Pause/resume issues in 3.5.0rc3+5?
Beta Firmware
685
    Exerqtor
    EDIT 01.04.2024: Changed the title of the thread due to the problem seemingly being related to pause/resume and not filament runout.
    System info:
    Duet3 Mini Wifi & 1LC 1.2a in standalone with RRF 3.5.0rc3+5 on both boards, DWC 3.5.0.rc3 & WiFiServer 2.1b7
    I thought I should use up some near empty spools I had layiing around and test out the filament runout routine at the same time.
    I've got the printer configured with a HAL sensor right before the "intake" of my LGX-lite (direct drive). It's configured like this:
    ; Monitor before extruder (runout sensor)
    M591 P1 C"121.io0.in" S1 D0 ; Filament monitor connected to 121.io0.in
    And it's functionally working with some manual testing, RRF detects when filament is/isn't there.
    So now for the chain of event's that revealed the issue:
    • I started printing it was maybe a couple meters of filament left on the first spool, so I started the print and checked that the first layer got put down like it should and left the house for a while.
    • When I came back i suspected the printer to have paused due to filament runout, which it had.
    • PanelDue indicated that extruder 0 had run out of filament, and it seemed like pause.g had ben run (based on where the toolhead was parked).
    • I load & prime the hotend new filament, check for proper function by extruding 20mm @ 5mm/s from PanelDue and press Resume.
    • The toolhead moves back over the workpiece (where i suspect it had run out) and then just hovers over it, not dropping down to the correct Z height.
    • I check the tool temp, and that's all ok. Then start to wonder what the fuck's going on.
    • I press Pause, the printer goes into a paused state and the toolhead moves off accordingly.
    • I try to extrude again with PD, which works.
    • Press Resume again, and the toolhead moves back to the same spot as before, stays there for maybe 1(?)
      second before it moves of to another place and then start raising the bed all "willy-nilly" and ends up ramming the print into the toolhead before I slap the E-stop.
    Here is the eventlog:
    2024-03-31 12:53:08 [warn] Started printing file 0:/gcodes//nevermore/V6_Plenum[2020_extrusion]_0.2mm_ABS_0.4n_2h41m.gcode
    2024-03-31 12:53:10 [warn] M150 sent for logo : yellow
    2024-03-31 12:53:10 [warn] M150 sent for nozzle : yellow
    2024-03-31 12:53:29 [warn] M150 sent for logo : teal
    2024-03-31 12:53:29 [warn] M150 sent for nozzle : bright_white
    2024-03-31 12:53:45 [warn] M150 sent for logo : light_pink
    2024-03-31 12:53:45 [warn] M150 sent for nozzle : bright_white
    2024-03-31 12:53:54 [warn] Leadscrew adjustments made: 0.094 0.123 0.103, points used 3, (mean, deviation) before (0.108, 0.011) after (0.000, 0.000)
    2024-03-31 12:54:04 [warn] Leadscrew adjustments made: -0.015 -0.004 -0.001, points used 3, (mean, deviation) before (-0.006, 0.005) after (-0.000, 0.000)
    2024-03-31 12:54:14 [warn] Leadscrew adjustments made: 0.001 0.001 -0.000, points used 3, (mean, deviation) before (0.001, 0.001) after (0.000, 0.000)
    2024-03-31 12:54:14 [warn] M150 sent for logo : teal
    2024-03-31 12:54:14 [warn] M150 sent for nozzle : bright_white
    2024-03-31 12:54:20 [warn] M150 sent for logo : green
    2024-03-31 12:54:20 [warn] M150 sent for nozzle : bright_white
    2024-03-31 12:54:58 [warn] 25 points probed, min error -0.046, max error 0.015, mean -0.015, deviation 0.013
    Height map saved to file 0:/sys/heightmap.csv
