    FINAL (I hope) RRF 1.20 release candidate 4 and DWS 1.20RC1
    Firmware installation
    9
    22
    3.2k
    • BMMalundefined
      BMMal
      Somewhere between the last beta and going to RC my wifi issues have become more frequent again. The machine is usable, just annoying to have to reset my wifi module from the panel due in order to edit or upload files.
      Duet Ethernet - Most likely the most recent Edge firmware
      Duet X5
      7" Panel Due V2
      Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
      • DjDemonDundefined
        DjDemonD
        Wifi server 1.20RC1 FW 1.20RC4 one print completed kossel Xl no issues.
        www.precisionpiezo.co.uk
          deckingman
          4 hours into a 25 hour print and no problem so far. However, in another thread (RC 2 release I think) someone pointed out that motor currents aren't displayed in the machine properties page of DWC. That is true for me too using the following:
          Firmware Name: RepRapFirmware for Duet Ethernet
          Firmware Electronics: Duet Ethernet 1.0 + DueX5
          Firmware Version: 1.20RC4 (2017-12-20)
          Web Interface Version: 1.20-RC3
            Thanks, Ian. I've confirmed the problem with displaying motor currents, and it will be fixed in the 1.20 release.
            • okerchoundefined
              okercho
              Hi, just a cosmetic thing I've found (I just installed the RC4, so I didn't test prints yet), Z probe is being marked as "Type:
              Unknown (8)" when P8 is selected in M558.
              Firmware Electronics: Duet WiFi 1.0
              WiFi Server Version: 1.20b10
              Oh, BTW, I installed it in this way:
              1. Extracted SD, copied Web files
              2. Turn printer on, upload firmware in settings. Choosed yes (I read after clicking that I should select NO)
              3. Printer restarted perfectly.Wifi worked fine. Uploaded and upgraded wifi server. Selected yes when asked
              4. Wifi didn't come back. Switched off and on printer by unplugging it
              5. Wifi came back (and seems to be stable so far)
              Regards!
              Okercho
              Custom Prusa i3 Hephestos with Duet Wi-Fi
              E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
              Rebuilding Hypercube Evolution
              • str8upundefined
                str8up
                Should the selections under Settings / User interface and List items remain after a printer on/off restart. Mine is reverting back to default.
                  @okercho:
                  Thanks. DWC doesn't yet know about new Z probe types 7 and 8. I've alerted chrishamm.
                  • totalitarianundefined
                    totalitarian
                    Just to confirm the issue above, uploaded both files via DWC (wifi server and firmware) needed to power cycle the machine to get wifi back on.
                      Thanks. Perhaps this is an alternative to installing the WiFi firmware twice, which is what I did when it didn't work first time.
                      • okerchoundefined
                        okercho
                        Hi there,
                        I put a little print last night, and it finished as expected. Ping is still working, although the web interface is not working anymore.
                        I've tested a few things and host seems to be up, but port 80 is filtered (??)
                        nmap -sV 192.168.1.120
                        Starting Nmap 7.01 ( https://nmap.org ) at 2017-12-22 10:13 CET
                        Nmap scan report for 192.168.1.120
                        Host is up (0.0018s latency).
                        Not shown: 999 closed ports
                        PORT STATE SERVICE VERSION
                        80/tcp filtered http
                        MAC Address: 5C:CF:7F:XX:XX:XX (Espressif)
                        I still have the printer on, in case you want me to execute something on it.
                        Okercho
                        • Gosuundefined
                          Gosu
                          this version made the wifi module much more stable i still get ocassional disconnects but im always able to reconnect
                          Thanks a lot
                            @okercho:
                            Hi there,
                            Can you get a Wireshark trace of an attempt to to connect the browser?
                              @Gosu:
                              Thanks a lot
                              Thanks for the feedback!
                              • okerchoundefined
                                okercho
                                Here you have it: https://www.dropbox.com/s/9z1pxu1v7rl1pd5/DuetWifiFiltered.pcapng?dl=0
                                I've filtered by source or origin equal the Duet IP, and I've confirmed before that the MAC address is the duet one.
                                • First you can see some errors
                                • then a ping (requests and replies, so the duet is there)
                                • then I tried a curl to http://DUET_IP, with no success (curl: (7) Failed to connect to 192.168.1.120 port 80: Operation timed out)
                                • then I tried with the browser, with same results
                                  Nmap still says port is filtered.
                                Do you want me to execute something else before rolling restart the duet?
                                Regards
                                @dc42:
                                @okercho:
                                Hi there,
                                Okercho
                                  Thanks! Please can you connect via USB and get a M122 report. Then send M552 S0 followed by M552 S1 and see if you can connect after that, giving it time to connect to the AP. If not, send M552 S-1 followed by M552 S1 and see if that is any better.
                                  That's all, so restart after that.
                                  • okerchoundefined
                                    okercho
                                    Here you have it: https://www.dropbox.com/s/w4j58dw8nk8a3lu/DuetLog.zip?dl=0
                                    You will find 3 files:
                                    • DuetLog-20171222: Contains the M122 report
                                    • DuetLog-20171222-2: Execution of M552 S0 and M552 S1. After the S1 the web was accesible again… until I disconnected Pronterface to avoid the tons of "aux: M408 S0 R110" (clicking in disconnect), in that moment, web stopped working (but duet still answers pings)
                                    • DuetLog-20171222-3: Execution of M552 S-1 and M552 S1. After clicking in "Connect" again, web came back again... however, after the S-1 and S1, log reported "incorrect password" and wifi never came back, even with a roll restart (after the roll restart it keeps saying wrong password).
                                    I had to execute M552 S0 and S1 through panel due, and then it came back.
                                    Makes sense to you?
                                    Regards
                                    @dc42:
                                    Okercho
                                      If you were getting those aux:M408 reports from Pronterface, then a M111 S1 command has been executed at some point to turn debugging on. That could be responsible for the network issues too. Next time you get these issues, try sending M111 from PanelDue to report the current debug state. If any debugging is turned on, send M111 S0 to turn it back off.
                                      • okerchoundefined
                                        okercho
                                        Ouch!
                                        Yes, my bad… when I updated to the RC, I enabled debugging in the config file... I've disabled it now.
                                        Thanks a lot!
                                        @dc42:
                                        Okercho
                                        • KeeganBundefined
                                          KeeganB
                                          Ok, I just updated to the latest RC's on all three. Lets see how it goes!
                                          Artemis
                                          Rostock Max v2
                                          Orion
