    3.5.0rc1: Input shaping causes layer shifts!?
    Beta Firmware
    19
    196
    15.7k
    • NeoDueundefined
      NeoDue @dc42
      @dc42 Okay, here is the full set of tests, three with IS off and three with IS on - it is nothing extruder related after all 😮
      test 1 (IS most likely off)
      Y homing error was 0.000
      X homing error was 0.012
      Y homing error was -0.012
      X homing error was -0.012
      test 2 (IS off)
      test 3 (IS off)
      X homing error was 0.000
      test 4 (IS on)
      X homing error was -0.788
      test 5 (IS on)
      test 6 (IS on)
      Y homing error was -1.613
      X homing error was -3.188
      That means something still must be wrong with Input shaping... but what?
      And one more thing puzzles me: the offsets measured here are quite a bit lower than the amount of layer shifts I get if I print the real part.
      The only logical reason I can think of that might cause this would be that... something... related to Input Shaping causes a significant temporary loss of torque in the steppers which causes them to loose some steps in free air, but also causes them to be more vulnerable against the slightly larger blobs which then result in more lost steps? The EMF calculator says the stepper configuration is okay. I had doublechecked that when I saw increasing motor currents did tendencially rather in- than decrease the layer shift occurrances...
      • oliofundefined
        oliof @NeoDue
        @NeoDue what IS algo are you using? I haven't tested thoroughly yet but I feel ZVDD may cause more issues than MZV.
        NeoDueundefined 1 Reply Last reply Reply Quote 0
        • NeoDueundefined
          NeoDue @oliof
          @oliof I used EI2 for all recent test cases here - measuring with the input shaping plugin gave me the result that either ZVDDD or EI2 should be the best two options for my printer. Which one will be ultimately the best is something I need to find out when I can finally use it 🙂
          • oliofundefined
            oliof @NeoDue
            @NeoDue I haven't tried EI2, but I have had much less issues with MZV than with ZVD. With my squirqle test, ZVD seems to be applied somewhat more irregularly than MZV; I would suspect that the variations in speed could affect extrusion as well which might contribute to the blobbing / extrusion irregularities.
            • NeoDueundefined
              NeoDue @oliof
              @oliof at least according to my tests with the accelerometer MZV seemed quite a bit less effective, that was the reason why I had discarded that one. The options the Duet offers should work after all 😉
              But I will keep that in mind, thanks for the hint.
              • NeoDueundefined
                NeoDue @dc42
                @dc42 one more test: I wanted to check if the TMC stepper maybe detects skipped steps while running the test and ran a M569.2 P0:0 and P0:3 R{0x73} (i.e. read the "LOST_STEPS" register) in regular intervals during the "print".
                The register stayed at 0 all the time, while your macro yielded the following result:
                test 7 (IS on)
                Y homing error was -0.692
                X homing error was -5.600
                  dc42 administrators @NeoDue
                  @NeoDue thanks for running all those tests.
                  I am trying to find the cause of the blobs you reported when IS is enabled that you said you believed were caused by particular lines of code. So I've been running this print job with full debug output, using your machine configuration, with IS enabled and with IS not enabled:
                  ; testing IS on short segments generated by PrusaSlicer
                  M83
                  M302 P1
                  M591 D0 S0
                  T0
                  G92 E0
                  G92 X-7.974 Y29.422 F3000			; set initial position
                  ;WIDTH:0.398828
                  G1 F8190
                  G1 X-7.953 Y29.175 E.00567
                  ;WIDTH:0.425466
                  G1 X-7.932 Y28.928 E.00608
                  G1 X-7.877 Y28.826 E.00284
                  ;WIDTH:0.398828
                  G1 X-7.823 Y28.723 E.00266
                  ;WIDTH:0.37219
                  G1 X-7.815 Y-7.037 E.75823
                  ;WIDTH:0.411061
                  G1 X-7.867 Y-7.142 E.00277
                  ;WIDTH:0.449932
                  G1 X-7.919 Y-7.246 E.00303
                  G1 X-7.922 Y-42.252 E.91196
                  The movement commands are taken from your print file. They include the lines you thought were where the blob occurs and a few preceding lines.
                  What I found is that IS isn't applied to any of those moves, mostly because they are too short (which is because you have segmentation enabled). The attempt to apply IS does change one of the moves very slightly but not in a way that significantly affects the step generation. So I haven't been able to find any cause of the blob you report.
                  Are you absolutely certain that these are the moves where the blob occurs when you run the print job with IS enabled?
                  I've put a new build of RRF for the 6HC at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0. I don't expect this to change the behaviour significantly, except that if you execute a G92 E command with a tool selected it now clears the fraction of an extruder step that is left over from the last move, for all extruders used by the current tool. I did this so that we can get consistent results regardless of the previous printing history.
