    1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
    Beta Firmware
    9
    147
    9.2k
    • Exerqtorundefined
      Exerqtor @A Former User
      @dc42 I tried installing 3.5.0-rc2 again, with a freshly formated SD card etc. to see if that might help (downloaded the binaries again also just in case) and it still shits the bed:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.2 (2023-12-14 10:30:57) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
      Used output buffers: 4 of 40 (40 max)
      Static ram: 102812
      Dynamic ram: 128720 of which 0 recycled
      Never used RAM 5196, free system stack 118 words
      Tasks: NETWORK(1,ready,119.4%,195) HEAT(3,nWait,0.7%,328) Move(4,nWait,14.5%,239) CanReceiv(6,nWait,1.2%,774) CanSender(5,nWait,0.3%,327) CanClock(7,delaying,0.2%,350) TMC(4,nWait,17.4%,74) MAIN(1,running,53.1%,580) IDLE(0,ready,19.8%,29) AIN(4,delaying,20.2%,264), total 246.8%
      Owned mutexes: WiFi(NETWORK)
      Last reset 24:56:40 ago, cause: software
      Last software reset at 2023-12-21 16:42, reason: User, Gcodes spinning, available RAM 12348, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00446000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 89801376, completed 89801376, timed out 0, errs 0
      MCU temperature: min 34.4, current 46.8, max 47.3
      Supply voltage: min 8.0, current 23.9, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 198/28, heap memory allocated/used/recyclable 2048/532/136, gc cycles 15646
      Events: 1 queued, 1 completed
      Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7119, writes 123, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x72
      Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 7120, writes 123, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 149, reads 7187, writes 56, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 145, reads 7185, writes 57, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 144, reads 7187, writes 55, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01
      Driver 5: not present
      Driver 6: not present
      Date/time: 2023-12-22 17:38:55
      Slowest loop: 226.03ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 16
      SD card longest read time 11.0ms, write time 62.9ms, max retries 0
      DMs created 83, segments created 43, maxWait 59621605ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 37 ticks, enabled
      Moves shaped first try 52954, on retry 20590, too short 71476, wrong shape 255081, maybepossible 11645
      === DDARing 0 ===
      Scheduled moves 2684, completed 2644, hiccups 1184, stepErrors 0, LaErrors 1095, Underruns [0, 0, 4], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.3
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is doing "G1 X131.338 Y134.213 E.09057" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 P250" in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0, sync state 1
      Queue2 is idle in state(s) 0
      Q0 segments left 1, axes/extruders owned 0x0000807
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 0
      Extruder 0 sensor: no filament
      === CAN ===
      Messages queued 1264763, received 1844452, lost 0, errs 1, boc 0
      Longest wait 6ms for reply type 6013, peak Tx sync delay 276, free buffers 26 (min 24), ts 449002/449001/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 211.13ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Module is connected to access point
      Failed messages: pending 0, notrdy 0, noresp 0
      Firmware version 2.1beta6
      MAC address c4:5b:be:ce:91:93
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36292
      WiFi IP address 192.168.10.x
      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002001
      M122 B121
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51)
      Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 2580, free system stack 89 words
      Tasks: Move(3,nWait,2.9%,71) HEAT(2,nWait,7.9%,91) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,1.0%,77) CanClock(5,nWait,0.4%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,70.2%,57) MAIN(1,running,53.1%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,111.1%,114), total 246.6%
      Last reset 24:56:46 ago, cause: software
      Last software reset data not available
      Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 5, write errors 1, ifcnt 112, reads 29381, writes 30, timeouts 10, DMA errors 0, CC errors 0, failedOp 0x01, steps req 0 done 54758132
      Moves scheduled 451072, completed 451072, in progress 0, hiccups 6856, segs 42, step errors 0, maxLate 2 maxPrep 759, maxOverdue 7315, maxInc 2784, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
      Peak sync jitter -2/12, peak Rx sync delay 280, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 8.3, current 24.1, max 24.6
      MCU temperature: min 39.4C, current 73.3C, max 79.5C
      Last sensors broadcast 0x00000012 found 2 138 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 1844535, send timeouts 0, received 1264877, lost 0, errs 1230, boc 0, free buffers 18, min 17, error reg 110000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 390, adv 34547/74657
      Accelerometer: LIS3DH, status: 00
      Inductive sensor: not found
      I2C bus errors 0, naks 6, contentions 0, other errors 0
      Interrupt 5726621 to 0us, poll 4 to 2681us
      And it's still happening at random points.
      droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Exerqtor
        @Exerqtor I can’t remember if you have posted your config.g recently, but if not, could you post it again, please? If it calls macros, maybe a zip of you sys folder might be easier, to include them all. It’s just the Mini 5+ and a 1LC? What revision of each board? And what extruder type and motor? Does it still do it if you run a ‘dry’ job with no filament? Finally, can you post a Gcode file that provokes the retractions? Though I suspect it isn’t related to the Gcode itself.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @droftarts
          @droftarts I'm not by the printer now so I'll post everything later.
          Yup it's just the Mini (1.02 WiFi) and 1LC (1.2) connected directly to eachother.
          The extruder is a Bondtech LGX-lite with the stock motor they come with (running the Bondtech adviced current).. Uuhm I haven't tried a "dry" job, but since the stepper reverses the filament rather than extrude it when it happens i doubt it's load related, if thats what you were thinking of 😅
          Regarding a Gcode file it's posted several through the thread here, but I've made a cloud folder with most of the config files and a job file in this post you can have a look at.
          Doubt it's anything else than a firmware bug tbh. since 3.5.0-b4 don't act up like this at all. The symptoms and behaviour i'm experiencing is exactly the same ones that plagued 3.5.0-b3.
            @Exerqtor okay thanks. I don’t have an LGX, but I’ve probably got a motor similar enough. I might get enough time between Xmas and New Year to setup a bench test. I’ve also got a stepper motor analyser, which might be helpful.
            • Exerqtorundefined
              Exerqtor @droftarts
              @droftarts Np, don't burn your xmas on this lol.
              I just reverted to 3.5.0-b4 again so i'm good over the holidays ✌️
              Wouldn't stepper specific issues have caused it to stall out rather than reverse btw (if that's what you're think about)? And again, since it don't happen on 3.5.0-b4 with the exact same config🤔
              • Exerqtorundefined Exerqtor referenced this topic
                T3P3Tony administrators @Exerqtor
                @Exerqtor reported here:
                https://github.com/Duet3D/RepRapFirmware/issues/942
                T3P3 created this issue in Duet3D/RepRapFirmware
                closed 1LC - stepper randomly reversing - ≤3.5.0-r1 #942
                Exerqtorundefined 1 Reply Last reply Reply Quote 1
                • Exerqtorundefined
                  Exerqtor @T3P3Tony
                  @T3P3Tony said in 1LC - stepper randomly reversing - ≤3.5.0-r1:
                  Hopefully this gets parched out right quick so I can update the fw and start using the StrideMax! 🤞
                    dc42 administrators @Exerqtor
                    @Exerqtor I have reviewed the code that manages motor direction on the 1XD. At the start of every move, RRF sets the direction of the driver, regardless of whether it should already be correct. So the only way that I can see for the direction to reverse and remain reversed is if the direction control set by M569 has changed. This might happen in the following ways:
                    1. The memory that holds the direction value could have become corrupted. In this case, if M569 is run then it should report the incorrect direction value.
                    2. The board could have reset and the direction value changed back to the default. In this case, M569 would report the wrong value and M122 would report that a reset had occurred.
                    3. The main board has sent a M569 command to the tool board. This seems unlikely.
                    Therefore, please can you run the following test:
                    • Upgrade your system to 3.5.0-rc.2
                    • Start one of the prints that is likely to reverse direction
                    • Once the print is going correctly, run M569 P121.0 and M122 B121 (if the tool board address is not 121 then change these commands appropriately)
                    • Wait until the extruder reverses direction
                    • Run M569 P121.0 and M122 B121 again
                    Then post all the results here.
                    Thanks - David
                    • Exerqtorundefined
                      Exerqtor @dc42
                      @dc42 I will try it, but i don't think it's fully reversing either since it sure don't reverse/retract filament in the same rate that it would have extruded it under normal operation. If that makes sense?
                      It's experiencing it the same way as it did in the 3.5.0-beta2 bug.
                      I'll report back as soon as I get time to test it never the less.
