    1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
    Beta Firmware
    9
    147
    8.7k
    • Exerqtorundefined
      Exerqtor @dc42
      @dc42 said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-r1:
      @Exerqtor thanks for testing. I've tracked down a bug in the input shaping code that could result in the main board asking the tool board to apply IS to a move when it was not possible. This could be relevant to your issue. So please try the new main board firmware at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0.
      Ok I tested those binaries (I see that it's been updated/changed just two hours ago at the time of posting this reply) and it's still the same unfortunately. Here is some reports.
      Extruding:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3+ (2024-02-21 12:51:12) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
      Used output buffers: 15 of 40 (30 max)
      Static ram: 103264
      Dynamic ram: 128424 of which 0 recycled
      Never used RAM 3680, free system stack 144 words
      Tasks: NETWORK(2,nWait 7,17.6%,182) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.2%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,78.9%,602) IDLE(0,ready,1.5%,30) AIN(4,delaying,0.9%,260), total 100.0%
      Owned mutexes:
      Last reset 00:04:16 ago, cause: software
      Last software reset at 2024-02-19 18:20, reason: User, Gcodes spinning, available RAM 12072, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 257248, completed 257248, timed out 0, errs 0
      MCU temperature: min 36.5, current 41.7, max 41.7
      Supply voltage: min 2.6, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/2932/2472, gc cycles 59
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 13469, writes 32, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 13468, writes 32, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 13480, writes 20, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 13480, writes 20, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 13481, writes 20, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2024-02-21 15:59:49
      Cache data hit count 419633128
      Slowest loop: 224.31ms; fastest: 0.09ms
      === Storage ===
      Free file entries: 16
      SD card longest read time 6.5ms, write time 63.1ms, max retries 0
      DMs created 83, segments created 14, maxWait 126549ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 98 ticks, enabled
      Moves shaped first try 43, on retry 0, too short 2, wrong shape 156, maybepossible 1
      === DDARing 0 ===
      Scheduled moves 345, completed 306, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.5
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 P250" in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 4, axes/extruders owned 0x0000807
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 0
      Extruder 0 sensor: no filament
      === CAN ===
      Messages queued 2616, received 5457, lost 0, errs 1228, boc 0
      Longest wait 2ms for reply type 6053, peak Tx sync delay 44848, free buffers 26 (min 25), ts 1285/1283/0
      Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 12.23ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      === WiFi ===
      Interface state: active
      Module is connected to access point
      Failed messages: pending 0, notrdy 0, noresp 0
      Firmware version 2.1beta7
      MAC address c4:5b:be:ce:91:93
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43040
      WiFi IP address 192.168.10.x
      Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002001
      M122 B121
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-15 13:22:28)
      Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 3728, free system stack 93 words
      Tasks: Move(3,nWait 7,0.0%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.0%,73) CanClock(5,nWait 1,0.0%,61) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.2%,317) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,112), total 100.0%
      Owned mutexes:
      Last reset 00:04:19 ago, cause: power up
      Last software reset data not available
      Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 64109, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 45910
      Moves scheduled 193, completed 192, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 277, maxOverdue 35, maxInc 20, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
      Peak sync jitter -2/9, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 23.3, current 24.1, max 24.4
      MCU temperature: min 49.5C, current 54.5C, max 54.5C
      Last sensors broadcast 0x00000012 found 2 26 ticks ago, 0 ordering errs, loop time 1
      CAN messages queued 5541, send timeouts 0, received 2686, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 327, adv 35687/74643
      Accelerometer: LIS3DH, status: 00
      I2C bus errors 0, naks 3, contentions 0, other errors 0
      Interrupt 5726621 to 0us, poll 2 to 1462us
      Driver 0: ok
      Not extruding:
      Used output buffers: 21 of 40 (40 max)
      Static ram: 103264
      Never used RAM 3104, free system stack 128 words
      Tasks: NETWORK(2,nWait 7,17.9%,182) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,2.4%,241) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,76.7%,602) IDLE(0,ready,1.1%,30) AIN(4,delaying,0.9%,260), total 100.0%
      Owned mutexes:
      Last reset 00:08:55 ago, cause: software
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 535900, completed 535900, timed out 0, errs 0
      MCU temperature: min 41.5, current 46.2, max 46.6
      Supply voltage: min 23.6, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/4036/3576, gc cycles 85
      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 14657, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 14658, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14658, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14657, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14657, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2024-02-21 16:04:28
      Cache data hit count 832601058
      Slowest loop: 37.19ms; fastest: 0.10ms
      === Storage ===
      SD card longest read time 9.0ms, write time 2.1ms, max retries 0
      DMs created 83, segments created 38, maxWait 2730ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 13 ticks, enabled
      Moves shaped first try 301, on retry 70, too short 131, wrong shape 2601, maybepossible 65
      === DDARing 0 ===
      Scheduled moves 4136, completed 4120, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
      === DDARing 1 ===
      File2 is idle in state(s) 0, sync state 1
      Q0 segments left 5, axes/extruders owned 0x0000807
      check 0 clear 0
      === CAN ===
      Messages queued 5975, received 5742, lost 0, errs 0, boc 0
      Longest wait 5ms for reply type 6024, peak Tx sync delay 264, free buffers 26 (min 24), ts 1393/1393/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 19.71ms; fastest: 0.06ms
