Solved y slope with 3.5.0-rc1, not seen with 3.4.6
@balajiramani I just tried a cube with 15% infill (not sure how much that matters) with the 3.5.1rc1+ firmware. The slope is back. I am reverting back to 3.4.6 for now.
@balajiramani phew - glad it's not just me. I find zero fill (and no top) prints vertical - not tried other fill levels.
@Adrian52 Are you using vase mode or regular mode with zero infill and no top surface? When I use vase mode for a cube that is longer in the X direction as compared to the Y direction, I get sloped prints. If the cube is longer in the Y direction, then it prints fine.
@balajiramani I have been using regular mode rather than vase mode. Will check out varying x:y ratio with no fill on my setup.
@balajiramani
tried with unfilled cuboids, with 3 perimeter walls :
30x20x20 (x, y, z) - very pronounced y slope, about 1.3mm over the 20mm z height.
20x30x20 - y slope almost gone, but still clearly there; about 0.3mm over 20mm z.
20x20x20 - rechecked this with exactly the same slicing as above, printed consecutively, and it comes out vertical.
What?? -
@dc42 The problem has definitely returned. For me, the clearest demonstration of the y slope is using a 30x20x20 cube (x,y,z), printed with no fill and no top with 3 perimeters. Strangely, a 20x20x20 cube printed in the same way appears vertical. the 30x20x20 cube printed in vase mode has only a slight slope for me. I have just reverted to 3.4.6, and the same gcode file of 30x20x20 with 3 perimeters prints vertical.
@Adrian52 please try the firmware build at https://www.dropbox.com/scl/fo/gaxzegafmnmagaefo9mgc/h?rlkey=hk4wpttdje76oews8zkuh86q3&dl=0. It fixes a likely cause of this issue.
--@dc42 thank you - I have tried the new version. Firstly, the y slope seems to have disappeared - excellent.
However, this version does not seem to play well with input shaping as I have it set.
When printing 30x20x20 cuboid with no fill and no top, extruder movement was sporadically irregular, which left little loops here and there on the corners.
The 30x20x20 cuboid with fill and top gave a very strange result - there was a ~1mm -y layer shift at z=7.3mm, with a very slight shift -x. I set IS to none from the console, and the cuboid printed perfectly. When I switched back to ie3 from the console, the cuboid printed with the layer shift at 7.3mm again. With a magnifying glass, the two layer shifted cuboids appear identical.
The other thing I noticed was an occasional graunching noise during the ie3 prints. This was quite brief (1sec?), and irregular, happening at 1- 3 min intervals. Not present when IS off.
I am printing pla on my delta with stand alone duet2wifi at 60mm/sec. -
@Adrian52 have revisited jerk settings, and find everything seems to work fine with 300 jerk. 3.5 seems to be much more sensitive to too high jerk.
@Adrian52 were you using the M593 L parameter? If so, there was a bug in the processing of that parameter in that firmware.
@dc42 I reported the L parameter problem in a separate thread. Currently I find prints look a little better with IS switched off - I suspect a slightly higher L parameter is needed, so looking forward to experimenting with rc2.
The y slope has returned for me using 3.5.rc3+4(from 13th March).
similar to before, with about 1mm overhang on a 20mm high cuboid, sloping in the +y direction. X facing sides are vertical. Similar with filled or unfilled cuboid(I used 30x20x20 xyz). Running a kossel style delta with duet2wifi standalone. -
Adding to this, I too am seeing layer shifts with the 3.5.0-rc3+4-mms firmware. In some cases, the problem occurs on the 1st layer itself and the nozzle digs into the bed. Here is a photo that shows it.
@balajiramani Is your printer a delta? If not I doubt if your problem is the same as this one. You may be better off starting a new thread to discuss your issue.
@gloomyandy Yes, it is a delta.
@balajiramani Can you post a picture or link of what the print that you had fail (in the photo above) is supposed to look like? I'm trying to work out what happened. Unfortunately I know very little about deltas, but it might be worth you posting your config.g file so that we can take a look at your settings.
@gloomyandy Here is the first layer of the same gcode printer using 3.4.6.
With 3.5.0-rc, the nozzle digs into the bed.
@balajiramani Here is another photo that shows the slope in the y direction.
The one on the left was printed with 3.5.0-rc and the one on the right was printed with 3.4.6.
@balajiramani please run M122 before you start the print, then post a M122 report taken after layer shifts have occurred. I am interested in whether it shows any step errors. Note, after reporting the step error count the count gets cleared to zero, so if you run M122 again the information will be lost.
