    Odd G4 Behaviour from Macro called from SD File
    Gcode meta commands
    318
    • NineMileundefined
      NineMile @NineMile
      @gloomyandy I've tried to simplify this as much as possible (using M3.8 so is not touching the complex M3.9 command from above)
      M3.8.g:
      if { !inputs[state.thisInput].active }
          M99
      var dwellTime = 10
      M3 P0 S{param.S}
      echo { "[L=" ^ line ^ " T=" ^ state.time ^ "] Waiting " ^ var.dwellTime ^ " seconds for spindle to change speed - #" ^ param.I }
      G4 S{var.dwellTime}
      echo { "[L=" ^ line ^ " T=" ^ state.time ^ "] Finished waiting for spindle to change speed - #" ^ param.I }
      test.gcode:
      (Home)
      G28
      (Movement Configuration)
      G90
      G21
      (Park ppindle)
      G0 Z0
      (Move to center of table)
      G0 X150 Y150
      (Start spindle)
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] Running M3.8 #1"  }
      M3.8 S24000 I1
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] M3.8 Complete #1" }
      (Do some moves)
      G0 X100 Y100
      G0 X0 Y200
      G0 X200 Y0
      G0 X100 Y100
      G0 X40 Y80
      (Change spindle speed)
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] Running M3.8 #2" }
      M3.8 S12000 I2
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] M3.8 Complete #2" }
      (Do some more moves)
      G0 X50 Y100
      G0 X0 Y200
      G0 X200 Y0
      G0 X100 Y100
      G0 X80 Y40
      G0 X150 Y150
      (Stop spindle)
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] Running M3.8 #3" }
      M3.8 S0 I3
      echo {"[L=" ^ line ^ " T=" ^ state.time ^ "] M3.8 Complete #3" }
      G0 X0 Y0
      echo { "[L=" ^ line ^ " T=" ^ state.time ^ "] File complete" }
      When running the test.gcode file, I would (naively I guess) expect there to be a 10 second pause after the machine moves to the centre of the table, and then another 10 second pause after 5 moves. I'd then expect the final 10 second wait to stop the spindle and then a move to X150 Y150.
      What actually happens is M3.8 is triggered as soon as the machine starts moving from the home location to X150 Y150, and then the machine continues moving from the centre point straight away, logging that it is waiting but actually proceeding with the moves. It then runs the next M3.8 command and completes that command before the G4 from the previous call to M3.8 has finished.
      After that point I'm not entirely sure what happens, but there is a 17 second delay after the File Complete message before the job actually completes, which makes me think there are multiple G4s in the queue still being processed sequentially.
      Full log of the file running in the screenshot below:
      I haven't managed to get any particularly useful info from interspersing M122 into the print (I'm not even sure how to do this properly given that they're queued differently, aside from File processing the movement commands (and the M3.8 macro) and the G4 commands ending up in Queue:
      HTTP is idle in state(s) 0
      File is doing "G0 X40 Y80" in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is doing "G4 S{var.dwellTime}" in state(s) 0 0, running macro
      LCD is idle in state(s) 0
      Daemon is doing "G4 P{global.mosDAEUR}" in state(s) 0 0, running macro
      File2 is idle in state(s) 0, sync state 2
      Queue2 is idle in state(s) 0
      Q0 segments left 1, axes/extruders owned 0x0000007
      Code queue 0 is empty
      Code queue 1 is empty
      gloomyandyundefined 1 Reply Last reply Reply Quote 0
      • gloomyandyundefined
        gloomyandy @NineMile
        @NineMile What happens without the M3 commands in your files? I have no way of running those commands, so really need an example without them.
          gloomyandy @gloomyandy
          @gloomyandy Just to be clear I mean the actual M3 spindle control commands not the M3.8 ones.
          NineMileundefined 1 Reply Last reply Reply Quote 0
          • NineMileundefined
            NineMile @gloomyandy
            @gloomyandy said in Odd G4 Behaviour from Macro called from SD File:
            With the M3 P0 S{param.S} line removed I see the following, and no pause in movement after 5 moves - so it looks like the behaviour is the same even without the M3.
              @NineMile If you substitute M98 calls to your M3.8 macro does the test do what you expect? I've just tried that on my test system and it seems to work as you might expect it to work. So I basically replaced
              M3.8 S24000 I1
              with
              M98 p"M3.8.g" S24000 I1
              and made similar changes to other parts of the test (noting the change to the parameters).