                        @Exerqtor are you saying that when it is commanded to retract filament and is operating in reverse, it doesn't attempt to extrude filament instead?
                        Perhaps you should pause the print after it has started reversing, and see exactly how it does behave in response to extrusion commands?
                        • Exerqtorundefined
                          Exerqtor @dc42
                          @dc42 What i meant is that when the issue happens, it don't behave like it simply reverses the extruder movement since it don't back the filament out at at the expected speed/feedrate.
                          I usually print at somewhere around 25mm³/s with a 0.4mm nozzle, so it's clearly visible when it works normally and one can see it pulling in filament. BUT when it starts acting up, it don't back out the filament at that rate at all.
                          It's more like it just stops doing the normal extrusions and only does retract moves (0.45mm FW retraction) but not the unretracts.
                          So if it was just reversing the stepper movement it would have unloaded the extruder within a minute as the job went on (have to do something like 35mm retraction to fully unload the extruder). But even after letting it go on with the problem active for 10-15minutes before pausing the print i only have to send one 20mm extrude command before it comes plastic out of the nozzle.
                          I've tried pausing the print(s) countless time when the issue happens, ans tried to run extrusion commands through PanelDue and those behave just as they should. But when i resue the print again it goes right back to the same mode of failure as before i paused.
                          Sorry for the messy atempt at an explenation 😮‍💨
                          I've changed the post title to better reflect whats going on.
                            @Exerqtor could it be that somehow the motor current has been reduced to a low value, so that the extruder motor is capable of retracting filament but not capable of overcoming nozzle back pressure?
                            It would be helpful if you could wait for the issue to happen, then pause the print and then run some tests on the extruder:
                            • Verify that the nozzle temperature is correct stable, and was correct when the issue first occurred. Note, if you have a Revo hot end then on early ones the temperature sensing goes wrong after a while. The good ones have blue thermistor wires, the old ones were white.
                            • Use M569 to check that the driver is in spread cycle mode, not stealthchop
                              Send M906 and M913 without parameters to check that RRF thinks it is using the correct motor current
                            • Test extruding and retracting at slow and medium speeds, e.g. 1 to 5mm/sec.
                            • Assuming it's not working properly try sending M906 Exxx (where xxx is the correct motor current) and M913 E100 to check whether this fixes it
                            Exerqtorundefined 3 Replies Last reply Reply Quote 0
                            • Exerqtorundefined
                              Exerqtor @dc42
                              @dc42 said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-r1:
                              I have no idea where how that could happen, but it sounds like a possible cause. Weird that it wouldn't happen on 3.5.0-b4 though.
                              I've got the "new" 60W heater (blue thermistor wires), so that shouldn't be an issue. I haven't seen any dips / fluctuations in the temperatures either (after I got the warranty replacement for the "white wire" variant or 60w from E3D, way before these extrusion issues started). Looking at the temperature chart in DWC everything is rock solid when the issue occurres
                              I will try all thay out some time this weekend! Haven't had the time during the week.
