    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    9.6k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 New crash:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-11-24 09:09:58) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
      Used output buffers: 1 of 40 (40 max)
      Static ram: 102844
      Dynamic ram: 123356 of which 0 recycled
      Never used RAM 12360, free system stack 188 words
      Tasks: NETWORK(1,ready,16.7%,219) HEAT(3,nWait,0.0%,327) Move(4,nWait,0.0%,348) CanReceiv(6,nWait,0.0%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,81.5%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:29:56 ago, cause: software
      Last software reset at 2023-11-29 18:54, reason: HardFault imprec, Gcodes spinning, available RAM 10104, slot 1
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fe8 Task NETW Freestk 506 ok
      Stack: 2002c118 20030c48 200014e8 00000000 20032e7d 0002fef5 0002ffb4 610ff200 00034731 2002bed0 2002bed0 00000004 0002f635 200014e8 e000e000 00000020 0009fc25 00000000 20034fa8 00000000 20034fa8 00000000 df0bd10a e000e000 2001e888 a5a5a5a5 a5a5a5a5
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 1796796, completed 1796794, timed out 0, errs 0
      MCU temperature: min 32.9, current 33.3, max 36.5
      Supply voltage: min 22.0, current 24.1, max 27.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/456/20, gc cycles 84
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 49, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29005, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 29006, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-11-29 19:24:40
      Cache data hit count 3045378646
      Slowest loop: 12.84ms; fastest: 0.13ms
      === Storage ===
      Free file entries: 18
      SD card longest read time 6.7ms, write time 4.5ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      === DDARing 1 ===
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 S1" in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000803
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      in 0 notIn 0
      Extruder 0 sensor: no filament
      === CAN ===
      Messages queued 16181, received 36876, lost 0, errs 1, boc 0
      Longest wait 2ms for reply type 6053, peak Tx sync delay 357, free buffers 26 (min 25), ts 8984/8983/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 6.04ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Module is connected to access point
      Failed messages: pending 0, notrdy 0, noresp 0
      Firmware version 2.1beta4
      MAC address c4:5b:be:ce:91:93
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42796
      WiFi IP address 192.168.10.x
      Signal strength -47dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002001
      MaxGyverundefined 1 Reply Last reply Reply Quote 0
      • MaxGyverundefined
        MaxGyver @Exerqtor
        @Exerqtor @dc42
        I can contribute some crash reports as well. My printer just rebooted mid print, this has never happend in one of the previous 3.5 betas.
        Duet 3 6HC with SBC on RRF 3.5-rc.1
        2.12.2023, 17:11:57: Verbindung zu duet3.local hergestellt
        2.12.2023, 17:12:14: M201: Accelerations (mm/sec^2): X: 20000.0, Y: 20000.0, Z: 250.0, E: 20000.0
        2.12.2023, 17:20:49: : Warning: SPI connection has been reset
        2.12.2023, 17:20:51: : Error: Expansion board 123 reconnected
        2.12.2023, 17:20:51: : Error: Expansion board 124 reconnected
        2.12.2023, 17:20:52: : Error: Expansion board 126 reconnected
        2.12.2023, 17:20:52: : Error: Expansion board 125 reconnected
        2.12.2023, 17:20:55: : Warning: M307: Heater 0 predicted maximum temperature at full power is 321°C
        2.12.2023, 17:20:55: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
        2.12.2023, 17:20:56: : Warning: M307: Heater 1 predicted maximum temperature at full power is 534°C
        2.12.2023, 17:21:07: M122: === Diagnostics ===
        RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.0 or earlier (SBC mode)
        Board ID: 08DJM-956L2-G43S8-6J1F2-3SN6N-1U0LG
        Used output buffers: 1 of 40 (18 max)
        Static ram: 154852
        Dynamic ram: 87280 of which 0 recycled
        Never used RAM 3604, free system stack 204 words
        Tasks: SBC(2,ready,1.7%,441) HEAT(3,nWait,0.0%,363) Move(4,nWait,0.0%,340) CanReceiv(6,nWait,0.0%,796) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,344) TMC(4,nWait,7.9%,61) MAIN(2,running,87.3%,137) IDLE(0,ready,3.1%,30), total 100.0%
        Owned mutexes: HTTP(MAIN)
        Last reset 00:00:17 ago, cause: software
        Last software reset at 2023-12-02 16:20, reason: OutOfMemory, Gcodes spinning, available RAM 4, slot 0
        Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x20421688 Task Move Freestk 319 ok
        Stack: 2041808c 00419f11 00000000 00000000 2045d0e0 0044a07d 204216f8 00442d47 2045d0e0 00000001 2045d0fc 00445b09 00000000 2045a200 204322a4 204296b6 204251bc 204296b8 00000000 00000002 00000000 20425cbc 00000001 00000001 20432418 00000000 00000001
        Error status: 0x00
        MCU temperature: min 34.5, current 34.8, max 35.2
        Supply voltage: min 3.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 0.9, current 12.1, max 12.2, under voltage events: 0
        Heap OK, handles allocated/used 99/8, heap memory allocated/used/recyclable 2048/120/0, gc cycles 0
        Events: 4 queued, 4 completed
        Driver 0: standstill, SG min 0, mspos 8, reads 27152, writes 16 timeouts 0
        Driver 1: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
