Heightmap issue.
304
    Joel
    After sorting some things out ( thanks for the help ) after reconfiguring my Voron 2.4, I am having height map issues. First problem was very big deviations which I knew were not real, slowed down the Z probe and that was solved. Now the deviation looks good ( not much ), but the map gets pushed down below the table.
    What I usually do,
    Turn on machine and home all axis.
    bed level till below .01mm
    rehome Z
    check/set Z offset
    mesh level
    This is what I get. what could be causing this offset?
    Thanks
    undefined 2 Replies Last reply 10 Apr 2024, 18:23 Reply Quote 0
      Simone @Joel
      @Joel hi i had the same problem some time ago you need to have a 'reference' offset from the tool to the bed
        Simone @Joel
        @Joel https://docs.duet3d.com/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status you need to use this command
        undefined 1 Reply Last reply 10 Apr 2024, 18:32 Reply Quote 0
          Simone @Simone
          @Simone
          this is an example
          M558 P5 C"^probe" H8 F1000 T2000 A2 S0.03 ; Z probe connected to Duet 2 E0 endstop input
          M557 X30:180 Y30:180 S30 ; define mesh grid 215
          G31 Z2.5 X-8 Y22 ; Z parameter trigger height
            Joel
            So I do have this,
            M558 P5 C"!^io4.in" H5 F120 T12000
            G31 P500 X0 Y0 Z-.45
            M557 X20:330 Y20:330 S77.5
            The tool offset is actually very accurate. changes ever so slightly when I change nozzles. For now I'm not using mesh and just do a new Z offset if I change nozzles.
              We'd need to see your config.g and homing files to get an idea of where your offset is coming from.
              How are you homing Z? How did you get G31 Z-0.45? That would mean the nozzle tip is half a mm below the bed surface when the probe triggers. Does that sound right?
              Review this and see if you're setting Z0 correctly or not.
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
              undefined 1 Reply Last reply 12 Apr 2024, 05:42 Reply Quote 0
                oliof @Phaedrux
                @Phaedrux negative offset might be correct for TAP probe, but that's for @Joel to confirm.
                undefined 1 Reply Last reply 21 Apr 2024, 15:43 Reply Quote 0
                  Joel @oliof
                  Yes, it is a tap probe, I lower the nozzle until it just touches the bed, then lower until it triggers.
                  What's the tag that inserts a code block so it easier to read? I post some of the shorter ones now.
                  If something changes I run my Z offset macro which adds or subtracts a bit an gets placed in config-override.g
                  ; Probed tool offsets
                  G10 P0 Z0.04
                  my z home macro is,
                  G91 ; relative positioning
                  G1 H2 Z10 F4000 ; lift Z relative to current position
                  G90 ; absolute positioning
                  G1 X175 Y175 F10000 ; go to first probe point
                  ;G90 ; absolute positioning
                  ;G1 X175 Y175 F4000 ; go to first bed probe point and home Z
                  G91 ; set relative move
                  G1 Z-999 H1 F500 ; quickly home Z
                  G1 z5 ; Lift z for final probe
                  G90
                  G1 X5 Y5 F10000
                  G1 Z10 F2000
                  M501
                  my z offset macro is,
                  T0
                  M291 P"Press ""OK"" if you would you like to calibrate the Z-offset for this Tool Cartridge." R"Calibrate Z-Offset" S3
                  M291 P"Homing, please wait..." R"Calibrate Z-Offset" S1
                  M208 Z-2 S1 ; allow movement below Z0
                  G1 X175 Y175 Z8 F4000 ; move to center of bed
                  M558 P0
                  G30 S-2
                  M208 Z-.5 S1 ; allow slight - Z so zoffset can work
                  G1 Z10 ; drop build plate
                  G1 X10 Y10 F4000
                  M558 P1 C"!^io4.in" H5 F500 T10000 ; restore probe type
                  G31 P500 X0 Y0
                  M291 P"Z-offset calibration complete! " R"Calibrate Z-Offset" S1 T3
                  M500 ; save results
                  M501 ; load new data
                    Joel
                    @Phaedrux
                    I was cleaning up my config.g file and going through it. It brought a question to mind that when I changed something, the height map started working, but I'm not sure why.
                    In my config file, there is a line G31 P500 X0 Y0 Z-.45 . This setup the offsets for the probe
                    At the end of my config file there is a G10 X0 Y0 Z0 which I thought was another tool offset, how does it relate to G31? When I do my Z-offset macro, it adds a line to config-override that is a G10 P0 Z xxxx. I thought this was an adjustment to the offset in the G31 Z-.45 offset.
                    When I commented out the G10 X0 Y0 Z0 in my config.g the height map was still broken. When I changed it G10 X0 Y0 Z-.45 ( to match the G31 setting ), the heightmap started working.
                    What should I be doing here?
                    I still don't know how to do the insert gcode thing, so I will attach my config.g as a file
                    Config.g.txt
                    Thanks
                    Joel
                    undefined 1 Reply Last reply 25 Apr 2024, 21:14 Reply Quote 0
                      Joel @Joel
                      I think I found my issue,
                      In my Z-offset routine, when I was restoring the probe type, I did not restore the Z trigger height.
                      Once I fixed the G31 command, the height map works as expected.
                      • undefined Phaedrux marked this topic as a question 26 Apr 2024, 00:58
                      • undefined Phaedrux has marked this topic as solved 26 Apr 2024, 00:58