    2024-03-31 12:55:00 [warn] M150 sent for logo : dim_gray
    2024-03-31 12:55:00 [warn] M150 sent for nozzle : dim_red
    2024-03-31 12:55:01 [warn] M150 sent for logo : yellow
    2024-03-31 12:55:01 [warn] M150 sent for nozzle : yellow
    2024-03-31 12:55:25 [warn] M150 sent for logo : light_blue
    2024-03-31 12:55:25 [warn] M150 sent for nozzle : bright_white
    2024-03-31 12:55:36 [warn] M150 sent for logo : red
    2024-03-31 12:55:36 [warn] M150 sent for nozzle : bright_white
    2024-03-31 14:09:53 [warn] Error: Filament error on extruder 0: noFilament
    2024-03-31 14:09:53 [warn] Resume state saved
    2024-03-31 14:46:48 [warn] Printing resumed
    2024-03-31 14:46:56 [warn] Resume state saved
    2024-03-31 14:47:01 [warn] Printing paused at X215.0 Y231.8 Z18.6
    2024-03-31 14:47:11 [warn] Printing resumed
    2024-03-31 14:47:22 [warn] Resume state saved
    2024-03-31 14:47:23 [warn] Error: Failed to switch off remote heater 1:
    2024-03-31 14:47:23 [warn] Cancelled printing file 0:/gcodes//nevermore/V6_Plenum[2020_extrusion]_0.2mm_ABS_0.4n_2h41m.gcode, print time was 1h 17m
    2024-03-31 14:47:23 [info] Event logging stopped
    power up + 00:00:03 [info] Event logging started at level warn
    power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-rc.3+5 (2024-03-27 11:34:04)
    power up + 00:00:04 [warn] WiFi module started
    power up + 00:00:04 [warn] M150 sent for logo : n/a
    power up + 00:00:04 [warn] M150 sent for nozzle : n/a
    power up + 00:00:09 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.x
    power up + 00:00:09 [warn] HTTP client 192.168.10.xx login succeeded (session key 2066145135)
    2024-03-31 14:47:34 [warn] Date and time set at power up + 00:00:09
    I haven't bothered utilizing filament-error.g since I haven't seen a need for it in my workflow/setup (yet?).
    But here is my pause/resume macro's:
    ; pause.g
    ; Called when a print from SD card is paused
    M83 ; Relative extruder moves
    G1 E-5 F3600 ; Retract 10mm of filament
    G91 ; Relative positioning
    G1 Z5 F360 ; Lift Z by 5mm
    G90 ; Absolute positioning
    G1 X0 Y0 F6000 ; Go to XY 0
    M98 P"/sys/lib/current/xy_current_high.g" ; Restore normal XY currents
    M98 P"/sys/lib/current/z_current_high.g" ; Restore normal Z currents
    ; resume.g
    ; Called before a print from SD card is resumed
    G1 R1 X0 Y0 Z5 F15000 ; Go to 5mm above position of the last print move
    G1 R1 X0 Y0 ; Go back to the last print move
    I can't see anything fishy in either of those that should call for the behaviour i experienced when resuming after the runout atleast? 😐
    undefined undefined undefined 3 Replies Last reply 31 Mar 2024, 13:22 Reply Quote 0
      Exerqtor @Exerqtor
      This post is deleted!
        NeoDue @Exerqtor
        @Exerqtor Hm. My printer is running rc3+ date 2024-02-27 here, and filament run-out detection. manual load via PanelDue and resume works perfectly fine.
        In case it helps, here are my pause/resume config files:
        ; pause.g
        M400 ; finish active moves
        G10 ; retract
        G91 ; relative Positioning
        G1 Z5 F360 ; move bed 5mm down
        G90 ; absolute positioning
        G1 H2 X{move.axes[0].min} U{move.axes[3].max} Y{move.axes[1].min} F6000 ; move heads to X=min/U=max and Y=min
        ; resume.g
        ; called before a print from SD card is resumed
        G1 R1 X0 Y0 Z5 F6000 ; move print head 5mm over last position saved in slot 1
        G1 R1 X0 Y0 Z0 ; move bed up 5mm.
