    CoreXY mode not being honored
    • wdenkerundefined
      wdenker
      I have a new machine I just built and have used this config on other machines but it seems that both motors are moving with the exception of one of the z motors which happens to be on my expansion board. Wondering where I went wrong I have attatched the config.g for the most part everything else is working. Also the filament runout sensor works as expected but am getting a pop up every 20-30 seconds saying no filament. Even though nothing is changing there. So a couple of oddities with it.config (2).g
      www.bd3dcustoms.com | BD3DCUSTOMS Supercube
      Dr_Ju_Juundefined 1 Reply Last reply Reply Quote 0
      • Dr_Ju_Juundefined
        Dr_Ju_Ju @wdenker
        @wdenker Why 2 sets of drive mappings (lines 19 & 29) ??
        Julian,
        Old goat, learning new things….
        wdenkerundefined 1 Reply Last reply Reply Quote 0
        • wdenkerundefined
          wdenker @Dr_Ju_Ju
          @Dr_Ju_Ju we were testing a theory on it but I need to remove one.
          • Dr_Ju_Juundefined
            Dr_Ju_Ju @wdenker
            @wdenker
            I don't know if will help, but here's my motor configs & mappings
            ; Configure Drives
            M569 P0.1 S1 ; physical drive 0.0 goes forwards - A
            M569 P0.0 S1 ; physical drive 0.1 goes forwards - B
            M569 P0.2 S0 ; physical drive 0.0 goes backwards - Z0
            M569 P0.3 S1 ; physical drive 0.1 goes forwards - Z1
            M569 P0.4 S0 ; physical drive 0.2 goes backwards - Z2
            M569 P0.5 S1 ; physical drive 0.3 goes forwards - Z3
            M569 P1.0 S0 ; physical drive 1.0 goes backwards - Extruder
            ; set drive mappings X, Y, Z
            M584 X0.0
            M584 Y0.1
            M584 Z0.2:0.3:0.4:0.5
            M584 E1.0 ; set drive mapping E (extruder on 3HC)
            Julian,
            • wdenkerundefined
              wdenker @Dr_Ju_Ju
              @Dr_Ju_Ju said in CoreXY mode not being honored:
              I figured it out for the movements.. Now to figure out the filament sensor. I can't have 0.1 assigned to two different axis'
              • Phaedruxundefined Phaedrux has marked this topic as solved