                  • NeoDueundefined
                    NeoDue @dc42
                    @dc42 thanks for the investigation! However, with the new results from your measurement macro, I fear that the whole "blob" topic was the wrong way to go anyway... 🤔
                    Therefore please consider the following information to be purely optional:
                    I had taken two videos (they probably won't help you much, but here is a link to download them anyway..) of that part of the print, one with IS on and one with IS off, and I doublechecked with those. There are indeed two possibilities that might be the culprit: first, the one I had sent you:
                    • starting from X-7.877 Y28.826, the print head first prints the thin long line to X-7.815 Y-7.037. Then it creates the two short lines and goes on to X-7.922 Y-42.252. At this position, the head retracts with a G10, lifts and moves back to X-7.919 Y-6.828, where it unretracts with G11 and creates a third long line to X-7.919 Y28.491.
                    And this third long line seems to be the second possibility where there is an issue - with IS on you hear a "crack" which, after listening to it with headphones several times, sounds more like noise from the extruder stepper to me.
                    During the test print, I only had managed to pause the printer after he made that third move, and I could see the larger blob where the two short segments are located. But one of the subsequent steps might be the culprit as well indeed.
                      @NeoDue the reason I wanted to investigate the blob was that it could have been caused by either incorrect extrusion or by incorrect axis movement, for example a short pause in axis movement; and incorrect axis movement is likely responsible for the layer shifts.
                      Investigating in depth the lines of GCode you provided has given me a better understand of what your print is doing. As a result I've identified another possible error in the code. Please can you try a print using the new files at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0. I'm interested both in whether there are any layer shifts, and in whether you still see the blobs that only occurred when you enable IS.
                      Thanks for your patience! You feedback has been invaluable to help me get this far.
                      NeoDueundefined adrianundefined 2 Replies Last reply Reply Quote 0
                      • NeoDueundefined
                        NeoDue @dc42
                        @dc42 On the contrary - I have to thank you for taking the time to dive into this problem so deeply! This is what makes owning a Duet so different from the other printer controllers: the dedication of the team behind it.
                        I will do the test print for you as soon as I can, but unless I am very lucky, it might take until the weekend until I can deliver!
                        • adrianundefined
                          adrian @dc42
                          I only had time to run my print again with your new firmware. Layer shifts even worse now.
                          My first run I forgot to enable IS and it ran fine. With IS on it layer shifted way more frequently than ever before.
                          m122
                          RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-19 14:31:56) running on Duet 3 MB6HC v1.02 or later (standalone mode)
                          Board ID: 08DJM-956BA-NA3TJ-6J1F8-3S06Q-1U86S
                          Used output buffers: 6 of 40 (40 max)
                          Static ram: 155208
                          Dynamic ram: 124316 of which 592 recycled
                          Never used RAM 62228, free system stack 100 words
                          Tasks: NETWORK(1,ready,115.5%,162) ETHERNET(5,nWait 7,0.2%,117) ACCEL(6,nWait 6,0.0%,344) HEAT(3,nWait 6,0.2%,321) Move(4,nWait 6,7.8%,214) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.1%,334) TMC(4,nWait 6,41.8%,54) MAIN(1,running,238.3%,103) IDLE(0,ready,0.3%,30), total 404.1%
                          Owned mutexes:
                          Last reset 02:06:49 ago, cause: software
                          Last software reset at 2024-02-19 20:45, reason: User, Gcodes spinning, available RAM 62324, slot 0
                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
                          Error status: 0x04
                          Aux0 errors 0,1,0
                          MCU temperature: min 33.8, current 34.3, max 35.3
                          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 11.7, current 12.1, max 12.8, under voltage events: 0
                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/56/56, gc cycles 0
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min 0, mspos 344, reads 49790, writes 21 timeouts 0
                          Driver 1: standstill, SG min 0, mspos 360, reads 49790, writes 21 timeouts 0
                          Driver 2: standstill, SG min 0, mspos 536, reads 49792, writes 21 timeouts 0
                          Driver 3: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
                          Driver 4: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
                          Driver 5: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
                          Date/time: 2024-02-19 22:51:54
                          Slowest loop: 236.02ms; fastest: 0.05ms
                          === Storage ===
                          Free file entries: 20
                          SD card longest read time 19.3ms, write time 1.8ms, max retries 0
                          DMs created 125, segments created 33, maxWait 313188ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval -13129, bad calcs 1068, ebfmin 0.00, ebfmax 1.00
                          no step interrupt scheduled
                          Moves shaped first try 11555, on retry 6745, too short 23528, wrong shape 45799, maybepossible 2852
                          === DDARing 0 ===
                          Scheduled moves 101503, completed 101503, hiccups 456, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                          === DDARing 1 ===
                          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
                          Heater 0 is on, I-accum = 0.3
                          Heater 1 is on, I-accum = 0.2
                          Heater 2 is on, I-accum = 0.0
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          File2 is idle in state(s) 0
                          Queue2 is idle in state(s) 0
                          Q0 segments left 0, axes/extruders owned 0x80000007
                          Code queue 0 is empty
                          Code queue 1 is empty
                          === CAN ===
                          Messages queued 68487, received 0, lost 0, errs 36169280, boc 0
                          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 38049/0/0
                          Tx timeouts 0,0,38048,0,0,30437 last cancelled message type 4514 dest 127
                          === Network ===
                          Slowest loop: 213.93ms; fastest: 0.03ms
                          Responder states: MQTT(0) HTTP(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                          HTTP sessions: 2 of 8
                          = Ethernet =
                          Interface state: active
                          Error counts: 0 0 13 0 0 0
                          Socket states: 2 5 3 2 2 0 0 0
                          === WiFi ===
                          Interface state: disabled
                          Module is disabled
                          Failed messages: pending 0, notrdy 0, noresp 0
                          === Multicast handler ===
                          Responder is inactive, messages received 0, responses 0
                            dc42 administrators @adrian
                            @adrian thanks for testing that firmware.
