Understanding CAN Connections
    JRCL
    Hello, was just hoping for some clarity and verification of my understanding of daisy chaining CAN-FD boards. If I have a Duet 3 MB6HC, 1LC toolboard, and 1XD expansion board that need to be connected, could I wire them like so?
    Does the CAN pass through work like I'm thinking on the 1XD board or do I need a tool distribution board?
    undefined undefined 2 Replies Last reply 2 Feb 2024, 16:23 Reply Quote 0
    • undefined JRCL marked this topic as a question 2 Feb 2024, 16:21
      jay_s_uk @JRCL
      @JRCL the way you have drawn it is correct. And you only need 2 wires going to the 1LC
        T3P3Tony administrators @JRCL
        @JRCL Yes that will work. The bus pass through is designed to be used in this way. Ensure the termination jumpers are not fitted on the 1XD, ad depending on the1LC toolboard version you either need to add a termination resistor or bridge the termination jumper pad on the toolboard.
        See connecting without a tool distribution board here:
        https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#can
        If you are planning on adding more tools in the future then a tool distribution board can make that easier but if the machine is only going to have 1 tool then the scheme you are planning will work ok
        • undefined JRCL has marked this topic as solved 2 Feb 2024, 16:45
          JRCL
          Thanks for the quick responses! Looking forward to trying out this configuration
          4 out of 4
