    Stuck at Connecting...
    Beta Firmware
    392
    • p8blrundefined
      p8blr
      I've been banging my head against the wall all day, installed new images from scratch and no matter what I do, I get stuck at connecting.
      My printer use to work fine, tried switching to a raspberry pi 5, didn't work, wanting to roll back to a 4 and now I can't get past this.
      Setup:
      6XD
      (5) 3HC
      (2) 1XD
      Raspberry pi 4 in sbc mode
      running 3.5.0 RC3
      Worked great up until I tried to switch. Now I'm back with a freshly imaged sd card, ran updates, etc. The crazy thing is that it works fine for a while until I reboot, and then it's stuck. Note that I get this issue directly on the pi with a monitor/keyboard/mouse attached, and over the network.
      Please help
        jay_s_uk @p8blr
        @p8blr can you look at the LEDs on the 6XD and maybe post a photo of them?
        specifically you are looking at the status LED
        p8blrundefined 1 Reply Last reply Reply Quote 0
        • p8blrundefined
          p8blr @jay_s_uk
          @jay_s_uk
            jay_s_uk @p8blr
            @p8blr is it flashing or is it steady?
            • p8blrundefined
              p8blr @jay_s_uk
              @jay_s_uk flashing
                jay_s_uk @p8blr
                @p8blr what version was installed on the 6XD before?
                It may be best to go and BOSSA the latest image onto the 6XD directly https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
                • p8blrundefined
                  p8blr @jay_s_uk
                  @jay_s_uk It shouldn't have changed, it was working great on 3.5.0 RC3. During the ordeal, I did attempt switching to stable and doing a downgrade according the documentation, which worked and DWC was connecting, but then when switched back to unstable, it started getting stuck at connecting... again. I want to also mention, that I have the printer beep at the end of the config.g file, and I hear it, so that means the code is at least running. It makes me think the issue is more on the web-interface side. I will try BOSSA and get back to you soon.
                  jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                    jay_s_uk @p8blr
                    @p8blr if it doesn't work then we'll need the logs from the SBC side.
                    • log into your Single Board Computer
                    • run sudo journalctl -xe -u duetcontrolserver
                    • p8blrundefined
                      p8blr @jay_s_uk
                      @jay_s_uk No dice. Even tried updating the web control files according to the documentation.
                      logs.txt
                        As a troubleshooting step I would try a fresh SD card, fresh download of Duet Pi stable, and use bossa to flash 3.4.6 to the Duet, and see if it will connect with a stock config setup. And then go from there. Add in your configs. If it still works, upgrade to unstable channel.
                        • p8blrundefined
                          p8blr @Phaedrux
                          @Phaedrux @jay_s_uk
                          It seems to be correlated with my config.g file. Adding that back in sometimes, but not all the time, prevents it from connecting...
                          See anything that might cause the instability?
                          config.g
                          DriveSetup.g
                          startup.g
                            What do you have in daemon.g?
                            • p8blrundefined
                              p8blr @Phaedrux
                              @Phaedrux daemon.g
                              heaterFaultBed.g
                              heaterFaultChamber.g
                              Also, I'm stuck at connecting... again.
                              I modified config.g so that my bed and chamber heaters were no longer combined and I think that solved the entire issue. I was experiencing it in this thread but never got it resolved.
                              https://forum.duet3d.com/topic/34758/tips-for-autotuning-a-very-large-heated-chamber?_=1710270256740
                              Johnnygundefined 1 Reply Last reply Reply Quote 0
                              • Johnnygundefined
                                Johnnyg @p8blr
                                This post is deleted!
                                    Phaedrux Moderator @Johnnyg
                                    @Johnnyg Please start a new thread.
