    y slope with 3.5.0-rc1, not seen with 3.4.6
    Beta Firmware
    10
    92
    5.2k
    • Adrian52undefined
      Adrian52 @balajiramani
      @balajiramani
      tried with unfilled cuboids, with 3 perimeter walls :
      30x20x20 (x, y, z) - very pronounced y slope, about 1.3mm over the 20mm z height.
      20x30x20 - y slope almost gone, but still clearly there; about 0.3mm over 20mm z.
      20x20x20 - rechecked this with exactly the same slicing as above, printed consecutively, and it comes out vertical.
      What??
      • Adrian52undefined
        Adrian52 @dc42
        @dc42 The problem has definitely returned. For me, the clearest demonstration of the y slope is using a 30x20x20 cube (x,y,z), printed with no fill and no top with 3 perimeters. Strangely, a 20x20x20 cube printed in the same way appears vertical. the 30x20x20 cube printed in vase mode has only a slight slope for me. I have just reverted to 3.4.6, and the same gcode file of 30x20x20 with 3 perimeters prints vertical.
          dc42 administrators @Adrian52
          @Adrian52 please try the firmware build at https://www.dropbox.com/scl/fo/gaxzegafmnmagaefo9mgc/h?rlkey=hk4wpttdje76oews8zkuh86q3&dl=0. It fixes a likely cause of this issue.
          Adrian52undefined 1 Reply Last reply Reply Quote 0
          • Adrian52undefined
            Adrian52 @dc42
            --@dc42 thank you - I have tried the new version. Firstly, the y slope seems to have disappeared - excellent.
            However, this version does not seem to play well with input shaping as I have it set.
            When printing 30x20x20 cuboid with no fill and no top, extruder movement was sporadically irregular, which left little loops here and there on the corners.
            The 30x20x20 cuboid with fill and top gave a very strange result - there was a ~1mm -y layer shift at z=7.3mm, with a very slight shift -x. I set IS to none from the console, and the cuboid printed perfectly. When I switched back to ie3 from the console, the cuboid printed with the layer shift at 7.3mm again. With a magnifying glass, the two layer shifted cuboids appear identical.
            The other thing I noticed was an occasional graunching noise during the ie3 prints. This was quite brief (1sec?), and irregular, happening at 1- 3 min intervals. Not present when IS off.
            I am printing pla on my delta with stand alone duet2wifi at 60mm/sec.
            Adrian52undefined dc42undefined 2 Replies Last reply Reply Quote 0
            • Adrian52undefined
              Adrian52 @Adrian52
              @Adrian52 have revisited jerk settings, and find everything seems to work fine with 300 jerk. 3.5 seems to be much more sensitive to too high jerk.
              • Adrian52undefined Adrian52 has marked this topic as solved
                @Adrian52 were you using the M593 L parameter? If so, there was a bug in the processing of that parameter in that firmware.
                • Adrian52undefined
                  Adrian52 @dc42
                  @dc42 I reported the L parameter problem in a separate thread. Currently I find prints look a little better with IS switched off - I suspect a slightly higher L parameter is needed, so looking forward to experimenting with rc2.
                  • NeoDueundefined NeoDue referenced this topic
                  • Adrian52undefined
                    Adrian52
                    The y slope has returned for me using 3.5.rc3+4(from 13th March).
                    similar to before, with about 1mm overhang on a 20mm high cuboid, sloping in the +y direction. X facing sides are vertical. Similar with filled or unfilled cuboid(I used 30x20x20 xyz). Running a kossel style delta with duet2wifi standalone.
                    balajiramaniundefined 1 Reply Last reply Reply Quote 0
                    • Phaedruxundefined Phaedrux has marked this topic as unsolved
                    • balajiramaniundefined
                      balajiramani @Adrian52
                      Adding to this, I too am seeing layer shifts with the 3.5.0-rc3+4-mms firmware. In some cases, the problem occurs on the 1st layer itself and the nozzle digs into the bed. Here is a photo that shows it.
                      gloomyandyundefined 1 Reply Last reply Reply Quote 0
                      • gloomyandyundefined
                        gloomyandy @balajiramani
                        @balajiramani Is your printer a delta? If not I doubt if your problem is the same as this one. You may be better off starting a new thread to discuss your issue.
                          balajiramani @gloomyandy
                          @gloomyandy Yes, it is a delta.
                            @balajiramani Can you post a picture or link of what the print that you had fail (in the photo above) is supposed to look like? I'm trying to work out what happened. Unfortunately I know very little about deltas, but it might be worth you posting your config.g file so that we can take a look at your settings.
                              @gloomyandy Here is the first layer of the same gcode printer using 3.4.6.
                              With 3.5.0-rc, the nozzle digs into the bed.
                                balajiramani @balajiramani
                                @balajiramani Here is another photo that shows the slope in the y direction.
                                The one on the left was printed with 3.5.0-rc and the one on the right was printed with 3.4.6.
                                  @balajiramani
                                  Here is my config.g file.
                                  config.g
                                    dc42 administrators @balajiramani
                                    @balajiramani please run M122 before you start the print, then post a M122 report taken after layer shifts have occurred. I am interested in whether it shows any step errors. Note, after reporting the step error count the count gets cleared to zero, so if you run M122 again the information will be lost.