        Driver 2: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
        Driver 3: standstill, SG min 0, mspos 8, reads 27153, writes 16 timeouts 0
        Driver 4: standstill, SG min 0, mspos 8, reads 27151, writes 18 timeouts 0
        Driver 5: standstill, SG min 0, mspos 8, reads 27158, writes 11 timeouts 0
        Date/time: 2023-12-02 16:21:05
        Slowest loop: 1.71ms; fastest: 0.07ms
        === Storage ===
        Free file entries: 20
        DMs created 250, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        === DDARing 0 ===
        === DDARing 1 ===
        Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
        Daemon is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x80000003
        === CAN ===
        Messages queued 166, received 566, lost 0, boc 0
        Longest wait 56ms for reply type 6041, peak Tx sync delay 38032, free buffers 50 (min 49), ts 90/86/0
        Tx timeouts 0,0,3,0,0,0 last cancelled message type 30 dest 127
        === SBC interface ===
        Transfer state: 5, failed transfers: 0, checksum errors: 0
        RX/TX seq numbers: 24333/3400
        SPI underruns 0, overruns 0
        State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98
        Buffer RX/TX: 0/0-0, open files: 0
        === Duet Control Server ===
        Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:16:31)
        Code buffer space: 4096
        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 2
        Full transfers per second: 49.12, max time between full transfers: 303.3ms, max pin wait times: 280.8ms/15.6ms
        Codes per second: 65.98
        Maximum length of RX/TX data transfers: 4456/1680
          dc42 administrators @MaxGyver
          @MaxGyver please can you take regular M122 reports next tike you.run this print. An out of memory error on a 6HC is very unusual and suggests that your print may be doing something that is triggering a memory leak in RRF.
            dc42 administrators @dc42
            @Exerqtor are you using the USB port on that Duet 3 Mini?
            dc42undefined Exerqtorundefined 2 Replies Last reply Reply Quote 0
              @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/1r49rb2x3jsn1az0jdu1j/h?rlkey=xke2yefix0hyp5dioxa58pgtp&dl=0 and post a M122 after any crash.
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
                Nope the USB port haven't got anything plugged in.
                OK, i'll install it right away.
                • Exerqtorundefined
                  Exerqtor @dc42
                  Hopefully this shines some more light on it:
                  M122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-04 12:12:17) running on Duet 3 Mini5plus WiFi (standalone mode)
                  Used output buffers: 10 of 40 (40 max)
                  Static ram: 102844
                  Dynamic ram: 123360 of which 0 recycled
                  Never used RAM 12356, free system stack 188 words
                  Tasks: NETWORK(1,ready,18.8%,239) HEAT(3,nWait,0.0%,336) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,79.3%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                  Owned mutexes:
                  Last reset 00:26:31 ago, cause: software
                  Last software reset at 2023-12-05 09:59, reason: HardFault imprec ibus, Gcodes spinning, available RAM 10968, slot 1
                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000500 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011f48 Task NETW Freestk 466 ok
                  Stack: 0d362e30 20032dec 000001bf 00000001 0d362e30 20032dec 000043ae 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd0f 2002bed4 2002be01 000001bf 2002c138 20031db0 2002c150 2001e888 a5a5a5a5 a5a5a5a5 0002ff15 00000000 00000000
                  Error status: 0x04
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 1591912, completed 1591912, timed out 0, errs 0
                  MCU temperature: min 33.2, current 34.0, max 36.2
                  Supply voltage: min 22.0, current 24.1, max 27.0, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1172/736, gc cycles 74
                  Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 227, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 150, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18223, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 18224, writes 13, timeouts 0, DMA errors 0, CC errors 0
                  Date/time: 2023-12-05 10:26:25
                  Cache data hit count 2710632535
                  Slowest loop: 9.77ms; fastest: 0.13ms
                  === Storage ===
                  SD card longest read time 7.1ms, write time 4.5ms, max retries 0
                  === DDARing 0 ===
                  === DDARing 1 ===
                  in 0 notIn 0
                  === CAN ===
                  Messages queued 14337, received 32674, lost 0, errs 1, boc 0
                  Longest wait 2ms for reply type 6053, peak Tx sync delay 260, free buffers 26 (min 25), ts 7960/7959/0
                  === Network ===
                  Slowest loop: 7.91ms; fastest: 0.00ms
                  HTTP sessions: 3 of 8
                  === WiFi ===
                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
                  Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
                    dc42 administrators @Exerqtor
                    @Exerqtor interesting, that one is a different sort of reset but in the same function. Please send M122 P500 S0, then wait for it to reset again and send the M122 report as usual.
