    3.5.0rc1: Input shaping causes layer shifts!?
    Beta Firmware
    19
    196
    16.3k
      dc42 administrators @NeoDue
      @NeoDue the reason I wanted to investigate the blob was that it could have been caused by either incorrect extrusion or by incorrect axis movement, for example a short pause in axis movement; and incorrect axis movement is likely responsible for the layer shifts.
      Investigating in depth the lines of GCode you provided has given me a better understand of what your print is doing. As a result I've identified another possible error in the code. Please can you try a print using the new files at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0. I'm interested both in whether there are any layer shifts, and in whether you still see the blobs that only occurred when you enable IS.
      Thanks for your patience! You feedback has been invaluable to help me get this far.
      NeoDueundefined adrianundefined 2 Replies Last reply Reply Quote 0
      • NeoDueundefined
        NeoDue @dc42
        @dc42 On the contrary - I have to thank you for taking the time to dive into this problem so deeply! This is what makes owning a Duet so different from the other printer controllers: the dedication of the team behind it.
        I will do the test print for you as soon as I can, but unless I am very lucky, it might take until the weekend until I can deliver!
        • adrianundefined
          adrian @dc42
          I only had time to run my print again with your new firmware. Layer shifts even worse now.
          My first run I forgot to enable IS and it ran fine. With IS on it layer shifted way more frequently than ever before.
          m122
          RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.3+ (2024-02-19 14:31:56) running on Duet 3 MB6HC v1.02 or later (standalone mode)
          Board ID: 08DJM-956BA-NA3TJ-6J1F8-3S06Q-1U86S
          Used output buffers: 6 of 40 (40 max)
          Static ram: 155208
          Dynamic ram: 124316 of which 592 recycled
          Never used RAM 62228, free system stack 100 words
          Tasks: NETWORK(1,ready,115.5%,162) ETHERNET(5,nWait 7,0.2%,117) ACCEL(6,nWait 6,0.0%,344) HEAT(3,nWait 6,0.2%,321) Move(4,nWait 6,7.8%,214) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.1%,334) TMC(4,nWait 6,41.8%,54) MAIN(1,running,238.3%,103) IDLE(0,ready,0.3%,30), total 404.1%
          Owned mutexes:
          Last reset 02:06:49 ago, cause: software
          Last software reset at 2024-02-19 20:45, reason: User, Gcodes spinning, available RAM 62324, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x04
          Aux0 errors 0,1,0
          MCU temperature: min 33.8, current 34.3, max 35.3
          Supply voltage: min 23.9, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 11.7, current 12.1, max 12.8, under voltage events: 0
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/56/56, gc cycles 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 344, reads 49790, writes 21 timeouts 0
          Driver 1: standstill, SG min 0, mspos 360, reads 49790, writes 21 timeouts 0
          Driver 2: standstill, SG min 0, mspos 536, reads 49792, writes 21 timeouts 0
          Driver 3: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
          Driver 4: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
          Driver 5: standstill, SG min 0, mspos 952, reads 49792, writes 21 timeouts 0
          Date/time: 2024-02-19 22:51:54
          Slowest loop: 236.02ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 20
          SD card longest read time 19.3ms, write time 1.8ms, max retries 0
          DMs created 125, segments created 33, maxWait 313188ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval -13129, bad calcs 1068, ebfmin 0.00, ebfmax 1.00
          no step interrupt scheduled
          Moves shaped first try 11555, on retry 6745, too short 23528, wrong shape 45799, maybepossible 2852
          === DDARing 0 ===
          Scheduled moves 101503, completed 101503, hiccups 456, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === DDARing 1 ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
          Heater 0 is on, I-accum = 0.3
          Heater 1 is on, I-accum = 0.2
          Heater 2 is on, I-accum = 0.0
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          File2 is idle in state(s) 0
          Queue2 is idle in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x80000007
          Code queue 0 is empty
          Code queue 1 is empty
          === CAN ===
          Messages queued 68487, received 0, lost 0, errs 36169280, boc 0
          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 38049/0/0
          Tx timeouts 0,0,38048,0,0,30437 last cancelled message type 4514 dest 127
          === Network ===
          Slowest loop: 213.93ms; fastest: 0.03ms
          Responder states: MQTT(0) HTTP(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 2 of 8
          = Ethernet =
          Interface state: active
          Error counts: 0 0 13 0 0 0
          Socket states: 2 5 3 2 2 0 0 0
          === WiFi ===
          Interface state: disabled
          Module is disabled
          Failed messages: pending 0, notrdy 0, noresp 0
          === Multicast handler ===
          Responder is inactive, messages received 0, responses 0
            dc42 administrators @adrian
            @adrian thanks for testing that firmware.