        G11 ; unretract if retracted
        undefined 1 Reply Last reply 1 Apr 2024, 11:00 Reply Quote 0
          Exerqtor @NeoDue
          @NeoDue Thx for your feedback, but you're running a somewhat older version of 3.5.0 rc3 than I am. Please try these binaries and check if it still works.
          I just tried another print with a manual filamentchange (who worked on on 3.5.0b4) and this make the machine stuck in a loop.
          I've got the machine setup to automatically purge(if "ok") & resume the print once i click "ok" or "skip" in when M600 is called (I'll post the macros farther down in the post).
          This is the way it's supposed to work (and have worked until recently):
          • M600 in the job g-code and filament-change.g gets run (look farther down for contence of filament-change.g).
          • The printer goes into the filament change position and a M291 S4 message with "OK" & "SKIP" get's displayed.
          • "OK" is pressed it will extrude(purge) "n" amount of filament, dim the chamber lights back down, change global.FilamentCHG to true and the that's the end of filament--change.g.
            If "SKIP" is pressed no filament will get extruded(purged), dim the chamber lights back down, change global.FilamentCHG to true and the that's the end of filament--change.g.
          • The following condition in daemon.g get's ran:
          ; Resume after filament change
          if exists(global.FilamentCHG)
          if global.FilamentCHG = true && state.status = "paused"
          M24 ; Resume the pause automatically now that the manual filament change is done
          set global.FilamentCHG = false
          • M24 gets sent by daemon.g and resume.g gets ran and the print continues(look farther down for contence of resume.g).
          This is what happens now:
          • "OK" is pressed it will extrude(purge) "n" amount of filament, dim the chamber lights back down, change global.FilamentCHG to true and the that's the end of filament-change.g.
          • M24 gets sent by daemon.g and resume.g gets ran and the print head returns over the point where it stopped printing but DON'T lower the nozzle down to the buildplate again.
          • Hovers over the buildplate for a split second and filament-change.g get's ran again, and hence it's stuck in a loop no matter if i press "OK" or "SKIP". The only way i can break the cycle is to power toggle the machine.
          Here is the event log from the failed filament change/resumes:
          2024-04-01 12:21:01 [warn] Started printing file 0:/gcodes/BFI/[a]_BFI_Front_with_Logo_M3_Symmetrical_x2_0.2mm_ABS_0.4n_21m8s.gcode
          2024-04-01 12:21:03 [warn] M150 sent for logo : yellow
          2024-04-01 12:21:03 [warn] M150 sent for nozzle : yellow
          2024-04-01 12:21:04 [warn] M150 sent for logo : teal
          2024-04-01 12:21:04 [warn] M150 sent for nozzle : bright_white
          2024-04-01 12:21:32 [warn] M150 sent for logo : green
          2024-04-01 12:21:32 [warn] M150 sent for nozzle : bright_white
          2024-04-01 12:21:46 [warn] 9 points probed, min error -0.014, max error 0.013, mean -0.004, deviation 0.008
          2024-04-01 12:21:47 [warn] M150 sent for logo : dim_gray
          2024-04-01 12:21:47 [warn] M150 sent for nozzle : dim_red
          2024-04-01 12:21:48 [warn] M150 sent for logo : yellow
          2024-04-01 12:21:48 [warn] M150 sent for nozzle : yellow
          2024-04-01 12:22:13 [warn] M150 sent for logo : light_blue
