    Unable to upload files and DWC connection issues
    Duet Web Control
    485
      Can you try uploading this wifi server version and see if it makes a difference?
      https://github.com/Duet3D/DuetWiFiSocketServer/releases/download/1.27/DuetWiFiServer.bin
      LuckyLukeundefined 1 Reply Last reply Reply Quote 0
      • LuckyLukeundefined
        LuckyLuke @Phaedrux
        @Phaedrux I uploaded the attached wifi server version and was able to upload a file afterwards. However, I was able to upload the .bin via DWC (which has been failing previously) so I may just be in one of the periods where I am able to upload. I will monitor over the next day or so and see if this wifi server version actually resolves the issues or not. I did not the load times are significantly longer, though that may be expected.
        @gloomyandy I was about to reply saying nothing had changed, outside connecting an accelerometer well after the issues started, but I did double check and it appears my Unifi APs firmware was updated the day the issue started. I hope that isn't a cause of the issue as I really don't like the idea of rolling back networking firmware (which included security updates). In the meantime, I'm going to try connecting my board to my phones hotspot as the only way I have to eliminate my network from the equation.
        I will update tomorrow with my findings on both of these items. Thanks for the help so far!
        Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 1
          Phaedrux Moderator @LuckyLuke
          @LuckyLuke said in Unable to upload files and DWC connection issues:
          You can also test in access point mode where the Duet creates an SSID that you connect to. This would eliminate the unifi AP from the setup.
          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m589-configure-access-point-parameters
            droftarts administrators @LuckyLuke
            @LuckyLuke check you are running the same version of DWC and firmware; their version numbers are now aligned. Version numbers are shown on the Settings > General tab.
            Check SD card function, see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card#troubleshooting-sd-card-issues
            soare0undefined 1 Reply Last reply Reply Quote 0
            • soare0undefined
              soare0 @droftarts
              @all
              What he wants to say is: NOTHING CHANGED between working and not working, at least so it appears.
              This is the case for me, running all 3.5.0 rc2: it worked for a couple of days, and then... nada. I mean I started printing something 3 hours ago, then I tried to upload a new part, and all broke. I cant even connect to the printer.
              It has fixed IP, and in its console is saying it is connected with that IP to the network.
              My network it is fine, I am just uploading (from the same computer) a website back-up, at 1.4 MiBs.
              The networks works ok, I am receiving e-mails, and can open files on some NAS.
              Tried from another computer on the same network... no use.
              Waiting to finish the upload, and try again.
              L.E. Upload finished, no use. I will try to restart all stuff.
              NOTE: this is why I love printing from SD card!
              L.L.E. Restarted again both PC and printer, and this time worked.
              What I do not know is what I did wrong. The browser seemed to receive temperatures (I noticed the rampling up, as I did it at Panel, before going to PC. I may have tried, by error, to upload again the file while it was already uploading it. Maybe I will check again these days...
              Not funny, but hey...
                LuckyLuke @Phaedrux
                @Phaedrux said in Unable to upload files and DWC connection issues:
                I will give this a try this evening, though I'm particularly keen on the idea of needing to disconnect my devices from my network (and internet) just to control my printer. Unless I am misunderstanding the process 🤞
                The 1.27 version of the wifi server has technically worked to resolve the "ERR_EMPTY_RESPONSE" errors and inability to upload files; however, the loading times have skyrocketed to averages over a minute for DWC to load with a few instances of DWC never loading requiring a power cycle of the board to regain access. DWC now also frequently loses connection and reconnects itself after a few seconds. This is almost as frustrating as the original issue, though I am at least able to upload files.
                @droftarts I am running the latest version of DWC "Duet Web Control 3.5.0-rc.2"
                Again, appreciate all the help!
                  LuckyLuke @LuckyLuke
                  I was able to set up access point mode and the connection seemed much more stable and uploading of files was successful and at expected speeds.
                  After this, I updated the wifi firmware back to 2.1beta6 and retested AP mode, with the same positive result. However, I don't consider this a viable solution as it requires disconnecting any control device from my regular network any time I want to do anything with my printer. Furthermore, I lose the ability to access my NAS where I store all my gcode files.
                  I did retest 2.1beta6 in standard mode and was able to connect and upload a few files, though these experienced the same speed and disconnect issues. And looking back in my original post I'm realizing I didn't fully explain the issue I was experiencing with uploading files. The failure mode is as follows:
                  • Select file(s) for upload
                  • Upload begins at standard transfer rates (350kb/s - 650kb/s)
                  • Upload progress stalls after around 100kb
                  • File upload fails and auto-retry kicks in
                  • Upload speed tanks to single digit kb/s, infrequently succeeding at these slow rates but more often fails after auto-retry threshold is reached
                  • DWC will sometimes disconnect during an upload attempt and the upload process dies as a result, at different points of the above process
                  From all I can see and have experienced, this appears to be a stability issue between wifi firmware after 1.27 and my Unifi network. If there is anything else I can try or assist with testing, I'll be happy to give it a go. As it is right now, this printer (my main machine) is so inconvenient to use that it's essentially out of commission.