                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Here you go ( i did a print or two after sending M122 P500 S0, hope that don't mess anything up):
                      Used output buffers: 6 of 40 (40 max)
                      Static ram: 102844
                      Never used RAM 12356, free system stack 196 words
                      Tasks: NETWORK(1,ready,19.1%,239) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.0%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.8%,264), total 100.0%
                      Last reset 01:09:12 ago, cause: software
                      Last software reset at 2023-12-06 08:16, reason: AssertionFailed, Gcodes spinning, available RAM 5824, slot 2
                      Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                      Stack: 0000090f 000af3c8 0002de29 2002bed4 2002be01 000001b0 2002c100 20031550 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 2003155c 00000800 20035a68 2002c100 20018678 2002bf9d 20018678 2001e888 000300af 00000000 00000000
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 4152839, completed 4152837, timed out 0, errs 0
                      MCU temperature: min 33.8, current 34.0, max 36.9
                      Supply voltage: min 22.5, current 24.1, max 26.5, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/1248/812, gc cycles 193
                      Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 89, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 248, read errors 0, write errors 1, ifcnt 88, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 52, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 51, reads 21917, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 50, reads 21918, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2023-12-06 09:25:54
                      Slowest loop: 12.98ms; fastest: 0.13ms
                      === Storage ===
                      SD card longest read time 6.9ms, write time 4.8ms, max retries 0
                      === DDARing 0 ===
                      === DDARing 1 ===
                      in 0 notIn 0
                      === CAN ===
                      Messages queued 37382, received 85164, lost 0, errs 1, boc 0
                      Longest wait 2ms for reply type 6053, peak Tx sync delay 270, free buffers 26 (min 25), ts 20763/20762/0
                      === Network ===
                      Slowest loop: 5.88ms; fastest: 0.00ms
                      HTTP sessions: 2 of 8
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42968
                        @Exerqtor thanks, that's back to normal. Please install the firmware from https://www.dropbox.com/scl/fo/pj3pphcoi373dtlcbsrao/h?rlkey=w3hwi2n2l51bywl0773j9uo6a&dl=0 (ignore all the other files there, you only need the .uf2 file) and again send M122 P500 S0 after it starts up. That command will persist until the next reset, so no problem if you do several prints.
                        • Exerqtorundefined
                          Exerqtor @dc42
                          "Normal" lol. Ok i'll install it once the current print finishes, and add M122 P500 S0 at the bottom of config.g.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            Here we have one:
                            M122
                            RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-06 12:09:26) running on Duet 3 Mini5plus WiFi (standalone mode)
                            Static ram: 102844
                            Never used RAM 12356, free system stack 194 words
                            Tasks: NETWORK(2,nWait,18.3%,228) HEAT(3,nWait,0.0%,355) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,108) MAIN(1,running,79.8%,670) IDLE(0,ready,0.3%,29) AIN(4,delaying,0.9%,264), total 100.0%
                            Last reset 00:05:36 ago, cause: software
                            Last software reset at 2023-12-07 02:46, reason: AssertionFailed, Gcodes spinning, available RAM 5440, slot 0
                            Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001b0 2002c100 20031598 2002c118 2001e888 a5a5a5a5 a5a5a5a5 312e303d 00000000 00000000 00000000 200315a4 00000800 20035ab0 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                            Error status: 0x04
                            Aux0 errors 0,0,0
                            MCU revision 3, ADC conversions started 336854, completed 336854, timed out 0, errs 0
                            MCU temperature: min 35.1, current 35.7, max 38.4
                            Supply voltage: min 22.4, current 24.1, max 26.6, under voltage events: 0, over voltage events: 0, power good: yes
                            Heap OK, handles allocated/used 99/33, heap memory allocated/used/recyclable 2048/640/204, gc cycles 16
                            Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 207, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 206, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 111, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 112, reads 17691, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 109, reads 17692, writes 13, timeouts 0, DMA errors 0, CC errors 0
