Duet2 Firmware Upgrade Issue
try increasing your motor current set in M906 to 1200
@Phaedrux Tried this and still getting the same error message
@Phaedrux It's also now giving me this error, not sure if it's possibly related?
20/04/2024, 18:20:07 Error: in file macro line 7: G1: Failed to enable endstops
@Bewaren said in Duet2 Firmware Upgrade Issue:
Sounds like your homing files are trying to use an endstop that doesn't exist. Post your homing files.
Phase disconnected means that either the wiring isn't good, or the driver is internally damaged. I'd replace the wiring, particularly the crimps.
Are you still getting expected movement from the motors?
@Phaedrux Unfortunately I've checked the wires already and have replaced them all, the motors are moving as expected however when it's homing multiple axis at once (X and Y) it seems to encounter an issue and starts skipping on the belt.
I'm assuming it's a issue with the driver then?
If so I assume there's nothing I can really do to repair it? I'm running two Z motors and a X and Y so won't have a free one once I add the extruder also
Thanks again for the help!
@Phaedrux Yeah it's just clicked it'll be my Z axis, I've not set the bed up as of yet so don't even have those motors connected
Are you getting the driver warning from the driver that the Z axis is connected to?
@Phaedrux I don't have anything connected to the Z axis drivers currently
I'm now getting a issue with Driver 2
'Warning: Driver 2 warning: phase A may be disconnected, phase B may be disconnected'
@Bailey-James said in Duet2 Firmware Upgrade Issue:
Yes, but your error is coming from the driver defined for Z which you don't have anything connected to, which is what the error is telling you.