          2024-04-01 12:22:13 [warn] M150 sent for nozzle : bright_white
          2024-04-01 12:22:23 [warn] M150 sent for logo : red
          2024-04-01 12:22:23 [warn] M150 sent for nozzle : bright_white
          2024-04-01 12:24:51 [warn] Resume state saved
          2024-04-01 12:26:46 [warn] Printing paused for filament change at X174.6 Y157.6 Z0.2
          2024-04-01 12:26:48 [warn] Printing resumed
          2024-04-01 12:26:48 [warn] Resume state saved
          2024-04-01 12:27:20 [warn] Printing paused for filament change at X174.6 Y157.6 Z5.2
          2024-04-01 12:27:21 [warn] Printing resumed
          2024-04-01 12:27:21 [warn] Resume state saved
          2024-04-01 12:27:38 [warn] Printing paused for filament change at X174.6 Y157.6 Z10.2
          2024-04-01 12:27:40 [warn] Printing resumed
          2024-04-01 12:27:40 [warn] Resume state saved
          2024-04-01 12:29:17 [warn] Printing paused for filament change at X174.6 Y157.6 Z15.2
          2024-04-01 12:29:18 [warn] Error: M0: Pause the print before attempting to cancel it
          2024-04-01 12:29:19 [warn] Printing resumed
          2024-04-01 12:29:19 [warn] Resume state saved
          2024-04-01 12:29:22 [warn] Error: M0: Pause the print before attempting to cancel it
          2024-04-01 12:32:34 [warn] HTTP client 192.168.10.1xx login succeeded (session key 4247479220)
          2024-04-01 12:34:00 [warn] Printing paused for filament change at X174.6 Y157.6 Z20.2
          2024-04-01 12:34:02 [warn] Printing resumed
          2024-04-01 12:34:02 [warn] Resume state saved
          2024-04-01 13:02:00 [warn] Warning: VIN under-voltage event (8.6V)
          power up + 00:00:10 [warn] HTTP client 192.168.10.xx login succeeded (session key 3077884437)
          2024-04-01 13:02:19 [warn] Date and time set at power up + 00:00:10
          The [warn] Error: M0: Pause the print before attempting to cancel it errors got thrown because I tried pressing cancel in PD & DWC after pressing "OK" / "SKIP" btw.
          ; /sys/filament-change.g v2.2
          ; Called when M600 is sent
          ; Used to do a filament change while printing
          ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
          ; Settings section
          ; Will not be used if you're using a "goto" macro
          var x = 40 ; The X axis location where you want the hotend to "park" while changing filament
          var y = 0 ; The Y axis location where you want the hotend to "park" while changing filament
          var spd = 15000 ; The speed of which you want the hotend to move to the "park" location
          var lift = 20 ; The Z clearance you want your nozzle to have from the print while changing filament
          var lights = true ; true / false depending if you have chamber lights or not that you want to turn on
          ; If you don't have lights you want to turn on don't mess with these
          var io = 0 ; The GPIO port number (set by M950) for the lights you want to turn on
          var pwm = 1 ; The PWM to be set on the GPIO port above, 0=off 1=full power
          var purge = 60 ; The amount of filament your hotend need to purge for a clean filament/color change
          ; Will be swaped out with global.unload_length if you have that defined!
          var unload = 12 ; The length of which filament have to be retracted to clear the meltzone
          ; Don't touch anyting beyond this point(unless you know what you're doing)!!
