Converting DateTime to string
Gcode meta commands
395
    jonathanbrent
    Hi Everyone,
    I can't seem to find a way to convert a DateTime variable to a string. I am trying to create a file at the start of my gcode that will include the current date and time (using state.time) in its title; however, it seems that the name of a file must be of type string.
    Any thoughts? Thanks!
    Current Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.6
    undefined undefined 2 Replies Last reply 12 Mar 2024, 18:32 Reply Quote 0
      dc42 administrators @jonathanbrent
      @jonathanbrent use the ^ operator to concatenate it with a string literal, even an empty string literal will do.
      undefined 1 Reply Last reply 12 Mar 2024, 18:57 Reply Quote 0
        jonathanbrent @dc42
        @dc42 Thanks! Now it turns out my issue is really that I can't include the ":" character in a file name. Is there a way for me to modify the string that I have retrieved from state.time (e.g. 2024-03-12T12:54:43)? Or is there some other way to get the current time without colons?
        Thanks again
        undefined undefined 2 Replies Last reply 15 Mar 2024, 09:42 Reply Quote 0
          @jonathanbrent I'm sorry, I can't think of a workaround at present.
            T3P3Tony administrators @jonathanbrent
            @jonathanbrent can you convert it to an int instead of a string. They the files will be sequential, with the right number of seconds between names. Just not easily human readable without converting the int back to a datetime.
            Being able to use datetime in a filename is a feature I would like as well. There is a feature request tracking something similar here:
            https://github.com/Duet3D/RepRapFirmware/issues/787
            T3P3 created this issue 24 Apr 2023, 19:55 in Duet3D/RepRapFirmware
            closed allow date and time to be retrieved as individual strings/ints #787
              oliof
              maybe a generic split function for strings would suffice?
              undefined 1 Reply Last reply 19 Mar 2024, 09:39 Reply Quote 0
                T3P3Tony administrators @oliof
                @oliof string split to an array would be even more useful for sure.
                undefined 1 Reply Last reply 19 Mar 2024, 15:37 Reply Quote 0
                  dc42 administrators @T3P3Tony
                  @T3P3Tony or maybe a replace-in-string function e.g. replace(state.time, ':', '-')
                  undefined 1 Reply Last reply 19 Mar 2024, 15:44 Reply Quote 1
                    T3P3Tony administrators @dc42
                    @dc42 yes that would work as well for the particular usecase of naming a file with a datetime that's a valid filename. Its less generalisable than being able to use just the date or just the time - but that's not necessarily an urgent requirement.
                    It depends on the overhead to implement various types of string handling.
                      @jonathanbrent Since 3.6.0beta4 the functions "drop","find" and"take" have been implemented.
                      documentation is here:
                      https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#functions
                      I have updated this github issue with an example of how to use them for date/time splitting into a string.
                      https://github.com/Duet3D/RepRapFirmware/issues/787#issuecomment-2658795794
                      • undefined T3P3Tony referenced this topic 14 Feb 2025, 10:02