      HTTP sessions: 2 of 8
      === WiFi ===
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42308
      Signal strength -49dBm, channel 6, mode 802.11n, reconnections 0
      M122 B121
      Never used RAM 3200, free system stack 73 words
      Tasks: Move(3,nWait 7,0.3%,91) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,73) CanClock(5,nWait 1,0.0%,61) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.6%,317) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
      Owned mutexes:
      Last reset 00:08:59 ago, cause: power up
      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 8596, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 340567
      Moves scheduled 2825, completed 2825, in progress 0, hiccups 118, segs 34, step errors 0, maxLate 0 maxPrep 880, maxOverdue 94, maxInc 76, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
      Peak sync jitter -1/9, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 23.9, current 24.1, max 24.4
      MCU temperature: min 49.5C, current 58.6C, max 58.6C
      Last sensors broadcast 0x00000012 found 2 225 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 5772, send timeouts 0, received 6029, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 349, adv 35572/98928
      I2C bus errors 0, naks 0, contentions 0, other errors 0
      Interrupt 5726621 to 0us, poll 9 to 1828us
      Driver 0: ok
        dc42 administrators @Exerqtor
        @Exerqtor do you only see this issue when input shaping is enabled? If so, please try the new main board binary at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0. It fixes a bug that could cause RRF to send expansion boards moves that were impossible to implement in time, which could have been causing the tool board to get confused. It also avoids sending tiny acceleration moves, which I spotted was happening quite often.
        Exerqtorundefined 2 Replies Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 I haven't tried running a print in a while with IS disabled so i can't say if that and determining factor.
          But i did try the print with IS enabled and the binaries you linked to just now (that's 2 hours old according to dropbox).
          I'm running a new test now with IS disabled, give me a couple minutes and i'll report back on how that turns out.
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 Ok that's something else, with IS disabled it totally shits the bed from the get go. It won't even do the purge line and stops extruding right off the bat (can't feel any feeding movement at all when i touch the filament going into the reverse bowden either.)
            Reports:
            M122
            Used output buffers: 1 of 40 (40 max)
            Static ram: 103264
            Never used RAM 3080, free system stack 124 words
            Tasks: NETWORK(1,ready,16.0%,182) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,0.5%,241) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,80.7%,602) IDLE(0,ready,0.9%,30) AIN(4,delaying,0.9%,260), total 100.0%
            Owned mutexes:
            Last reset 00:38:59 ago, cause: software
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU revision 3, ADC conversions started 2340236, completed 2340235, timed out 0, errs 0
            MCU temperature: min 39.6, current 46.0, max 46.4
            Supply voltage: min 23.4, current 24.0, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
            Heap OK, handles allocated/used 198/32, heap memory allocated/used/recyclable 4096/2492/2044, gc cycles 261
            Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 51, reads 29396, writes 19, timeouts 0, DMA errors 0, CC errors 0
            Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 51, reads 29396, writes 19, timeouts 0, DMA errors 0, CC errors 0
            Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 28, reads 29407, writes 8, timeouts 0, DMA errors 0, CC errors 0
            Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 27, reads 29409, writes 7, timeouts 0, DMA errors 0, CC errors 0
            Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 27, reads 29409, writes 7, timeouts 0, DMA errors 0, CC errors 0
            Date/time: 2024-02-21 16:34:32
            Cache data hit count 3897963068
            Slowest loop: 223.37ms; fastest: 0.09ms
            === Storage ===
            SD card longest read time 9.3ms, write time 4.5ms, max retries 0
            DMs created 83, segments created 39, maxWait 1368993ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
            next step interrupt due in 84 ticks, enabled
            Moves shaped first try 879, on retry 264, too short 252, wrong shape 3751, maybepossible 153
            === DDARing 0 ===
            Scheduled moves 758, completed 737, hiccups 0, stepErrors 0, LaErrors 10, Underruns [0, 0, 2], CDDA state 3
            === DDARing 1 ===
            Heater 0 is on, I-accum = 0.4
            Daemon is idle in state(s) 0 0, running macro
            Q0 segments left 3, axes/extruders owned 0x0000807
            check 0 clear 0
            === CAN ===
            Messages queued 22739, received 37190, lost 0, errs 0, boc 0
            Longest wait 6ms for reply type 6024, peak Tx sync delay 210, free buffers 26 (min 24), ts 9021/9021/0
            === Network ===
            Slowest loop: 207.53ms; fastest: 0.06ms
            === WiFi ===
            Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 36344
            Signal strength -51dBm, channel 6, mode 802.11n, reconnections 0
            	M122 B121
            Tasks: Move(3,nWait 7,0.1%,91) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.0%,73) CanClock(5,nWait 1,0.0%,61) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.1%,317) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,112), total 100.0%
            Owned mutexes:
            Last reset 00:39:01 ago, cause: power up
            Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 48253, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 139106
            Moves scheduled 3211, completed 3211, in progress 0, hiccups 193, segs 34, step errors 0, maxLate 0 maxPrep 884, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
            Peak sync jitter -2/10, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
            MCU temperature: min 49.5C, current 62.7C, max 62.7C
            Last sensors broadcast 0x00000012 found 2 193 ticks ago, 0 ordering errs, loop time 0
            CAN messages queued 37145, send timeouts 0, received 22662, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 342, adv 35802/74653
            Interrupt 5726621 to 0us, poll 5 to 1478us
            Driver 0: ok
              @Exerqtor where did you get the tool board firmware from? The date reported by M122 doesn't appear to match the one on Dropbox that I installed on my toolchanger.
