    Issues flashing firmware to PanelDue 7i over USB
    PanelDue
    367
    • cdoeundefined
      cdoe
      I've tried re-flashing 3.5.0 rc 8 firmware over usb and followed process described in documentation.
      PanelDue had 3.4.1 firmware previously. However, it was in storage and was stuck in calibration prompt - i.e. a dot on top of the screen was visible and there was a prompt to touch it, but that was not progressing as if touch was not detected.
      Here are some outputs from bossac:
      $ ./bossac --port=/dev/ttyACM0 -i
      Atmel SMART device 0x289b09e0 found
      Device       : ATSAM4S4
      Chip ID      : 289b09e0
      Version      : v1.13 RC2 Feb 20 2013 13:25:17
      Address      : 4194304
      Pages        : 512
      Page Size    : 512 bytes
      Total Size   : 256KB
      Planes       : 1
      Lock Regions : 16
      Locked       : none
      Security     : false
      Boot Flash   : false
      output when flashing with 3.5.0:
      ./bossac --port=/dev/ttyACM0 -e -w -v -b ~/Downloads/PanelDueFirmware-3.5.0-rc8-7.0i.bin
      Erase flash
      done in 0.001 seconds
      Write 176720 bytes to flash (346 pages)
      [                              ] 0% (0/346 pages)
      Flash command failed
      Similar output when trying with version 3.4.1:
      ./bossac --port=/dev/ttyACM0 -e -w -v -b ~/Downloads/PanelDueFirmware-3.4.1/PanelDueFirmware-3.4.1-7.0i.bin
      Erase flash
      Write 170916 bytes to flash (334 pages)
      [                              ] 0% (0/334 pages)
      Are there any troubleshooting steps I could try to figure out why flashing no longer works and if hardware is in working condition?
      There are no torn wires or connector strips on visual inspection
        Does Bossa say the flash is complete and verified successfully?
        It sounds more like the touch input digitizer has potentially failed preventing the calibration from completing.
        cdoeundefined 1 Reply Last reply Reply Quote 0
        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
        • cdoeundefined
          cdoe @Phaedrux
          bossac says “flash command failed”
            I'd give the GUI version of Bossa a try and make sure you're following the steps here.
            https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue
            Let us know if you're still encountering issues.
            • cdoeundefined
              cdoe @Phaedrux
              I've been able to flash 3.4.1 with bossac. GUI version is windows/macos version only which i don't have, so it seems that my paneldue is now just a bunch of useless hardware 😞
                jay_s_uk @cdoe
                @cdoe why not just flash the paneldue using RRF? just erase the paneldue and reset then use M997 S4 to flash it.
                I do that with paneldues I have even. saves messing with BOSSA
                cdoeundefined 2 Replies Last reply Reply Quote 2
                • cdoeundefined
                  cdoe @jay_s_uk
                  Thanks I'll try that. Didn't realise it can be done while paneldue has no firmware at all...
                  • cdoeundefined
                    cdoe @jay_s_uk
                    Thanks again, updating from duet board worked. Digitizer doesn't work though but that's a separate issue