                                    Adrian52undefined balajiramaniundefined 2 Replies Last reply Reply Quote 0
                                    • Adrian52undefined
                                      Adrian52 @dc42
                                      @dc42 I am getting a smooth y slope with no hics or step errors printing a 30x20x20 cuboid (filled)
                                      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.3+ (2024-03-18 09:34:21) running on Duet WiFi 1.0 or 1.01
                                      Board ID: 08DAM-999TL-MQ4SD-6J9FD-3SJ6J-K593W
                                      Used output buffers: 2 of 26 (26 max)
                                      Static ram: 23256
                                      Dynamic ram: 72748 of which 12 recycled
                                      Never used RAM 11760, free system stack 120 words
                                      Tasks: NETWORK(1,ready,14.3%,193) HEAT(3,nWait 5,0.1%,319) Move(4,nWait 5,1.7%,258) MAIN(1,running,84.0%,841) IDLE(0,ready,0.0%,29), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:37:17 ago, cause: power up
                                      Last software reset at 2024-03-05 21:23, reason: User, Gcodes spinning, available RAM 11272, slot 1
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      MCU temperature: min 20.8, current 27.5, max 34.6
                                      Supply voltage: min 24.1, current 24.4, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/32/32, gc cycles 0
                                      Events: 0 queued, 0 completed
                                      Driver 0: standstill, SG min 0
                                      Driver 1: standstill, SG min 0
                                      Driver 2: standstill, SG min 0
                                      Driver 3: standstill, SG min 0
                                      Driver 4: standstill, SG min 0
                                      Driver 5:
                                      Driver 6:
                                      Driver 7:
                                      Driver 8:
                                      Driver 9:
                                      Driver 10:
                                      Driver 11:
                                      Date/time: 2024-03-20 18:38:24
                                      Slowest loop: 226.78ms; fastest: 0.14ms
                                      === Storage ===
                                      Free file entries: 10
                                      SD card longest read time 1.6ms, write time 4.9ms, max retries 0
                                      DMs created 105, segments created 24, maxWait 487529ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval -676, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                                      no step interrupt scheduled
                                      Moves shaped first try 2635, on retry 98, too short 2405, wrong shape 2294, maybepossible 2
                                      === DDARing 0 ===
                                      Scheduled moves 9392, completed 9392, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                                      Movement locks held by null
                                      HTTP is idle in state(s) 0
                                      Telnet is idle in state(s) 0
                                      File is idle in state(s) 0
                                      USB is idle in state(s) 0
                                      Aux is idle in state(s) 0
                                      Trigger is idle in state(s) 0
                                      Queue is idle in state(s) 0
                                      LCD is idle in state(s) 0
                                      Daemon is idle in state(s) 0
                                      Q0 segments left 0
                                      Code queue 0 is empty
                                      === Filament sensors ===
                                      check 5549352 clear 2119357
                                      Extruder 0: pos -9.93, brightness 12, shutter 78, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                      === Network ===
                                      Slowest loop: 207.88ms; fastest: 0.07ms
                                      Responder states: HTTP(0) HTTP(1) HTTP(0) FTP(0) Telnet(0)
                                      HTTP sessions: 1 of 8
                                      === WiFi ===
                                      Interface state: active
                                      Module is connected to access point
                                      Failed messages: pending 0, notrdy 0, noresp 0
                                      Firmware version 2.1beta6
                                      MAC address 5c:cf:7f:2c:24:6b
                                      Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 42972
                                      WiFi IP address 192.168.1.16
                                      Signal strength -57dBm, channel 13, mode 802.11n, reconnections 0
                                      Clock register 00002002
                                      Socket states: 5 0 3 0 0 0 0 0
                                        @Adrian52 thanks. Please repeat that with input shaping disabled.
                                        • Adrian52undefined
                                          Adrian52 @dc42
                                          @dc42 No y slope with IS disabled
                                          Used output buffers: 16 of 26 (26 max)
                                          Static ram: 23256
                                          Tasks: NETWORK(2,nWait 6,13.9%,193) HEAT(3,nWait 5,0.1%,307) Move(4,nWait 5,0.9%,258) MAIN(1,running,85.2%,836) IDLE(0,ready,0.0%,29), total 100.0%
                                          Owned mutexes: WiFi(NETWORK)
                                          Last reset 01:43:15 ago, cause: power up
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          MCU temperature: min 27.1, current 28.2, max 34.6
                                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/64/64, gc cycles 0
                                          Driver 5:
                                          Driver 6:
                                          Driver 7:
                                          Driver 8:
                                          Driver 9:
                                          Driver 10:
                                          Driver 11:
                                          Date/time: 2024-03-20 19:44:21
                                          Slowest loop: 221.83ms; fastest: 0.14ms
                                          === Storage ===
                                          SD card longest read time 3.5ms, write time 0.0ms, max retries 0
                                          DMs created 105, segments created 24, maxWait 2378135ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                                          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                          === DDARing 0 ===
                                          Q0 segments left 0
                                          check 10744745 clear 11675643
                                          Extruder 0: pos -0.80, brightness 17, shutter 91, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                                          === Network ===
                                          Slowest loop: 212.40ms; fastest: 0.07ms
                                          Responder states: HTTP(0) HTTP(1) HTTP(1) FTP(0) Telnet(0)
                                          === WiFi ===
                                          Module reset reason: Turned on by main processor, Vcc 3.38, flash size 2097152, free heap 36260
                                          Signal strength -54dBm, channel 13, mode 802.11n, reconnections 0
                                          Socket states: 5 0 3 3 0 0 0 0
                                            @Adrian52 please provide those two GCode files you are printing that exhibit the problem.
