    New firmware 1.20 Release Candidate 2 - please try it!
    Firmware installation
    30
    97
    15.3k
    • Camalot977undefined
      Camalot977
      @dc42:
      Which firmware version were you upgrading from?
      1.1.9 something 😉
      • stripsundefined
        strips
        Flashing RC3 yesterday wifi seemed to work properly and worked a few seconds after power up now and then this:
        Recv: Error retrieving WiFi status message
        Wifi debug does not give me any more info. Web server is dead.
        M999 resets and I get connected to wifi:
        Recv: FIRMWARE_NAME: RepRapFirmware for Duet WiFi FIRMWARE_VERSION: 1.20RC3 ELECTRONICS: Duet WiFi 1.0 + DueX5 FIRMWARE_DATE: 2017-12-16
        Recv: ok
        Recv: Wifi module is connected to access point Tomato24, IP address 192.168.1.111
        Then 15-20 seconds later without doing anything is crashes again with lots of "Recv: Error retrieving WiFi status message"
        This is a new one for me.
        Ender 5 Plus, E3D Bigbox Dual
          @strips, please follow the instructions at https://www.duet3d.com/forum/thread.php?pid=32944#p32944.
          • stripsundefined
            strips
            David, that is what I did.
            Connected to DuetWifi by USB (octoprint in bigbox). The M111 S1 P14 really does not give my anything after it failed. I need to try again and enable before it fails to see if I get anything before.
            • stripsundefined
              strips
              Funny… not changing anything today everything works 😮
              So I have to call this one off for the moment 🙂
                Please try the new 1.20RC4 and DWS 1.20RC1 that I have just released.
                • BMMalundefined
                  BMMal
                  The Machine Properties tab is not reporting the motor currents in RC4 or RC3. Not sure about earlier versions. Could be a DWC thing too I suppose?
                  Duet Ethernet - Most likely the most recent Edge firmware
                  Duet X5
                  7" Panel Due V2
                  Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                  • justine.hauptundefined
                    justine.haupt
                    @dc42:
                    1. Use M140 H0:2:3:4 to configure multiple bed heaters, instead of M140 P0 H0, M140 P1 H3 etc.
                    Thoughts?
                    That sounds very good to me.
                    • T-Printerundefined
                      T-Printer
                      Hi I still a lot of problems to Connect, to my DuetWifi board, is just go on and off.
                      I Have install the new 1.20RC4 and DWS 1.20RC1, but NO, the only drifrence from RC3 I can see, is it now only reconnect once, the it say WiFi reported error: Timed out while trying to connect to ….
                      This is from Pronterface, and running a M111 S1 P14
                      Connecting...
                      Printer is now online.
                      WiFi reported error: Lost connection, auto reconnecting
                      M111 S1 P14
                      SENDING:M111 S1 P14
                      Debugging enabled for modules: WiFi(14)
                      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) GCodes(3) Move(4) Heat(5) DDA(6) Roland(7) Scanner(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13)
                      WiFi reported error: Timed out while trying to connect to Nordbygaard
                      WiFi: sleep enable,type: 2
                      WiFi: sl
                      WiFi: scandone
                      WiFi: usl
                      WiFi: state: 5 -> 0 (0)
                      WiFi: rm 0
                      WiFi: pm close 7
                      WiFi: del if0
                      WiFi: usl
                      WiFi: mode : null
                      Any ide, what this can be?
                      • Dougal1957undefined
                        Dougal1957
                        Don't understand why you installed a release candidate rather than the full release one https://www.duet3d.com/forum/thread.php?id=3817
                          T-Printer
                          Just to try is, because the full release do the same on and off. Now I an´m back to the full release.
                          From Pronterface:
                          SENDING:M111 S1 P14
                          WiFi: bcn_timout,ap_probe_send_start
                          WiFi: ap_probe_send over, rest wifi status to disassoc
                          WiFi: state: 5 -> 0 (1)
                          WiFi: rm 0
                          WiFi: pm close 7
                          WiFi: scandone
                          WiFi: state: 0 -> 2 (b0)
                          WiFi: state: 2 -> 3 (0)
                          WiFi: state: 3 -> 5 (10)
                          WiFi: add 0
                          WiFi: aid 6
                          WiFi: cnt
                          WiFi:
                          WiFi: connected with Nordbygaard, channel 7
                          WiFi: dhcp client start…
                          WiFi: pm open,type:2 0
                          WiFi: sl
                          WiFi: scandone
                          WiFi: usl
                          WiFi: rm 0
                          WiFi: pm close 7
                          WiFi: del if0
                          WiFi: usl
                          WiFi: mode : null
                          To connect aging, I have to power off / on.
                          • stripsundefined
                            strips
                            On RC4 now and so far so good! Running through levelling and calibration routines because of a rebuild.
                            • o_lampeundefined
                              o_lampe
                              Maybe a bit late to claim an issue with RC4 now that it is officially released.
                              I have some G1 or G0 moves in the end code of the slicer to park the effector at X0 Y0 Z160.
                              These moves get misinterpreted by DWC and it always shows layer count 799. Thereby the estimated print duration based on
                              layer time x #layers is totally wrong too.
                              I tried G0 and G1 moves, both with same result.
                              If DWC would check for moves which include an extrusion, it would detect the last relevant layer.
                              Sorry, if that has been posted earlier, I'm not a regular visitor here…
                                That's a well-known issue. The solution is put a comment starting with ;E or ; E at the end of the G0 or G1 command line that does that movement.
