Duet 3 mini5+ nightly restarts 3.5.2
@droftarts
The board in the printer seems to be stable now after almost 24h since the last reset. (According to M122). I have the feeling that the problem occurs more often when the printer is printing. I will leave it now how it is and wait for the next reset. Nest test will be a print without filament to get a better understanding whether it happens sooner if the printer is working or not. Let me know if you think that this does not make sense from your point of view.I can replace the board in the printer with my bench board if we see that the board on the bench is stable. If we agree that this makes sense. And let me know if you want me to parcel the board to you guys.
I have two more printers with a mini5+ in similar setups, one with 2 toolboards, one without one. None of them have 3.5.1, I can update one of them and test with them too if we think that this will bring us forward.
Cheers, Chriss
Hi @droftarts
Update: Both boards did not reboot after 90 and 80 hours of uptime.
I replaced the SD card od my bench board today to get rid od some strange problems with the the DWC (saving of files failed).The real printer will get a print job now without any filament to understand whether the printer failed more often when it is printing.
Cheers, Chriss
@Chriss I've had your config running on mine all weekend with axes homed, and it hasn't skipped a beat either. Can't run a print, it'll break my machine! I'm going to revert to my regular config.g, and with your results, I'm going to assume it doesn't happen when idle.
Yes and no Ian, I saw the issue when the printer was not printing over night. And I saw that issue more than than once in 48 hours, all without printing. That is the reason for my confusion that it did not happen in the last 90 hours. And we should not forget that my printer and ProteanReveries printer has a other "board" conencted via CAN but my bench board not.
Anyway, I used SuperSlicer to generate new g-code with an object which is about 155mm high, that should produce the error. The only change is that I lowered the temperatures a lot and have no filament in the extruder. I do not want to waist more plastic.
Let's hope that we see the problem again. The bench board will lay here for some more days with the fresh SD card, so the counter is at 0h for now. I will keep you updated.
Cheers, Chriss
@Chriss I have a 1LC CAN board on the Mini 5+ I was testing on.
@droftarts
It is mega strange, remember that I spoke about the 2nd failed print which made me thinking about going back to a older release? I used this SLT today again and it completed successfully toady. I restarted the print with the same gcode. The uptime of the printer is 126h now.
OK, the bed is off and the hotend is at 80°C, but this should not make any difference. Electrostatic discharge came in my mind but that should not be the problem because I did see the incident when the printer was not moving at all (over night)I'm a bit helpless to be honest.
@ProteanReverie : Did you see the problem again in the last 5-6 days?
Cheers, Chriss
@droftarts I'm constantly printing the same since 2-3 days and had no reboot since the last planed reboot. :?
I think that I will do more tests during the weekend, this time with filament. Maybe somehow related to the heaters....Cheers, Chriss
I had not seen any restarts since the last time I reported on June 3rd, until last night. I did briefly power down the board earlier this week to move some things around, so it was not permanent uptime but close. Here is my latest data.
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: 65LYX-8Q6KL-K65J0-409N0-NP02Z-ZFK3T Used output buffers: 1 of 40 (26 max) === RTOS === Static ram: 103232 Dynamic ram: 119916 of which 24 recycled Never used RAM 15388, free system stack 143 words Tasks: NETWORK(1,ready,526.0%,218) HEAT(3,nWait 6,0.4%,372) Move(4,nWait 6,0.1%,355) CanReceiv(6,nWait 1,0.6%,808) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.3%,348) TMC(4,nWait 6,31.4%,102) MAIN(1,running,127.6%,677) IDLE(0,ready,0.3%,30) AIN(4,delaying,33.0%,260), total 719.6% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 09:47:57 ago, cause: software Last software reset at 2024-06-14 00:45, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 15164, slot 1 Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011ff0 Task NETW Freestk 483 ok Stack: 00000160 00000002 200014e8 0000015f ffffffff 000a07ef 0002ff8e 810f0000 0002ff85 00000000 00000000 00000000 200305e4 00000800 2002c5c8 2002c5c8 00000001 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 00000000 Error status: 0x00 MCU revision 3, ADC conversions started 35277450, completed 35277448, timed out 0, errs 0 MCU temperature: min 38.5, current 40.8, max 41.0 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 21659, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 21659, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 21658, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 21658, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 21658, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c Driver 5: not present Driver 6: not present Date/time: 2024-06-14 10:33:11 Cache data hit count 4294967295 Slowest loop: 10.17ms; fastest: 0.16ms === Storage === Free file entries: 19 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.2ms, write time 2.6ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 176386, received 282222, lost 0, errs 1, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 318, free buffers 26 (min 26), ts 176386/176385/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 10.13ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:d0 Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 42764 WiFi IP address 10.1.10.46 Signal strength -59dBm, channel 1, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 Log file snippet around the time of the issue. Starts at the end of an M122 I ran yesterday morning, ends at the start of the M122 that is part of this post.
2024-06-13 09:41:40 [debug] Socket states: 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] 0 2024-06-13 09:41:40 [debug] ok power up + 00:00:00 [info] Event logging started at level debug power up + 00:00:00 [info] Running: Duet 3 Mini5plus WiFi: 3.5.1 (2024-04-19 14:41:25) power up + 00:00:00 [debug] Done! power up + 00:00:00 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:00 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point SD3D-24, IP address 10.1.10.46 power up + 00:00:08 [warn] HTTP client 10.1.10.9 login succeeded (session key 1488020678) 2024-06-14 00:45:23 [warn] Date and time set at power up + 00:00:08 2024-06-14 10:32:57 [warn] HTTP client 10.1.10.9 disconnected 2024-06-14 10:33:01 [warn] HTTP client 10.1.10.9 login succeeded (session key 4151032817) 2024-06-14 10:33:11 [debug] === Diagnostics === -
Hello!
I am experiencing the same problem with my Duet 3 Mini 5+ Wi-Fi board. After weeks of unsuccessful prints, I see on the forum that I am not the only one with the same issue.
I have two printers with Duet 3 Mini 5+ boards, and on Friday I started a two-day print on both printers. The older board completed the print without any problems. The second one, however, reset itself three times, and this morning I restarted it, expecting it to happen again. At least, I hope so, as I can then provide you with some data or log files from the second board.
If you need any information from board 2 or both boards to compare them, please let me know.
Thank you, Alex
@Aleksander-Cane please post what version of RRF you’re using on both boards. Send M122 and post the response for each board, which will also show the reason for the last restart.
Were they both running the same Gcode? Do they have toolboards or any other non-standard extras? Please post config.g too.
Hi Ian,
I am using the boards for 3D printers in standalone mode and they are not connected to any non-standard boards. Below, I have provided the requested information for both boards.
The machines were not running the same Gcode. However, I have never encountered this problem with Duet Printer 1, while I am continuously experiencing it with Duet Printer 2.
If it can be helpful, several times after the board (Duet Printer 2) restarted, the layer cooling fan remained on, the motors were disabled, and one of the three Z-axis drivers was not working when I requested the Z-axis homing. To restart them, I had to reboot the printer.If you need any additional information/actions, please let me know.
M122
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.6 (2023-07-21 14:09:13) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: R5GU7-D296U-D65J0-40KMJ-L903Z-7T0FN Used output buffers: 1 of 40 (28 max) === RTOS === Static ram: 103712 Dynamic ram: 110476 of which 36 recycled Never used RAM 27488, free system stack 192 words Tasks: NETWORK(notifyWait,57.7%,250) HEAT(notifyWait,0.1%,340) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,941) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.1%,342) TMC(notifyWait,4.8%,115) MAIN(running,33.9%,425) IDLE(ready,0.0%,30) AIN(delaying,3.4%,263), total 100.0% Owned mutexes: === Platform === Last reset 07:02:37 ago, cause: software Last software reset at 2024-06-17 08:06, reason: User, GCodes spinning, available RAM 23240, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 25357202, completed 25357201, timed out 0, errs 0 Step timer max interval 1487 MCU temperature: min 32.5, current 33.2, max 34.7 Supply voltage: min 24.2, current 24.3, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 2, read errors 0, write errors 0, ifcnt 40, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 44, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 44, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 44552, writes 0, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6f Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 46, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 44553, writes 0, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-06-17 15:08:57 Cache data hit count 4294967295 Slowest loop: 6.44ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.4ms, write time 0.0ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: no data received === CAN === Messages queued 205540, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 114189/0/0 Tx timeouts 0,0,114189,0,0,91351 last cancelled message type 30 dest 127 === Network === Slowest loop: 100.72ms; fastest: 0.06ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Interface state: active Module is connected to access point Failed messages: pending 0, notready 0, noresp 2 WiFi firmware version 1.26 WiFi MAC address f0:08:d1:03:80:e0 WiFi Vcc 3.44, reset reason Power up WiFi flash size 2097152, free heap 25208 WiFi IP address 172.16.1.10 WiFi signal strength -40dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 Config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"RatRig_1" ; set printer name M669 K1 ; CoreXY G21 ; Set Units to Millimeters ; Configurazione della connessione Wi-Fi M587 S"******" P"******" ; Salva il nome e la password della rete Wi-Fi M552 S1 ; Abilita la connessione Wi-Fi M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0.0 S1 ; physical drive 0.0 goes forwards M569 P0.1 S1 ; physical drive 0.1 goes forwards M569 P0.2 S1 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 ; set steps per mm M906 X1600 Y1600 Z1600 I30 ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+ M84 S30 ; Set idle timeout ; M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) ; M203 X10800.00 Y10800.00 Z1000.00 E5000.00 ; set maximum speeds (mm/min) ; M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) M566 X800.00 Y800.00 Z12.00 E240.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X24000.00 Y24000.00 Z3000.00 E15000.00 ; set maximum speeds (mm/min) M201 X9000.00 Y9000.00 Z300.00 E6000.00 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X475 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io3.in" ; configure active high endstops M574 Y2 S1 P"io1.in" ; configure active high endstops M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5 ; define positions of Z leadscrews or bed levelling screws M557 X20:280 Y20:280 P5 ; define 5x5 mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 Q11 ; create bed heater output on out5 and map it to sensor 0, lower switching frequency to 11Hz M307 H0 B0 S3.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C ;; Run Bed PID Tune!! Below is an example for a 300x300 bed ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; Fans ;M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency ;M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off ; 4-wire PWM fan and tacho M950 F0 C"!out4+out4.tach" ; Definisce la ventola 3 con controllo PWM su io4.out e tachimetro su io4.in M106 P0 C"Layer Fan" S0 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F1 C"out3" Q500 ; create fan 1 on pin out3 and set its frequency M106 P1 C"Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F2 C"out6" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 C"Electronics Fan" S1 H-1 ; set fan 2 name and value. Thermostatic control turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set the maximum temperature in C for heater ; EVA 2 / BMG / E3D V6 M92 E400 ; set extruder steps per mm, 0.9 angle/step (LGX BONDTECH) M906 E600 ; set extruder motor current (mA) and idle factor in per cent M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend" ;; Run Heater PID Tune!! M307 H1 R2.796 K1.398:0.000 D8.59 E1.35 S1.00 B0 V24.2 M570 H1 P30 T30 ; Imposta un tempo di tolleranza di 30 secondi (P30) e un tempo di monitoraggio di 30 minuti (T30) per Heater 1 ; Z-Probe ;; Inductive Probe ; M558 P5 C"!io3.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds ; G31 P500 X-30 Y-15 Z0.20 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ;; BLTouch M950 S0 C"io2.out" ; Create a servo pin on io2 M558 P9 C"io2.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds G31 P25 X-28.00 Y-13.00 Z3.8 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ; Select default tool T0 ; Pressure Advance M572 D0 S0.08 ; Panel Due 7i M575 P1 B57600 S1 ; Avvia communicazione seriale ; Sensore fillamento ;M591 D0.5 P7 C"io5.in" S1 F30:200 ; Dichiara pulse generating sensore di filamento M591 D0.5 P7 L6.5 E20 C"io5.in" S0 R1:99999 ; -
Duet Printer 2
M122
M122 === Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.4.0 (2022-03-15 18:59:15) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: D3XWJ-AN6KL-K65J0-409NL-JPW1Z-ZGHMG Used output buffers: 9 of 40 (40 max) === RTOS === Static ram: 103684 Dynamic ram: 110780 of which 24 recycled Never used RAM 23336, free system stack 118 words Tasks: NETWORK(ready,96.3%,202) HEAT(notifyWait,0.2%,338) Move(notifyWait,15.6%,267) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,356) CanClock(delaying,0.1%,337) TMC(notifyWait,9.3%,71) MAIN(running,120.7%,428) IDLE(ready,0.1%,29) AIN(delaying,6.3%,264), total 248.6% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 07:25:59 ago, cause: power up Last software reset at 2024-06-16 10:56, reason: User, GCodes spinning, available RAM 27008, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x04 Aux0 errors 0,0,0 MCU revision 3, ADC conversions started 26760958, completed 26760958, timed out 0, errs 0 Step timer max interval 912 MCU temperature: min 34.2, current 39.5, max 41.2 Supply voltage: min 23.6, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/26/0, gc cycles 0 Events: 1 queued, 1 completed Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7577, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7576, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7576, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7575, writes 11, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7577, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 5: ok, SG min 0, read errors 0, write errors 0, ifcnt 11, reads 7576, writes 11, timeouts 0, DMA errors 0, CC errors 0 Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 9, reads 7578, writes 9, timeouts 0, DMA errors 0, CC errors 0 Date/time: 2024-06-17 15:21:50 Cache data hit count 4294967295 Slowest loop: 60.25ms; fastest: 0.09ms === Storage === Free file entries: 9 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 2.1ms, write time 7.8ms, max retries 0 === Move === DMs created 83, segments created 43, maxWait 1393453ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 662178, completed 662138, hiccups 0, stepErrors 0, LaErrors 0, Underruns [136, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.7 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 X362.183 Y193.699 E1554.25171" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0: pos 80.86, errs: frame 33 parity 0 ovrun 0 pol 0 ovdue 0 === CAN === Messages queued 240831, received 0, lost 0, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 133796/0/0 Tx timeouts 0,0,133795,0,0,107034 last cancelled message type 30 dest 127 === Network === Slowest loop: 71.89ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.26 WiFi MAC address e8:68:e7:e1:50:99 WiFi Vcc 3.38, reset reason Power up WiFi flash size 2097152, free heap 25592 WiFi IP address 172.16.1.11 WiFi signal strength -49dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 config.g
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"RatRig_2" ; set printer name M669 K1 ; CoreXY G21 ; Set Units to Millimeters ; Configurazione della connessione Wi-Fi M587 S"*****" P"******" ; Salva il nome e la password della rete Wi-Fi M552 S1 ; Abilita la connessione Wi-Fi M586 P0 S1 ; enable HTTP M586 P1 S0 ; enable FTP M586 P2 S0 ; enable Telnet ; Drives M569 P0.0 S0 ; physical drive 0.0 goes forwards M569 P0.1 S0 ; physical drive 0.1 goes forwards M569 P0.2 S0 ; physical drive 0.2 goes forwards M569 P0.3 S1 ; physical drive 0.3 goes forwards M569 P0.4 S1 ; physical drive 0.4 goes forwards M569 P0.5 S1 ; physical drive 0.5 goes forwards M584 X0.4 Y0.3 Z0.0:0.1:0.2 E0.5 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z800.00 ; set steps per mm M906 X1600 Y1600 Z1600 I30 ; set motor currents (mA) and motor idle factor in per cent -- safe for Duet 3 mini 5+ M84 S30 ; Set idle timeout ; M566 X400.00 Y400.00 Z6.00 E120.00 P1 ; set maximum