              So this is the test file I have been using (I had to make some changes because I can't run in CNC mode):
              ;(Home)
              ;G28
              ;(Movement Configuration)
              G90
              G21
              ;(Park ppindle)
              G0 Z10
              ;(Move to center of table)
              G0 X150 Y150
              ;(Start spindle)
              ;M3.8 S24000 I1
              ;(Do some moves)
              G0 X100 Y100
              G0 X0 Y200
              G0 X200 Y0
              G0 X100 Y100
              G0 X40 Y80
              ;(Change spindle speed)
              ;M3.8 S12000 I2
              M98 p"M3.8.g" S12000 I2
              ;(Do some more moves)
              G0 X50 Y100
              G0 X0 Y200
              G0 X200 Y0
              G0 X100 Y100
              G0 X80 Y40
              G0 X150 Y150
              ;(Stop spindle)
              ;M3.8 S0 I3
              M98 p"M3.8.g" S0 I3
              G0 X0 Y0
              Without the above change, I think I'm basically seeing what you are seeing with the dwell commands not running until the end of the file (at least that is what it looks like, it is a little confusing).
              NineMileundefined 1 Reply Last reply Reply Quote 1
              • NineMileundefined
                M3.8 S24000 I1
                with
                ;(Home)
                ;G28
                G90
                G21
                ;(Park ppindle)
                G0 Z10
                G0 X150 Y150
                ;(Start spindle)
                ;M3.8 S24000 I1
                ;(Do some moves)
                G0 X100 Y100
                G0 X0 Y200
                G0 X200 Y0
                G0 X100 Y100
                G0 X40 Y80
                ;M3.8 S12000 I2
                G0 X50 Y100
                G0 X0 Y200
                G0 X200 Y0
                G0 X100 Y100
                G0 X80 Y40
                G0 X150 Y150
                ;(Stop spindle)
                ;M3.8 S0 I3
                M98 p"M3.8.g" S0 I3
                G0 X0 Y0
                Yep using M98 P"M3.8.g"... works as I would expect - so there's a difference in the way M98 runs macros vs how macros are run when they're called directly by their M-Code?
                What's the chances that these can be made to work in the same manner?
                I tried using an intermediate macro (So the gcode runs M3.7 and M3.7 runs M98 P"M3.8.g" ... but that exhibited the previous ("broken") behaviour.
                  @NineMile I think at this point we probably need to @dc42 to have a look at this issue. I'm not sure how using a macros to replace a gcode is supposed to work and if there are any limitations on what you can do in those macros.
                  • NineMileundefined NineMile referenced this topic
                    dc42 administrators @NineMile
                    @NineMile said in Odd G4 Behaviour from Macro called from SD File:
                    Notes: RRF 3.5.0-rc3 stm32, not the version that fixes the multiple movement systems issues but I have code at the top of all of my macros to stop them executing in the secondary movement system.
                    If this issue occurs only when the macro is called from a job file then please try a more recent firmware build.
                    gloomyandyundefined 2 Replies Last reply Reply Quote 0
                      gloomyandy @dc42
                      @dc42 I've tried the same code with yesterday's build and it did the same thing for me.See this post for details: https://forum.duet3d.com/post/336370
                        gloomyandy @dc42
                        @dc42 Just to clear with the build as of 27th Mar, the version of the file using M3.8 directly does not seem to delay when you might expect it to. The version using M98 to run the same macro file does delay as expected.
                        I've just tried the same test files on a Duet3 running 3.5.0-rc.3+8 and see the same "odd" behaviour with the macro being "called" as a substitute for a gcode then the dwell does not happen when expected (they seem to happen at the end of the print), but with the same macro call using M98 then the dwell happens as expected.
                        These are the test files I used on the duet3, first the file I print (from my "jobs" directory):
                        G92 X0 Y0
                        M564 H0
                        ;(Home)
                        ;G28
                        G90
                        G21
                        ;(Park ppindle)
                        G0 X150
                        ;(Start spindle)
                        M3.8 S24000 I1
                        ;M98 p"M3.8.g" S24000 I1
                        ;(Do some moves)
                        G0 X100
                        G0 X0
                        G0 X200
                        G0 X100
                        G0 X40
                        M3.8 S12000 I2
                        ;M98 p"M3.8.g" S12000 I2
                        G0 X50
                        G0 X0
                        G0 X200
                        G0 X100
                        G0 X80
                        G0 X150
                        ;(Stop spindle)
                        M3.8 S0 I3
                        ;M98 p"M3.8.g" S0 I3
                        G0 X0
                        Then the M3.8 macro (that goes in system):
                        ;if { !inputs[state.thisInput].active }
                        ;    M99
                        var dwellTime = 10
                        G4 S{var.dwellTime}
                        Note my Duet3 is a bench test system that only has a single stepper motor attached (as X) and has no homing switches hence the changes to allow the print file to run. I don't think any of these changes make any difference to the problem described here.