              Exerqtorundefined 1 Reply Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                @dc42 I grabbed the toolboard firmware from the same dropbox folder, thats at least what I meant to do 🤔 I'll re-download and install it again in a couple minutes to make sure.
                  @Exerqtor I'll rebuild all the expansion board firmware binaries and check that they update correctly on my machine.
                    dc42 administrators @dc42
                    @Exerqtor that's done. I'll now do a test print using them.
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Ok, i just did the same thing, downloaded and installed the binaries you just built. I'll try one print now first with my normal IS config and see how that turns out and update the post once that's done. If it acts up i'll disable IS and run another test.
                      And with IS enabled it's the same behaviour as before, it stops extruding a little ways into layer 3.
                      While extruding:
                      M122
                      Used output buffers: 27 of 40 (40 max)
                      Static ram: 103264
                      Dynamic ram: 128608 of which 44 recycled
                      Never used RAM 2852, free system stack 124 words
                      Tasks: NETWORK(2,nWait 7,16.0%,174) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,0.2%,241) CanReceiv(6,nWait 1,0.1%,563) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,delaying,0.8%,68) MAIN(1,running,81.0%,599) IDLE(0,ready,1.0%,30) AIN(4,delaying,0.9%,260), total 100.0%
                      Owned mutexes: WiFi(NETWORK)
                      Last reset 01:09:24 ago, cause: software
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 4165028, completed 4165028, timed out 0, errs 0
                      MCU temperature: min 40.6, current 44.5, max 46.8
                      Supply voltage: min 23.4, current 24.0, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 198/32, heap memory allocated/used/recyclable 4096/2352/1904, gc cycles 438
                      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 72, reads 30477, writes 21, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 72, reads 30477, writes 21, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 30487, writes 10, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 30487, writes 10, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 30486, writes 11, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2024-02-21 17:04:57
                      Slowest loop: 238.42ms; fastest: 0.09ms
                      === Storage ===
                      SD card longest read time 8.8ms, write time 4.8ms, max retries 0
                      DMs created 83, segments created 39, maxWait 1529482ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                      next step interrupt due in 33 ticks, enabled
                      Moves shaped first try 78, on retry 2, too short 33, wrong shape 335, maybepossible 21
                      === DDARing 0 ===
                      Scheduled moves 306, completed 267, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
                      === DDARing 1 ===
                      check 0 clear 0
                      === CAN ===
                      Messages queued 20689, received 37300, lost 0, errs 13199, boc 0
                      Longest wait 5ms for reply type 6024, peak Tx sync delay 36947, free buffers 26 (min 25), ts 9124/9111/0
                      Tx timeouts 0,0,13,0,0,8 last cancelled message type 30 dest 127
                      === Network ===
                      Slowest loop: 206.88ms; fastest: 0.06ms
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 41072
                      Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
                      M122 B121
                      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-21 15:51:16)
                      Never used RAM 3688, free system stack 91 words
                      Tasks: Move(3,nWait 7,0.0%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,112), total 100.0%
                      Owned mutexes:
                      Last reset 00:04:11 ago, cause: software
                      Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 1, ifcnt 29, reads 60061, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 45444
                      Moves scheduled 193, completed 191, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 268, maxOverdue 38, maxInc 38, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                      Peak sync jitter -1/9, peak Rx sync delay 207, resyncs 0/0, no timer interrupt scheduled
                      MCU temperature: min 60.5C, current 65.6C, max 65.6C
                      Last sensors broadcast 0x00000012 found 2 168 ticks ago, 0 ordering errs, loop time 0
                      CAN messages queued 5136, send timeouts 0, received 2603, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 326, adv 35737/74646
                      Interrupt 5726621 to 0us, poll 4 to 1454us
                      Driver 0: ok
                      Not extruding:
                      M122
                      Static ram: 103264
                      Tasks: NETWORK(1,ready,18.1%,174) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,2.4%,241) CanReceiv(6,nWait 1,0.1%,563) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,76.4%,599) IDLE(0,ready,1.2%,30) AIN(4,delaying,0.9%,260), total 100.0%
                      Last reset 01:14:00 ago, cause: software
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 4441220, completed 4441220, timed out 0, errs 0
                      MCU temperature: min 44.5, current 46.4, max 47.0
                      Supply voltage: min 23.7, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/1956/1496, gc cycles 464
                      Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 72, reads 14528, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 72, reads 14527, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 14528, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 14528, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 38, reads 14528, writes 0, timeouts 0, DMA errors 0, CC errors 0
                      Date/time: 2024-02-21 17:09:33
                      Slowest loop: 38.31ms; fastest: 0.10ms
                      === Storage ===
                      SD card longest read time 8.6ms, write time 4.3ms, max retries 0
                      DMs created 83, segments created 39, maxWait 2726ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                      next step interrupt due in 81 ticks, enabled
                      Moves shaped first try 296, on retry 68, too short 130, wrong shape 2590, maybepossible 65
                      === DDARing 0 ===
                      Scheduled moves 4080, completed 4058, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
                      === DDARing 1 ===
                      Q0 segments left 6, axes/extruders owned 0x0000807
                      check 0 clear 0
                      === CAN ===
                      Messages queued 5933, received 5691, lost 0, errs 0, boc 0
                      Longest wait 6ms for reply type 6024, peak Tx sync delay 165, free buffers 26 (min 25), ts 1381/1381/0
                      === Network ===
                      Slowest loop: 19.88ms; fastest: 0.07ms
                      === WiFi ===
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42872
                      M122 B121
                      Never used RAM 3112, free system stack 71 words
                      Tasks: Move(3,nWait 7,0.3%,85) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                      Owned mutexes:
                      Last reset 00:08:46 ago, cause: software
                      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 6214, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 340512
                      Moves scheduled 2820, completed 2820, in progress 0, hiccups 106, segs 36, step errors 0, maxLate 0 maxPrep 860, maxOverdue 155, maxInc 95, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                      Peak sync jitter -1/11, peak Rx sync delay 257, resyncs 0/0, no timer interrupt scheduled
                      MCU temperature: min 60.5C, current 67.4C, max 67.7C
                      Last sensors broadcast 0x00000012 found 2 66 ticks ago, 0 ordering errs, loop time 0
                      CAN messages queued 5680, send timeouts 0, received 5905, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 366, adv 36093/104573
                      Interrupt 5726621 to 0us, poll 9 to 1498us
                      Driver 0: ok
                      I'll stop that print, disable IS and run another test.
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        And the same again, with IS disabled (M593 "none") it shits the bed right away. No extrusion what so ever.
                        M122
                        Used output buffers: 25 of 40 (40 max)
                        Static ram: 103264
                        Tasks: NETWORK(2,nWait 7,18.1%,174) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,1.4%,241) CanReceiv(6,nWait 1,0.1%,563) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,77.4%,595) IDLE(0,ready,1.3%,30) AIN(4,delaying,0.9%,260), total 100.0%
                        Last reset 01:23:42 ago, cause: software
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 5023693, completed 5023692, timed out 0, errs 0
                        MCU temperature: min 43.4, current 46.4, max 46.7
                        Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/3684/3224, gc cycles 525
                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 91, reads 30609, writes 19, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 90, reads 30611, writes 18, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 45, reads 30621, writes 7, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 44, reads 30621, writes 7, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 30620, writes 8, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2024-02-21 17:19:15
                        Slowest loop: 226.04ms; fastest: 0.09ms
                        === Storage ===
                        SD card longest read time 9.0ms, write time 6.2ms, max retries 0
                        DMs created 83, segments created 39, maxWait 127541ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                        next step interrupt due in 121 ticks, enabled
                        Moves shaped first try 525, on retry 158, too short 148, wrong shape 2212, maybepossible 91
                        === DDARing 0 ===
                        Scheduled moves 1713, completed 1689, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 2], CDDA state 3
                        === DDARing 1 ===
                        check 0 clear 0
                        === CAN ===
                        Messages queued 10329, received 12134, lost 0, errs 0, boc 0
                        Longest wait 5ms for reply type 6024, peak Tx sync delay 228, free buffers 26 (min 25), ts 2911/2911/0
                        === Network ===
                        Slowest loop: 208.54ms; fastest: 0.06ms
                        HTTP sessions: 3 of 8
                        === WiFi ===
                        Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 42700
                        M122 B121
                        Tasks: Move(3,nWait 7,0.2%,85) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,90.9%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                        Owned mutexes:
                        Last reset 00:18:30 ago, cause: software
                        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 28986, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 106034
                        Moves scheduled 3054, completed 3054, in progress 0, hiccups 117, segs 36, step errors 0, maxLate 0 maxPrep 891, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                        Peak sync jitter 0/11, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
                        VIN voltage: min 23.4, current 24.0, max 24.5
                        MCU temperature: min 60.5C, current 69.1C, max 69.4C
                        Last sensors broadcast 0x00000012 found 2 84 ticks ago, 0 ordering errs, loop time 0
                        CAN messages queued 12160, send timeouts 0, received 10346, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 344, adv 35820/104577
                        Interrupt 5726621 to 0us, poll 5 to 1697us
                        Driver 0: ok
                          @Exerqtor that's weird, my print using a 6HC and 1LC worked perfectly, as usual.
                          • Exerqtorundefined
                            Exerqtor @dc42
                            @dc42 Beats me, could the issue be isolated to a Mini teamed up with a 1LC?
                              @Exerqtor said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-r1:
                              I think that's unlikely. Do you have just the one TOOL1LC board? I'm wondering whether it could be a hardware issue that only the 3.5 firmware is affected by, as nobody else has reported this issue.
                              • Exerqtorundefined
                                Exerqtor @dc42
                                I only have the one 1LC v1.2 avalible, so I can't rule that out without doing a warranty return on it or something like that. I bought the board from E3D march 2022 at least.