instantaneous speed changes (mm/min) ; M203 X10800.00 Y10800.00 Z1000.00 E5000.00 ; set maximum speeds (mm/min) ; M201 X3000.00 Y3000.00 Z100.00 E3600.00 ; set accelerations (mm/s^2) M566 X800.00 Y800.00 Z12.00 E240.00 P1 ; set maximum instantaneous speed changes (mm/min) M203 X24000.00 Y24000.00 Z3000.00 E15000.00 ; set maximum speeds (mm/min) M201 X9000.00 Y9000.00 Z300.00 E6000.00 ; set accelerations (mm/s^2) ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X500 Y500 Z500 S0 ; set axis maxima ; Endstops M574 X1 S1 P"io3.in" ; configure active high endstops M574 Y2 S1 P"io1.in" ; configure active high endstops M671 X-4.5:150:304.5 Y-4.52:305:-4.52 S5 ; define positions of Z leadscrews or bed levelling screws M557 X20:280 Y20:280 P5 ; define 5x5 mesh grid ; Heaters M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"Bed" ; configure sensor 0 as thermistor on pin temp0 M950 H0 C"out0" T0 Q11 ; create bed heater output on out5 and map it to sensor 0, lower switching frequency to 11Hz M307 H0 B0 S3.00 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S110 ; set temperature limit for heater 0 to 110C ;; Run Bed PID Tune!! Below is an example for a 300x300 bed ;; M307 H0 A303.1 C356.7 D1.4 S1.00 V24.0 B0 ; Fans ;M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency ;M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off ; 4-wire PWM fan and tacho M950 F0 C"!out4+out4.tach" ; Definisce la ventola 3 con controllo PWM su io4.out e tachimetro su io4.in M106 P0 C"Layer Fan" S0 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F1 C"out3" Q500 ; create fan 1 on pin out3 and set its frequency M106 P1 C"Hotend Fan" S0 H1 T45 ; set fan 1 name and value. Thermostatic control turned on for Hotend M950 F2 C"out5" Q500 ; create fan 2 on pin out5 and set its frequency M106 P2 C"Electronics Fan" S1 H-1 ; set fan 2 name and value. Thermostatic control turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S300 ; set the maximum temperature in C for heater ; EVA 2 / BMG / E3D V6 M92 E400 ; set extruder steps per mm, 0.9 angle/step (LGX BONDTECH) M906 E600 ; set extruder motor current (mA) and idle factor in per cent M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.060000e-8 A"Hotend" ;; Run Heater PID Tune!! ;; M307 H1 A751.5 C196.6 D4.7 S1.00 V23.9 B0 ; Z-Probe ;; Inductive Probe ; M558 P5 C"!io3.in" H5 F400 T5000 ; set Z probe type to unmodulated and the dive height + speeds ; G31 P500 X-30 Y-15 Z0.20 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ;; BLTouch M950 S0 C"io2.out" ; Create a servo pin on io2 M558 P9 C"io2.in" H5 F240 T10800 A5 ; set Z probe type to unmodulated and the dive height + speeds G31 P25 X-28.00 Y-13.00 Z3.5 ; set Z probe trigger value, offset and trigger height, more Z means closer to the bed ; Select default tool T0 ; Pressure Advance M572 D0 S0.10 ; Panel Due 7i M575 P1 B57600 S1 ; Avvia communicazione seriale ; Sensore fillamento M591 D0.5 P3 C"io5.in" R0:99999 S0; E22.0; filament monitor connected to E0_stop M591 D0.5 ; display filament sensor parameters for extruder drive 0 -
@Aleksander-Cane i would suggest updating to 3.5.2 on both. you are running firmware that is not being discussed as part of this thread
@jay_s_uk
I will upgrade as soon as the printing is finished on Duet Printer 2 -
Another occurrence overnight last night.
M122
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: 65LYX-8Q6KL-K65J0-409N0-NP02Z-ZFK3T Used output buffers: 1 of 40 (26 max) === RTOS === Static ram: 103232 Dynamic ram: 119916 of which 24 recycled Never used RAM 15388, free system stack 150 words Tasks: NETWORK(1,ready,209.7%,196) HEAT(3,nWait 6,0.4%,372) Move(4,nWait 6,0.1%,355) CanReceiv(6,nWait 1,0.5%,808) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.3%,348) TMC(4,nWait 6,29.5%,102) MAIN(1,running,411.0%,677) IDLE(0,ready,0.3%,30) AIN(4,delaying,31.0%,260), total 682.9% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 09:48:56 ago, cause: software Last software reset at 2024-06-19 22:49, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 15364, slot 2 Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011ff0 Task NETW Freestk 483 ok Stack: 00000160 00000002 200014e8 0000015f ffffffff 000a07ef 0002ff8e 810f0000 0002ff85 00000000 00000000 00000000 20030dfc 00000800 2002c5c8 2002c5c8 00000004 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 00000000 Error status: 0x00 MCU revision 3, ADC conversions started 35336574, completed 35336574, timed out 0, errs 0 MCU temperature: min 38.1, current 39.8, max 40.4 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24771, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24771, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24770, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24770, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 24771, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-06-20 08:38:41 Cache data hit count 4294967295 Slowest loop: 606.35ms; fastest: 0.16ms === Storage === Free file entries: 19 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 2.1ms, write time 110.2ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 176682, received 282694, lost 0, errs 1, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 296, free buffers 26 (min 26), ts 176682/176681/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 302.72ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 41307, noresp 247 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:d0 Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 42228 WiFi IP address 10.1.10.46 Signal strength -57dBm, channel 11, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 4 0 4 4 0 0 0 0 Log data from all of yesterday and up till the above M122 query.
2024-06-19 09:01:12 [warn] HTTP client 10.1.10.9 login succeeded (session key 1729998681) 2024-06-19 09:01:38 [warn] HTTP client 10.1.10.9 login succeeded (session key 3562654751) 2024-06-19 09:01:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 224611796) 2024-06-19 09:02:33 [warn] HTTP client 10.1.10.9 login succeeded (session key 4179562653) 2024-06-19 09:03:20 [warn] HTTP client 10.1.10.9 login succeeded (session key 2552758708) 2024-06-19 09:03:41 [warn] HTTP client 10.1.10.9 login succeeded (session key 2600420170) 2024-06-19 09:03:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 1537291509) 2024-06-19 09:05:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 2699331822) 2024-06-19 09:06:03 [warn] HTTP client 10.1.10.9 login succeeded (session key 2564007033) 2024-06-19 09:07:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 3369922870) 2024-06-19 09:08:26 [warn] HTTP client 10.1.10.9 login succeeded (session key 1329585505) 2024-06-19 09:11:00 [warn] HTTP client 10.1.10.9 login succeeded (session key 3908567028) 2024-06-19 09:11:44 [warn] HTTP client 10.1.10.9 login succeeded (session key 3973151085) 2024-06-19 09:13:07 [warn] HTTP client 10.1.10.9 login succeeded (session key 3663609420) 2024-06-19 09:13:36 [warn] HTTP client 10.1.10.9 login succeeded (session key 3203760620) 2024-06-19 10:06:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 3770264939) 2024-06-19 10:08:04 [warn] HTTP client 10.1.10.9 login succeeded (session key 864774496) 2024-06-19 10:08:42 [warn] HTTP client 10.1.10.9 login succeeded (session key 3541419882) power up + 00:00:00 [info] Event logging started at level debug power up + 00:00:00 [info] Running: Duet 3 Mini5plus WiFi: 3.5.1 (2024-04-19 14:41:25) power up + 00:00:00 [debug] Done! power up + 00:00:00 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:00 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point SD3D-24, IP address 10.1.10.46 power up + 00:00:11 [warn] HTTP client 10.1.10.9 login succeeded (session key 2501685194) 2024-06-19 22:49:56 [warn] Date and time set at power up + 00:00:11 2024-06-19 23:05:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 3338192771) 2024-06-19 23:19:44 [warn] HTTP client 10.1.10.9 login succeeded (session key 995382963) 2024-06-19 23:23:41 [warn] HTTP client 10.1.10.9 login succeeded (session key 577045155) 2024-06-20 00:02:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 2819024432) 2024-06-20 00:03:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 1555340288) 2024-06-20 00:03:36 [warn] HTTP client 10.1.10.9 login succeeded (session key 1829290603) 2024-06-20 00:32:14 [warn] HTTP client 10.1.10.9 login succeeded (session key 135584297) 2024-06-20 00:32:16 [warn] HTTP client 10.1.10.9 login succeeded (session key 3569997682) 2024-06-20 00:32:36 [warn] HTTP client 10.1.10.9 login succeeded (session key 2193291301) 2024-06-20 00:32:57 [warn] HTTP client 10.1.10.9 login succeeded (session key 1877243154) 2024-06-20 00:33:18 [warn] HTTP client 10.1.10.9 login succeeded (session key 3649632143) 2024-06-20 00:33:29 [warn] HTTP client 10.1.10.9 login succeeded (session key 3785599525) 2024-06-20 00:33:41 [warn] HTTP client 10.1.10.9 login succeeded (session key 2111682295) 2024-06-20 00:34:03 [warn] HTTP client 10.1.10.9 login succeeded (session key 2523734364) 2024-06-20 00:34:26 [warn] HTTP client 10.1.10.9 login succeeded (session key 514956231) 2024-06-20 00:34:46 [warn] HTTP client 10.1.10.9 login succeeded (session key 1775476910) 2024-06-20 00:35:09 [warn] HTTP client 10.1.10.9 login succeeded (session key 3441070004) 2024-06-20 00:35:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 1713792156) 2024-06-20 00:35:57 [warn] HTTP client 10.1.10.9 login succeeded (session key 500570079) 2024-06-20 00:36:02 [warn] HTTP client 10.1.10.9 login succeeded (session key 2568201165) 2024-06-20 00:36:26 [warn] HTTP client 10.1.10.9 login succeeded (session key 1106806294) 2024-06-20 00:36:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 3038400876) 2024-06-20 00:37:20 [warn] HTTP client 10.1.10.9 login succeeded (session key 3915957228) 2024-06-20 00:37:47 [warn] HTTP client 10.1.10.9 login succeeded (session key 633926971) 2024-06-20 00:38:13 [warn] HTTP client 10.1.10.9 login succeeded (session key 356966781) 2024-06-20 00:38:42 [warn] HTTP client 10.1.10.9 login succeeded (session key 495343722) 2024-06-20 00:39:14 [warn] HTTP client 10.1.10.9 login succeeded (session key 3960934741) 2024-06-20 00:39:40 [warn] HTTP client 10.1.10.9 login succeeded (session key 3167420754) 2024-06-20 00:40:07 [warn] HTTP client 10.1.10.9 login succeeded (session key 849883161) 2024-06-20 00:40:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 637706513) 2024-06-20 00:40:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 942590317) 2024-06-20 01:12:43 [warn] HTTP client 10.1.10.9 login succeeded (session key 2862368256) 2024-06-20 01:40:58 [warn] HTTP client 10.1.10.9 login succeeded (session key 384322062) 2024-06-20 01:41:27 [warn] HTTP client 10.1.10.9 login succeeded (session key 1801224662) 2024-06-20 01:55:05 [warn] HTTP client 10.1.10.9 login succeeded (session key 2018069423) 2024-06-20 02:04:58 [warn] HTTP client 10.1.10.9 login succeeded (session key 800357292) 2024-06-20 02:05:23 [warn] HTTP client 10.1.10.9 login succeeded (session key 3587811362) 2024-06-20 02:05:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 1966587174) 2024-06-20 02:06:02 [warn] HTTP client 10.1.10.9 login succeeded (session key 975835003) 2024-06-20 02:06:14 [warn] HTTP client 10.1.10.9 login succeeded (session key 2429128476) 2024-06-20 02:11:39 [warn] HTTP client 10.1.10.9 login succeeded (session key 817814135) 2024-06-20 02:12:04 [warn] HTTP client 10.1.10.9 login succeeded (session key 2812448363) 2024-06-20 02:15:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 149586810) 2024-06-20 02:16:17 [warn] HTTP client 10.1.10.9 login succeeded (session key 2141131527) 2024-06-20 02:16:39 [warn] HTTP client 10.1.10.9 login succeeded (session key 3682049859) 2024-06-20 02:17:01 [warn] HTTP client 10.1.10.9 login succeeded (session key 2619402717) 2024-06-20 02:17:11 [warn] HTTP client 10.1.10.9 login succeeded (session key 2985926046) 2024-06-20 02:17:27 [warn] HTTP client 10.1.10.9 login succeeded (session key 803132847) 2024-06-20 02:17:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 3323915025) 2024-06-20 02:18:21 [warn] HTTP client 10.1.10.9 login succeeded (session key 2247458471) 2024-06-20 02:18:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 2536628431) 2024-06-20 02:19:10 [warn] HTTP client 10.1.10.9 login succeeded (session key 3060954282) 2024-06-20 02:19:37 [warn] HTTP client 10.1.10.9 login succeeded (session key 1737042006) 2024-06-20 02:20:08 [warn] HTTP client 10.1.10.9 login succeeded (session key 612654718) 2024-06-20 02:20:37 [warn] HTTP client 10.1.10.9 login succeeded (session key 1068865091) 2024-06-20 02:21:01 [warn] HTTP client 10.1.10.9 login succeeded (session key 771435670) 2024-06-20 02:21:24 [warn] HTTP client 10.1.10.9 login succeeded (session key 3928580257) 2024-06-20 02:24:50 [warn] HTTP client 10.1.10.9 login succeeded (session key 2386749170) 2024-06-20 02:25:14 [warn] HTTP client 10.1.10.9 login succeeded (session key 251546035) 2024-06-20 02:25:41 [warn] HTTP client 10.1.10.9 login succeeded (session key 3523239507) 2024-06-20 02:26:07 [warn] HTTP client 10.1.10.9 login succeeded (session key 3218200729) 2024-06-20 02:26:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 3720041818) 2024-06-20 02:27:01 [warn] HTTP client 10.1.10.9 login succeeded (session key 3716254985) 2024-06-20 02:27:32 [warn] HTTP client 10.1.10.9 login succeeded (session key 3899442431) 2024-06-20 02:27:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 2116079794) 2024-06-20 02:27:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 894565428) 2024-06-20 02:28:27 [warn] HTTP client 10.1.10.9 login succeeded (session key 1305853595) 2024-06-20 02:28:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 2151292634) 2024-06-20 02:29:19 [warn] HTTP client 10.1.10.9 login succeeded (session key 3350555338) 2024-06-20 02:29:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 3462100455) 2024-06-20 02:30:03 [warn] HTTP client 10.1.10.9 login succeeded (session key 4071707954) 2024-06-20 02:30:29 [warn] HTTP client 10.1.10.9 login succeeded (session key 50000306) 2024-06-20 02:30:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 1667854501) 2024-06-20 02:31:27 [warn] HTTP client 10.1.10.9 login succeeded (session key 2048630315) 2024-06-20 02:55:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 2439682909) 2024-06-20 03:02:04 [warn] HTTP client 10.1.10.9 login succeeded (session key 2978987675) 2024-06-20 03:04:28 [warn] HTTP client 10.1.10.9 login succeeded (session key 2758490383) 2024-06-20 03:04:50 [warn] HTTP client 10.1.10.9 login succeeded (session key 2437031831) 2024-06-20 03:05:20 [warn] HTTP client 10.1.10.9 login succeeded (session key 3913432380) 2024-06-20 03:05:47 [warn] HTTP client 10.1.10.9 login succeeded (session key 1213636342) 2024-06-20 03:56:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 4277151167) 2024-06-20 03:57:24 [warn] HTTP client 10.1.10.9 login succeeded (session key 1982808784) 2024-06-20 04:40:40 [warn] HTTP client 10.1.10.9 login succeeded (session key 128428737) 2024-06-20 04:42:53 [warn] HTTP client 10.1.10.9 login succeeded (session key 3218278673) 2024-06-20 04:43:05 [warn] HTTP client 10.1.10.9 login succeeded (session key 3065571460) 2024-06-20 04:43:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 1165941569) 2024-06-20 04:43:52 [warn] HTTP client 10.1.10.9 login succeeded (session key 3591443734) 2024-06-20 04:44:06 [warn] HTTP client 10.1.10.9 login succeeded (session key 1605038994) 2024-06-20 04:47:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 978053962) 2024-06-20 04:48:24 [warn] HTTP client 10.1.10.9 login succeeded (session key 3811958236) 2024-06-20 04:48:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 3390835297) 2024-06-20 04:49:21 [warn] HTTP client 10.1.10.9 login succeeded (session key 2588243843) 2024-06-20 04:49:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 4267056045) 2024-06-20 04:50:18 [warn] HTTP client 10.1.10.9 login succeeded (session key 923226743) 2024-06-20 04:50:31 [warn] HTTP client 10.1.10.9 login succeeded (session key 2771938442) 2024-06-20 04:50:59 [warn] HTTP client 10.1.10.9 login succeeded (session key 3787427531) 2024-06-20 04:51:25 [warn] HTTP client 10.1.10.9 login succeeded (session key 1763409621) 2024-06-20 04:51:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 1054323863) 2024-06-20 04:52:20 [warn] HTTP client 10.1.10.9 login succeeded (session key 2793445079) 2024-06-20 04:52:58 [warn] HTTP client 10.1.10.9 login succeeded (session key 449632642) 2024-06-20 04:53:26 [warn] HTTP client 10.1.10.9 login succeeded (session key 1251356753) 2024-06-20 04:53:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 3408456684) 2024-06-20 04:54:27 [warn] HTTP client 10.1.10.9 login succeeded (session key 479221908) 2024-06-20 04:54:48 [warn] HTTP client 10.1.10.9 login succeeded (session key 1290029679) 2024-06-20 04:55:01 [warn] HTTP client 10.1.10.9 login succeeded (session key 1074154654) 2024-06-20 04:55:11 [warn] HTTP client 10.1.10.9 login succeeded (session key 3453020502) 2024-06-20 04:55:25 [warn] HTTP client 10.1.10.9 login succeeded (session key 991458339) 2024-06-20 04:57:22 [warn] HTTP client 10.1.10.9 login succeeded (session key 3754189644) 2024-06-20 04:59:10 [warn] HTTP client 10.1.10.9 login succeeded (session key 680735117) 2024-06-20 06:56:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 3924206460) 2024-06-20 08:25:24 [warn] HTTP client 10.1.10.9 login succeeded (session key 3691413688) 2024-06-20 08:26:23 [warn] HTTP client 10.1.10.9 login succeeded (session key 3147903152) 2024-06-20 08:26:50 [warn] HTTP client 10.1.10.9 login succeeded (session key 944295359) 2024-06-20 08:38:41 [debug] === Diagnostics === 2024-06-20 08:38:41 [debug] RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode) 2024-06-20 08:38:41 [debug] Board ID: 65LYX-8Q6KL-K65J0-409N0-NP02Z-ZFK3T 2024-06-20 08:38:41 [debug] Used output buffers: 1 of 40 (26 max) -
@ProteanReverie @Chriss
@dc42 is away this week and next week, but I'll remind him of this issue when he's back. Please keep posting M122 and logging reports, I'm sure that the 'HardFault bfarValid precise' errors will help him track this painful bug down.Ian
@droftarts For sure... you will be the first who will get an update if that happens again. Btw: I did not changed my setting last weekend, I was to short in time. So my printer is still printing the same gcode over and over without any filament, nopt bed heater and a hotend at 80°C. I hope that I can change that this weekend.
Cheers, Chriss
Hi @droftarts
My printer is out of the printing pool for a while.... I have some mechanical issues with my belt.
And I do not have replacements on stock. I will be back at this topic if my bench board hast it and when my playground printer is fixed.
Cheers, Chriss
Another occurance over the weekend.
M122
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: 65LYX-8Q6KL-K65J0-409N0-NP02Z-ZFK3T Used output buffers: 14 of 40 (18 max) === RTOS === Static ram: 103232 Dynamic ram: 119916 of which 24 recycled Never used RAM 15388, free system stack 150 words Tasks: NETWORK(2,nWait 7,580.1%,218) HEAT(3,nWait 6,0.4%,372) Move(4,nWait 6,0.1%,355) CanReceiv(6,nWait 1,0.6%,808) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.3%,348) TMC(4,nWait 6,34.6%,102) MAIN(1,running,35.1%,677) IDLE(0,ready,0.3%,30) AIN(4,delaying,36.4%,260), total 688.1% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 11:24:14 ago, cause: software Last software reset at 2024-06-23 21:22, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 15364, slot 0 Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011ff0 Task NETW Freestk 483 ok Stack: 00000160 00000002 200014e8 0000015f ffffffff 000a07ef 0002ff8e 810f0000 0002ff85 00000000 00000000 00000000 2002fdcc 00000800 20035308 2002c5f8 200187fc 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 ffffffff Error status: 0x00 MCU revision 3, ADC conversions started 41054418, completed 41054418, timed out 0, errs 0 MCU temperature: min 38.2, current 39.6, max 41.0 Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 63568, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 63568, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 63568, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 63568, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 63568, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-06-24 08:46:40 Cache data hit count 4294967295 Slowest loop: 7.67ms; fastest: 0.16ms === Storage === Free file entries: 19 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 3.2ms, write time 3.8ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 205271, received 328436, lost 0, errs 1, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 390, free buffers 26 (min 26), ts 205271/205270/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 7.95ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:d0 Module reset reason: Power up, Vcc 3.42, flash size 2097152, free heap 29568 WiFi IP address 10.1.10.46 Signal strength -59dBm, channel 11, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 3 0 0 0 0 0 0 0 Relevant log file section
2024-06-21 20:23:42 [warn] HTTP client 10.1.10.9 login succeeded (session key 2318516549) 2024-06-22 12:46:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 2498040479) 2024-06-22 12:51:11 [warn] HTTP client 10.1.10.9 login succeeded (session key 2882910232) 2024-06-23 12:58:37 [warn] HTTP client 10.1.10.9 login succeeded (session key 2274061159) 2024-06-23 13:14:38 [warn] HTTP client 10.1.10.9 login succeeded (session key 4219374896) 2024-06-23 13:14:58 [warn] HTTP client 10.1.10.9 login succeeded (session key 1587684493) 2024-06-23 13:15:18 [warn] HTTP client 10.1.10.9 login succeeded (session key 871240276) 2024-06-23 18:32:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 640519980) 2024-06-23 20:18:14 [warn] HTTP client 10.1.10.9 login succeeded (session key 1301043269) 2024-06-23 20:19:52 [warn] HTTP client 10.1.10.9 login succeeded (session key 3916440988) 2024-06-23 20:20:20 [warn] HTTP client 10.1.10.9 login succeeded (session key 3232781641) 2024-06-23 20:20:40 [warn] HTTP client 10.1.10.9 login succeeded (session key 1725357550) 2024-06-23 20:20:56 [warn] HTTP client 10.1.10.9 login succeeded (session key 2497689280) power up + 00:00:00 [info] Event logging started at level debug power up + 00:00:00 [info] Running: Duet 3 Mini5plus WiFi: 3.5.1 (2024-04-19 14:41:25) power up + 00:00:00 [debug] Done! power up + 00:00:00 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:00 [warn] WiFi module started power up + 00:00:08 [warn] WiFi module is connected to access point SD3D-24, IP address 10.1.10.46 power up + 00:00:08 [warn] HTTP client 10.1.10.9 login succeeded (session key 3424165787) 2024-06-23 21:22:35 [warn] Date and time set at power up + 00:00:08 2024-06-23 21:54:45 [warn] HTTP client 10.1.10.9 login succeeded (session key 835669197) 2024-06-23 21:54:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 1712060142) 2024-06-23 21:55:04 [warn] HTTP client 10.1.10.9 login succeeded (session key 2620441938) 2024-06-23 21:55:12 [warn] HTTP client 10.1.10.9 login succeeded (session key 2547895376) 2024-06-23 21:55:35 [warn] HTTP client 10.1.10.9 login succeeded (session key 519733317) 2024-06-24 00:17:19 [warn] HTTP client 10.1.10.9 login succeeded (session key 1091016330) 2024-06-24 00:17:48 [warn] HTTP client 10.1.10.9 login succeeded (session key 598095062) 2024-06-24 00:18:08 [warn] HTTP client 10.1.10.9 login succeeded (session key 994352261) 2024-06-24 00:57:15 [warn] HTTP client 10.1.10.9 login succeeded (session key 852304322) 2024-06-24 04:59:31 [warn] HTTP client 10.1.10.9 login succeeded (session key 713145612) 2024-06-24 08:46:40 [debug] === Diagnostics === -
No occurrences through the week last week, but did have another over the weekend.
M122
=== Diagnostics === RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode) Board ID: 65LYX-8Q6KL-K65J0-409N0-NP02Z-ZFK3T Used output buffers: 1 of 40 (18 max) === RTOS === Static ram: 103232 Dynamic ram: 119940 of which 24 recycled Never used RAM 15364, free system stack 156 words Tasks: NETWORK(1,ready,419.7%,218) HEAT(3,nWait 6,0.7%,356) Move(4,nWait 6,0.2%,341) CanReceiv(6,nWait 1,1.0%,808) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.6%,348) TMC(4,nWait 6,57.1%,102) MAIN(1,running,87.1%,677) IDLE(0,ready,0.5%,30) AIN(4,delaying,60.0%,260), total 627.0% Owned mutexes: === Platform === Last reset 20:58:29 ago, cause: software Last software reset at 2024-06-30 11:35, reason: HardFault bfarValid precise, Platform spinning, available RAM 15364, slot 1 Software reset code 0x0060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000004 SP 0x20011ff0 Task NETW Freestk 483 ok Stack: 00000160 00000002 200014e8 0000015f ffffffff 000a07ef 0002ff8e 810f0000 0002ff85 00000000 00000000 00000000 200305e4 00000800 2002c5f8 2002c5f8 00000001 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 20468121 Error status: 0x00 MCU revision 3, ADC conversions started 75510090, completed 75510090, timed out 0, errs 0 MCU temperature: min 38.7, current 39.8, max 41.4 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/12/12, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 42014, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 42014, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 42014, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 42014, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 42015, writes 10, timeouts 0, DMA errors 0, CC errors 0 Driver 5: not present Driver 6: not present Date/time: 2024-07-01 08:34:24 Cache data hit count 4294967295 Slowest loop: 7.01ms; fastest: 0.16ms === Storage === Free file entries: 19 SD card 0 detected, interface speed: 22.5MBytes/sec SD card longest read time 0.7ms, write time 2.6ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === DDARing 1 === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 === GCodes === Movement locks held by null, null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 File2 is idle in state(s) 0 Queue2 is idle in state(s) 0 Q0 segments left 0, axes/extruders owned 0x0000000 Code queue 0 is empty Q1 segments left 0, axes/extruders owned 0x0000000 Code queue 1 is empty === CAN === Messages queued 377549, received 604082, lost 0, errs 1, boc 0 Longest wait 0ms for reply type 0, peak Tx sync delay 297, free buffers 26 (min 26), ts 377549/377548/0 Tx timeouts 0,0,0,0,0,0 === Network === Slowest loop: 7.38ms; fastest: 0.00ms Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address e8:68:e7:e1:4e:d0 Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 42784 WiFi IP address 10.1.10.46 Signal strength -60dBm, channel 11, mode 802.11n, reconnections 0 Clock register 00002001 Socket states: 0 0 0 0 0 0 0 0 Log.txt
2024-06-26 13:58:26 [warn] HTTP client 10.1.10.9 login succeeded (session key 3446445976) 2024-06-27 07:44:43 [warn] HTTP client 10.1.10.9 login succeeded (session key 2598975707) 2024-06-27 11:34:42 [warn] HTTP client 10.1.10.9 login succeeded (session key 3419397635) 2024-06-27 12:00:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 3802106080) 2024-06-27 14:17:11 [warn] HTTP client 10.1.10.9 login succeeded (session key 3855690080) power up + 00:00:00 [info] Event logging started at level debug power up + 00:00:00 [info] Running: Duet 3 Mini5plus WiFi: 3.5.1 (2024-04-19 14:41:25) power up + 00:00:00 [debug] Done! power up + 00:00:00 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running. power up + 00:00:00 [warn] WiFi module started power up + 00:00:07 [warn] WiFi module is connected to access point SD3D-24, IP address 10.1.10.46 power up + 00:00:08 [warn] HTTP client 10.1.10.9 login succeeded (session key 526990551) 2024-06-30 11:36:03 [warn] Date and time set at power up + 00:00:08 2024-06-30 13:26:46 [warn] HTTP client 10.1.10.9 login succeeded (session key 2188381128) 2024-06-30 13:26:51 [warn] HTTP client 10.1.10.9 login succeeded (session key 1375067276) 2024-06-30 13:26:54 [warn] HTTP client 10.1.10.9 login succeeded (session key 587158328) 2024-06-30 13:27:19 [warn] HTTP client 10.1.10.9 login succeeded (session key 3511153781) 2024-06-30 14:25:24 [warn] HTTP client 10.1.10.9 login succeeded (session key 2762896906) 2024-07-01 01:18:55 [warn] HTTP client 10.1.10.9 login succeeded (session key 96132253) 2024-07-01 01:20:58 [warn] HTTP client 10.1.10.9 login succeeded (session key 1951105233) 2024-07-01 08:34:24 [debug] === Diagnostics ===
