    serialOM.py : easy ObjectModel access for Python and microPython
    Third-party software
    • EasyTargetundefined
      EasyTarget
      Hi all; this is something I have been working on to power my PrintEYE replacement but it took on a life of it's own and I'd like to get it out of my system.. so here goes.
      serialOM.py is a self-contained python class that connects to the OM on a RRF device via USB or UART, and provides a local copy of the OM that can be periodically updated.
      https://github.com/easytarget/serialOM
      The readme there does a proper TL;DR but the highlights are:
      • Python3/microPython cross-compatible with both PySerial and the mpy UART support
      • Keys to be fetched can be specified on a per-mode basis and the 'seqs' key is used to only do verbose fetches when needed.
      • Controller reboots and mode changes are handled appropriately. soft failures (timeouts) are tolerated and detectable. Hard (comms port) errors trigger a custom exception.
      • more.. see readme.
      Basic use can be as simple as:
      from serialOM import serialOM
      from serial import Serial
      rrf = Serial('/dev/ttyACM0',57600)
      OM  = serialOM(rrf, {'FFF':[],'CNC':[],'Laser':[]}, quiet=True)
      print('state: ' + OM.model['state']['status']
           + ', up: ' + str(OM.model['state']['upTime']) + 's')
      There is an associated printPy program that implements a robust logging / console info loop. It reconnects as USB ports change etc. and logs human-readable print/CNC/Laser status, value and progress data to the console and an optional file.
      I consider the CPython side of this 'done' (unless bugs.. quite likely because I'm no Pythonista), it runs well from a Pi3 with a USB connection to my Duet2 WiFi.
      There is a work in progress microPython version of this loop; printMPy which can do the same console output, but also has RGB 'mood/activity' light control and button/status controls being implemented.
      Both of the print*Py loops use a separate output class. currently the same 'TXT' demo works on both. This is a template for my in-progress I2C output class can be run in a thread to allow screen animations independent of the serial comms.
      Disaster? The original Printeye is dying with RRF 3.5 (M208 depreciated).
      PrintPy2024 to the rescue!
      MicroPython based; with simple wiring and and no custom PCB.
      T3P3Tonyundefined berniejundefined 2 Replies Last reply Reply Quote 5
        T3P3Tony administrators @EasyTarget
        @EasyTarget thanks for posting this here and sharing the code with the community!
        • berniejundefined
          berniej @EasyTarget
          @EasyTarget This is really useful tool! Thank you!
          EasyTargetundefined 1 Reply Last reply Reply Quote 1
            EasyTarget @berniej
            @berniej Thankyou! I'm glad if this is useful for others.
            Please note that I have just done some tweaks to the response reading and sequence processing that address a couple of concerns I had, it should be less liable to briefly de-syncing when console (or json) status messages arrive.
            There is a new release, v1.1.0 in the repo, the changes are all internal, usage has not changed.
            Finally; I got to do some gc.mem_free() data gathering at various points in the loop under micropython; I max out at about 24K total additional RAM consumed by the serialOM loop; even when I have cycled the controller through three modes and run a simulation in each to fully populate the local OM with typical data.
            I'm pretty happy with this, better than I expected.
            • oliofundefined oliof referenced this topic
              EasyTarget
              A quick note that I just published a small update as release: v1.2.0
              This removes the need to have a the separate compatLib.py library present; all the cross-python handling is now done in serialOM.py itself. Nothing else is changed.
