    FINAL (I hope) RRF 1.20 release candidate 4 and DWS 1.20RC1
    Firmware installation
    9
    22
    3.2k
    • DjDemonDundefined
      DjDemonD
      Wifi server 1.20RC1 FW 1.20RC4 one print completed kossel Xl no issues.
      www.precisionpiezo.co.uk
        deckingman
        4 hours into a 25 hour print and no problem so far. However, in another thread (RC 2 release I think) someone pointed out that motor currents aren't displayed in the machine properties page of DWC. That is true for me too using the following:
        Firmware Name: RepRapFirmware for Duet Ethernet
        Firmware Electronics: Duet Ethernet 1.0 + DueX5
        Firmware Version: 1.20RC4 (2017-12-20)
        Web Interface Version: 1.20-RC3
          Thanks, Ian. I've confirmed the problem with displaying motor currents, and it will be fixed in the 1.20 release.
          • okerchoundefined
            okercho
            Hi, just a cosmetic thing I've found (I just installed the RC4, so I didn't test prints yet), Z probe is being marked as "Type:
            Unknown (8)" when P8 is selected in M558.
            Firmware Electronics: Duet WiFi 1.0
            WiFi Server Version: 1.20b10
            Oh, BTW, I installed it in this way:
            1. Extracted SD, copied Web files
            2. Turn printer on, upload firmware in settings. Choosed yes (I read after clicking that I should select NO)
            3. Printer restarted perfectly.Wifi worked fine. Uploaded and upgraded wifi server. Selected yes when asked
            4. Wifi didn't come back. Switched off and on printer by unplugging it
            5. Wifi came back (and seems to be stable so far)
            Regards!
            Okercho
            Custom Prusa i3 Hephestos with Duet Wi-Fi
            E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
            Rebuilding Hypercube Evolution
            • str8upundefined
              str8up
              Should the selections under Settings / User interface and List items remain after a printer on/off restart. Mine is reverting back to default.
                @okercho:
                Thanks. DWC doesn't yet know about new Z probe types 7 and 8. I've alerted chrishamm.
                • totalitarianundefined
                  totalitarian
                  Just to confirm the issue above, uploaded both files via DWC (wifi server and firmware) needed to power cycle the machine to get wifi back on.
                    Thanks. Perhaps this is an alternative to installing the WiFi firmware twice, which is what I did when it didn't work first time.
                    • okerchoundefined
                      okercho
                      Hi there,
                      I put a little print last night, and it finished as expected. Ping is still working, although the web interface is not working anymore.
                      I've tested a few things and host seems to be up, but port 80 is filtered (??)
                      nmap -sV 192.168.1.120
                      Starting Nmap 7.01 ( https://nmap.org ) at 2017-12-22 10:13 CET
                      Nmap scan report for 192.168.1.120
                      Host is up (0.0018s latency).
                      Not shown: 999 closed ports
                      PORT STATE SERVICE VERSION
                      80/tcp filtered http
                      MAC Address: 5C:CF:7F:XX:XX:XX (Espressif)
                      I still have the printer on, in case you want me to execute something on it.
                      Okercho
                      • Gosuundefined
                        Gosu
                        this version made the wifi module much more stable i still get ocassional disconnects but im always able to reconnect
                        Thanks a lot
                          @okercho:
                          Hi there,
                          Can you get a Wireshark trace of an attempt to to connect the browser?
                            @Gosu:
                            Thanks a lot
                            Thanks for the feedback!
                            • okerchoundefined
                              okercho
                              Here you have it: https://www.dropbox.com/s/9z1pxu1v7rl1pd5/DuetWifiFiltered.pcapng?dl=0
                              I've filtered by source or origin equal the Duet IP, and I've confirmed before that the MAC address is the duet one.
                              • First you can see some errors
                              • then a ping (requests and replies, so the duet is there)
                              • then I tried a curl to http://DUET_IP, with no success (curl: (7) Failed to connect to 192.168.1.120 port 80: Operation timed out)
                              • then I tried with the browser, with same results
                                Nmap still says port is filtered.
                              Do you want me to execute something else before rolling restart the duet?
                              Regards
                              @dc42:
                              @okercho:
                              Hi there,
                              Okercho
                                Thanks! Please can you connect via USB and get a M122 report. Then send M552 S0 followed by M552 S1 and see if you can connect after that, giving it time to connect to the AP. If not, send M552 S-1 followed by M552 S1 and see if that is any better.
                                That's all, so restart after that.
                                • okerchoundefined
                                  okercho
                                  Here you have it: https://www.dropbox.com/s/w4j58dw8nk8a3lu/DuetLog.zip?dl=0
                                  You will find 3 files:
                                  • DuetLog-20171222: Contains the M122 report
                                  • DuetLog-20171222-2: Execution of M552 S0 and M552 S1. After the S1 the web was accesible again… until I disconnected Pronterface to avoid the tons of "aux: M408 S0 R110" (clicking in disconnect), in that moment, web stopped working (but duet still answers pings)
                                  • DuetLog-20171222-3: Execution of M552 S-1 and M552 S1. After clicking in "Connect" again, web came back again... however, after the S-1 and S1, log reported "incorrect password" and wifi never came back, even with a roll restart (after the roll restart it keeps saying wrong password).
                                  I had to execute M552 S0 and S1 through panel due, and then it came back.
                                  Makes sense to you?
                                  Regards
                                  @dc42:
                                  Okercho
                                    If you were getting those aux:M408 reports from Pronterface, then a M111 S1 command has been executed at some point to turn debugging on. That could be responsible for the network issues too. Next time you get these issues, try sending M111 from PanelDue to report the current debug state. If any debugging is turned on, send M111 S0 to turn it back off.
                                    • okerchoundefined
                                      okercho
                                      Ouch!
                                      Yes, my bad… when I updated to the RC, I enabled debugging in the config file... I've disabled it now.
                                      Thanks a lot!
                                      @dc42:
                                      Okercho
                                      • KeeganBundefined
                                        KeeganB
                                        Ok, I just updated to the latest RC's on all three. Lets see how it goes!
                                        Artemis
                                        Rostock Max v2
                                        Orion
