Cant get the WiFi to Work
Firmware installation
2.9k
    elmoret
    What have you done leading up to this? I saw in your past posts some comments about changing firmware versions, could you detail what was done with regards to that?
      Amilious
      I just tried a few different versions to see if it was caused by the firmware. I have tried
      1.18
      1.18.2
      1.19
      1.19.1
      1.19.2
      1.20beta11
      I could not get the wifi to work on any of those firmware versions.
      I just get:
      M587: Failed to add SSID to remembered list
      and
      M997 S1
      Trying to connect at 460800 baud: failed
      Trying to connect at 230400 baud: failed
      Trying to connect at 115200 baud: failed
      Trying to connect at 74880 baud: failed
      Error: Installation failed due to comm write error
        Amilious
        I have had this board since Aug, but I did not try to use it until last week. I had been busy and did not have my printer put together yet. I have built a Hypercube Evolution. Just trying to give any information that may help. It could maybe be something in my config.g as well. I am new to this board and got this config from another thread about a HEVO.
        [[language]]
        M503
        ; Configuration file for Duet WiFi (firmware version 1.17)
        ; generated by RepRapFirmware Configuration Tool on Fri Jun 30 2017 19:04:28 GMT-0500 (Central Daylight Time)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P2 ; Set firmware compatibility to look like Marlin
        M667 S1 ; Select CoreXY mode
        M208 X300 Y300 Z300 S0 ; Set axis maxima
        M574 X1 Y1 Z1 S1; Define active high microswitches
        M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
        G31 P500 X0 Y0 Z2.32 ; Set Z probe trigger value, offset and trigger height
        M557 X13:293 Y5:260 S83 ; Define mesh grid
        M569 P0 S0 ; X goes forwards
        M569 P1 S1 ; Y Reversed
        M569 P2 S0 ; Z goes forwards
        M569 P3 S0 ; Extruder goes forwards
        M92 X99.5 Y99.5 Z399.7 E79.9 ; Set steps per mm
        M566 X900 Y900 Z120 E900 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000 Y18000 Z500 E1200 ; Set maximum speeds (mm/min)
        M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
        M906 X1200 Y1200 Z1200 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M572 D0 S0.1	;Pressure Advance
        M143 S260 ; Set maximum heater temperature to 260C
        ;M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
        M305 P1 T100000 B4725 C7.06e-8 R4700 ; Set thermistor + ADC parameters for heater 1
        M563 P0 D0 H1 ; Define tool 0
        M550 PHYPERCUBE ; Set machine name
        M552 S1 ; Enable network
        ;M587 S"Amilious" P"{my password was here}"; Configure access point and IP addresses. You can delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S1 ; enable Telnet
        M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        ok
          Amilious
          Just tried to comment out all the network lines, but got the same result
            @Amilious:
            M997 S1
            If you were using USB power only at the time, try again with VIN power. Otherwise, ask for your Duet to be replaced or repaired - sounds like it needs a new WiFi module.
              Amilious
              I figured it was probably that. I have read through the forums and that seemed likely to be the problem. I purchased this board on August 11th, and did not take it out of the box until last week. I project got delayed and i was not able to work on it until recently. I have been talking to my supplier(Filastruder). I am waiting for them to get a response from Think3DPrint3D, because I guess I am past the normal time for the exchange. I guess the six month warranty is only after November 14th purchases. The supplier has been very helpful and informative. I'm just a little frustrated because i have been excited to use this board on the HEVO that I have built, that ended up costing twice as much as i originally planed. At least i still have my trusty Anet A8. Ha ha ha. I do have a spare 24V ramps kit laying around, but i hope it does not come to that.
                Amilious
                I replacement was approved. Thank you for your time and help. I would also like to thank Tim from Filastruder, for his work getting this issue resolved for me.
                  elmoret
                  *Tim 😄
                    Amilious
                    ha ha ha ha. I knew that, I don't know why i wrote Jim. lol!! Probably because my father is Jim. lol!! Thank you!!!
                      elmoret
                      Just got this return, it seems the ESP8266 has developed an internal fault. It gets warm, not too hot to touch but noticeably warm. Can confirm the following:
                      SENT: M552
                      READ: WiFi module is disabled
                      SENT: M552 S1
                      READ: ok
                      SENT: M552
                      READ: WiFi module is being started
                      Issuing replacement.
                        Amilious
                        I received the fixed or replaced board. I was able to update the firmware and connect to wifi!
                          lolorc
                          I've upgraded to 1.21RC2 and I'm encountering the same issue.
                          Can't get the board to add the SSID
                          • WiFi -
                            Network state is starting
                          it was working perfectly with 1.19 just before
                          [[language]]
                          ttyACM1 18°> M115
                          SENDING:M115
                          FIRMWARE_NAME: RepRapFirmware for Duet WiFi and Duet Ethernet FIRMWARE_VERSION: 1.21RC2 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-02-15 build 2
                          ttyACM1 18°> M552 S1
                          SENDING:M552 S1
                          Turn off the current WiFi mode before selecting a new one
                          ttyACM1 18°> M589
                          SENDING:M589
                          M589: Failed to retrieve own SSID data
                            Send M552 S-1 to reset the wifi module, then M552 S0. Then send M122 and check what wifi firmware version it reports in the network diagnostics.
                              lolorc
                              [[language]]
                              Used output buffers: 1 of 32 (1 max)
                              RepRapFirmware for Duet WiFi and Duet Ethernet version 1.21RC2 running on Duet WiFi 1.0 or 1.01
                              [[language]]
                              === Network ===
                              HTTP sessions: 0 of 8
                              - WiFi -
                              Can't see the specific WifiServer version
                                The WiFi module is stuck on starting. Copy the new DuetWiFiServer.bin file to /sys on the SD card in a PC, then put the card back in the Duet and try installing it using M997 S1 again.
                                  lolorc
                                  yep, sorry for the noise, it's now ok :
                                  [[language]]
                                  ttyACM0 17°> M997 S1
                                  SENDING:M997 S1
                                   success
                                  Erasing 4096 bytes...
                                  Erasing 24576 bytes...
                                  I should have checked the filesize when I downloaded the bin…
                                  Thanks !
                                    SputnikOC3d
                                    I just tried this or noticed this issue and sent M997 S1 to the board via YAt … wonder if it changes anything
                                      @lolorc:
                                      [[language]]
                                      SENDING:M997 S1
                                       success
                                      Thanks !
                                      Yes, 24576 bytes is about 10% of the correct size.
