Solved Can this be fixed ?
@Richard-F can you grab an output of
M122 B20
as well? -
M122 b20 Diagnostics for board 20: Duet TOOL1LC firmware version 3.3RC2 (2021-05-11 14:59:50) Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25) Never used RAM 3292, free system stack 0 words Tasks: Move(notifyWait,0.0%,153) HEAT(delaying,0.2%,81) CanAsync(notifyWait,0.0%,66) CanRecv(notifyWait,0.0%,79) CanClock(notifyWait,0.0%,66) ACCEL(notifyWait,0.0%,61) TMC(notifyWait,2.8%,57) MAIN(running,92.0%,349) IDLE(ready,0.0%,26) AIN(delaying,4.9%,62), total 100.0% Last reset 00:01:59 ago, cause: software Last software reset at 2024-04-16 16:33, reason: AssertionFailed, available RAM 3292, slot 0 Software reset code 0x0120 ICSR 0x00000000 SP 0x20004094 Task x> Freestk 136 ok Stack: 00000544 00023174 00019cb5 20003044 00016e33 20003044 00016505 200071c8 00000001 00000001 0000828d 200071c8 200071c8 00000000 20000f50 00000020 00011311 200071c8 00008611 200071d8 000ed7d1 000ed7d1 434d0b16 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: position 0, 397.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 1, ifcnt 32, reads 59584, writes 12, timeouts 0, DMA errors 0, steps req 0 done 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 10, peak Rx sync delay 632, resyncs 1, no step interrupt scheduled VIN: 24.2V MCU temperature: min 42.6C, current 42.6C, max 44.4C Ticks since heat task active 227, ADC conversions started 119222, completed 119220, timed out 0, errs 0 Last sensors broadcast 0x00000001 found 1 232 ticks ago, loop time 0 CAN messages queued 1470, send timeouts 0, received 619, lost 0, free buffers 36, min 36, error reg 0 dup 0, oos 0, bm 0, wbm 0 Accelerometer detected: yes, status: 00 I2C bus errors 0, naks 0, other errors 0
@Richard-F said in Can this be fixed ?:
That'll be it! Upload the 1LC firmware from the 3.5.0-rc3 release. Or the zip package rc4 release to update everything to that: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.5.0-rc.4
Edit: Strange that it has a later bootloader version than firmware version:
@droftarts yes i download the bootloader earlier , im not all that sure what all the different files are
is it the bin file i need ?
@droftarts do i need to enter a m code to install / run the bin file
@Richard-F DWC should automatically prompt you
@jay_s_uk i clicked update , chose bin , then it just says uploaded , then nothing tool board is still 3.3
@Richard-F in which case
M997 B20
im not to sure what file i need from the github
@Richard-F just upload the zip file at the top. don't unzip it locally, just upload it
@jay_s_uk ok
Great success ! lol
@jay_s_uk OMG the E motor is working ! , you guys are genesis .. This is why buying from duet is worth the extra money, for the awesome support .. thank you so much
@Richard-F you're welcome. enjoy!
@Richard-F Great, glad you got there! Now, deep breath, and sleeeeeeeeeeeep....
@droftarts Lol . irk , thanks Ian , you're a superstar
