    Unknown Pin Name
    269
    • Proschi3Dundefined
      Proschi3D
      Hello, since I connected a Toolboard and a Tool Distribution Board, I’ve been getting an error message about an unknown pin name ‘io5.in.’ This pin corresponds to the filament sensor of the extruder with the Toolboard. Additionally, the Neopixel LED is no longer functioning. The printer is an iDEX printer, and I’ve previously equipped one extruder with the Toolboard. The firmware version is 3.5.1
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
        Proschi3D @Proschi3D
        @Proschi78
        RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode)
        Board ID: L0Z2A-S096U-D65J0-40KMU-MY03Z-RMV8H
        Used output buffers: 12 of 40 (33 max)
        Error in macro line 49 while starting up: Unknown pin name 'io5.in'
        Static ram: 103232
        Dynamic ram: 124560 of which 0 recycled
        Never used RAM 10768, free system stack 198 words
        Tasks: NETWORK(2,nWait 7,24.3%,204) HEAT(3,nWait 6,0.0%,342) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,799) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,1.4%,102) MAIN(1,running,72.7%,665) IDLE(0,ready,0.6%,30) AIN(4,delaying,0.9%,260), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:01:01 ago, cause: power up
        Last software reset at 2024-05-26 14:38, reason: User, Gcodes spinning, available RAM 7600, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x00
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 62609, completed 62609, timed out 0, errs 0
        MCU temperature: min 12.2, current 20.6, max 20.8
        Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/152/96, gc cycles 0
        Events: 0 queued, 0 completed
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5582, writes 15, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5582, writes 15, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5581, writes 15, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5581, writes 15, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 15, reads 5582, writes 15, timeouts 0, DMA errors 0, CC errors 0
        Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 5587, writes 10, timeouts 0, DMA errors 0, CC errors 0
        Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 10, reads 5586, writes 10, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2024-05-27 07:22:46
        Cache data hit count 111491868
        Slowest loop: 19.92ms; fastest: 0.17ms
        === Storage ===
        Free file entries: 20
        SD card longest read time 6.3ms, write time 0.0ms, max retries 0
        DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
        === DDARing 0 ===
        === DDARing 1 ===
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon is idle in state(s) 0
        Aux2 is idle in state(s) 0
        File2 is idle in state(s) 0
        Queue2 is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x0000000
        Code queue 0 is empty
        Code queue 1 is empty
        === Filament sensors ===
        check 0 clear 202598
        Extruder 0 sensor: ok
        === CAN ===
        Messages queued 582, received 2165, lost 0, errs 0, boc 0
        Longest wait 2ms for reply type 6048, peak Tx sync delay 6, free buffers 26 (min 25), ts 310/309/0
        Tx timeouts 0,0,0,0,0,0
        === Network ===
        Slowest loop: 13.12ms; fastest: 0.00ms
        Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
        HTTP sessions: 2 of 8
        === WiFi ===
        Interface state: active
        Module is connected to access point
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1.0
        MAC address f0:08:d1:03:80:5e
        Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 40188
        WiFi IP address 192.168.178.91
        Signal strength -32dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002001
        27.5.2024, 07:22:48	M122
        Static ram: 103232
        Error status: 0x00
        Aux0 errors 0,0,0
        === Storage ===
        === DDARing 0 ===
        === DDARing 1 ===
        === CAN ===
        === Network ===
        === WiFi ===
          ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
          ; General preferences_____________________________________________________________________________________________
          M575 P1 S1 B57600                                         ; enable support for PanelDue
          G90                                                       ; send absolute coordinates...
          M83                                                       ; ...but relative extruder moves
          M550 P"Proschi 3D E2"                                        ; set printer name
          M552 S1                                                   ; enable network
          M586 P0 S1                                                ; enable HTTP
          M586 P1 S1                                                ; disable FTP
          M586 P2 S0                                              ; enable Telnet
          G4 S5
          ; Drives___________________________________________________________________________________________________________
          M569 P0.4 S0 D3 H50 V30                                          ; physical drive 0.0 goes forwards
          M915 P0.4 T50
          M569 P0.1 S1 D3 H45 V35                                           ; Y Achse physical drive 0.1 goes forwards
          M915 P0.1 T50
          M569 P0.2 S0 D3 H50 V30                                           ; physical drive 0.2 goes forwards
          M915 P0.2 T50
          M569 P0.3 S1 D3 H50 V30                                          ; physical drive 0.3 goes forwards
          M915 P0.3 T50
          M569 P0.0 S0 D3 H50 V30                                           ; physical drive 0.4 goes forwards
          M915 P0.0 T50
          M569 P11.0 S1                                           ; physical drive 0.5 goes forwards
          ;M569 P25.0 S0 D3 H50 V30                    ; physical drive 0.5 goes forwards
          M584 X0.4 Y0.1 Z0.2 E3:11.0 U0                   ; set drive mapping
          M350 X16 Y16 U16 Z16 E16:16 I1                     ; configure microstepping without interpolation
          M92 X80 Y160 U80 Z800 E286.216 :286.216             ; set steps per mm
          M566 X480 Y480 U480 Z30 E300:300                   ; set maximum instantaneous speed changes (mm/min)
          M203 X9000 U9000 U9000 Y7200 Z650  E3000:3000             ; set maximum speeds (mm/min)
          M201 X1000 U1000 Y1000 Z100 0 E3000:3000            ; set accelerations (mm/s^2)
          M906 X1200 U1200 Y1400 Z900 E800:800 I30            ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          ; Axis Limits_________________________________________________________________________________________________________________
          M208 X10 Y-3 Z-0.3 U35 S1                                         ; set axis minima
          M208 X335 Y255 Z240 U355 S0                                    ; set axis maxima
          ; Endstops____________________________________________________________________________________________________________________
          M574 Y1 S1 P"io1.in"
          M574 X1 S1 P"io2.in"
          M574 U2 S1 P"Io4.in"
          ;M574 Z1 S1 P"!Io6.in"      ; Auto Z offset
          ;M915 X S-63 H10 R1 ; Set very sensitive stall detect
          ;M574 X1 S3 ; configure endstop for stall detection
          ;M915 X S20 H140 R0 ; Set very sensitive stall detect
          ; Filament Sensoren___________________________________________________________________________________________________________
          M591 D1 P1 C"Io5.in"  S1
          M591 D0 P1 C"spi.cs2" S1
          ; Z-Probe_____________________________________________________________________________________________________________________
          M558 K0 P8 C"io3.in" H5 S0.008 F200 T6000           ; set Z probe type to unmodulated and the dive height + speeds
          G31 K0 P500 X10 Y30  ;0.55 Simplify set Z probe trigger value, offset and trigger height
          ;BL Touch________________________________________________________________________________________________________________________
          M950 K1 S0 C"25.io1.out"
          M558 K1 C"25.io1.in" P9 H5 F200 T18000 B0 A4 S0.005 R0.4			; disable Z probe but set dive height, probe speed and travel speed
          G31 K1 P500 X15 Y-5.50 Z4.25
          ;M557 X30:330 Y50:200 P14                             ; define mesh grid
          ;G31 P500 X10 Y30									; BLTouch X and Y offset
          M557 X{move.axes[0].min + sensors.probes[0].offsets[0] + 1, move.axes[0].max + sensors.probes[0].offsets[0] - 1} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 0, move.axes[1].max + sensors.probes[0].offsets[1] - 75} P15:10
          ; The M557 is used to define the mesh grid area. It uses the P parameter to set the amount of probing points. P10:10 would be a 10x10 grid. Supports up to a 21x21 grid.
          M98 P"config_probe.g"										; Load the Z-offset from the config_probe.g file
          ; The Z_offset value is now set in config_probe.g, not in config.g
          ; Adjust the values there, do not adjust anything here.
          ; Heaters_______________________________________________________________________________________________________________________
          M308 S0 P"Temp0" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
          M307 H0 B1 S1.00                                          ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                                   ; map heated bed to heater 0
          M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
          M308 S1 P"11.Temp0" Y"thermistor" T100000 B4725 C7.06e-8    ; configure sensor 1 as thermistor on pin temp1
          M950 H1 C"out1" T2                                       ; create nozzle heater output on out1 and map it to sensor 1
          M307 H1 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S340                                              ; set temperature limit for heater 1 to 340C
          M308 S2 P"Temp2" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 2 as thermistor on pin temp2
          M950 H2 C"11.out0" T1                                        ; create nozzle heater output on out2 and map it to sensor 2
          M307 H2 B0 S1.00                                          ; disable bang-bang mode for heater  and set PWM limit
          M143 H2 S340                                              ; set temperature limit for heater 2 to 340C
          M308 S3 P"25.temp0" Y"thermistor" A"Gehäuse" T100000 B4138           ; configure sensor 1 as thermistor on pin temp1
          ; Temp Sensoren_________________________________________________________________________________________________________________________
          M308 S10 Y"mcu-temp" A"MCU" ; defines sensor 10 as MCU temperature sensor
          ;M308 S11 Y"drivers" A"Duet stepper drivers" ; defines sensor 11 as stepper driver temperature sensor
          M308 S8 Y"mcu-temp" P"25.dummy" A"Can MCU"
          ;M308 S9 Y"drivers" P"25.dummy" A"Can Stepper"
          ; Fans___________________________________________________________________________________________________________________________________
          M950 F1 C"25.vfd" Q500                                      ; create fan 0 on pin out4 and set its frequency
          M106 P1 C"Links" S0 H-1
          M950 F0 C"11.out1" Q500                                      ; create fan 0 on pin out4 and set its frequency
          M106 P0 C"Rechts" S0 H-1
          M950 F7 C"11.out2" Q500                               ; create fan 0 on pin out3 and set its frequency
          M106 P7 C"Hotend Fan rechts" S1 H1 T45                        ; set fan 0 name and value. Thermostatic control turned on for Hotend
          ;M950 F5 C"out6" Q500
          ;M106 P5 C"Board" S0 H-1
          M950 F2 C"out3" Q500                                    ; create fan 0 on pin out4 and set its frequency
          M106 P2 C"Filter Lüfter" S0 H-1 Q25000                                        ; set fan 0 value. Thermostatic control is turned off
          M950 F3 C"out5" Q500                                      ; create fan 2 on pin vfd and set its frequency
          M106 P3 C"LED" S150 H-1                                            ; set fan 2 value. Thermostatic control is turned off
          M950 F4 C"out4+out4.tach" Q25000
          M106 P4 C"Aktiv Kühlung" S0 H-1
          M950 F5 C"25.out5" Q100
          M106 P5 C"Board Kühler"   ;Die Lüftersteuerung ist in Deamon.g festgelegt            ; Create a tool that uses the low end (X) carriage
          M950 F6 C"25.out4+out4.tach" Q100
          M106 P6 C"CanBoard"
          ;Acclerometer
          M955 P11.0 I24                ; configure accelerometer on toolboard with CAN address 121 and specify orientation
          M593 F80 S0.2  P"zvddd"
          ;LED__________________________________________________________________________________________________________________________________
          M950 E0 C"led" T2
          ;Switch_______________________________________________________________________________________________________________________________
          M950 J1 C"25.io6.in"
          M581 P1 S0 T5 R0	; T5 only while processing gcode
          M581 P1 S1 T6 R0
          ;Tools________________________________________________________________________________________________________________________________
          M563 P0 D0 H1 F1  S"linker Extruder"           ; tool 0 uses extruder 0, heater 1 and fan 0
          G10 P0 X0 Y0 Z-0.1 S0 R0       ; set tool 0 offsets and temperatures
          ; Create a tool that uses the high end (U) carriage
          M563 P1 D1 H2 X3 F0  S"rechter Extruder"        ; tool 1 uses extruder 1, heater 2, fan 2, and maps X to U
          G10 P1 Y1 U27,6 Z-0.3 R0       ; set tool 1 offsets and temperatures
          ; Create a tool that prints 2 copies of the object using both carriages
          M563 P2 D0:1 H1:2 X0:3 F0:0 S"Duplicate"; tool 2 uses both extruders, hot end heaters and fans, and maps X to both X and U
          G10 P2 X-25 Y0 U-176.3 Z0.0 S0 R0 ; set tool offsets and temperatures
          G10 P2 R0 S0
          M567 P2 E1:1 ; set mix ratio 100% on both extruders
          ;Create a tool that Prints in Mirrior Mode
          M563 P3 S"Mirror" H1:2 D0:1 X0:3 F0:0
          G10 P3 X165 Y0 U-165 Z0 S0 R0
          G10 P3 R0 S-2
          ;Temperatur anpassung MCU
          M912 P0 S2
          ; Miscellaneous_________________________________________________________________________________________________________________________________
          M501                                                      ; load saved parameters from non-volatile memory
          ;M911 S10 R11 P"M913 X0 U0 Y0 G91 M83 G1 Z3 E-5 F1000"        ; set voltage thresholds and actions to run on power loss
          ;Global Variables_______________________________________________________________________________________________________________________________
          M98 P"GlobaleBuildplate.g"
          ;LED Neopixel___________________________________________________________________________________________________________________________________
          • oliofundefined
            oliof
            I see that you wrote "Io5.in" and not "io5.in" ... check whether changing that to lower case helps. Also, I believe that filament sensors need to attached to the board of the extruder to work correctly.
              Proschi3D @oliof
              @oliof It makes no difference whether "io5.in" or "Io5.in".
              If it were the case that they only worked on the toolboard, it would be a shame, since they are installed on my housing and right next to the Duet 3 mini. It also seems a bit suspicious to me that this is the case.
              • oliofundefined
                oliof @Proschi3D
                @Proschi78 it's documented here https://docs.duet3d.com/en/User_manual/RepRapFirmware/CAN_limitations#permanent-limitations
                Last paragraph:
                Filament monitors must be connected to the same board as the corresponding extruder motor. This use so that the firmware can correlate the measured filament movement and the commanded extruder movement in real time.
                oliofundefined 1 Reply Last reply Reply Quote 1
                • oliofundefined
                  oliof @oliof
                  @oliof /cc @droftarts for the broken grammar in that sentence
                    Proschi3D @oliof
                    @oliof
                    I just tested it, it actually is.
                    is there a way to get around this? but what about the Neopixel Led?
                    • oliofundefined
                      oliof @Proschi3D
                      @Proschi78 No idea about the LED, config seems to be missing from the config.g. Either way, there was a bug in 3.5.x about enabling the first LED in a strip caused by the compiler optimizing away stuff that'll be fixed in the upcoming 3.5.2
                        Proschi3D @oliof
                        @oliof It would also be possible to define the filament sensors as switches and then query them with the active extruder, right?
                        • oliofundefined
                          oliof @Proschi3D
                          @Proschi78 you mean a switch as a trigger that sends a pause when it's not activated by the filament? Possibly, maybe, but with no guarantee that it will trigger quickly; which may be sufficient for your use case.
                            Proschi3D @oliof
                            @oliof Exactly. I will try to create a macro like this. I still have about 250mm of filament after the sensor, that should be enough
