023-12-07 07:03:01
                Cache data hit count 327929753
                Slowest loop: 8.69ms; fastest: 0.14ms
                === Storage ===
                SD card longest read time 3.8ms, write time 3.7ms, max retries 0
                === DDARing 0 ===
                === DDARing 1 ===
                in 0 notIn 0
                === CAN ===
                Messages queued 1768, received 4041, lost 0, errs 1, boc 0
                Longest wait 2ms for reply type 6053, peak Tx sync delay 345, free buffers 26 (min 25), ts 977/976/0
                === Network ===
                Slowest loop: 6.88ms; fastest: 0.00ms
                === WiFi ===
                dc42undefined 2 Replies Last reply Reply Quote 0
                  @Exerqtor thanks for those. I'll have another firmware build for you to test shortly.
                  The corrupt data appears to be 4 characters of ASCII text. In two cases it is =0.1 and in one case =0.6 . Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?
                    @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/y34newtid8z5zp7qa5ted/h?rlkey=i65uvg992k74vrgygg4rp4g98&dl=0.
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Sounds like progress 😁
                      But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print. So all the crashes has happened with the printer in an idle state (unless otherwise mentioned).
                      Ok, I'll download and install it straight away!
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        @Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
                        I guess what daemon.g is doing still applies while the printer is idle, so here is how that looks as of now (just grabbed it straight of the printer):
                        ; /sys/daemon.g  v2.4
                        ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again.
                        ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
                        ; Loop, to be able to turn on/off daemon.g
                        while global.RunDaemon
                          ; Stuff goes here
                          ; Resume after filament change
                          if exists(global.FilamentCHG)
                            if global.FilamentCHG = true && state.status="paused"
                              M24        ; Resume the pause automatically now that the manual filament change is done
                              set global.FilamentCHG = false
                          ; Refresh chamber lights status
                          if exists(global.chamber_leds)
                            set global.chamber_leds = state.gpOut[0].pwm * 100
                          ;Check sb_leds status
                          var SB_LEDS = true                                                           ; Turn on(true) / off(false) the Stealthburner led "system"
                          if var.SB_LEDS
                            if fileexists("/sys/lib/led/sb_leds-state.g")
                              M98 P"/sys/lib/led/sb_leds-state.g"                                      ; Check if global.sb_leds has changed since last run/loop
                          ; Print acceleration & input shaping control
                          if global.accel_control
                            ; Low accel on the whole first layer so that it gets good adhesion
                            if global.layer_number = 1
                              M204 P500        ; Set printing acceleration(mm/s�)
                            ; Everything else
                            else
                              if global.line_type = "External perimeter"
                                if move.printingAcceleration != global.low_accel
                                  M204 P{global.low_accel}                                             ; Set printing acceleration(mm/s�)
                                ;if move.shaping.type != global.input_shaper
                                  ;M593 P{global.input_shaper}                                          ; Configure input shaping
                              elif global.line_type = "Perimeter"
                                if move.printingAcceleration != 2000
                                  M204 P2000                                                           ; Set printing acceleration(mm/s�)
                              elif global.line_type = "Solid infill"
                                ;if move.shaping.type != "none"
                                  ;M593 P"none"                                                         ; Configure input shaping
                              elif global.line_type = "Top solid infill"
                              ; When none of the above line extrusion types
                              else
                                if move.printingAcceleration != global.def_print_accel
                                  M204 P{global.def_print_accel}                                       ; Set printing acceleration(mm/s�)
                                  ;M593 P"none"                                                         ; Disable input shaping
                          ; Daemon loop delay
                          G4 S1        ; Delay running again or next command for at least 1 second
                        And sb_leds-state.g:
                        ; /sys/lib/led/sb_leds-state.g  v2.0
                        ; Created by sb_leds.g to store the current/active LED colors
                        ; Called by daemon.g to check if global.sb_leds status has changed since last run
                        var sb_leds = "boot"
                        if var.sb_leds = global.sb_leds
                          ; Same status, do nothing
                        else
                          ; New status, change colors
                          M98 P"/sys/lib/led/sb_leds.g"
                        And while the printer is idle global.sb_leds don't change value.
                        So as far as i can see it shouldn't be any =0.1 or =0.6 anywhere.
