"sudo apt dist-upgrade" Doesn't update main board?
@DocTrucker try sending
M997
and see if that updates the board.
If not, you could either briefly run the board in standalone mode and update it that way or use BOSSA -
@jay_s_uk that got it, thanks.
Can someone update the documentation to add a note relating to this to step 6?
https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
@DocTrucker on a typical install, using M997 shouldn't be needed and the SBC should do it all for you. I don't know why it failed in your case
@DocTrucker said in "sudo apt dist-upgrade" Doesn't update main board?:
@droftarts Not a bad idea?
