6XD+1LC+RC3 Bltouch throws random error mode
So the system was running no problem at all.
Installed RC3 firmware and it started - the BLTouch would go into error mode randomly while probing the bed.
Tried different probing speed, different height, different sebsitivity - nothing helped.
Finally went back to RC2 and all issues are gone. -
Can you share your homing files and config?
@Phaedrux - what does homing file have to do with this?
RC2 - works no issues at all
ungraded to RC3 - probes random amount of points and then throws an error
went back to RC2 - works as expected - not a single errorNO chnages in the config/homing or anything else have been made. ONLY firmware upgraded and downgaded.
Config is below - but you will not find anything in there because it works with RC2
And yes different G31 pxxx values have been tsted. from 200 to 1000 and made no difference on RC3.
On RC2 anything works; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"My Giga Vega" ; set printer name ; Wait a moment for the CAN expansion boards to start G4 S3 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet M575 P1 S0 B57600 M669 K1 ; Drives M569 P15.1 S0 ; physical drive 121.0 goes forwards M569 P15.0 S1 ;M569 P122.0 S0 ; physical drive 0.1 goes forwards M569 P0.0 S1 T5:5:7:0 ; physical drive 0.2 goes forwards M569 P0.1 S1 T5:5:7:0 M569 P0.2 S1 T5:5:7:0 M569 P0.3 S1 T5:5:7:0 M569 P121.0 S0 D3 V40 ; physical drive 0.3 goes forwards M584 X15.0 Y15.1 Z0.0:0.1:0.2:0.3 E121.0 ; set drive mapping M671 X-180:-180:1100:1100 Y40:1100:1100:40 S14 M350 X16 Y16:16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80 Y80 Z3000 E400.00 ; set steps per mm M566 X1200.00 Y1200.00 Z7.5 E10000.00 ; set maximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z300 E10800.00 ; set maximum speeds (mm/min) M201 X1750.00 Y1750.00 Z35 E2000.00 ; set accelerations (mm/s^2) M906 X2000 Y2000 Z2000 E600 ; Axis Limits M208 X0 Y0 Z-1 S1 ; set axis minima M208 X1000 Y1000 Z1000 S0 ; set axis maxima M564 H0 ; Endstops M574 X2 S1 P"!121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin M574 Y1 S1 P"15.!io1.in" M574 Z1 S2 ; Z-Probe M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch M558 P9 C"121.^io0.in" H7.5 F3600 T9000 S0.25 ; set Z probe type to bltouch and the dive height + speeds G31 P300 X-30 Y5 Z2.6 ; set Z probe trigger value, offset and trigger height Increase Z number if the nozzle is too far M557 X50:700 Y70:850 S150 ; Heaters ;M140 H-1 ; disable heated bed (overrides default heater mapping) M308 S1 P"121.temp0" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin 121.temp0 M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S350 ; Fans M950 F1 C"out6" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 ; set fan 1 value. Thermostatic control is turned off M950 F1 C"out5" Q500 ; create fan 1 on pin out4 and set its frequency M106 P1 S1 ; set fan 1 value. Thermostatic control is turned off M950 F2 C"121.out2" Q500 M106 P2 T45 H1 M950 F3 C"121.out1" Q500 ; create fan 0 on pin out3 and set its frequency M106 P3 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 S"Left Extruder" D0 H1 F3 ; define tool 1 M568 P0 S0 R0 A0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined T0 M376 H2 M501 M955 P121.0 I52 M593 P"EI3" F60
@Aurimas said in 6XD+1LC+RC3 Bltouch throws random error mode:
Probing when doing what? You don't specify.
@Phaedrux said in 6XD+1LC+RC3 Bltouch throws random error mode:
G32 or G29.
it can throw an error after 2, 5 or 10 probed points.
the fact is that it works with RC2 but fails with RC3 -
@Aurimas we have been discussing how the BL touch goes into error mode. This could be an issue with the probe deploy and retract files, please could you share those.
And also bed.g file please.
 @T3P3Tony said in 6XD+1LC+RC3 Bltouch throws random error mode:
unless it is something different in RC3 from RC2 I cannot see how it could effect anything.
on top of that - it is working, but no the whole way.I have also replaced BLTouch a couple of time just to make sure - nothing changed.
File attached - just rename it to .zip
download.g -
Those bed and probe files are extremely basic. Definitely not the issue.
@Aurimas
Thanks, posting here to make it easier.; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 08 2021 10:30:30 GMT+1000 (Australian Eastern Standard Time) M280 P0 S90 ; retract BLTouch
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 08 2021 10:30:30 GMT+1000 (Australian Eastern Standard Time) M280 P0 S10 ; deploy BLTouch
; bed.g ; called to perform automatic bed compensation via G32 ; ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sat May 08 2021 10:30:29 GMT+1000 (Australian Eastern Standard Time) M561 ; clear any bed transform G30 P0 X0 Y50 Z-99999 ; probe near a leadscrew G30 P1 X0 Y900 Z-99999 ; probe near a leadscrew G30 P2 X900 Y900 Z-99999 G30 P3 X900 Y50 Z-99999 S4 ; probe near a leadscrew and calibrate 3 motors
Do you have a mesh.g ? If so please post that.
Can you confirm that when you say going into error mode, please describe this.
Probes keeps going around and probes the points.
At random stage it would hesitate to respond to the touch and goes into error mode.
starts blinking and duet reports that probe was trigered before probing.
I could not finish single G29 on RC3
back on RC2 didn't have a single issue so far -
@Aurimas And chance you are seeing an "invalid Z probe index" error too? Before I updated Duet3Firmware_TOOL1LC.bin and the other files several times I was getting that error. I went to the line number it gave and nothing was wrong with the g31 command. Resent all the RC3 files over one at a time again and rebooted again and all was well.
@gtrider - no errors. nothing to do with it
@Aurimas Yours was the only BLtouch related posting I saw on RC3 . Mine seems to probe OK, I tried it twice and a G32 just in case and they work fine. . Had that error at first and went looking to see if something changed in the config.
undefined Phaedrux moved this topic from Firmware installation