                                But wouldn't a fw version dependant hardware fault be a little bit unlikely too?
                                  T3P3Tony administrators @Exerqtor
                                  @Exerqtor I think we will arrange a replacement board being sent to you to rule this out. Can you email info@duet3d.com to co-ordinate.
                                  Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                  • Exerqtorundefined
                                    Exerqtor @T3P3Tony
                                    While waiting for the replacement/test board to arrive I have to get some prints done. So I reverted back to 3.5.0-b4 on the main and tool board. Then tried the same "doomed" job as I've been testing out the different 3.5.0-rc's on and it's currently going without any issues (like i expected).
                                    Here is a couple reports, the first one is from layer1 with the second being from layer81.
                                    Layer 1 / Z 0.25:
                                    M122
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Used output buffers: 1 of 40 (30 max)
                                    Static ram: 102996
                                    Dynamic ram: 130800 of which 0 recycled
                                    Never used RAM 4316, free system stack 138 words
                                    Tasks: NETWORK(1,ready,19.3%,197) HEAT(3,nWait,0.0%,331) Move(4,nWait,0.1%,244) CanReceiv(6,nWait,0.1%,557) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,74) MAIN(1,running,78.0%,578) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.8%,266), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:19:17 ago, cause: software
                                    Last software reset at 2024-02-24 13:14, reason: User, Gcodes spinning, available RAM 11080, slot 2
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 1157769, completed 1157767, timed out 0, errs 0
                                    MCU temperature: min 38.3, current 44.3, max 44.3
                                    Supply voltage: min 3.0, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/516/56, gc cycles 277
                                    Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 60866, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 60866, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 60877, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2024-02-24 13:34:08
                                    Cache data hit count 1894456688
                                    Slowest loop: 226.36ms; fastest: 0.09ms
                                    === Storage ===
                                    SD card longest read time 7.9ms, write time 5.7ms, max retries 0
                                    DMs created 83, segments created 12, maxWait 1002320ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                    next step interrupt due in 106 ticks, enabled
                                    === DDARing 0 ===
                                    Scheduled moves 439, completed 400, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                    === DDARing 1 ===
                                    Daemon is doing "G4 P250        " in state(s) 0 0, running macro
                                    === CAN ===
                                    Messages queued 10819, received 23940, lost 0, boc 0
                                    Longest wait 3ms for reply type 6053, peak Tx sync delay 4577, free buffers 18 (min 17), ts 5787/5785/0
                                    === Network ===
                                    Slowest loop: 207.25ms; fastest: 0.00ms
                                    = WiFi =
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43028
                                    M122 B121
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
                                    Never used RAM 1440, free system stack 88 words
                                    Tasks: Move(3,nWait,0.0%,111) HEAT(2,nWait,0.5%,65) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,0.0%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.5%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,142), total 100.0%
                                    Last reset 00:19:21 ago, cause: VDD brownout
                                    Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 56507, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c, steps req 0 done 58104
                                    Moves scheduled 311, completed 305, in progress 1, hiccups 6, step errors 0, maxPrep 528, maxOverdue 71, maxInc 71, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 0.98
                                    Peak sync jitter -2/9, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
                                    VIN voltage: min 23.3, current 24.3, max 24.5
                                    MCU temperature: min 40.3C, current 58.4C, max 58.4C
                                    Last sensors broadcast 0x00000012 found 2 78 ticks ago, 0 ordering errs, loop time 1
                                    CAN messages queued 24058, send timeouts 0, received 10938, lost 0, free buffers 18, min 18, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 327, adv 35902/74656
                                    I2C bus errors 0, naks 3, other errors 0
                                    Interrupt 5726621 to 0us, poll 2 to 2104us
                                    Driver 0: ok
                                    Layer 81 / Z 16.25:
                                    M122
                                    Used output buffers: 14 of 40 (37 max)
                                    Static ram: 102996
                                    Never used RAM 3668, free system stack 128 words
                                    Tasks: NETWORK(2,nWait,18.2%,197) HEAT(3,nWait,0.0%,331) Move(4,nWait,2.4%,244) CanReceiv(6,nWait,0.1%,557) CanSender(5,nWait,0.1%,328) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.8%,74) MAIN(1,running,76.3%,578) IDLE(0,ready,1.2%,29) AIN(4,delaying,1.0%,266), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:50:38 ago, cause: software
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 3039527, completed 3039526, timed out 0, errs 0
                                    MCU temperature: min 46.2, current 46.4, max 46.6
                                    Supply voltage: min 23.8, current 23.9, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/708/248, gc cycles 679
                                    Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 302, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 302, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 301, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2024-02-24 14:05:30
                                    Slowest loop: 9.14ms; fastest: 0.12ms
                                    === Storage ===
                                    SD card longest read time 8.3ms, write time 4.2ms, max retries 0
                                    DMs created 83, segments created 39, maxWait 350ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                    next step interrupt due in 27 ticks, enabled
                                    === DDARing 0 ===
                                    Scheduled moves 55744, completed 55731, hiccups 0, stepErrors 0, LaErrors 1, Underruns [0, 0, 0], CDDA state 3
                                    === DDARing 1 ===
                                    File is doing "G1 X230.443 Y223.609 E.02122" in state(s) 0
                                    Q0 segments left 1, axes/extruders owned 0x0000807
                                    Queue 0 has 'M106 S204' for move 55735
                                    === CAN ===
                                    Messages queued 157, received 118, lost 0, boc 0