                              • Exerqtorundefined
                                Exerqtor @dc42
                                I just had time to do the testing, updated to 3.5.0-rc2 on everything, sliced one of the "doomed" models again to verify that it wasn't slicer generated (Orca Slicer 1.9.0 stable has launched since last testing), and surely it fails just like it did a month ago 🤣
                                Here is what you asked for @dc42, first off M122 B121 & M569 P121.0 while laying down the first layer (not paused) with everything working like it should as a "baseline":
                                M122 B121
                                Never used RAM 3252, free system stack 89 words
                                Tasks: Move(3,nWait,0.1%,75) HEAT(2,nWait,16.8%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.5%,77) CanClock(5,nWait,0.8%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,136.3%,57) MAIN(1,running,616.0%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,215.9%,114), total 986.4%
                                Last reset 08:07:59 ago, cause: power up
                                Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 24943, writes 12, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x6f, steps req 0 done 106290
                                Moves scheduled 718, completed 716, in progress 1, hiccups 0, segs 14, step errors 0, maxLate 1 maxPrep 320, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                                Peak sync jitter -2/10, peak Rx sync delay 218, resyncs 0/0, no timer interrupt scheduled
                                VIN voltage: min 23.3, current 24.1, max 24.4
                                MCU temperature: min 37.8C, current 55.1C, max 55.1C
                                Last sensors broadcast 0x00000012 found 2 166 ticks ago, 0 ordering errs, loop time 0
                                CAN messages queued 600447, send timeouts 0, received 264383, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 332, adv 35999/109737
                                Interrupt 5726621 to 0us, poll 4 to 1470us
                                Driver 0: ok
                                M569 P121.0
                                Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 448
                                And then we have M122 B121 & M569 P121.0 taken while the issue is occurring (not paused):
                                M122 B121
                                Never used RAM 2724, free system stack 89 words
                                Tasks: Move(3,nWait,0.3%,71) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.1%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.1%,57) MAIN(1,running,91.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,114), total 100.0%
                                Last reset 08:11:58 ago, cause: power up
                                Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 53546, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 282853
                                Moves scheduled 2822, completed 2822, in progress 0, hiccups 3, segs 36, step errors 0, maxLate 1 maxPrep 833, maxOverdue 3250, maxInc 3250, mcErrs 0, gcmErrs 0, ebfmin -0.96 max inf
                                Peak sync jitter -2/10, peak Rx sync delay 226, resyncs 0/0, no timer interrupt scheduled
                                VIN voltage: min 23.9, current 24.0, max 24.3
                                MCU temperature: min 37.8C, current 56.7C, max 56.9C
                                Last sensors broadcast 0x00000012 found 2 25 ticks ago, 0 ordering errs, loop time 0
                                CAN messages queued 4935, send timeouts 0, received 5351, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 350, adv 36140/74649
                                I2C bus errors 0, naks 0, contentions 0, other errors 0
                                Interrupt 5726621 to 0us, poll 9 to 1550us
                                Driver 0: ok
                                M569 P121.0
                                Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 168
                                Screenshot of the temperature chart during warmup, working print & failing print:
                                So i would say that's sufficiently stable😄
                                Answered above.
                                Before pausing while issue is occuring:
                                M906
                                Motor current (mA) - X:1750, Y:1750, Z:850, E:650, idle factor 40%
                                M913
                                Motor current % of normal - X:100, Y:100, Z:100, E:100
                                After pausing while issue is occuring:
                                M906
                                M913
                                Tried extruding 100mm @ 1mm/sec through paneldue while paused : no issues
                                Tried extruding 100mm @ 5mm/sec through paneldue while paused : no issues
                                So yeah, that's that 😂
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  @dc42 I suspect that didn't give you any more clues as to whats going on? 😓
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    I just ran the same job file/test after installing 3.5.0-rc3 and it still fails in the same exact manner.
                                    I was touching/feeling the filament right as it enters the PTFE tube as the print progressed, and it stopped pulling it in right about at the 0.65mm (Z-axis height) mark.
                                    Here is a link to the file (same as my previous post just for clarity).
                                    M122 B121 & M569 P121.0 while laying down the first layer (not paused) with everything working like it should:
                                    M122 B121
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3 (2024-01-24 17:55:14)
                                    Never used RAM 3072, free system stack 83 words
                                    Tasks: Move(3,nWait 7,0.0%,79) HEAT(2,nWait 6,7.3%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.3%,71) CanClock(5,nWait 1,0.4%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,67.2%,53) MAIN(1,running,97.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,96.9%,112), total 269.3%
                                    Owned mutexes:
                                    Last reset 18:26:14 ago, cause: power up
                                    Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 26023, writes 13, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 83994
                                    Moves scheduled 517, completed 516, in progress 1, hiccups 0, segs 13, step errors 0, maxLate 1 maxPrep 304, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                                    Peak sync jitter -3/10, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
                                    MCU temperature: min 34.9C, current 55.2C, max 55.2C
