    Cant get the WiFi to Work
    Firmware installation
    2.9k
    • Amiliousundefined
      Amilious
      ha ha ha ha. I knew that, I don't know why i wrote Jim. lol!! Probably because my father is Jim. lol!! Thank you!!!
      • elmoretundefined
        elmoret
        Just got this return, it seems the ESP8266 has developed an internal fault. It gets warm, not too hot to touch but noticeably warm. Can confirm the following:
        SENT: M552
        READ: WiFi module is disabled
        SENT: M552 S1
        READ: ok
        SENT: M552
        READ: WiFi module is being started
        Issuing replacement.
        • Amiliousundefined
          Amilious
          I received the fixed or replaced board. I was able to update the firmware and connect to wifi!
          • lolorcundefined
            lolorc
            I've upgraded to 1.21RC2 and I'm encountering the same issue.
            Can't get the board to add the SSID
            • WiFi -
              Network state is starting
            it was working perfectly with 1.19 just before
            [[language]]
            ttyACM1 18°> M115
            SENDING:M115
            FIRMWARE_NAME: RepRapFirmware for Duet WiFi and Duet Ethernet FIRMWARE_VERSION: 1.21RC2 ELECTRONICS: Duet WiFi 1.0 or 1.01 FIRMWARE_DATE: 2018-02-15 build 2
            ttyACM1 18°> M552 S1
            SENDING:M552 S1
            Turn off the current WiFi mode before selecting a new one
            ttyACM1 18°> M589
            SENDING:M589
            M589: Failed to retrieve own SSID data
              Send M552 S-1 to reset the wifi module, then M552 S0. Then send M122 and check what wifi firmware version it reports in the network diagnostics.
              • lolorcundefined
                lolorc
                [[language]]
                Used output buffers: 1 of 32 (1 max)
                RepRapFirmware for Duet WiFi and Duet Ethernet version 1.21RC2 running on Duet WiFi 1.0 or 1.01
                [[language]]
                === Network ===
                HTTP sessions: 0 of 8
                - WiFi -
                Can't see the specific WifiServer version
                  The WiFi module is stuck on starting. Copy the new DuetWiFiServer.bin file to /sys on the SD card in a PC, then put the card back in the Duet and try installing it using M997 S1 again.
                  • lolorcundefined
                    lolorc
                    yep, sorry for the noise, it's now ok :
                    [[language]]
                    ttyACM0 17°> M997 S1
                    SENDING:M997 S1
                    Trying to connect at 230400 baud:
                     success
                    Erasing 4096 bytes...
                    Erasing 24576 bytes...
                    I should have checked the filesize when I downloaded the bin…
                    Thanks !
                    • SputnikOC3dundefined
                      SputnikOC3d
                      I just tried this or noticed this issue and sent M997 S1 to the board via YAt … wonder if it changes anything
                        @lolorc:
                        [[language]]
                        SENDING:M997 S1
                         success
                        Thanks !
                        Yes, 24576 bytes is about 10% of the correct size.