          if exists(global.unload_length)
          set var.unload = global.unload_length
          var pwm_res = state.gpOut[{var.io}].pwm ; Store the PWM from the PPIO port so that it can be returned after changing filament
          if var.lights
          M42 P{var.io} S{var.pwm} ; Turn on the lights
          if fileexists("/sys/lib/beep/l.g")
          M98 P"/sys/lib/beep/l.g" ; Long beep
          M400 ; Wait for moves to finish
          M83 ; Extruder relative positioning
          G10 ; Retraction
          G1 Z1.00 X20.0 Y20.0 F20000 ; Short quick move to disengage from print
          G1 Z{var.lift - 1} F800 ; Go to spesified Z clearance
          if !fileexists("/sys/lib/goto/front_right.g")
          G1 X{var.x} Y{var.y} F{var.spd} ; Move the nozzle to the location defined in the settings section
          if fileexists("/sys/lib/goto/front_right.g")
          M98 P"/sys/lib/goto/front_right.g" {var.spd} ; Move to front right for filament change
          G1 E2 F800 ; Extrude slightly to help form a nice tip on the filament
          G1 E{-(var.unload)} F800 ; Retract filament from the meltzone
          if fileexists("/sys/lib/beep/xl.g")
          M98 P"/sys/lib/beep/xl.g" ; Extra long beep
          M291 S4 R"Manual Filament Change" P"Change & prime filament, then press OK." K{"OK","SKIP",}
          ; "OK"
          if input = 0
          G1 E{var.purge} F200 ; Purge filament
          ; "SKIP"
          if input = 1
          G1 E{var.unload} F800 ; Extrude filament back to the meltzone
          if var.lights
          M42 P{var.io} S{var.pwm_res} ; Return lights to previous state
          if !exists(global.FilamentCHG)
          global FilamentCHG = true
          else
          set global.FilamentCHG = true
          ; resume.g
          undefined 1 Reply Last reply 1 Apr 2024, 12:13 Reply Quote 0
            NeoDue @Exerqtor
            @Exerqtor Will do, but probably not before the weekend - I have to finish a longer print first.
            In the meantime, I will try to understand that complicated filament change logic of yours... 😵
            Offtopic and just to understand: why the heck do you use daemon.g to restart the print instead of simply using filament-change.g to handle everything, including the decision to resume the print?
            undefined 1 Reply Last reply 1 Apr 2024, 12:48 Reply Quote 0
              Exerqtor @NeoDue
              @NeoDue said in Pause/resume issues in 3.5.0rc3+5?:
              It's talked about in this thread from about this time last year lol. It might be that RRF has changed it's behaviour in regard to how the states and resume is dealt with on filament change by now that I haven't picked up on. But if you skim through that thread you will see what I/we wanted to achieve.
              undefined 1 Reply Last reply 1 Apr 2024, 13:40 Reply Quote 0
                NeoDue @Exerqtor
                @Exerqtor Thanks for the link! I faintly remember reading it while I worked on my setup... and that it was the reason for deciding that a manual filament change is perfectly fine for now 😇
                But @dc42's information in there that M24 within filament-change.g is not allowed is the answer to my question.
                Edit: one thought however: I do not use M600 or such, but I do use a custom filament load macro (not named "filament-change.g") - which is however called by hand via pressing the corresponding Macro button in the PanelDue. When the filament is loaded, I press resume manually - which also works, at least for my firmware version. Did you already try to narrow down the issue, e.g. by calling your filament change macro manually / replacing M24 with a manual call etc?
                undefined 1 Reply Last reply 1 Apr 2024, 15:56 Reply Quote 0
                  Exerqtor @NeoDue
                  @NeoDue Well it's happening in two different scenarios for me now at least, one from the printer being paused by a filament runout, and one from a filament change.
                  And since i'm not using filament-error.g the filament runout is pretty much just a regular pause but with a runout flag.
                  So i'm quite sure it's something under the hood of RRF's thats broken and causing this 😅
                  undefined 1 Reply Last reply 1 Apr 2024, 16:33 Reply Quote 0
                    NeoDue @Exerqtor
                    @Exerqtor Yes, but it might help the devs if you can tell them for example "step x works if I start the macro manually but if I let M600 start it it fails" or such, hence the question. You do have a rather complex routine there 😉
                      gloomyandy @Exerqtor
                      @Exerqtor We are currently investigating a problem with pause/resume in the latest builds of RRF. I suspect this may be what is causing this problem. You may want to hold off any further investigations until we have a fix for that problem available.
                      undefined 1 Reply Last reply 1 Apr 2024, 17:33 Reply Quote 2
                        Exerqtor @gloomyandy
                        @gloomyandy Glad to hear my assumptions were right 😆 I'll avoid anything pause/resume related until then lol
                        Is it related to the commits made for fixing pause/resume issues made in the 3.5-mms-changes branch? I don't think I had any issues before MMS got merged with 3.5-dev 🤔
                        undefined 1 Reply Last reply 1 Apr 2024, 18:33 Reply Quote 0
                          @Exerqtor MMS has been present in pretty much all of the 3.5 releases.
                          undefined 1 Reply Last reply 1 Apr 2024, 18:47 Reply Quote 0
                            @gloomyandy Yeah I know, I meant the 3.5-mms-changes branch David made March first and the commits made to that branch March 4th [1] & [2] related to resume after pause. I stated the wrong branch name in the previous post(edited it by now).
                            dc42undefined 3 Replies Last reply 2 Apr 2024, 12:01 Reply Quote 0
                              dc42 administrators @Exerqtor
                              @Exerqtor please try the 3.5.0-rc.3+6 build at https://www.dropbox.com/scl/fo/x7ec0sg11a2zrevxoj3j8/h?rlkey=pcdfiv72z0dkkrbv5i8cem5fd&dl=0.
                                @Exerqtor oops, that's the wrong firmware build. Give me a few minutes to correct it.
                                  @Exerqtor I've updated those files.
                                  undefined 1 Reply Last reply 2 Apr 2024, 14:05 Reply Quote 1
                                    Exerqtor @dc42
                                    Aaah i just did a test with the first ones you supplied there and was about to repport that the issue is persistent.
                                    I'll try the NEWER ones after dinner and report back!
                                    @dc42 Naah that build is borked! Now Z won't even move after homing. Or if i try to move the bed from PD / DWC nothing happens.
                                    The printer reported Z0.54 after homing, and if i try to lower Z with 5mm the reported Z-height changes to 5.54 but no actual movement.
                                    Don't know if M122 reports will help any, but here they are:
                                    RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3+6 (2024-04-02 14:34:06) running on Duet 3 Mini5plus WiFi (standalone mode)
                                    Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
                                    Used output buffers: 29 of 40 (40 max)
                                    Static ram: 103232
                                    Dynamic ram: 126672 of which 12 recycled
                                    Never used RAM 8380, free system stack 135 words
                                    Tasks: NETWORK(2,nWait 7,16.1%,229) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.0%,256) CanReceiv(6,nWait 1,0.1%,797) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,339) TMC(4,nWait 6,0.8%,68) MAIN(1,running,81.2%,654) IDLE(0,ready,0.9%,30) AIN(4,delaying,0.8%,260), total 100.0%
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 00:19:21 ago, cause: software
                                    Last software reset at 2024-04-02 15:40, reason: User, Gcodes spinning, available RAM 11360, slot 1
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 1161890, completed 1161890, timed out 0, errs 0
                                    MCU temperature: min 39.6, current 43.6, max 47.8
                                    Supply voltage: min 2.8, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1500/940, gc cycles 264
                                    Events: 0 queued, 0 completed
                                    Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 61101, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 61101, writes 32, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 22, reads 61111, writes 22, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 61111, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 61112, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 5: not present
                                    Driver 6: not present
                                    Date/time: 2024-04-02 16:36:25
                                    Cache data hit count 2117861953
                                    Slowest loop: 164.57ms; fastest: 0.13ms
                                    === Storage ===
                                    Free file entries: 16
                                    SD card longest read time 7.6ms, write time 8.1ms, max retries 0
                                    DMs created 83, segments created 11, maxWait 737572ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                    no step interrupt scheduled
                                    Moves shaped first try 5, on retry 0, too short 0, wrong shape 4, maybepossible 0
                                    === DDARing 0 ===
                                    Scheduled moves 25, completed 25, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                    === DDARing 1 ===
                                    Heater 0 is on, I-accum = 0.4
                                    Heater 1 is on, I-accum = 0.0
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0 0 0 0 0, running macro
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    SBC is idle in state(s) 0
                                    Daemon is doing "G4 P250" in state(s) 0 0, running macro
                                    Aux2 is idle in state(s) 0
                                    File2 is idle in state(s) 0
                                    Queue2 is idle in state(s) 0
                                    Q0 segments left 0, axes/extruders owned 0x0000807
                                    Code queue 0 is empty
                                    Code queue 1 is empty
                                    === Filament sensors ===
                                    check 0 clear 0
                                    Extruder 0 sensor: no filament
                                    === CAN ===
                                    Messages queued 10493, received 23836, lost 0, errs 1307, boc 0
                                    Longest wait 2ms for reply type 6031, peak Tx sync delay 8139, free buffers 26 (min 25), ts 5810/5808/0
                                    Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
                                    === Network ===
                                    Slowest loop: 201.24ms; fastest: 0.00ms
                                    Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                    HTTP sessions: 2 of 8
                                    === WiFi ===
                                    Interface state: active
                                    Module is connected to access point
                                    Failed messages: pending 0, notrdy 1, noresp 1
                                    Firmware version 2.1beta7
                                    MAC address c4:5b:be:ce:91:93
                                    Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 36232
                                    WiFi IP address 192.168.10.x
                                    Signal strength -54dBm, channel 6, mode 802.11n, reconnections 0
                                    Clock register 00002001
                                    M122 B121
                                    Diagnostics for board 121:
                                    Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+6 (2024-04-02 12:49:31)
                                    Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                                    All averaging filters OK
                                    Never used RAM 3928, free system stack 134 words
                                    Tasks: Move(3,nWait 7,0.0%,135) HEAT(2,nWait 6,0.4%,105) CanAsync(5,nWait 4,0.0%,51) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.2%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,112), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:19:29 ago, cause: power up
                                    Last software reset at 2024-03-12 16:55, reason: StackOverflow, available RAM 2968, slot 0
                                    Software reset code 0x0100 ICSR 0x0042600e SP 0x20007f34 Task Move Freestk 3342 ok
                                    Stack: 20004a80 20004ab4 0001cf33 20004c98 20004938 00000000 0001c011 20003320 fffffffd a5a5a5a5 00000000 20007f8c 00000000 20007f8c 0001cc97 00000000 200017c4 20001748 0001c4d7 20001748 200017c4 00000032 454c4449 00022700 0001ac77 200018e0 200018e0
                                    Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 60547, writes 11, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                                    Moves scheduled 0, completed 0, in progress 0, hiccups 0, segs 0, step errors 0, maxLate 0 maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.00
                                    Peak sync jitter -2/9, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
                                    VIN voltage: min 23.7, current 24.7, max 24.9
                                    MCU temperature: min 65.2C, current 71.7C, max 71.7C
                                    Last sensors broadcast 0x00000012 found 2 15 ticks ago, 0 ordering errs, loop time 0
                                    CAN messages queued 24032, send timeouts 0, received 10573, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                                    Accelerometer: LIS3DH, status: 00
                                    I2C bus errors 0, naks 3, contentions 0, other errors 0
                                    Interrupt 5726621 to 0us, poll 4 to 1432us
                                    Driver 0: ok
                                    I just saw that the printer state is permanently "Busy" now after trying to home & lower Z. Dispite the printer not doing anything.
                                    dc42undefined 1 Reply Last reply 2 Apr 2024, 17:05 Reply Quote 0
                                      @Exerqtor I'm sorry about that, I'm about to run a print to test the correction.
                                      undefined 1 Reply Last reply 2 Apr 2024, 17:20 Reply Quote 0
                                        Exerqtor @dc42
                                        @dc42 Nothing to say sorry for, it's a pre-release afterall 👌
                                        dc42undefined 1 Reply Last reply 2 Apr 2024, 18:10 Reply Quote 0
                                          @Exerqtor I've updated the files, same link as before. A remaining issue I have noticed is that when resuming after a pause there is a slight delay between restoring the XYZ position and starting printing again. I think I know the reason for that and I'll look into it tomorrow.
                                          undefined 1 Reply Last reply 2 Apr 2024, 18:13 Reply Quote 0
                                          2 out of 25