                                    Longest wait 4ms for reply type 6029, peak Tx sync delay 133, free buffers 18 (min 17), ts 28/28/0
                                    === Network ===
                                    Slowest loop: 19.54ms; fastest: 0.07ms
                                    Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                    = WiFi =
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36164
                                    M122 B121
                                    Never used RAM 888, free system stack 88 words
                                    Tasks: Move(3,nWait,1.0%,111) HEAT(2,nWait,0.6%,57) CanAsync(5,nWait,0.0%,53) CanRecv(3,nWait,0.2%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.2%,57) MAIN(1,running,89.7%,336) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.2%,142), total 100.0%
                                    Last reset 00:50:42 ago, cause: VDD brownout
                                    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 35259, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 172975
                                    Moves scheduled 48482, completed 48482, in progress 0, hiccups 154, step errors 0, maxPrep 1236, maxOverdue 713, maxInc 461, mcErrs 0, gcmErrs 0, ebfmin -0.99, ebfmax 1.00
                                    Peak sync jitter 1/11, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
                                    VIN voltage: min 23.9, current 24.3, max 24.5
                                    MCU temperature: min 40.3C, current 74.1C, max 74.1C
                                    Last sensors broadcast 0x00000012 found 2 175 ticks ago, 0 ordering errs, loop time 2
                                    CAN messages queued 1522, send timeouts 0, received 2712, lost 0, free buffers 18, min 17, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 416, adv 35935/74658
                                    I2C bus errors 0, naks 0, other errors 0
                                    Interrupt 5726621 to 0us, poll 10 to 2689us
                                    Driver 0: ok
                                    (And again, the "VDD brownout reset cause" on the 1LC is the reboot after downgrading to 3.5.0-b4 and relays controlling the 24V rails flipping off/on).
                                    Doubt it's any value in those reports, but it's atleast another proof that the issue manifest after 3.5.0-b4.
                                    I'll let the print finish just for the sake of sanity and arguent and update this post.
                                    And it finished without a hickup:
                                    • Exerqtorundefined
                                      Exerqtor @Exerqtor
                                      @dc42 I received the replacement 1LC today, so I first updated the firmware to the binaries you posted a couple days ago on both the main & old tool board. Then ran a test
                                      print with the same file as before to have solid point of reference before swaping boards.
                                      The old board behaved just like suspected and stoped extruding a little bit into layer 3, here are the reports.
                                      Extruding:
                                      M122
                                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3+ (2024-02-27 13:52:47) running on Duet 3 Mini5plus WiFi (standalone mode)
                                      Used output buffers: 21 of 40 (32 max)
                                      Static ram: 103264
                                      Dynamic ram: 128648 of which 0 recycled
                                      Never used RAM 5512, free system stack 144 words
                                      Tasks: NETWORK(2,nWait 7,15.9%,220) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,delaying,0.8%,68) MAIN(1,running,81.1%,610) IDLE(0,ready,1.2%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:11:35 ago, cause: software
                                      Error status: 0x00
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 696225, completed 696224, timed out 0, errs 0
                                      MCU temperature: min 34.2, current 40.7, max 40.7
                                      Supply voltage: min 2.6, current 23.9, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                                      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1092/632, gc cycles 176
                                      Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 36577, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 36577, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 36587, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 36587, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 36587, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2024-02-28 16:00:56
                                      Cache data hit count 1133766067
                                      Slowest loop: 217.97ms; fastest: 0.09ms
                                      === Storage ===
                                      SD card longest read time 7.5ms, write time 50.3ms, max retries 0
                                      DMs created 83, segments created 14, maxWait 557540ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                      next step interrupt due in 44 ticks, enabled
                                      Moves shaped first try 43, on retry 0, too short 2, wrong shape 169, maybepossible 1
                                      === DDARing 0 ===
                                      Scheduled moves 345, completed 315, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                      === DDARing 1 ===
                                      check 0 clear 0
                                      === CAN ===
                                      Messages queued 6581, received 14457, lost 0, errs 1237, boc 0
                                      Longest wait 4ms for reply type 6029, peak Tx sync delay 46266, free buffers 26 (min 25), ts 3480/3478/0
                                      === Network ===
                                      Slowest loop: 27.07ms; fastest: 0.00ms
                                      === WiFi ===
                                      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                                      M122 B121
                                      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-26 15:24:37)
                                      Tasks: Move(3,nWait 7,0.0%,91) HEAT(2,nWait 6,0.4%,95) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:11:38 ago, cause: power up
                                      Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 21380, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 46371
                                      Moves scheduled 194, completed 193, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 297, maxOverdue 39, maxInc 39, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                                      Peak sync jitter -2/9, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
                                      MCU temperature: min 39.2C, current 50.6C, max 50.6C
                                      Last sensors broadcast 0x00000012 found 2 121 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 14535, send timeouts 0, received 6637, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 324, adv 36007/74649
                                      Interrupt 5726621 to 0us, poll 2 to 1512us
                                      Driver 0: ok
                                      Not extruding:
                                      M122
                                      Used output buffers: 13 of 40 (40 max)
                                      Static ram: 103264