                            Date/time: 2023-12-07 02:51:52
                            Cache data hit count 560391083
                            Slowest loop: 12.95ms; fastest: 0.14ms
                            === Storage ===
                            SD card longest read time 6.9ms, write time 4.6ms, max retries 0
                            === DDARing 0 ===
                            === DDARing 1 ===
                            in 0 notIn 0
                            === CAN ===
                            Messages queued 3040, received 6936, lost 0, errs 1, boc 0
                            Longest wait 2ms for reply type 6031, peak Tx sync delay 253, free buffers 26 (min 25), ts 1684/1683/0
                            === Network ===
                            Slowest loop: 8.87ms; fastest: 0.00ms
                            === WiFi ===
                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42948
                            Signal strength -46dBm, channel 6, mode 802.11n, reconnections 0
                            • Exerqtorundefined
                              Exerqtor @Exerqtor
                              And another:
                              M122
                              Static ram: 102844
                              Dynamic ram: 122128 of which 0 recycled
                              Never used RAM 13588, free system stack 198 words
                              Tasks: NETWORK(1,ready,18.3%,203) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,116) MAIN(1,running,79.7%,670) IDLE(0,ready,0.4%,29) AIN(4,delaying,0.8%,264), total 100.0%
                              Last reset 00:03:15 ago, cause: software
                              Last software reset at 2023-12-07 06:59, reason: AssertionFailed, Gcodes spinning, available RAM 13540, slot 0
                              Stack: 00000913 000af408 0002de53 2002bed4 2002be01 000001a8 2002c100 20031d28 2002c118 2001e888 a5a5a5a5 a5a5a5a5 362e303d 00000000 00000000 00000000 20031d34 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                              Error status: 0x04
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 195496, completed 195496, timed out 0, errs 0
                              MCU temperature: min 34.2, current 34.8, max 37.3
                              Supply voltage: min 22.6, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/1524/1128, gc cycles 8
                              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 249, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 248, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 153, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 154, reads 10256, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 151, reads 10257, writes 13, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2023-12-07 07:03:01
                              Cache data hit count 327929753
                              Slowest loop: 8.69ms; fastest: 0.14ms
                              === Storage ===
                              SD card longest read time 3.8ms, write time 3.7ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              in 0 notIn 0
                              === CAN ===
                              Messages queued 1768, received 4041, lost 0, errs 1, boc 0
                              Longest wait 2ms for reply type 6053, peak Tx sync delay 345, free buffers 26 (min 25), ts 977/976/0
                              === Network ===
                              Slowest loop: 6.88ms; fastest: 0.00ms
                              === WiFi ===
                              dc42undefined 2 Replies Last reply Reply Quote 0
                                @Exerqtor thanks for those. I'll have another firmware build for you to test shortly.
                                The corrupt data appears to be 4 characters of ASCII text. In two cases it is =0.1 and in one case =0.6 . Does that text appear in the file you printed, or in any of your macro files that the print may be invoking?
                                  @Exerqtor please try the firmware at https://www.dropbox.com/scl/fo/y34newtid8z5zp7qa5ted/h?rlkey=i65uvg992k74vrgygg4rp4g98&dl=0.
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    Sounds like progress 😁
                                    But no, all the reports I've posted since we uncovered the crashes being CPU-WiFi transfere related I've turned off the WiFi module when I print. So all the crashes has happened with the printer in an idle state (unless otherwise mentioned).
                                    Ok, I'll download and install it straight away!
                                    • Exerqtorundefined
                                      Exerqtor @Exerqtor
                                      @Exerqtor said in Reboots/crashes - RRF 3.5.0-rc1:
                                      I guess what daemon.g is doing still applies while the printer is idle, so here is how that looks as of now (just grabbed it straight of the printer):
                                      ; /sys/daemon.g  v2.4
                                      ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again.
