    Tool failed during print
    582
      Phaedrux Moderator @jumpedwithbothfeet
      @jumpedwithbothfeet said in Tool failed during print:
      MCU temperature: min 37.5C, current 87.2C, max 87.4C
      That is pretty toasty. Is this an enclosed printer?
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
      • jumpedwithbothfeetundefined
        jumpedwithbothfeet @Phaedrux
        @Phaedrux yes it is but only passively heated, water cooled hot end, Im trying to figure out a way of water cooling the board as a fan won’t cut it! And I’m guessing the board rear side is where the heat gets transferred like the main board?
        6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
          jumpedwithbothfeet
          Update, found a crimp that had gone bad on the part cooling fan (ground side) this maybe partly to blame, but doesn’t solve the hot cpu issue, could it cause the memory issue?
            does it still get hot like that without the bed heater and extruder heater going and the enclosure open?
            jumpedwithbothfeetundefined 2 Replies Last reply Reply Quote 0
              @Phaedrux so essentially the printer turned on but not running a print? I’ve not tried it, I’ll turn it on and report back 🙂
                @Phaedrux the temperature increased from 23.3 degrees to 31.4 over an hour.
                M122 B121
                Diagnostics for board 121:
                Duet TOOL1LC rev 1.1 or later firmware version 3.5.1 (2024-04-19 14:42:41)
                Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
                All averaging filters OK
                Never used RAM 4128, free system stack 132 words
                Tasks: Move(3,nWait 7,0.0%,135) HEAT(2,nWait 6,0.3%,107) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.4%,53) MAIN(1,running,91.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.6%,112), total 100.0%
                Owned mutexes:
                Last reset 01:07:56 ago, cause: power up
                Last software reset at 2024-04-21 11:59, reason: OutOfMemory, available RAM 0, slot 0
                Software reset code 0x01c0 ICSR 0x00000000 SP 0x20004c68 Task Move Freestk 115 ok
                Stack: 20004ee0 000063e3 20004f40 20005fa8 20004f40 0000a51d 20004ccc 00008faf c5784ca0 2e89a8bb 2e89a8bb 47a79800 be3335d3 ce2ae763 41661135 00014f30 00000001 0001f46a 200026cc 20005fa8 200076b0 000492ca 20004ccc 00009629 000007d0 3e5c209d 3f4c1414
                Driver 0: pos 0, 860.0 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 44134, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Moves scheduled 0, completed 0, in progress 0, hiccups 0, segs 0, step errors 0, maxLate 0 maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.00
                Peak sync jitter 5/8, peak Rx sync delay 204, resyncs 0/0, no timer interrupt scheduled
                VIN voltage: min 24.4, current 24.4, max 24.4
                MCU temperature: min 15.5C, current 31.2C, max 31.4C
                Last sensors broadcast 0x00000002 found 1 23 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 1799, send timeouts 0, received 802, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                Accelerometer: LIS3DH, status: 00
                I2C bus errors 0, naks 0, contentions 0, other errors 0
                  I guess that eliminates a failed component getting hot and cooking the rest of it. The driver chip and it's supporting electronics would be the main source of heat on the board.
                  Can you try running a print without the enclosure sealed to see if it stays cooler/lasts longer?
                    @Phaedrux I’ve just run a 1hr print door wide open the MCU crept up consistently during the print it was 25 degrees at the start, 68.5 just before finishing so it’s getting warm, I’ll sort out a 2 hour print tomorrow to see if it continues to climb or plateaus again with the door open.
                    M122 b121
                    Never used RAM 3096, free system stack 71 words
                    Tasks: Move(3,nWait 7,0.3%,89) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.5%,53) MAIN(1,running,91.1%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,112), total 100.0%
                    Owned mutexes:
                    Last reset 01:22:03 ago, cause: power up
                    Driver 0: pos 0, 860.0 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 35276, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 46438
                    Moves scheduled 59221, completed 59218, in progress 1, hiccups 57, segs 43, step errors 0, maxLate 0 maxPrep 504, maxOverdue 65, maxInc 64, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                    Peak sync jitter 4/9, peak Rx sync delay 204, resyncs 0/0, no timer interrupt scheduled
                    VIN voltage: min 24.3, current 24.4, max 24.6
                    MCU temperature: min 15.8C, current 68.3C, max 68.5C
                    Last sensors broadcast 0x00000002 found 1 157 ticks ago, 0 ordering errs, loop time 0
                    CAN messages queued 1450, send timeouts 0, received 1488, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
                    dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 363, adv 36385/74657
                    I
                      @Phaedrux just about to finish a 3 hour print, the temp with the door open reached 73.1 so still fairly toasty! I’m gonna try it again with the cable cover off see if it makes a difference….
                      M122 B121
                      Never used RAM 3144, free system stack 71 words
                      Tasks: Move(3,nWait 7,0.3%,85) HEAT(2,nWait 6,0.4%,91) CanAsync(5,nWait 4,0.0%,49) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.5%,53) MAIN(1,running,91.0%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.7%,112), total 100.0%
                      Owned mutexes:
                      Last reset 03:45:34 ago, cause: power up
                      Driver 0: pos 0, 860.0 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 36389, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 698704
                      Moves scheduled 203158, completed 203157, in progress 1, hiccups 853, segs 41, step errors 0, maxLate 0 maxPrep 567, maxOverdue 92, maxInc 64, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                      Peak sync jitter 5/9, peak Rx sync delay 236, resyncs 0/0, no timer interrupt scheduled
                      VIN voltage: min 24.1, current 24.3, max 24.6
                      MCU temperature: min 16.1C, current 71.9C, max 73.1C
                      Last sensors broadcast 0x00000002 found 1 117 ticks ago, 0 ordering errs, loop time 0
                      CAN messages queued 19890, send timeouts 0, received 21397, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 369, adv 36230/74658
                        jumpedwithbothfeet @jumpedwithbothfeet
                        No difference with the cover off!