                                      Never used RAM 4960, free system stack 138 words
                                      Tasks: NETWORK(2,nWait 7,17.4%,218) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.4%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,330) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,77.0%,610) IDLE(0,ready,1.3%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                      Last reset 00:16:08 ago, cause: software
                                      Error status: 0x04
                                      Aux0 errors 0,0,0
                                      MCU revision 3, ADC conversions started 968535, completed 968535, timed out 0, errs 0
                                      MCU temperature: min 40.4, current 46.0, max 46.6
                                      Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/772/312, gc cycles 235
                                      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 14324, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                      Date/time: 2024-02-28 16:05:28
                                      Cache data hit count 1522225812
                                      Slowest loop: 36.63ms; fastest: 0.10ms
                                      === Storage ===
                                      SD card longest read time 8.4ms, write time 4.5ms, max retries 0
                                      DMs created 83, segments created 37, maxWait 2140ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                      next step interrupt due in 15 ticks, enabled
                                      Moves shaped first try 290, on retry 63, too short 121, wrong shape 2546, maybepossible 57
                                      === DDARing 0 ===
                                      Scheduled moves 4027, completed 3987, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
                                      === DDARing 1 ===
                                      File is doing "G2 X223.055 Y232.264 I.189 J-.413 E.01443" in state(s) 0
                                      Queue 0 has 'M106 S135' for move 4021
                                      check 0 clear 0
                                      === CAN ===
                                      Messages queued 5799, received 5612, lost 0, errs 0, boc 0
                                      Longest wait 6ms for reply type 6024, peak Tx sync delay 295, free buffers 26 (min 25), ts 1361/1361/0
                                      === Network ===
                                      Slowest loop: 20.10ms; fastest: 0.07ms
                                      === WiFi ===
                                      Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 43028
                                      Signal strength -56dBm, channel 6, mode 802.11n, reconnections 0
                                      M122 B121
                                      Tasks: Move(3,nWait 7,0.3%,87) HEAT(2,nWait 6,0.4%,95) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                                      Owned mutexes:
                                      Last reset 00:16:11 ago, cause: power up
                                      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 5275, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 339601
                                      Moves scheduled 2821, completed 2821, in progress 0, hiccups 111, segs 36, step errors 0, maxLate 0 maxPrep 886, maxOverdue 97, maxInc 38, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                                      Peak sync jitter 0/9, peak Rx sync delay 225, resyncs 0/0, no timer interrupt scheduled
                                      MCU temperature: min 39.2C, current 55.8C, max 55.9C
                                      Last sensors broadcast 0x00000012 found 2 148 ticks ago, 0 ordering errs, loop time 0
                                      CAN messages queued 5639, send timeouts 0, received 5877, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 363, adv 35929/74647
                                      Interrupt 5726621 to 0us, poll 9 to 1728us
                                      Driver 0: ok
                                      • Exerqtorundefined
                                        Exerqtor @Exerqtor
                                        Had to make two posts due to character limit.
                                        And the new board behaves exactly the same.
                                        Extruding:
                                        M122
                                        Used output buffers: 17 of 40 (32 max)
                                        Static ram: 103264
                                        Dynamic ram: 128512 of which 0 recycled
                                        Never used RAM 5648, free system stack 135 words
                                        Tasks: NETWORK(2,nWait 7,16.0%,228) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,80.8%,595) IDLE(0,ready,1.3%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                        Last reset 00:11:44 ago, cause: software
                                        Last software reset at 2024-02-28 17:11, reason: User, Gcodes spinning, available RAM 11836, slot 0
                                        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                        Error status: 0x00
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 704369, completed 704369, timed out 0, errs 0
                                        MCU temperature: min 34.0, current 43.4, max 43.4
                                        Supply voltage: min 2.8, current 23.9, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1924/1464, gc cycles 175
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 36995, writes 46, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 47, reads 36994, writes 47, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 37018, writes 23, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 37017, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 37017, writes 24, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2024-02-28 17:23:20
                                        Cache data hit count 1145422321
                                        Slowest loop: 225.76ms; fastest: 0.09ms
                                        === Storage ===
                                        SD card longest read time 7.8ms, write time 46.0ms, max retries 0
                                        DMs created 83, segments created 14, maxWait 534741ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                        next step interrupt due in 65 ticks, enabled
                                        Moves shaped first try 48, on retry 0, too short 2, wrong shape 155, maybepossible 1
                                        === DDARing 0 ===
                                        Scheduled moves 307, completed 301, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                                        === DDARing 1 ===
                                        File is doing "G1 X107.735 Y134.32 E.04472" in state(s) 0
                                        check 0 clear 0
                                        === CAN ===
                                        Messages queued 6647, received 14643, lost 0, errs 1247, boc 0
                                        Longest wait 2ms for reply type 6031, peak Tx sync delay 47841, free buffers 26 (min 25), ts 3521/3519/0
                                        === Network ===
                                        Slowest loop: 199.19ms; fastest: 0.00ms
                                        === WiFi ===
                                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39764
                                        M122 B121