                                      ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
                                      ; Loop, to be able to turn on/off daemon.g
                                      while global.RunDaemon
                                        ; Stuff goes here
                                        ; Resume after filament change
                                        if exists(global.FilamentCHG)
                                          if global.FilamentCHG = true && state.status="paused"
                                            M24        ; Resume the pause automatically now that the manual filament change is done
                                            set global.FilamentCHG = false
                                        ; Refresh chamber lights status
                                        if exists(global.chamber_leds)
                                          set global.chamber_leds = state.gpOut[0].pwm * 100
                                        ;Check sb_leds status
                                        var SB_LEDS = true                                                           ; Turn on(true) / off(false) the Stealthburner led "system"
                                        if var.SB_LEDS
                                          if fileexists("/sys/lib/led/sb_leds-state.g")
                                            M98 P"/sys/lib/led/sb_leds-state.g"                                      ; Check if global.sb_leds has changed since last run/loop
                                        ; Print acceleration & input shaping control
                                        if global.accel_control
                                          ; Low accel on the whole first layer so that it gets good adhesion
                                          if global.layer_number = 1
                                            M204 P500        ; Set printing acceleration(mm/s�)
                                          ; Everything else
                                          else
                                            if global.line_type = "External perimeter"
                                              if move.printingAcceleration != global.low_accel
                                                M204 P{global.low_accel}                                             ; Set printing acceleration(mm/s�)
                                              ;if move.shaping.type != global.input_shaper
                                                ;M593 P{global.input_shaper}                                          ; Configure input shaping
                                            elif global.line_type = "Perimeter"
                                              if move.printingAcceleration != 2000
                                                M204 P2000                                                           ; Set printing acceleration(mm/s�)
                                            elif global.line_type = "Solid infill"
                                              ;if move.shaping.type != "none"
                                                ;M593 P"none"                                                         ; Configure input shaping
                                            elif global.line_type = "Top solid infill"
                                            ; When none of the above line extrusion types
                                            else
                                              if move.printingAcceleration != global.def_print_accel
                                                M204 P{global.def_print_accel}                                       ; Set printing acceleration(mm/s�)
                                                ;M593 P"none"                                                         ; Disable input shaping
                                        ; Daemon loop delay
                                        G4 S1        ; Delay running again or next command for at least 1 second
                                      And sb_leds-state.g:
                                      ; /sys/lib/led/sb_leds-state.g  v2.0
                                      ; Created by sb_leds.g to store the current/active LED colors
                                      ; Called by daemon.g to check if global.sb_leds status has changed since last run
                                      var sb_leds = "boot"
                                      if var.sb_leds = global.sb_leds
                                        ; Same status, do nothing
                                      else
                                        ; New status, change colors
                                        M98 P"/sys/lib/led/sb_leds.g"
                                      And while the printer is idle global.sb_leds don't change value.
                                      So as far as i can see it shouldn't be any =0.1 or =0.6 anywhere.
                                      • droftartsundefined droftarts referenced this topic
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        EDIT:
                                        Started a new thread to keep this one on topic.
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          First M122 report after a crash on that build (also in a idle state when crashing) :
                                          M122
                                          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode)
                                          Used output buffers: 11 of 40 (40 max)
                                          Static ram: 102844
                                          Dynamic ram: 122152 of which 0 recycled
                                          Never used RAM 13564, free system stack 186 words
                                          Tasks: NETWORK(1,ready,1687.6%,203) HEAT(3,nWait,2.1%,330) Move(4,nWait,0.2%,351) CanReceiv(6,nWait,4.3%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.6%,350) TMC(4,nWait,60.6%,108) MAIN(1,running,1092.0%,670) IDLE(0,ready,21.0%,29) AIN(4,delaying,73.1%,264), total 2941.7%
                                          Last reset 04:49:41 ago, cause: software
                                          Last software reset at 2023-12-08 01:28, reason: AssertionFailed, Platform spinning, available RAM 12356, slot 2
                                          Software reset code 0x4120 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                                          Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001af 2002c100 20031d10 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 20031d1c 00000800 20035a10 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                                          Error status: 0x04
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 17381709, completed 17381709, timed out 0, errs 0
                                          MCU temperature: min 34.2, current 34.8, max 38.2
                                          Supply voltage: min 22.7, current 24.1, max 26.4, under voltage events: 0, over voltage events: 0, power good: yes
                                          Heap OK, handles allocated/used 99/29, heap memory allocated/used/recyclable 2048/492/96, gc cycles 783
                                          Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 106, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
                                          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 222, reads 62816, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 219, reads 62817, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2023-12-08 06:17:56
                                          Slowest loop: 12.85ms; fastest: 0.14ms
                                          === Storage ===
                                          SD card longest read time 7.2ms, write time 4.5ms, max retries 0
                                          === DDARing 0 ===
                                          === DDARing 1 ===
                                          in 0 notIn 0
                                          === CAN ===
                                          Messages queued 156442, received 356364, lost 0, errs 0, boc 0
                                          Longest wait 2ms for reply type 6042, peak Tx sync delay 275, free buffers 26 (min 25), ts 86907/86906/0
                                          === Network ===
                                          Slowest loop: 24.24ms; fastest: 0.00ms
                                          === WiFi ===
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42964
                                          Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0
                                            droftarts administrators @Exerqtor
                                            @Exerqtor do you get crashes if you disable daemon.g?
