    Stuck at Connecting...
    Beta Firmware
    474
      jay_s_uk @p8blr
      @p8blr is it flashing or is it steady?
      p8blrundefined 1 Reply Last reply Reply Quote 0
      • p8blrundefined
        p8blr @jay_s_uk
        @jay_s_uk flashing
          jay_s_uk @p8blr
          @p8blr what version was installed on the 6XD before?
          It may be best to go and BOSSA the latest image onto the 6XD directly https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#all-other-duet-boards
          • p8blrundefined
            p8blr @jay_s_uk
            @jay_s_uk It shouldn't have changed, it was working great on 3.5.0 RC3. During the ordeal, I did attempt switching to stable and doing a downgrade according the documentation, which worked and DWC was connecting, but then when switched back to unstable, it started getting stuck at connecting... again. I want to also mention, that I have the printer beep at the end of the config.g file, and I hear it, so that means the code is at least running. It makes me think the issue is more on the web-interface side. I will try BOSSA and get back to you soon.
            jay_s_ukundefined 1 Reply Last reply Reply Quote 1
              jay_s_uk @p8blr
              @p8blr if it doesn't work then we'll need the logs from the SBC side.
              • log into your Single Board Computer
              • run sudo journalctl -xe -u duetcontrolserver
              • p8blrundefined
                p8blr @jay_s_uk
                @jay_s_uk No dice. Even tried updating the web control files according to the documentation.
                logs.txt
                  As a troubleshooting step I would try a fresh SD card, fresh download of Duet Pi stable, and use bossa to flash 3.4.6 to the Duet, and see if it will connect with a stock config setup. And then go from there. Add in your configs. If it still works, upgrade to unstable channel.
                  • p8blrundefined
                    p8blr @Phaedrux
                    @Phaedrux @jay_s_uk
                    It seems to be correlated with my config.g file. Adding that back in sometimes, but not all the time, prevents it from connecting...
                    See anything that might cause the instability?
                    config.g
                    DriveSetup.g
                    startup.g
                      What do you have in daemon.g?
                      • p8blrundefined
                        p8blr @Phaedrux
                        @Phaedrux daemon.g
                        heaterFaultBed.g
                        heaterFaultChamber.g
                        Also, I'm stuck at connecting... again.
                        I modified config.g so that my bed and chamber heaters were no longer combined and I think that solved the entire issue. I was experiencing it in this thread but never got it resolved.
                        https://forum.duet3d.com/topic/34758/tips-for-autotuning-a-very-large-heated-chamber?_=1710270256740
                        Johnnygundefined 1 Reply Last reply Reply Quote 0
                        • Johnnygundefined
                          Johnnyg @p8blr
                          This post is deleted!
                              Phaedrux Moderator @Johnnyg
                              @Johnnyg Please start a new thread.
