    Warning: Driver 0.3 warning: phase A/B may be disconnected
    300
    • Jeronimo88undefined
      Jeronimo88
      Like the titles is mentioning; im getting warning errors for my extruder driver.
      Sinds 2-3 days. Its also really killing my prints because some times it stops extruding...
      So i find a finished print but not completed.
      Ive traces the wiring, and even just for the sake of it, made a new wire and put it outside my printer for testing purposes.
      (that was after i paused the print @ 14;46 today. And you can see i got 2 times B back after resuming.) It does still extrude
      but it annoys me.
      I don't have a spare driver anymore, but perhaps im going to switch that out and remodel my config for it.
      Specs:
      Ender 5 plus with Duet3d 3 mini 5+ LAN
      E3D Hemera 24v DD extruder
      Paneldeu 7i.
      FYI. I also have sometimes a Memorycard fault that im looking, regarding not enough space.
      26-5-2024 17:29:15	Finished printing file 0:/gcodes/MountingPlate_PETG_2h3m.gcode, print time was 2h 24m
      26-5-2024 17:21:28	Warning: Driver 0.3 warning: phase A may be disconnected
      26-5-2024 17:01:30	Warning: Driver 0.3 warning: phase A may be disconnected
      26-5-2024 16:56:08	Warning: Driver 0.3 warning: phase A may be disconnected, phase B may be disconnected
      26-5-2024 16:36:53	Warning: Driver 0.3 warning: phase B may be disconnected
      26-5-2024 16:17:12	Warning: Driver 0.3 warning: phase B may be disconnected
      26-5-2024 16:12:09	Printing resumed
      26-5-2024 15:46:38	Printing paused at X186.3 Y210.0 Z3.5
      26-5-2024 15:46:33	Resume state saved
      26-5-2024 15:45:28	Warning: Driver 0.3 warning: phase A may be disconnected
      26-5-2024 15:27:49	Warning: Driver 0.3 warning: phase A may be disconnected
      26-5-2024 15:20:55	Warning: Driver 0.3 warning: phase B may be disconnected
      26-5-2024 14:52:40	Warning: Driver 0.3 warning: phase A may be disconnected
      26-5-2024 14:47:02	=== Diagnostics ===
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3 (2024-01-24 17:56:48) running on Duet 3 Mini5plus Ethernet (standalone mode)
      Board ID: 5QZRJ-6F6M2-G65J0-409FD-3Q81Z-72HAQ
      Used output buffers: 10 of 40 (40 max)
      Static ram: 103200
      Dynamic ram: 115480 of which 12 recycled
      Never used RAM 18980, free system stack 126 words
      Tasks: NETWORK(1,ready,27.5%,173) ETHERNET(5,nWait 7,0.2%,570) HEAT(3,nWait 6,0.0%,332) Move(4,nWait 6,0.4%,244) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,335) TMC(4,nWait 6,0.8%,68) MAIN(1,running,70.2%,649) IDLE(0,ready,0.1%,30) AIN(4,delaying,0.8%,260), total 100.0%
      Owned mutexes:
      Last reset 00:26:37 ago, cause: power up
      Last software reset at 2024-05-25 03:36, reason: User, Gcodes spinning, available RAM 18484, slot 0
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,1,0
      MCU revision 0, ADC conversions started 1598383, completed 1598381, timed out 0, errs 0
      MCU temperature: min 25.3, current 45.5, max 45.5
      Supply voltage: min 23.9, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/108/80, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 18518, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 18518, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 18517, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 18521, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 18518, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2024-05-26 14:47:01
      Cache data hit count 2594616740
      Slowest loop: 265.41ms; fastest: 0.10ms
      === Storage ===
      Free file entries: 18
      SD card longest read time 5.0ms, write time 10.4ms, max retries 0
      DMs created 83, segments created 37, maxWait 910275ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, ebfmin -1.00, ebfmax 1.00
      next step interrupt due in 320 ticks, enabled
      Moves shaped first try 237, on retry 12, too short 146, wrong shape 2506, maybepossible 1
      === DDARing 0 ===
      Scheduled moves 3181, completed 3173, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 3], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.5
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0, sync state 1
      Queue2 is idle in state(s) 0
      Q0 segments left 3, axes/extruders owned 0x0000807
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 14380, received 0, lost 0, errs 7612244, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 7990/0/0
      Tx timeouts 0,0,7989,0,0,6389 last cancelled message type 4514 dest 127
      === Network ===
      Slowest loop: 228.32ms; fastest: 0.03ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      = Ethernet =
      Interface state: active
      Error counts: 0 0 0 0 0 0
      26-5-2024 14:41:03	Leadscrew adjustments made: 0.002 0.004, points used 2, (mean, deviation) before (0.003, 0.001) after (-0.000, 0.000)
      26-5-2024 14:40:52	Leadscrew adjustments made: 0.066 0.105, points used 2, (mean, deviation) before (0.085, 0.014) after (0.000, 0.000)
      26-5-2024 14:39:39	File 0:/gcodes/MountingPlate_PETG_2h3m.gcode selected for printing
      26-5-2024 14:28:38	SD card in slot 0: capacity 7.95GB, partition size 0.26GB, free space 0.17GB, speed 22.50MBytes/sec, cluster size 512 bytes
      Config:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.5)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Wed Dec 13 2023 21:57:46 GMT+0100 (Midden-Europese standaardtijd)
      M575 P1 S1 B57600                                     ; enable support for PanelDue
      G90                                                   ; send absolute coordinates...
      M83                                                   ; ...but relative extruder moves
      M550 P"Ender 5 Plus"                                  ; set printer name
      M552 P192.168.178.96 S1                               ; enable network and set IP address
      M553 P255.255.255.0                                   ; set netmask
      M554 P192.168.178.1                                   ; set gateway
      M586 P0 S1                                            ; enable HTTP
      M586 P1 S0                                            ; disable FTP
      M586 P2 S0                                            ; disable Telnet
      M569 P0.0 S0                                          ; physical drive 0.0 goes backwards
      M569 P0.1 S0                                          ; physical drive 0.1 goes backwards
      M569 P0.2 S0                                          ; physical drive 0.2 goes backwards (Z Axis Left)
      M569 P0.3 S0                                          ; physical drive 0.3 goes backwards
      M569 P0.4 S0                                          ; physical drive 0.4 goes backwards (Z Axis Right)
      M584 X0.0 Y0.1 Z0.2:0.4 E0.3                    	  ; set drive mapping
      M350 X16 Y16 Z16 E16 I1		             	          ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z800.00 E394.26       		      ; set steps per mm
      M566 X1200.00 Y1200.00 Z60.00 E3000.00 	         	  ; set maximum instantaneous speed changes (mm/min)(was X900.00 Y900.00 Z60.00(600) E120.00)
      M203 X5000.00 Y5000.00 Z180.00 E5000.00	     		  ; set maximum speeds (mm/min)(was X6000.00 Y6000.00 Z180.00 E1200.00)
      M201 X1500.00 Y1500.00 Z20.00 E5000.00   	  		  ; set accelerations (mm/s^2)(was X500.00 Y500.00 Z20.00(80) E500.00)
      M906 X800 Y800 Z800 E800 I30 	                  	  ; set motor currents (mA) and motor idle factor in per cent(was X800 Y800 Z800 E800 I30)
      M84 S30                                               ; Set idle timeout
      M208 X0 Y0 Z0 S1                                      ; set axis minima
      M208 X350 Y335 Z400 S0                                ; set axis maxima
      M574 X2 S1 P"!io5.in"                                 ; configure switch-type (e.g. microswitch) endstop for high end on X via pin !io5.in
      M574 Y2 S1 P"!io6.in"                                 ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !io6.in
      M574 Z1 S2                                            ; configure Z-probe endstop for low end on Z
      M950 S0 C"io3.out"                                    ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H2 F120 T6000                       ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X-33 Y-5 Z3.786                              ; set Z probe trigger value, offset and trigger height
      M557 X25:315 Y40:310 S19.3:18                         ; define mesh grid
      ; Bed adjustment screw locations
      M671 X-33:383 Y166:166 S8            				  ;Z pivot points are at Left(-33,166) and Right(383,166)
      M308 S0 P"temp0" Y"thermistor" T98801 B4185           ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                    ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                      ; Disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                               ; map heated bed to heater 0
      M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                                    ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 B0 S1.00 									  ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S285                                          ; set temperature limit for heater 1 to 285C
      ; Extruder Fan
      M950 F1 C"out3" Q500 	            	              ; create fan 1 on pin out3 and set its frequency
      M106 P1 C"Extruder" S1 H1 T60		                  ; set fan 1 name and value. Thermostatic control is turned on
      ; Part Fan
      M950 F0 C"out4" Q100                          		  ; create fan 0 on pin out4 and set its frequency
      M106 P0 C"Part" S0 H-1                      		  ; set fan 0 name and value. Thermostatic control is turned off
      M563 P0 D0 H1 F0                 	                  ; define tool 0
      G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
      G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
      ; Input Shaping accelerometer
      ;M955 P0 C"spi.cs2+spi.cs1" I14      				  ; Oriantation 14(+X to -X) all wires connected to temp DB connector, no temperature daughterboard
      M593 P"ZVDDD" F54 S0.15                               ; use ZVDDD input shaping to cancel ringing at 54Hz with a damping factor of 0.15 with 2 moves
      M501                                                  ; load saved parameters from non-volatile memory
        A few things.
        1. your SD card is full. It's likely that you're using the card that came with the Duet which has two partitions on it. One is for using with a Rpi and the other for the Duet, but this restricts the usable size for either. I suggest you backup the contents of your SD card, and reformat it as a single large partition and put the files back, or better yet, save this SD card as a backup and replace it with a larger capacity 32gb card and copy the contents over.
        2. update your firmware. 3.5.1 final release is available now. Release candidates are no longer supported.
        Solve those two things and see if the issue still remains. If so, I would suspect a crimp issue. The error message and the symptoms both indicate that the extruder motor is losing contact with the driver.
        Jeronimo88undefined 2 Replies Last reply Reply Quote 2
          Jeronimo88 @Phaedrux
          @Phaedrux
          Thanks (again) for the reply. I have updated the firmware. And backup-ed and format my 8gb SDcard.
          It up and running and i will test it tomorrow again.
          If something is faulty hardware side, i think its the driver or the motor. I already made a new cabel to rule out the bad krimping.
            @Phaedrux
            Unfortunately its still there.. And also after only the update - back up and format SD card i have some laying down first layer problems i need to address. And it looks like some extrusion problems with printing but not sure yet.
            Connection interrupted it also a new one.
            Have to look in to it,
            30-5-2024 22:52:37	Connection established
            30-5-2024 22:52:37	Connection interrupted, attempting to reconnect...
            Operation failed (Reason: Service Unavailable)
            30-5-2024 22:52:32	Warning: Driver 0.3 warning: phase A may be disconnected
            30-5-2024 22:50:12	Warning: Driver 0.3 warning: phase B may be disconnected
            30-5-2024 22:27:07	Connection established
            30-5-2024 22:27:07	Connection interrupted, attempting to reconnect...
            30-5-2024 22:27:04	Connection established
            30-5-2024 22:27:04	Connection interrupted, attempting to reconnect...
            30-5-2024 22:26:58	Warning: Driver 0.3 warning: phase B may be disconnected
            30-5-2024 22:07:30	Warning: Driver 0.3 warning: phase B may be disconnected
            30-5-2024 22:06:51	Connection established
            30-5-2024 22:06:51	Connection interrupted, attempting to reconnect...
            30-5-2024 22:06:46	Warning: Driver 0.3 warning: phase B may be disconnected
            30-5-2024 22:03:42	Warning: Driver 0.3 warning: phase B may be disconnected
            30-5-2024 21:14:47	Warning: Driver 0.3 warning: phase A may be disconnected
              The driver may be damaged. Have you tried a different driver assignment?
              Jeronimo88undefined 1 Reply Last reply Reply Quote 1
                @Phaedrux
                Well i switched 0.3 with 0.4. (extruder was 0.3 and now 0.4, one of the z motors is now on 0.3)
                (can you double check old vs new if i did it correctly?)
                So am i right to conclude there is something wrong with the steppenmotor of my E3D Hemera? @Phaedrux
                2-6-2024, 10:16:12	Warning: Driver 0.4 warning: phase B may be disconnected
                2-6-2024, 09:59:06	Leadscrew adjustments made: -0.003 0.011, points used 2, (mean, deviation) before (0.004, 0.005) after (0.000, 0.000)
                2-6-2024, 09:58:55	Leadscrew adjustments made: 0.115 0.070, points used 2, (mean, deviation) before (0.093, 0.016) after (0.000, 0.000)
                2-6-2024, 09:58:08	File 0:/gcodes/corner_brace_3m_bolts_PETG_44m55s.gcode selected for printing
                New
                M569 P0.3 S0                                          ; physical drive 0.4 goes backwards (Z Axis Right)
                M569 P0.4 S0                                          ; physical drive 0.3
                M584 X0.0 Y0.1 Z0.2:0.3 E0.4                    	  ; set drive mapping
                Old
                extra information:
                2-6-2024, 21:10:48	Finished printing file 0:/gcodes/blank_carriage_PETG_5h26m.gcode, print time was 6h 14m
                2-6-2024, 20:51:29	Warning: Driver 0.4 warning: phase A may be disconnected, phase B may be disconnected
                2-6-2024, 20:20:03	Warning: Driver 0.4 warning: phase A may be disconnected
                2-6-2024, 19:48:10	Warning: Driver 0.4 warning: phase B may be disconnected
                2-6-2024, 19:46:37	Warning: Driver 0.4 warning: phase B may be disconnected
                2-6-2024, 19:44:45	Warning: Driver 0.4 warning: phase A may be disconnected
                2-6-2024, 19:38:50	Warning: Driver 0.4 warning: phase A may be disconnected
                2-6-2024, 19:29:59	m122
                RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus Ethernet (standalone mode)
                Used output buffers: 8 of 40 (40 max)
                Static ram: 103232
                Dynamic ram: 116100 of which 12 recycled
                Never used RAM 18112, free system stack 122 words
                Tasks: NETWORK(1,ready,76.0%,180) ETHERNET(5,nWait 7,0.2%,567) HEAT(3,nWait 1,0.2%,326) Move(4,nWait 6,6.2%,237) CanReceiv(6,nWait 1,0.0%,940) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,2.6%,68) MAIN(1,running,12.2%,665) IDLE(0,ready,0.0%,30) AIN(4,delaying,2.7%,260), total 100.0%
                Owned mutexes:
                Last reset 04:39:09 ago, cause: power up
                Last software reset at 2024-06-02 10:55, reason: User, Gcodes spinning, available RAM 18184, slot 1
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                Error status: 0x04
                Aux0 errors 0,1,0
                MCU revision 0, ADC conversions started 16749063, completed 16749063, timed out 0, errs 0
                MCU temperature: min 24.8, current 47.6, max 47.9
                Supply voltage: min 23.6, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/3, heap memory allocated/used/recyclable 2048/176/56, gc cycles 0
                Events: 14 queued, 14 completed
                Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 29302, writes 14, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 29301, writes 14, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 29301, writes 14, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 29301, writes 14, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 29304, writes 12, timeouts 0, DMA errors 0, CC errors 0
                Date/time: 2024-06-02 15:47:29
                Slowest loop: 225.69ms; fastest: 0.13ms
                === Storage ===
                Free file entries: 19
                SD card longest read time 4.9ms, write time 79.8ms, max retries 0
                DMs created 83, segments created 46, maxWait 339966ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                next step interrupt due in 174 ticks, enabled
                Moves shaped first try 36396, on retry 2560, too short 106922, wrong shape 35365, maybepossible 5431
                === DDARing 0 ===
                Scheduled moves 194886, completed 194876, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === DDARing 1 ===
                File is doing "G1 X108.786 Y129.904 E1.61464" in state(s) 0
                Q0 segments left 1, axes/extruders owned 0x0000807
                === CAN ===
                Messages queued 150740, received 0, lost 0, errs 79636997, boc 0
                Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 83746/0/0
                Tx timeouts 0,0,83745,0,0,66993 last cancelled message type 30 dest 127
                === Network ===
                Slowest loop: 80.64ms; fastest: 0.03ms
                HTTP sessions: 1 of 8
                = Ethernet =
                  Phaedrux Moderator @Jeronimo88
                  @Jeronimo88 said in Warning: Driver 0.3 warning: phase A/B may be disconnected:
                  So you switched the motor and wiring to driver 0.4 and the problem followed the motor? In that case it's either the wiring itself or the motors wiring internally.
                    @Phaedrux Indeed, and im on my second set of wiring and its still giving me errors on the extruder.
                    I will check if i can find a replacement motor for my E3D Hemera, perhaps ill mount the XS motor if its fits.
                    What does seems "funny" that the errors don't screw up my prints.. So is there something i can "tweak" that its perhaps a bit less sensitive?
                    But i also get a lot of connection errors? Wondering if they are connected? I already did some searching and put my AJAX from 3 to 5. And when its done printing i will also update my Paneldue 7i to latest firmware.
                    See a small section of the errors now below, and thanks for coming back every time. Much appreciated.
                    3-6-2024 18:39:04	Connection established
                    3-6-2024 18:38:58	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:55	Connection established
                    3-6-2024 18:38:55	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:52	Connection established
                    3-6-2024 18:38:52	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:49	Connection established
                    3-6-2024 18:38:49	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:46	Connection established
                    3-6-2024 18:38:45	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:42	Connection established
                    3-6-2024 18:38:42	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:39	Connection established
                    3-6-2024 18:38:39	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:36	Connection established
                    3-6-2024 18:38:36	Connection interrupted, attempting to reconnect...
                    3-6-2024 18:38:31	Warning: Driver 0.4 warning: phase A may be disconnected
                    3-6-2024 18:38:31	Warning: Driver 0.4 warning: phase A may be disconnected, phase B may be disconnected
                    3-6-2024 18:37:01	Warning: Driver 0.4 warning: phase A may be disconnected
                    3-6-2024 18:01:10	Warning: Driver 0.4 warning: phase A may be disconnected
                    3-6-2024 17:38:38	Warning: Driver 0.4 warning: phase A may be disconnected
                    3-6-2024 16:56:41	Leadscrew adjustments made: 0.003 0.019, points used 2, (mean, deviation) before (0.011, 0.006) after (-0.000, 0.000)
                    3-6-2024 16:56:29	Leadscrew adjustments made: 0.099 0.062, points used 2, (mean, deviation) before (0.081, 0.013) after (-0.000, 0.000)
                    3-6-2024 16:54:56	File 0:/gcodes/Rear_left_lower_PETG_6h10m.gcode selected for printing
                      Do you have logging enabled? The increased activity can sometimes have unintended consequences.
                      Do you have a fresh SD card to test with? A failing SD card can cause seemingly random issues as well.
                      Jeronimo88undefined 1 Reply Last reply Reply Quote 0
                        @Phaedrux Ill will look for another SD, probably will find one.
                        ~~I cant seem to find the log, or the option in the manual for DWC?
                        Any pointers to find out/activate it?~~
                        I find something, ill look into it after my print is done with printing.
                        It was in the GCode dictionary
                        EDIT 2
                        Can i just add this to the end of my GCode? @Phaedrux
                        M929 P"eventlog.txt" S1                               ; start logging warnings to file eventlog.txt
                        M929 P"eventlog.txt" S2                               ; start logging Info to file eventlog.txt
                        M929 P"eventlog.txt" S3                               ; start logging DEBUG to file eventlog.txt
                          I wasn't suggesting you enable logging, just asking if it was already in use. I don't think you're going to get anything useful out of it in this case.
                            @Phaedrux
                            Ah, i see/read what you ment. But then the answer is no, i have not enabled logging.
                            Do you know something about my question i asked earlier?
                            "So is there something i can "tweak" so that it perhaps is a bit less sensitive?" and maybe doesn't give the errors? Because
                            its not affecting my prints. (As far i can tell).
                              You can ignore it, but you can't prevent the warnings. Something is wrong with the connections to the motor coils, maybe intermittent.
                              Can you try with a temporary motor replacement just to determine if it's the motor itself or not? You don't need to run an actual print, just connect a motor and do a dry run.
                              If the motor is failing and it's from E3D you may be able to get a replacement from them.
