    Laser filament monitor
    Filament Monitor
    73
    179
    41.6k
      deckingman
      IMO, even with a perfectly calibrated extruder there may still be a need to alter the extrusion multiplier to compensate for say models which have a lot of short slow moves vs models which have predominantly long fast moves. Another factor which is related to that is temperature and by that I mean the temperature throughout the filament from outside edge to the core. The filament itself is a very poor thermal conductor so when printing at high(ish) speed, there is less time in the melt chamber so the inner core may be significantly cooler than the outer surface. So even measuring die swell at one fixed speed/temperature combination might not be a practical solution.
      • veng1undefined
        veng1
        The schematic for Prusa's laser sensor has been published in his github. The part number on the print is PAT9125SEL
        https://github.com/prusa3d/PRUSA_Laser_filament_sensor/blob/master/rev.02/laser-sensor.pdf
        Slightly off topic but he has also published the power panic circuit. From the picture, I think it may need a slot routed in the pcb between L and N to meet UL creep distance.
          Thanks, that confirms that the sensor we chose is the same one.
          • elmoretundefined
            elmoret
            @veng1:
            Can confirm slot! Just received MK3.
            • S1lencerundefined
              S1lencer
              Happy to hear that the laser sensor is on the way ;).
              Would be happy to test it.
              Had problems lately with filamentgrinding.
              That would be a thing of the past then.
              • McAdamundefined
                McAdam
                For a while I've been toying with the idea of a filament thickness detector.
                I often do 20 hour prints on 2.5kg spools, so the thickness of filament can vary a bit within a single print.
                Supplier states 1.75mm +/- 0.05mm but I have found it to be closer to 0.08mm
                The idea I've had so far is to use a digital tire gauge caliper, it's inexpensive, fairly accurate, and has a built-in serial output.
                http://www.ebay.co.uk/itm/NEW-Digital-Tyre-Tire-Tread-Brakes-Shoe-Pad-Wear-Depth-Gauge-Caliper-0-25mm-/321762696307
                Reading the output with a small microcontroller (ESP8266) I can then adjust the flowrate.
                For actual filament movement; A 16 bit resolution rotary encoder with a extruder gear on it.
                I know these solutions are more mechanical than the current suggestions, but maybe they can inspire some new thoughts.
                • fmaundefined
                  fma
                  Does the section of your filament vary that much?
                  You need to measure the diameter in both directions, as the filament can be oval, and the section remaining the same…
                  Frédéric
                  • McAdamundefined
                    McAdam
                    @fma:
                    Over a whole 2.5kg spool, it can vary quite a lot.
                    Yes, checking for OVALness will be very difficult, I have not thought of a solution to it yet 😞
                    • DjDemonDundefined
                      DjDemonD
                      There are some very expensive laser-based diameter and roundness testing devices but they're $1500… Its whether there is a way to do it for a lot less, rotating the laser filament monitor that Duet3D are playing with around the filament?
                      www.precisionpiezo.co.uk
                      • DeltaConundefined
                        DeltaCon
                        @McAdam:
                        …The idea I've had so far is to use a digital tire gauge caliper, it's inexpensive, fairly accurate, and has a built-in serial output.
                        Nice idea, but would you press the gauge against the filament using a spring or something? I guess when a whole spool of filament passed this plastic toy, there would be a huge abraded hole in it. 😉
                        If you think trial and error is dangerous, try routine. That's even more so!
                          I've just had notification that the prototype PCBs for the laser filament sensor are on their way to me from HK! I only ordered them last Sunday.
                          • Dougal1957undefined
                            Dougal1957
                            That's good news David
                            • S1lencerundefined
                              S1lencer
                              Nice to hear.
                              • McAdamundefined
                                McAdam
                                @DeltaCon:
                                @McAdam:
                                Idea was to have a small pulley attached to the end of the guage, (similar to pulleys found in extruders) so there will be no friction.
                                • McAdamundefined
                                  McAdam
                                  @dc42:
                                  Great news!
                                  Is there still space on the Beta List?
                                  • totalitarianundefined
                                    totalitarian
                                    Sorry to jump in but what is the advantage of this compared to a simple micro switch?
                                    • adavidmundefined
                                      adavidm
                                      @totalitarian:
                                      These monitors track the amount of filament passing through the system. You can use that to tell if the extruder drive is slipping, not just if there is filament present.
                                      David has raised the possibility of auto-calibration of e-steps using the system, which would be very neat if it works.
                                        totalitarian
                                        Ah I see, very clever!
                                        • Qdeathstarundefined
                                          Qdeathstar
                                          When will either sensor be available. I'm definitely adding a filament sensor to the printer I am building now and rather buy from the makers of the duet than some no-name AliExpress company.
                                            I'm sorry, we can't give a date yet. I expect to have a few prototype laser filament sensors by the end of this week, which should put us on track to decide which version to manufacture at the end of this month.