            Please can you try the firmware at https://www.dropbox.com/scl/fo/618dnwt7u1gxjs88hxvlg/h?rlkey=efh8iqql2nsbofa0n6k44zktc&dl=0. In this build I have disabled part of the input shaping so that I can determine which part the bug lies in.
              dc42 administrators @dc42
              @NeoDue @adrian I've found a likely cause of RRF trying to apply input shaping to moves when it was not possible, which is likely to lead to jerky motion. So please can you try the new firmware at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
              PS - a check I added has just found an anomaly that I need to fix; so you may wish to wait for a new build from me tomorrow.
              adrianundefined 1 Reply Last reply Reply Quote 0
              • adrianundefined
                adrian @dc42
                I’ll try and test tomorrow with the upcoming version
                  @adrian @NeoDue and anyone else having layer shift issues in 3.5.0-rc3 when IS is enabled, please try the new main board binaries at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
                  This version fixes a probable cause of layer shifts in previous versions. It also produces debug output if it detects a malformed movement segment. To avoid having to connect a USB terminal to see any debug messages, you can use the new M111 B parameter. If you are running on any Duet 3 board then I suggest M111 B4096. If you are running on Duet 2 or Maestro then you won't have enough free RAM for that, but you can try M111 B256 and accept that the messages will be truncated.
                  Please report any debug messages you see here, as well as whether you get any later shifts (and a M122 report at the end of the print if you do).
                  NeoDueundefined adrianundefined leoneundefined 3 Replies Last reply Reply Quote 0
                  • NeoDueundefined
                    NeoDue @dc42
                    @dc42 Perfect! And I was lucky and have some time right now. Just a quick question regarding M111: if I use "P1", I get flooded with messages such as
                    Received 365 bytes
                    New conn on socket 0 for local port 80
                    Found responder
                    Received 378 bytes
                    Found responder
                    How can I turn that off?
                      @NeoDue don't use P1, use P0. Or don't use P at all. The debug messages I was talking about are sent regardless of the debug enable status.
                      NeoDueundefined 2 Replies Last reply Reply Quote 0
                      • NeoDueundefined
                        NeoDue @dc42
                        @dc42 This means "M111 S1 P0 B4096" or "M111 S1 B4096"? Okay, thanks!
                        edit: 1st "dry" test (print w/o filament, measure x and y offset) ist running right now!
                        • NeoDueundefined
                          NeoDue @dc42
                          ... and once again @dc42 has fulfilled the picture of an electronics wizard that I have of him:
                          (no, I cannot draw at all, this was generated with hotpot.ai art-generator, and I could not get that stupid KI to make the PCB larger)
                          Three prints up to over 6mm without filament and one with filament, all with Input shaping enabled - and not a single "bang" or layer shift! For the first time ever! 😃 😃 😃
                          Congratulations, Sir!
                          As far as I can tell, it seems you have solved the issue!! THANK YOU!
                          Now I guess I can finally throw all these away 😉
                          (By the way, the larger blob is still there, however not in the first affected layer but in the other two for some reason. But now the printer simply runs over it, so this is a minor annoyance now and nothing more. I will check if including the retract/unretract command into the print file instead of letting it the Duet do has an effect or such. In case I find something, I will open a new thread for that)
                          Edit: @adrian @oliof Please also write here if the current version solves the issue for you, then I would mark this as solved
                          adrianundefined 1 Reply Last reply Reply Quote 2
                          • adrianundefined
                            adrian @NeoDue
                            @NeoDue Testing... Fingers crossed
                            Update: 35% finished, so far no shifting... I have few more hours to go to complete the print.
                            Update 2: 46% and going strong...
                            Checked this morning: finished correctly
                            Working for me
                            • adrianundefined
                              adrian @dc42
                              Newest version works with IS on. It was quieter during infills, as well. Thanks for all your work
                              NeoDueundefined 1 Reply Last reply Reply Quote 0
                              • NeoDueundefined
                                NeoDue @adrian
                                @adrian Great! Then @oliof is the last one missing.
                                balajiramaniundefined oliofundefined 2 Replies Last reply Reply Quote 0
                                • balajiramaniundefined
                                  balajiramani @NeoDue
                                  @NeoDue I too, previously had layer shifts. With the newer firmware, there are no layer shifts and it works great!
                                  Thank you, @dc42!!
                                  • oliofundefined
                                    oliof @NeoDue
                                    @NeoDue I did a quick test today and the new version has no issues for me (but that's not worth a lot since I fixed my previous issues with increased current).
                                    • NeoDueundefined
                                      NeoDue @oliof
                                      @oliof well, maybe you can reduce currents now again 😉
                                      But thanks for the feedback! I will mark the thread as solved then.
                                      Once more @dc42: thank you very, very much for all that detective work you did!
                                      dc42undefined 1 Reply Last reply Reply Quote 3
                                      • NeoDueundefined NeoDue has marked this topic as solved
                                      • gloomyandyundefined gloomyandy referenced this topic
                                        My thanks to all of you who provided data to help me solve this issue.
                                        • NeoDueundefined NeoDue referenced this topic
                                          balajiramani
                                          I tried a different model and I see the layer shift with the newer firmware.
                                          When I switched back to 3.4.6, It prints fine. So, it looks like the problem still exists.
                                          • NeoDueundefined
                                            NeoDue @balajiramani
                                            @balajiramani you need to help me there... where is the layer shift in your picture? I only see some ringing...
                                            balajiramaniundefined 1 Reply Last reply Reply Quote 0
