MAX31856 duet2 wifi board pin number
looking to see if i can find the pin values for duet MAX31856 connected to the duet2 wifi v1.03
pin referring to:
sensor_pin: PB14 -- I think this is correct
spi_speed
spi_bus ?
sclk_pin ?
mosi_pin ?
smiso_pin ?any help would be great
Thanks gary
@gorf32 said in MAX31856 duet2 wifi board pin number:
MAX31856
If it helps, this is the schematic of 1.04.
https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet2/Duet2v1.04/DuetWifi_Schematic_v1.04.pdf
@gorf32 Here's the schematic for the Duet3D thermocouple board: https://github.com/Duet3D/TempDaughterboards/blob/master/MAXTempTC/MAXTempTCv1.1.pdf
Wiki page: https://docs.duet3d.com/Duet3D_hardware/Accessories/Thermocouple_DaughterboardIan
@gorf32 This is a pinmap I often use as reference.
@zapta Thanks I got it working sort of, it reading the temp but it seems to be about 20c to high when cold i am getting a value 43c cold it should read around 23 to 25c
thamks
@gorf32 if the reference resistor on your MAX31865 board has a value other than 400 ohms then you need to tell RRF what value it is using the R parameter of the M308 command.
@dc42 I don't know much about circuits, but i think this is the layout
@gorf32 looks like your reference resistor is 430 ohms.
@dc42 Thanks i did get it to work was a value of 400
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
