    Duet2 wifi stuck repeating Wifi Error.
    2.9k
      droftarts administrators @zBeeble
      @zBeeble I've passed the info on to @rechrtb who does the ESP side of things, hopefully he'll get a chance to look at it and come back with any suggestions. Have you turned off FTP?
      • rechrtbundefined
        rechrtb @zBeeble
        @zBeeble Hello, I have some questions:
        "DWC is unavailable (port is just closed)"
        When you said , did the browser only keep spinning when trying to load DWC, or was there a more definite error message?
        I was unable to get all that together.
        Did you mean trying to get M122 failed as well, or were you only not able to attempt to do a M122 prior to reboot?
        My Duet2 Wifi occasionally sticks repeating
        Do you have some notion on how often this repeats? Does it happen when printing, or when the printer has a high uptime? What's the signal level like on the printer normally, is it far from the AP? Are there multiple DWC instances open from multiple devices?
        rechrtbundefined zBeebleundefined 2 Replies Last reply Reply Quote 0
        • rechrtbundefined
          rechrtb @rechrtb
          @zBeeble , also are you able and willing to load a special build of the WiFi firmware with more debug output on the printer? This can help us tremendously in diagnosing the problem if you can.
          If you are, the other thing is also to turn on wifi and network debug outputs using M111 P14 S1 and M111 P1 S1, and having the printer continuously connected to a computer, monitoring the serial output , until the issue happens again . And then once it does happen, we have more logs to go by.
          • rechrtbundefined
            rechrtb @rechrtb
            @OwenD @danzaywer you previously reported this issue on other threads mentioned by @droftarts , are you still encountering this issue?
            If yes, are you also able to do https://forum.duet3d.com/post/339484?
            zBeebleundefined OwenDundefined 2 Replies Last reply Reply Quote 0
            • zBeebleundefined
              zBeeble @rechrtb
              @rechrtb said in Duet2 wifi stuck repeating Wifi Error.:
              I'm a network guy (most familiar with the FreeBSD IP stack). I didn't try telnetting to it, but the browser response was that of the port being closed before the page was being delivered. I'm relatively sure it's delivering no data, but I didn't check that for sure. I am sure it's closing the port.
              I didn't have time to sort out a usb/serial cable.
              From a large view ... it's been happening about once a week. It may have happened before the 3.5.0 beta -> 3.5.1 update, but not before then. At a more granular view, previously, it errored a few times and then was back online. This constant error until restart is new ... it's happened twice. The errors happen so quickly that I cannot usefully cancel them on the printer display.
              rechrtbundefined 1 Reply Last reply Reply Quote 0
              • zBeebleundefined
                zBeeble @rechrtb
                I'm certainly willing. I'll try to find a cable. Do I just need an A to mini-A?
                • zBeebleundefined
                  zBeeble @rechrtb
                  @rechrtb urnh? That seems to point to this forum post.
                    @zBeeble The link @rechrtb posted was asking the other users that had reported this problem to look at his previous post.
                    Can you get an M122 report? I want to check what version of DuetWiFiServer you are using.
                    Yes, just make sure it's power AND data, some aren't. SendM111 P14 S1 and M111 P1 S1 at startup, and you'll need to connect to the Duet using a serial monitor (eg YAT) and leave it connected and running.
                    • OwenDundefined
                      OwenD @rechrtb
                      @rechrtb
                      I was randomly having that issue, but haven't seen it for a while.
                      I turned off telnet , but still have ftp running.
                      DWC was unresponsive when it happened, but I could connect via usb.
                      zBeebleundefined rechrtbundefined 2 Replies Last reply Reply Quote 0
                      • zBeebleundefined
                        zBeeble @OwenD
                        @OwenD How do you turn telnet and/or ftp on/off?
                        OwenDundefined 1 Reply Last reply Reply Quote 0
                        • rechrtbundefined
                          rechrtb @zBeeble
                          @zBeeble Great! Here is the custom WiFi module firmware. To confirm you have this, M122 should say Firmware version 2.1.0d.
                          DuetWiFiServer.bin
                          Also, I would suggest logging the terminal outputs to a file (some terminal software have this feature). This is because some terminals have a line/character liimit - and this might be a long term log gathering. If you mention the terminal software you are going to use, we can maybe advise you on how to turn on logging to file.
                          • rechrtbundefined
                            rechrtb @OwenD
                            @OwenD Are you currently on 1.27 or 2.x wifi firmware?
                            • zBeebleundefined
                              zBeeble @rechrtb
                              @rechrtb I was just going to jack it into one of the FreeBSD boxes here ... so any unix/linux software. I'm lazy enough to use CU for most things, but there are a few term programs.
                              • zBeebleundefined
                                zBeeble @rechrtb
                                • zBeebleundefined
                                  zBeeble @rechrtb
                                  @rechrtb BTW... I'm familliar with uploading a .zip to the printer to update it ... i usually choose the everything.zip. How do I update the one file?
                                  • zBeebleundefined
                                    zBeeble
                                    Here is the M122 reply:
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later
                                    Board ID: 08DDM-9FAM2-LW4SD-6J9F8-3SN6J-T3ZRY
                                    Used output buffers: 10 of 26 (26 max)
                                    Static ram: 23256
                                    Dynamic ram: 72952 of which 12 recycled
                                    Never used RAM 13588, free system stack 112 words
                                    Tasks: NETWORK(2,nWait 6,284.1%,179) HEAT(3,nWait 5,7.2%,303) Move(4,nWait 5,239.6%,298) MAIN(1,running,141.2%,700) IDLE(0,ready,3.8%,29), total 675.9%
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 48:48:00 ago, cause: power up
                                    Last software reset at 2024-04-23 19:06, reason: StuckInSpinLoop, Gcodes spinning, available RAM 14084, slot 2
                                    Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x200026e0 Task NETW Freestk 4294966911 ok
                                    Stack: 2000b2b4 ffffffff ffffffff 00000000 20005a28 0045ae97 0045da54 01070000 0045d8b3 20002764 00000005 20008d10 0045ae97 2000b2b0 0043e1a3 a5a5a5a5 2000b2b4 00000000 20002774 00000101 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 27.4, current 37.4, max 39.5
                                    Supply voltage: min 11.0, current 12.0, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
                                    Heap OK, handles allocated/used 99/5, heap memory allocated/used/recyclable 2048/1736/1600, gc cycles 2
                                    Events: 0 queued, 0 completed
                                    Driver 0: ok, SG min 0
                                    Driver 1: ok, SG min 0
                                    Driver 2: ok, SG min 0
                                    Driver 3: ok, SG min 0
                                    Driver 4: standstill, SG min n/a
                                    Driver 5:
                                    Driver 6:
                                    Driver 7:
                                    Driver 8:
                                    Driver 9:
                                    Driver 10:
                                    Driver 11:
                                    Date/time: 2024-05-21 00:39:36
                                    Slowest loop: 811.39ms; fastest: 0.15ms
                                    === Storage ===
                                    Free file entries: 9
                                    SD card longest read time 9.2ms, write time 72.2ms, max retries 0
                                    DMs created 83, segments created 20, maxWait 29694948ms, bed compensation in use: mesh, height map offset -0.003, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                                    next step interrupt due in 23 ticks, disabled
                                    Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                                    === DDARing 0 ===
                                    Scheduled moves 129868, completed 129828, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 34], CDDA state 3
                                    Heater 0 is on, I-accum = 0.3
                                    Heater 1 is on, I-accum = 0.3
                                    Movement locks held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is doing "G1 X82.087 Y92.177 E0.0121" in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Q0 segments left 1
                                    Code queue 0 is empty
                                    === Filament sensors ===
                                    check 442843913 clear 210991400
                                    Extruder 0 sensor: ok
                                    === Network ===
                                    Slowest loop: 789.19ms; fastest: 0.00ms
                                    Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                    HTTP sessions: 2 of 8
                                    === WiFi ===
                                    Interface state: active
                                    Module is connected to access point
                                    Failed messages: pending 0, notrdy 0, noresp 0
                                    MAC address 60:01:94:73:54:4c
                                    Module reset reason: Turned on by main processor, Vcc 3.42, flash size 4194304, free heap 41012
                                    WiFi IP address 192.168.221.183
                                    Signal strength -40dBm, channel 6, mode 802.11n, reconnections 0
                                    Clock register 00002002
                                    2024-05-20, 9:48:27 p.m. 	File 0:/gcodes/CFFFP_Bullywug Updated.gcode selected for printing```
                                    • zBeebleundefined
                                      zBeeble
                                      oh-and... which usb do I connect?
                                      • rechrtbundefined
                                        rechrtb @zBeeble
                                        @zBeeble The instructions for updating WiFi firmware only is at: https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#updating-wifi-firmware
                                        Regarding the M122 output you posted, this is before you attempt to upgrade the WiFi firmware right?
                                        After you upgrade, towards the end of the logs, it should read: Firmware version 2.1.0d (note the additional d ).
                                        As for the "which USB" question, I'm not sure I know what you meant by this question. Can you clarify?
                                        • zBeebleundefined
                                          zBeeble @rechrtb
                                          @rechrtb I thought there was more than one USB on the board. My bad.
                                          ... but I don't think anyone has told me how to update only the wifi binary.
                                            Phaedrux Moderator @zBeeble
                                            @zBeeble said in Duet2 wifi stuck repeating Wifi Error.:
