3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2
Beta Firmware
8
29
1.5k
    tas @Exerqtor
    @Exerqtor @gloomyandy
    The test print worked perfectly.
    So the Y shifts were due to a configuration error on my part. The motors do need more current to meet the demands of input shaping.
    The motors got a bit hotter than I would like by the end of the print but most people would call them warm so that is interesting for me. I will bump up the current in my configs.
    Thank you both for the suggestions.
    undefined 1 Reply Last reply 22 Dec 2023, 06:29 Reply Quote 2
    • undefined Phaedrux marked this topic as a question 21 Dec 2023, 17:43
    • undefined Phaedrux has marked this topic as solved 21 Dec 2023, 17:43
      dc42 administrators @tas
      @tas with input shaping enabled, do the motors sound normal? I get a slight clunking sound when some types of IS are enabled on one of my machines. However, as the IS code is being rewritten I decided not to investigate this before releasing RC2.
      You might like to run M122 after doing one of these prints. It has a new field that lists the maximum number of overdue steps encountered, and that may be related.
      undefined undefined 3 Replies Last reply 22 Dec 2023, 12:41 Reply Quote 1
        tas @dc42
        @dc42 I can't say I noticed a noise difference but I will do some testing today and report back.
          tas @dc42
          I did a test 'print' without filament using the Klipper ringing part in vase mode at 100mm/s. I tried none, zvd, zvdd, zvddd and with IS off.
          The noise sounded 'silkier' with IS enabled and to my ear is the same no matter which type was used.
          I did not hear any clunks, clicks or other unusual noises. The highest value for max steps late was 1. I hope that is the new value you are referring to.
          Using a speed of 100mm/s I tried all Input Shapers starting with IS disabled. I did M122 at random times during each 'print' to get the following info.
          No IS:
          M122 Move:
          DMs created 83, segments created 9, maxWait 1020ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.89, ebfmax 0.98
          next step interrupt due in 28 ticks, disabled
          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
          IS "zvd":
          M122 Move:
          DMs created 83, segments created 22, maxWait 881ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.79, ebfmax 0.98
          next step interrupt due in 6 ticks, disabled
          Moves shaped first try 34, on retry 18, too short 63, wrong shape 4, maybepossible 1
          IS "zvdd":
          M122 Move:
          DMs created 83, segments created 33, maxWait 17471ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.97, ebfmax 0.99
          next step interrupt due in 49 ticks, disabled
          Moves shaped first try 73, on retry 25, too short 112, wrong shape 9, maybepossible 0
          IS "zvddd":
          M122 Move:
          DMs created 83, segments created 38, maxWait 2364ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin -0.95, ebfmax 1.00
          next step interrupt due in 12 ticks, disabled
          Moves shaped first try 114, on retry 65, too short 189, wrong shape 20, maybepossible 0
          Let me know if you need any other info or other tests done and I can do them later today.
            edsped @dc42
            @dc42 said in 3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2:
            With RC2 I get clunking bad enough that it causes layer shifts. I would get slight clunks on RC1 but RC2 is a whole other level... I'm to the point that I'm starting to try to figure out how to get back to RC1 with SBC. I can't downgrade to stable because I'm running RRF-36's. ZVD seems to be the mildest for me and ZVDDD is just plain awful.
            undefined undefined 2 Replies Last reply 22 Dec 2023, 20:35 Reply Quote 0
              gloomyandy @edsped
              @edsped What are your M593 settings?
              undefined 1 Reply Last reply 22 Dec 2023, 21:21 Reply Quote 0
                tas @edsped
                @edsped
                It may be an SBC issue then. I heard no clunks at all.
                  edsped @gloomyandy
                  @gloomyandy said in 3.5.0rc1 Input Shaping Layer Shifts not addressed in 3.5.0rc2:
                  M593 P"ZVDDD" F60 L0.8 S0
                  I changed the L value because lower values cause the print head to slow down quite a bit at start and stop areas during infill.
                  undefined 1 Reply Last reply 22 Dec 2023, 21:29 Reply Quote 0
                    gloomyandy @edsped
                    @edsped Did you specify an L value in your RC1 settings? If so what was it? There have not been a lot of changes to IS since RC1 so it is interesting that you are having issues.
                    undefined 2 Replies Last reply 22 Dec 2023, 21:37 Reply Quote 1
                      edsped @gloomyandy
                      @gloomyandy I did not, was getting weird slowdowns in small areas and a little digging around led me to the L value.
                      undefined 1 Reply Last reply 22 Dec 2023, 21:39 Reply Quote 0
                        edsped @edsped
                        @edsped I'll try lowering the L value to the default .25 and test again but it may take a couple of hours.
                          edsped @gloomyandy
                          Reverting to default for L value solved it. Thank you!
                          27 out of 29
