    Wifi Error during print
    wifi duet error
    • danny_v1undefined
      danny_v1
      I have some questions, after a long time I did not use my printer I update my duet2wifi yesterday to the newest firmeware.
      Then I send the print file to the printer and every thing works well. After a while the printer stops with an error that wifi is unavailable.
      I use this printer in a room where I have no Wifi, so I make a hotspot with my smartphone, upload the printfile and the I want to turn off the hotspot, so how can I avoid the Wifi error?
      And the second question, when I use Bambu Studio, I get always messages that there was a bad command, can I use Bambu studio with RRF?
      droftartsundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @danny_v1
        @danny_v1 Losing WiFi shouldn't cause the printer to stop during a print. If possible, capture the actual error message reported - do you have a screen like a PanelDue connected? If you go to the Console it should show a list of messages.
        When you next connect via WiFi, please send M122 via the console and post the response, so we can see the firmware version. Also check what version of DWC you are using by going to Settings > General.
        Bambu Studio is a modified version of Prusaslicer specifically for BambuLabs printers. Most likely it is putting in Gcodes that are specifically for their printers; I don't know if these can be omitted. Orcaslicer is the open source version of Bambu Studio and is more geared towards other printers, so you may get better results from that.
        • oliofundefined
          oliof
          For the wifi issue, you could set up the Duet board to use AP mode so you connect to the boards own wifi.
            @danny_v1 Further to @oliof's suggestion, see https://docs.duet3d.com/en/User_manual/Machine_configuration/Networking#configuring-duet-in-wifi-access-point-mode