                            Please can you try the firmware at https://www.dropbox.com/scl/fo/618dnwt7u1gxjs88hxvlg/h?rlkey=efh8iqql2nsbofa0n6k44zktc&dl=0. In this build I have disabled part of the input shaping so that I can determine which part the bug lies in.
                              dc42 administrators @dc42
                              @NeoDue @adrian I've found a likely cause of RRF trying to apply input shaping to moves when it was not possible, which is likely to lead to jerky motion. So please can you try the new firmware at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
                              PS - a check I added has just found an anomaly that I need to fix; so you may wish to wait for a new build from me tomorrow.
                              adrianundefined 1 Reply Last reply Reply Quote 0
                              • adrianundefined
                                adrian @dc42
                                I’ll try and test tomorrow with the upcoming version
                                  @adrian @NeoDue and anyone else having layer shift issues in 3.5.0-rc3 when IS is enabled, please try the new main board binaries at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
                                  This version fixes a probable cause of layer shifts in previous versions. It also produces debug output if it detects a malformed movement segment. To avoid having to connect a USB terminal to see any debug messages, you can use the new M111 B parameter. If you are running on any Duet 3 board then I suggest M111 B4096. If you are running on Duet 2 or Maestro then you won't have enough free RAM for that, but you can try M111 B256 and accept that the messages will be truncated.
                                  Please report any debug messages you see here, as well as whether you get any later shifts (and a M122 report at the end of the print if you do).
                                  NeoDueundefined adrianundefined leoneundefined 3 Replies Last reply Reply Quote 0
                                  • NeoDueundefined
                                    NeoDue @dc42
                                    @dc42 Perfect! And I was lucky and have some time right now. Just a quick question regarding M111: if I use "P1", I get flooded with messages such as
                                    Received 365 bytes
                                    New conn on socket 0 for local port 80
                                    Found responder
                                    Received 378 bytes
                                    Found responder
                                    How can I turn that off?
                                      @NeoDue don't use P1, use P0. Or don't use P at all. The debug messages I was talking about are sent regardless of the debug enable status.
                                      NeoDueundefined 2 Replies Last reply Reply Quote 0
                                      • NeoDueundefined
                                        NeoDue @dc42
                                        @dc42 This means "M111 S1 P0 B4096" or "M111 S1 B4096"? Okay, thanks!
                                        edit: 1st "dry" test (print w/o filament, measure x and y offset) ist running right now!
                                        • NeoDueundefined
                                          NeoDue @dc42
                                          ... and once again @dc42 has fulfilled the picture of an electronics wizard that I have of him:
                                          (no, I cannot draw at all, this was generated with hotpot.ai art-generator, and I could not get that stupid KI to make the PCB larger)
                                          Three prints up to over 6mm without filament and one with filament, all with Input shaping enabled - and not a single "bang" or layer shift! For the first time ever! 😃 😃 😃
                                          Congratulations, Sir!
                                          As far as I can tell, it seems you have solved the issue!! THANK YOU!
                                          Now I guess I can finally throw all these away 😉
                                          (By the way, the larger blob is still there, however not in the first affected layer but in the other two for some reason. But now the printer simply runs over it, so this is a minor annoyance now and nothing more. I will check if including the retract/unretract command into the print file instead of letting it the Duet do has an effect or such. In case I find something, I will open a new thread for that)
                                          Edit: @adrian @oliof Please also write here if the current version solves the issue for you, then I would mark this as solved
                                          adrianundefined 1 Reply Last reply Reply Quote 2
                                          • adrianundefined
                                            adrian @NeoDue
                                            @NeoDue Testing... Fingers crossed
                                            Update: 35% finished, so far no shifting... I have few more hours to go to complete the print.
                                            Update 2: 46% and going strong...
                                            Checked this morning: finished correctly
                                            Working for me