                                    Last sensors broadcast 0x00000012 found 2 98 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 1360939, send timeouts 0, received 598056, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 330, adv 35701/74648
                                    I2C bus errors 0, naks 3, contentions 0, other errors 0
                                    Interrupt 5726621 to 0us, poll 4 to 1445us
                                    Driver 0: ok
                                    M569 P121.0
                                    Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 267
                                    M122 B121
                                    Never used RAM 2520, free system stack 83 words
                                    Tasks: Move(3,nWait 7,0.3%,79) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                                    Owned mutexes:
                                    Last reset 18:30:29 ago, cause: power up
                                    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 61284, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 304108
                                    Moves scheduled 2820, completed 2820, in progress 0, hiccups 3, segs 36, step errors 0, maxLate 1 maxPrep 810, maxOverdue 41, maxInc 41, mcErrs 0, gcmErrs 0, ebfmin -0.98 max inf
                                    Peak sync jitter -1/10, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
                                    VIN voltage: min 23.9, current 24.1, max 24.4
                                    MCU temperature: min 34.9C, current 57.7C, max 57.7C
                                    Last sensors broadcast 0x00000012 found 2 10 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 5254, send timeouts 0, received 5624, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 339, adv 35800/74648
                                    Interrupt 5726621 to 0us, poll 9 to 1438us
                                    Driver 0: ok
                                    M569 P121.0
                                    Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 440
                                    Screenshot of the temperature chart during warmup, working print & failing print (to show that the temps are stable, the drop off at the end is from when i cancelled the print) :
                                    M906
                                    M913
                                    M906
                                    M913
                                    While paused this time i tried extruding 1mm at the time until it actually started coming molten platic out of the nossle and i had to press "extrude" on PD 9-10 times before anything happened. So it's surely retracting the filament a little bit at a time.
                                    Like i mentioned earlier i'm running 0.45mm FW retraction, and my pause.g don't contain any extruder movement at all. So all the 10mm (ish) of retracted filament has happened before i call for a pause.
                                      @Exerqtor please test whether the new firmware binaries at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0 fix tihi issue.
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Just had time to try it, and it's still the exact same behaviour.
                                        M122 B121
                                        Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-01 12:48:48)
                                        Never used RAM 3048, free system stack 83 words
                                        Tasks: Move(3,nWait 7,0.0%,79) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:12:59 ago, cause: VDD brownout
                                        Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 61969, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 42336
                                        Moves scheduled 155, completed 154, in progress 1, hiccups 3, segs 12, step errors 0, maxLate 1 maxPrep 268, maxOverdue 17, maxInc 17, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.99
                                        Peak sync jitter -2/8, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
                                        MCU temperature: min 43.5C, current 57.6C, max 57.6C
                                        Last sensors broadcast 0x00000012 found 2 23 ticks ago, 0 ordering errs, loop time 0
                                        CAN messages queued 16201, send timeouts 0, received 7328, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 328, adv 35675/74645
                                        Interrupt 5726621 to 0us, poll 2 to 1474us
                                        Driver 0: ok
                                        M569 P121.0
                                        Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 1017
                                        M122 B121
                                        Never used RAM 2472, free system stack 83 words
                                        Tasks: Move(3,nWait 7,0.3%,79) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:17:36 ago, cause: VDD brownout
                                        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 7102, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 343188
                                        Moves scheduled 2808, completed 2808, in progress 0, hiccups 29, segs 36, step errors 0, maxLate 1 maxPrep 842, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0, ebfmin -0.98 max inf
                                        Peak sync jitter -1/10, peak Rx sync delay 217, resyncs 0/0, no timer interrupt scheduled
                                        MCU temperature: min 43.5C, current 59.9C, max 60.1C
                                        Last sensors broadcast 0x00000012 found 2 148 ticks ago, 0 ordering errs, loop time 0
                                        CAN messages queued 5716, send timeouts 0, received 5953, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 357, adv 36225/109301
                                        Interrupt 5726621 to 0us, poll 9 to 1416us
                                        Driver 0: ok
                                        M569 P121.0
                                        Driver 121.0 runs in reverse, active low enable, mode spreadCycle, ccr 0x00053, toff 3, tblank 0, hstart/hend/hdec 5/0/0, pos 776
                                          @Exerqtor are you saying that when the issue occurs, the hot end stops heating and cools down?
                                          Looks like the 1LC lost power.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            No nothing happens except it stops feeding filament. The cooling down part in the temp chart is from after I've cancelled the print.
                                            I only included the temp charts to show that the temps are stable (I've updated the "caption" for the chart images on the original posts to reflect on that now).
                                            That's from the reset point is from when i rebooted the mainboard after installing 3.5.0-rc3+, I've got relays on the 24v lines controlled with PS_ON.
