    Endstops not stopping external drivers on the expansion header
    4.0k
    • mhallettundefined
      mhallett
      I an using the expansion header running hybrid servo drives, the movements are fine all the endstops report back fine with the m119 command. Problem is they dont stop any of the motors when they are triped. All the endstops work correctly when I was using the duex 5 with the onboard drivers.
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Sep 02 2017 15:26:26 GMT-0400 (Eastern Daylight Time)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      G90 ; Send absolute coordinates…
      M555 P2 ; Set firmware compatibility to look like Marlin
      M911 S12.0:19.5:22.0 // auto-pause at 19,5V, then either stop at 12V or auto-resume at 22V
      M667 S1 ; Select CoreXY mode
      M208 X700 Y700 Z800 S0 ; Set axis maxima
      M574 X2 Y2 Z2 S1 ; Define active high microswitches
      M558 P1 X0 y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P500 x46 y0 Z1.27; Set Z probe trigger value, offset and trigger height
      m569 p5 s1 r1 ; Drive 5 goes forwards
      m569 p6 s1 r1 ; Drive 6 goes forwards
      m569 p7 s1 r1 ; Drive 7 goes forwards
      m569 p8 s1 r1 ; Drive 8 goes forwards
      m569 p9 s1 r1 ; Drive 9 goes forwards
      m584 x5 y6 z7:8:9 E3:4
      M350 E16:16 I0 ; Configure microstepping without interpolation
      M92 X160 Y160 Z800 E476.5:476.5; Set steps per mm
      M566 X1600 Y1600 Z200 E120:120 ; Set maximum instantaneous speed changes (mm/min)
      M203 X15000 Y15000 Z3000 E1200:1200 ; Set maximum speeds (mm/min)
      M201 X800 Y800 Z150:150:150 E5000:5000 ; Set accelerations (mm/s^2)
      M906 X2000 Y2000 Z2000 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S300 ; Set maximum heater temperature to 300C
      M301 H0 S1.00 P1088.5 I1.567 D1486.6 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M305 P2 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 2
      Heater 0 model: gain 58.4, time constant 694.7, dead time 2.0, max PWM 1.00, mode: PID
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M550 PMJ 30 ; Set machine name
      M552 S1 ; Enable network
      ; Access point is configured manually via M587 by the user
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M584 maps axes to drivers. It does not map endstops. So you should use the X, Y and Z endstop inputs on the Duet.
        • mhallettundefined
          mhallett
          @dc42:
          I am using them but they are not stopping the movement. it seems as if it is not sending the signal to the appropriate drive. It will work if i disconnect the expansion board and plug a stepper into the integrated chip.
          • mhallettundefined
            mhallett
            So if the endstops wont stop movement to external drivers via the breakout board can you open the endstops up for mapping in the firmware? Or do you have any other suggestions for what is happening? otherwise I have a 5k printer that is useless. The drives are hss57 hybrid servo drives. 3z 1x 1y.
            • mhallettundefined
              mhallett
              I have started with a blank sd card and re did all the files from scratch and still the end stops don't work with the external drives. I tried firmware 1.19.2 and now have 1.20RC4 neither worked. If I plug a standard stepper into the integrated driver it stops when the endstop is triggered. but it will not stop any of the drives on the breakout. does the breakout not support STOP? I am using the ethernet but I have a WIFI laying around and also a DUEX5 but not sure how to run 5 external drivers from them. It is just frustrating because everything moves just as it should it just wont stop… I cleaned up the config file when I wrote the new one with some of the suggestions I found in the other forum posts. It just seems like the end stop is not communicating to the breakout board. Is there a way to test this? I have included the new config file. I have not set final size, thermocouples, fans, and all that stuff yet but that should not matter. All the movement; and end stop info is correct. I did see a rather rude guy posting on here about the same issue but he uploaded new firmware and that solved his problem or so he said ( not quite sure if he was truly all there, if you know what I mean).
              Configuration file for Duet Ethernet (firmware version 1.20 or newer)
              M911 S22 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
              M208 X670 Y720 Z750 S0 ; Set axis maxima
              M574 X1 Y2 Z2 S1 ; Set active high endstops
              M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
              M557 X15:655 Y15:705 S20 ; Define mesh grid
              M569 P3 S0 ; Drive 3 goes backwards
              M569 P5 S1 R1 T4 ; Drive 5 goes forwards
              M569 P6 S1 R1 T4 ; Drive 6 goes forwards
              M569 P7 S1 R1 T4 ; Drive 7 goes forwards
              M569 P8 S1 R1 T4 ; Drive 8 goes forwards
              M569 P9 S1 R1 T4 ; Drive 9 goes forwards
              M584 X5 Y6 Z7:8:9 E3:4 ; Apply custom drive mapping
              M350 X16 Y16 Z16:16:16 I0 ; Configure microstepping without interpolation
              M350 E16:16 I1 ; Configure microstepping with interpolation
              M92 X160 Y160 Z800:800:800 E476.5:476.5 ; Set steps per mm
              M566 X1600 Y1600900 Z50:50:50 E120:120 ; Set maximum instantaneous speed changes (mm/min)
              M203 X15000 Y15000 Z750:750:750 E1200:1200 ; Set maximum speeds (mm/min)
              M201 X700 Y700 Z75:75:75 E250:250 ; Set accelerations (mm/s^2)
              M906 X2000 Y2000 Z2000:2000:2000 E800:800 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
              M305 P1 T100000 B4138 C0 R4700 X101 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 101
              M143 H1 S400 ; Set temperature limit for heater 1 to 400C
              M305 P2 T100000 B4138 C0 R4700 X102 ; Set thermistor + ADC parameters for heater 2 and remap it to channel 102
              M143 H2 S400 ; Set temperature limit for heater 2 to 400C
              ;*** Networking - Enable for both WiFi and Ethernet boards.
              M552 S1 ; Turn network on
              ;*** Ethernet networking: Adjust the IP address and gateway in the following 2 lines to suit your network
              M552 P0.0.0.0 ; (0 = DHCP)
              M554 P192.168.1.255 ; Gateway
              M553 P255.255.255.0 ; Netmask
              M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
              ; Custom settings are not configured, endstops, and probe info is correct.
                I am puzzled by your report. The endstops work independently of whether you are using internal or external drivers, so there should be no difference between the two.
                The first step in debugging endstop issues is to test the endstops and their configuration. Go to the Settings -> Machine Properties page or Duet Web Control. In the "Endstop hit" column, the first, second and third rows show the state of the X, Y and Z endstops. Ignore the fact that column to the left says "Drive", because the "Endstop hit" column is unrelated to drives. Check that the X, Y and Z endstop states displayed there follow the state of the switches themselves.
                • mhallettundefined
                  mhallett
                  They all register fine, 0,1,2 all say no and when triped they say yes. X,Y,Z all still move even when it says yes in that column.
                  • whosrdaddyundefined
                    whosrdaddy
                    @mhallett:
                    sure why not? It is only when you home that they will serve…
                    • mhallettundefined
                      mhallett
                      So you are saying the only time an endstop works is when you are executing a home command?
                        whosrdaddy
                        @mhallett:
                        Yes
                        • mhallettundefined
                          mhallett
                          Ok i will write all the home files and give it a shot, thank you.
                          • Dougal1957undefined
                            Dougal1957
                            yes the firmware will take hard limits coded into the config.g to take care of the print limits once homed
                            • mhallettundefined
                              mhallett
                              No dice I ended up with two broken sendstops LOL. As i said earlier if I plug a standard stepper into the the integrated stepper drivers it functions just fine. It is just the expansion that is is not communicating with. Everything move is the correct direction to home just does not trigger the external drives to stop. I am going to swap the Ethernet board with a Wifi I have laying around and see what happens. maybe there is a short in the 50 pin connector. I am going to use the same sd card so everything is equal. Will see what happens.
                              • mhallettundefined
                                mhallett
                                Problem solved!!!!!! not sure what is wrong with the ethernet board but wifi works beautifully.Guess I will just hang on to the ethernet board for my sons delta that will use the integrated drivers. Thanks guys for all the help….
                                • ect2undefined
                                  ect2
                                  So is it just a faulty board or other people have similar problems with endstops when using expansion breakout board?
                                  • mhallettundefined
                                    mhallett
                                    I am guessing just a faulty expansion header. The rest of the board operates just fine but the 50 pin plug has something going on with it. Usually the problem is the endstop or the wiring so I was going nuts trying to figure out what was going on. This has been my first real issue that was not of my doing and I have built 4 printers all with duet electronics.
                                    • mhallettundefined
                                      mhallett
                                      Is there anywhere I can send this Ethernet board to have it repaired?
                                        Bear in mind that when you map axis drivers using M584, that does not map endstops. You must still use the XYZ endstop inputs on the Duet.
                                        • mhallettundefined
                                          mhallett
                                          It was, I know it is a board issue. I swapped to my wifi board that I was saving for a different printer and it works fine. The only thing I changed was the board, I even swapped the sdcard so it was running identical settings and firmware. I don't want a free repair I will gladly pay to have it done, but just don't know of anyone qualified to send it to.
                                            I don't see how it can be a hardware problem. Please can you try the latest release (1.20.1RC2) and if that has the same problem, share your config.g and homing files.
