Can you help , wifi issues
184
    Richard F
    somehow both heaters and temp sensors are linked , i control 1 it affects the other
    20= tool board "can" address
    ; Sensors
    ;nozzle
    M308 S0 P"20.temp0" Y"thermistor" A"Nozzle" T100000 B4388 C7.06e-8 ; configure sensor #0
    ;bed
    M308 S1 P"temp2" Y"thermistor" A"Bed" T100000 B4388 C7.06e-8 ; configure sensor #0 ; Configure sensor #0 for the nozzle on temp input 0configure sensor #0 M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8
    ; Nozzle
    M950 H0 C"20.out0" T0 ; create heater #0 for the nozzle
    M140 P0 H0
    M143 H0 P0 T0 C300 S0 A0 ; configure nozzle heater monitor
    ; Heaters BED
    M950 H1 C"out0" T1 ; create heater #1 for the bed
    M140 P1 H1 ; assign bed heater to heater 1
    M143 H1 P1 T1 C100 S0 A0 ; configure bed heater monitor
    M950 F0 C"20.out1" ; create part cooling fan
    M106 P0 S0 L0 X1 B0.1 ; configure fan 0
    M950 F1 C"20.out2" ; create hotend cooling fan
    M106 P1 S0 L0 X1 B0.1 ; configure fan 1
    M563 P0 S"Evo" D0 H0 F0 ; M563 P0 S"Evo" D0 H1 F0 ; create tool #0
    M568 P0 R0 S0
    ;M563 P1 S"Bed" H1 F0 ; M563 P0 S"Evo" D0 H1 F0 ; create tool #0
    ;M568 P1 R0 S0
    undefined undefined 2 Replies Last reply 24 Apr 2024, 16:26 Reply Quote 0
      Richard F @Richard F
        Can you send M122 and M98 P"config.g" and post the results?
        Can you upload your full config.g?
        I notice you have an extra space in your tool definition.
        M568 P0 R0 S0
        ;M568 P1 R0 S0
        Also, you do not create a tool for the bed.
        Does your DWC version match your firmware version?
          droftarts administrators @Richard F
          @Richard-F said in i have no idea:
          ; Nozzle
          M140 P0 H0
          ; Heaters BED
          You have defined both the 'Nozzle' and the 'Heaters BED' as bed heaters with M140. Remove the M140 P0 H0 in the Nozzle configuration.
          undefined 1 Reply Last reply 25 Apr 2024, 03:09 Reply Quote 0
            Richard F @droftarts
            @droftarts Hi Ian , that worked, thanks, 🙂 I'm still getting my head around how the code works. i was trying to figure it out myself for hours, lol .. But we learn .. Thanks again Ian
            undefined 1 Reply Last reply 25 Apr 2024, 03:48 Reply Quote 0
              im always getting this M552 Error . im not sure why , and connection keeps dropping out. i don't think it's my network
              or signal strength
              ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi
              ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.3 on Thu Mar 14 2024 13:43:02 GMT+0000 (Greenwich Mean Time)
              ; General
              M550 P"Duet 3" ; set hostname
              ;M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
              M552 S1
              M587 S"HeX" P"Spyder30" ; configure WiFi adapter
              M586 P0 S1 ; configure HTTP
              ; LED Strips
              ;M950 E0 C"io1.out" T2 ; configure LED strip #0
              ; Smart Drivers
              M569 P0.0 S0 D3 V3 ; driver 0.0 goes forwards (X axis)
              M569 P0.1 S0 D3 V3 ; driver 0.1 goes forwards (Y axis)
              M569 P0.2 S0 D3 V3 ; driver 0.2 goes forwards (Z axis)
              M569 P20.0 S0 D3 V3
              ; Motor Idle Current Reduction
              M906 I50 ; set motor current idle factor
              M84 S50 ; set motor current idle timeout
              ; Axes
              M584 X0.0 Y0.1 Z0.2 ; set axis mapping
              M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
              M906 X1000 Y1200 Z1000 ; set axis driver currents
              M92 X80 Y80 Z400 ; configure steps per mm
              M208 X0:300 Y0:215 Z-3:160 ; set minimum and maximum axis limits
              M566 x20 Y10 Z20 ; set maximum instantaneous speed changes (mm/min)
              M203 X7000 Y6000 Z500 ; set maximum speeds (mm/min)
              M201 X350 Y300 Z25 ; set accelerations (mm/s^2)
              ; Extruders
              M584 E20.0 ; set extruder mapping
              M350 E16 I1 ; configure microstepping with interpolation
              M906 E900 ; set extruder driver currents
              M92 E397 ; configure steps per mm
              M566 E800 ; set maximum instantaneous speed changes (mm/min)
              M203 E3600 ; set maximum speeds (mm/min)
              M201 E1000 ; set accelerations (mm/s^2)
              ; Kinematics
              M669 K0 ; configure Cartesian kinematics
              M574 X1 P"!io5.in" S1 ; configure X axis endstop
              M574 Y1 P"!io6.in" S1 ; configure Y axis endstop
              M574 Z1 P"!io0.in" S1 ; configure Z axis endstop
              ; Mesh Bed Compensation
              ;M557 X25:175 Y25:175 S40:40 ; define grid for mesh bed compensation
              ; Sensors
              ;nozzle
              ;bed
              ; Nozzle
              ;M140 P0 H1 ; create heater #0 for the nozzle
              M143 H0 P0 T0 C0 S300 A0 ; configure nozzle heater monitor
              ; Heaters BED
              M143 H1 P1 T1 C0 S100 A0 ; configure bed heater monitor
              M568 P0 R0 S0
              undefined 1 Reply Last reply 25 Apr 2024, 05:12 Reply Quote 0
                oliof @Richard F
                @Richard-F remove the M587 line from config.g -- the wifi module stores these values and M552 S1 is sufficient in config.g to start it up.
                undefined 1 Reply Last reply 25 Apr 2024, 06:16 Reply Quote 0
                  Richard F @oliof
                  @oliof
                  thank you
                  , i wasn't sure 🙂
                  5 out of 8