                                        Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
                                        Never used RAM 3688, free system stack 85 words
                                        Tasks: Move(3,nWait 7,0.0%,95) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:11:46 ago, cause: power up
                                        Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 25412, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 43148
                                        Moves scheduled 171, completed 167, in progress 1, hiccups 7, segs 12, step errors 0, maxLate 0 maxPrep 268, maxOverdue 38, maxInc 38, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.99
                                        Peak sync jitter -3/9, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
                                        VIN voltage: min 23.7, current 24.5, max 25.3
                                        MCU temperature: min 40.5C, current 55.5C, max 55.5C
                                        Last sensors broadcast 0x00000012 found 2 185 ticks ago, 0 ordering errs, loop time 1
                                        CAN messages queued 14716, send timeouts 0, received 6697, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 322, adv 35722/74642
                                        Interrupt 5726621 to 0us, poll 2 to 1472us
                                        Driver 0: ok
                                        Not extruding:
                                        M122
                                        Used output buffers: 22 of 40 (40 max)
                                        Static ram: 103264
                                        Never used RAM 5072, free system stack 135 words
                                        Tasks: NETWORK(2,nWait 7,17.4%,218) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.4%,238) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,76.9%,595) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
                                        Last reset 00:17:04 ago, cause: software
                                        Error status: 0x04
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 1025081, completed 1025080, timed out 0, errs 0
                                        MCU temperature: min 43.2, current 46.2, max 46.6
                                        Supply voltage: min 23.5, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/580/120, gc cycles 245
                                        Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 47, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 16869, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 16870, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2024-02-28 17:28:41
                                        Cache data hit count 1601436176
                                        Slowest loop: 35.52ms; fastest: 0.10ms
                                        === Storage ===
                                        SD card longest read time 9.7ms, write time 10.6ms, max retries 0
                                        DMs created 83, segments created 38, maxWait 2147ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                        next step interrupt due in 34 ticks, enabled
                                        Moves shaped first try 439, on retry 114, too short 173, wrong shape 3194, maybepossible 90
                                        === DDARing 0 ===
                                        Scheduled moves 5246, completed 5224, hiccups 0, stepErrors 0, LaErrors 4, Underruns [0, 0, 0], CDDA state 3
                                        === DDARing 1 ===
                                        check 0 clear 0
                                        === CAN ===
                                        Messages queued 7296, received 6608, lost 0, errs 0, boc 0
                                        Longest wait 6ms for reply type 6024, peak Tx sync delay 264, free buffers 26 (min 25), ts 1604/1604/0
                                        === Network ===
                                        Slowest loop: 19.51ms; fastest: 0.06ms
                                        === WiFi ===
                                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43020
                                        M122 B121
                                        Tasks: Move(3,nWait 7,0.3%,87) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,90.5%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                                        Owned mutexes:
                                        Last reset 00:17:06 ago, cause: power up
                                        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 28621, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 359702
                                        Moves scheduled 2891, completed 2891, in progress 0, hiccups 154, segs 36, step errors 0, maxLate 0 maxPrep 871, maxOverdue 136, maxInc 81, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                                        Peak sync jitter -2/10, peak Rx sync delay 214, resyncs 0/0, no timer interrupt scheduled
                                        VIN voltage: min 24.3, current 24.4, max 25.0
                                        MCU temperature: min 40.5C, current 60.0C, max 60.0C
                                        Last sensors broadcast 0x00000012 found 2 104 ticks ago, 0 ordering errs, loop time 0
                                        CAN messages queued 6604, send timeouts 0, received 7291, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 353, adv 35628/107888
                                        Interrupt 5726621 to 0us, poll 9 to 1545us
                                        Driver 0: ok
                                          droftarts administrators @Exerqtor
                                          @Exerqtor I'm going to set up a printer tomorrow with a Mini 5+ and 1LC, to see if we can replicate this issue. Can you post your current config.g and any other relevant files (I can't immediately find them in the thread, sorry if you have already posted them), and tell me a little about your printer? I think you have a Voron Trident or something similar, with a Stealthburner? It would also be good to know what extruder and hot end, nozzle size, filament type and size, etc. I'm a bit limited in hardware, but I'll try and replicate your setup at least functionally. Is the gcode file you linked in the first post of this thread still the one all the tests have been carried out on?
                                          • Exerqtorundefined
                                            Exerqtor @droftarts
                                            @droftarts
                                            I'll take a complete SD-card dump and upload later today including the job file. I think I forgot to do it earlier dispite saying I was going to do so a while back🤦‍♂️
                                            Specs:
                                            • Voron Trident
                                            • Meanwell 24v & 5v PSU (original, not clones lol)
                                            • Keenovo 230v bed heathwr, through a Omron SSR.
                                            • Stealthburner toolhead with optoTAP
                                            • Stealthburner leds connected to the mainboard (if you want / have the parts to test that)
                                            • Highflow(60w) Revo micro (with a 0.4mm HF nozzle atm)
                                            • LGX-lite and a 0.4mm highflow nozzle
                                            • Hall-element filament runout sensor
                                            • Regarding filament I've tried and comfirmed it bugging out with both 1,75MM Flashforge, Esun and Fiberlogy ABS/ABS-plus & ASA.