                  Thanks in advance for the continued assistance!
                    I didn't suggest it as a long term solution, just a test to see if the module is working correctly which it seems to be. The issue is with your router settings and how it's interacting with the Duet. Further digging would be needed to determine what is going on.
                    You can try the different releases of the newer wifi firmware to see if there is a version that works correctly and where it stops working. That would be useful in identifying the change that broke it.
                    https://github.com/Duet3D/WiFiSocketServerRTOS/releases
                      LuckyLuke @Phaedrux
                      Understood; I agree the module appears to be working correctly and the issue is related to the firmware compatibility with my network.
                      Though, personally, I don't think it is unreasonable to expect a premium priced product which advertises web access to work on a major networking retailers platform. If I were running a homebrew or community based network solution, I would be more understanding of these types of issues, but not on a main stream, enterprise level network infrastructure.
                      I will work through the 2.1beta releases of the firmware to see if I can identify if/where a break happens. Thanks again!
                      derBruchpilotProundefined 1 Reply Last reply Reply Quote 0
                      • derBruchpilotProundefined
                        derBruchpilotPro @LuckyLuke
                        Hello everyone,
                        I faced some very similar connection problems after upgrading from 3.4.x to 3.5rc3.
                        AP (Mikrotik) is about 1m away from the CNC (RSSI -27db) and the Macbook, ping and telnet seems to work well but
                        DWC fails to load.
                        After connecting my Macbook via Ethernet to the AP it started to work as expected, so I suspect its some kind of WIFI interference since updating the Duet 2 (rev. 1.02).
                        Maybe this Info could help to track the issues down.
                          derBruchpilotPro @derBruchpilotPro
                          @derBruchpilotPro
                          Okay, I thought connecting the Laptop via Ethernet solved the problem, but here is another one.
                          After some more clicking on the DWC I got completely disconnected, so I tried to connect via USB (without rebooting the duet).
                          Interesting thing is M587 says:
                          Failed to retrieve network list: another SPI transfer is pending
                          Here is the output of M122:
                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.0-rc.3 (2024-01-24 17:56:24) running on Duet WiFi 1.02 or later
                          Board ID: 08DGM-95BNL-MGPSJ-6JKFJ-3S86K-12ZVX
                          Used output buffers: 1 of 26 (24 max)
                          Static ram: 23224
                          Dynamic ram: 72012 of which 184 recycled
                          Never used RAM 14700, free system stack 132 words
                          Tasks: NETWORK(1,ready,38.6%,212) HEAT(3,nWait 5,0.0%,379) Move(4,nWait 5,0.4%,301) MAIN(1,running,60.9%,699) IDLE(0,ready,0.1%,30), total 100.0%
                          Owned mutexes: WiFi(NETWORK) USB(MAIN)
                          Last reset 00:56:36 ago, cause: power up
                          Last software reset at 2024-01-30 00:29, reason: User, Gcodes spinning, available RAM 14700, slot 2
                          Error status: 0x00
                          MCU temperature: min 34.5, current 36.2, max 39.7
                          Supply voltage: min 24.3, current 24.4, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min 0
                          Driver 1: standstill, SG min 0
                          Driver 2: standstill, SG min 0
                          Driver 3: standstill, SG min n/a
                          Driver 4: standstill, SG min n/a
                          Driver 5:
                          Driver 6:
                          Driver 7:
                          Driver 8:
                          Driver 9:
                          Driver 10:
                          Driver 11:
                          Date/time: 2024-02-01 11:04:56
                          Slowest loop: 303.09ms; fastest: 0.19ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 101.0ms, write time 130.4ms, max retries 0
                          DMs created 83, segments created 7, maxWait 1867110ms, bed compensation in use: none, height map offset 0.000, max steps late 1, ebfmin 0.00, ebfmax 0.00
                          no step interrupt scheduled
                          Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                          === DDARing 0 ===
                          Scheduled moves 1546, completed 1546, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 14], CDDA state -1
                          Movement locks held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is ready with "M122" in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Q0 segments left 0
                          Code queue 0 is empty
                          === Network ===
                          Slowest loop: 332.61ms; fastest: 0.07ms
                          Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                          HTTP sessions: 0 of 8
                          === WiFi ===
                          Interface state: active
                          Module is connected to access point
                          Failed messages: pending 0, notrdy 4886, noresp 1
                          Failed to get WiFi status
                          Socket states: 0 6 0 0 0 0 0 0
                            jay_s_uk @derBruchpilotPro
                            @derBruchpilotPro please see this post https://forum.duet3d.com/post/332835
                              derBruchpilotPro @jay_s_uk
                              @jay_s_uk
                              Wow, DWC feels now MUCH more responsive!
                              Thank you!!!
                              Let's hope that will solve the 2nd issue too.
