    [3.5.0-rc.3] Conditional 'abort' command called unexpectedly
    Beta Firmware
    652
    • gloomyandyundefined
      gloomyandy @lycean
      @lycean It's not a simulation, it is running through all of the gcodes, it is just that only some of them are being executed by each stream. See: https://docs.duet3d.com/User_manual/RepRapFirmware/Multiple_motion_systems
      lyceanundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @gloomyandy
        @gloomyandy said in [3.5.0-rc.3] Conditional 'abort' command called unexpectedly:
        @OwenD Could be SBC or could be related to the multiple gcode stream feature, so you may not see it on a Duet2.
        Very true.
        If it's multiple stream issue the perhaps a G4 P100 before the if and abort commands would be a work around?
        • lyceanundefined
          lycean @gloomyandy
          @gloomyandy The reason I said 'simulation' was this quote by @dc42 (from https://forum.duet3d.com/post/104962)
          One of the applications for multiple GCode streams is to have the second stream reading the print file ahead of the main one and simulating it, so that it can predict a tool change or colour mix change in advance, and prepare the new tool or change the colour mix ahead of time.
          Using the multiple motion streams that you pointed out requires the use of the M596 command which I'm not using, so my assumption was that it might be the simulation idea mentioned in that post.
          gloomyandyundefined 1 Reply Last reply Reply Quote 0
            gloomyandy @lycean
            @lycean My understanding is that there are two motion systems and in the case of a print from a file there are also two gcode streams in operation (file1 and file2). These are two separate but related concepts, file1 executes movement commands via movement stream 0 while file2 executes them via movement stream 1. However some G and M commands are executed by both gcode processors (note that they are executed not simulated in that they change the actual machine state), to see which commands are executed by both file1 and file2 see the link I provided above. My understanding is that macros are executed by both file1 and file2 streams. The key question is are meta commands executed by both file streams or not. I think that they are, but perhaps @dc42 could clarify that (@droftarts I think it would be good to clarify what happens with meta commands in the documentation).
            So what I think may be happening here is that your macro is being executed by file2, however it will not process the G31 commands (as no M596 command has been used to switch "general gcode processing to movement stream 1) but it will execute the meta commands in particular the if statement and the subsequent abort statement. But it will be using whatever values are already set for the threshold and offset not the ones being set in the macro (because those commands will not have been executed by file2). I think this may also explain why you need to execute a movement command and execute a delay to see the problem. I think these will delay the execution of file1 (and hence the actual execution of the G31 commands) and will be allowing file2 to "be ahead" of file1, but after file1 has executed the G31 command to set the threshold to 2000.
            Note that I've not tried your example and the above is just based on my understanding of the code. There are some things I don't understand, so for instance are echo commands executed by both file1 and file2? If they are why do we not see two sets of echo output?
            • lyceanundefined
              lycean @gloomyandy
              @gloomyandy Interesting, thanks for the information!
              It certainly looks like something is evaluating the gcode ahead of the motion processing, and when the G31 is hit that evaluation follows the true path for the if statement (because that's correct given the state of the system at that instant) and then hits the abort. However, if that's the case, it shouldn't do anything - just like the echo doesn't do anything.
              Hopefully someone with some more knowledge can take a peek, I just don't have the time or motivation to go pull the code and figure out how all this works.
              SumoSniperundefined 1 Reply Last reply Reply Quote 0
              • SumoSniperundefined
                SumoSniper @lycean
                @lycean I've come up with a simple set of gcode in my thread here that I believe replicates this MMS forward evaluation issue. Seems like we are running into similar issues.
                Mutiple Motion Systems & Macro Conflicts in 3.5
                dc42undefined lyceanundefined 2 Replies Last reply Reply Quote 1
                • SumoSniperundefined SumoSniper referenced this topic
                  dc42 administrators @SumoSniper
                  @lycean as @SumoSniper says, this is caused y the behaviour of multiple motion streams. See the thread he referenced.
                  The latest firmware binaries at https://www.dropbox.com/scl/fo/p0136wx04h8xf6ejwdnn9/h?rlkey=efrfwyb6o5tqid11gustz3uvy&dl=0 do not execute abort commands from an inactive motion stream.
                  lyceanundefined 1 Reply Last reply Reply Quote 1
                  • lyceanundefined
                    lycean @SumoSniper
                    @SumoSniper Thanks for pointing out your thread!
                    • lyceanundefined
                      lycean @dc42
                      @dc42 Thanks, that's great, and I also see your suggestion in @SumoSniper's thread to get the inactive reader to skip processing problematic macros with
                      if state.thisInput != null & !state.thisInput.active
                        M99
                        dc42 administrators @lycean
                        @lycean if you use the lates firmware at https://www.dropbox.com/scl/fo/3y4agkmfzfmqcifuecqo3/h?rlkey=j0kibs1tubm5dfj7o2vz1vbzj&dl=0 then you won't need to change your macros.
