"sudo apt dist-upgrade" Doesn't update main board?
Hi all. I followed the instructions for SBC connected duet upgrades and it doesn't appear to have upgraded the Duet3 main board. I am getting compatability warnings and the board appears to be on 3.3.
How should I upgrade?
undefined DocTrucker marked this topic as a question
@DocTrucker try sending
M997
and see if that updates the board.
If not, you could either briefly run the board in standalone mode and update it that way or use BOSSA -
@jay_s_uk that got it, thanks.
Can someone update the documentation to add a note relating to this to step 6?
https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
@DocTrucker on a typical install, using M997 shouldn't be needed and the SBC should do it all for you. I don't know why it failed in your case
undefined DocTrucker has marked this topic as solved
@DocTrucker said in "sudo apt dist-upgrade" Doesn't update main board?:
@droftarts Not a bad idea?
undefined BlueDust referenced this topic