                        • droftartsundefined droftarts referenced this topic
                        • Exerqtorundefined
                          Exerqtor @dc42
                          EDIT:
                          Started a new thread to keep this one on topic.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            First M122 report after a crash on that build (also in a idle state when crashing) :
                            M122
                            RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode)
                            Used output buffers: 11 of 40 (40 max)
                            Static ram: 102844
                            Dynamic ram: 122152 of which 0 recycled
                            Never used RAM 13564, free system stack 186 words
                            Tasks: NETWORK(1,ready,1687.6%,203) HEAT(3,nWait,2.1%,330) Move(4,nWait,0.2%,351) CanReceiv(6,nWait,4.3%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.6%,350) TMC(4,nWait,60.6%,108) MAIN(1,running,1092.0%,670) IDLE(0,ready,21.0%,29) AIN(4,delaying,73.1%,264), total 2941.7%
                            Last reset 04:49:41 ago, cause: software
                            Last software reset at 2023-12-08 01:28, reason: AssertionFailed, Platform spinning, available RAM 12356, slot 2
                            Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                            Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001af 2002c100 20031d10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 20031d1c 00000800 20035a10 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                            Error status: 0x04
                            Aux0 errors 0,0,0
                            MCU revision 3, ADC conversions started 17381709, completed 17381709, timed out 0, errs 0
                            MCU temperature: min 34.2, current 34.8, max 38.2
                            Supply voltage: min 22.7, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/492/96, gc cycles 783
                            Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
                            Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Date/time: 2023-12-08 06:17:56
                            Slowest loop: 12.85ms; fastest: 0.14ms
                            === Storage ===
                            SD card longest read time 7.2ms, write time 4.5ms, max retries 0
                            === DDARing 0 ===
                            === DDARing 1 ===
                            in 0 notIn 0
                            === CAN ===
                            Messages queued 156442, received 356364, lost 0, errs 0, boc 0
                            Longest wait 2ms for reply type 6042, peak Tx sync delay 275, free buffers 26 (min 25), ts 86907/86906/0
                            === Network ===
                            Slowest loop: 24.24ms; fastest: 0.00ms
                            === WiFi ===
                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42964
                            Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0
                              droftarts administrators @Exerqtor
                              @Exerqtor do you get crashes if you disable daemon.g?
                              • Exerqtorundefined
                                Exerqtor @droftarts
                                @droftarts said in Reboots/crashes - RRF 3.5.0-rc1:
                                As in setting the global to false disable, or have a empty daemon.g?
                                I can try both, i just set the global to false (i'm pretty sure we tested this earlier, but it's been such a long time since this all started I have a hard time keeping up).
                                  @Exerqtor better to have a daemon.g file with just a very long G4 command in it.
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    In general you mean? Or could elaborate on that a little bit?
                                    I have alot of crap in daemon.g currently, it's mostly disabled since i ditched what i was trying to do with it. Just haven't gotten around to cleaning it up yet.
                                    Guess i could do that now 🤷‍♂️
                                      @Exerqtor what I meant was that a daemon.g file with just a long G4 delay in it would result in less S card access than no daemon.g at all. The maximum value for a G4 delay command is about 2 million seconds.
                                      Conversely, if you try reducing the G4 S1 delay in your current daemon.g file (e.g. try G4 P10) then this will result in more SD card reads. It would be interesting to see if that results in more frequent resets. Please try that.
                                      Another thing you could do at the same time is to pad out the end of daemon.g with a few long comment lines something like this:
                                      ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
                                      This might indicate whether the data that overwrites the return address comes from the residue of the sector of daemon.g that is currently past the end of the file. The sector size is 512 bytes so the number of comment characters in total shod be at least that.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Gotcha!
                                        I just did the much needed cleanup in my daemon.g, but I've now added what you said mentioned.
                                        This is how it looks as of now:
                                        ; /sys/daemon.g  v2.5
                                          ; Stuff goes below this line
                                          if var.SB_LEDS
                                          ; Daemon loop delay
                                          G4 P10        ; Delay running again or next command for at least 1 second (was S1)
                                          @Exerqtor thanks, let's see if that resets more often than before.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            EDIT:
