    Dual motor axis end stop woes -> Bug report
    • abraxasundefined
      abraxas
      Using the config tool I found out a Bug that can produce serious damage when homing:
      When defining endstops like this (on four 1HCL Ports):
      Axis Driver Endstop Type Endstop Port Endstop Location Homing Speeds
      X 112.0 Switch 112.io0.in Low end 10/5 mm/s
      X 114.0 112.io1.in
      Y 111.0 Switch 111.io0.in Low end 10/5 mm/s
      Y 113.0 114.io0.in
      the tool produces this code:
      M574 X1 P"112.io0.in+io1.in" S1 ; configure X axis endstop
      M574 Y1 P"111.io0.in+io0.in" S1 ; configure Y axis endstop
      That produces a homing sequence moving only one end of the X Axis and one end of the Y Axis. The working code is:
      M574 X1 P"112.io0.in+112.io1.in" S1 ; configure X axis endstop
      M574 Y1 P"111.io0.in+114.io0.in" S1 ; configure Y axis endstop
      I hope that helps someone, best, Felix
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @abraxas
        @abraxas one for @chrishamm
        • chrishammundefined
          chrishamm administrators @abraxas
          @abraxas Thanks for pointing it out, I've got a fix ready that avoids stripping the board number of following ports if they diverge. Are you sure that 112.io0.in+io1.in doesn't work for ports io0.in and io1.in on expansion board #112? I could confirm that M574 does require explicit board numbers unlike M950. I've updated the configtool again.
          Duet software engineer
          • abraxasundefined abraxas marked this topic as a question
          • abraxasundefined abraxas has marked this topic as solved
