I've tried re-flashing 3.5.0 rc 8 firmware over usb and followed process described in documentation.
PanelDue had 3.4.1 firmware previously. However, it was in storage and was stuck in calibration prompt - i.e. a dot on top of the screen was visible and there was a prompt to touch it, but that was not progressing as if touch was not detected.
Here are some outputs from bossac:$ ./bossac --port=/dev/ttyACM0 -i Atmel SMART device 0x289b09e0 found Device : ATSAM4S4 Chip ID : 289b09e0 Version : v1.13 RC2 Feb 20 2013 13:25:17 Address : 4194304 Pages : 512 Page Size : 512 bytes Total Size : 256KB Planes : 1 Lock Regions : 16 Locked : none Security : false Boot Flash : false
output when flashing with 3.5.0:
./bossac --port=/dev/ttyACM0 -e -w -v -b ~/Downloads/PanelDueFirmware-3.5.0-rc8-7.0i.bin Atmel SMART device 0x289b09e0 found Erase flash done in 0.001 seconds Write 176720 bytes to flash (346 pages) [ ] 0% (0/346 pages) Flash command failed
Similar output when trying with version 3.4.1:
./bossac --port=/dev/ttyACM0 -e -w -v -b ~/Downloads/PanelDueFirmware-3.4.1/PanelDueFirmware-3.4.1-7.0i.bin Atmel SMART device 0x289b09e0 found Erase flash done in 0.001 seconds Write 170916 bytes to flash (334 pages) [ ] 0% (0/334 pages) Flash command failed
Are there any troubleshooting steps I could try to figure out why flashing no longer works and if hardware is in working condition?
There are no torn wires or connector strips on visual inspection -
Does Bossa say the flash is complete and verified successfully?
It sounds more like the touch input digitizer has potentially failed preventing the calibration from completing.
undefined Phaedrux moved this topic from Firmware installation
bossac says “flash command failed”
I'd give the GUI version of Bossa a try and make sure you're following the steps here.
https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
Let us know if you're still encountering issues.
I've been able to flash 3.4.1 with bossac. GUI version is windows/macos version only which i don't have, so it seems that my paneldue is now just a bunch of useless hardware
@cdoe why not just flash the paneldue using RRF? just erase the paneldue and reset then use M997 S4 to flash it.
I do that with paneldues I have even. saves messing with BOSSA -
Thanks I'll try that. Didn't realise it can be done while paneldue has no firmware at all...
Thanks again, updating from duet board worked. Digitizer doesn't work though but that's a separate issue
