    3.5.1 - 'Error: Pop(): stack underflow on Aux'
    Beta Firmware
    8
    37
    1.7k
    • gnydickundefined
      gnydick @gloomyandy
      @gloomyandy I issue those same commands from DWC all of the time and it hasn't happened.
      • omtekundefined
        omtek
        Right now I can consistently get the error by doing the following:
        • Heating the tool to print temp (205C in this case)
        • Use the PanelDue to extrude 20mm of material.
        • Tap the tool icon on the PanelDue to put the tool into standby and deselect
        I've been able to get a single 'Error: Pop(): stack underflow on Aux' with five out of five attempts.
        If I perform the same actions in DWC, I don't get the error.
        Additionally the error doesn't occur when doing the following:
        • Extruding in DWC and putting the tool into standby on the PanelDue.
        • Extruding on the PanelDue and putting the tool into standby in DWC
        And aside from this error, the printer has been working great.
          droftarts administrators @omtek
          @omtek how is the PanelDue wired to the Duet, ribbon cable or 4-wire cable? Is it particularly long?
          You also have the PanelDue serial comms speed set higher than we normally suggest. From your config:
          M575 P1 S1 B115200
          Try M575 P1 S1 B57600
          I suggest checking the wiring, crimps and connectors for good connections, and make sure they are not running close to motor or heater wires, which could be sources of interference.
          omtekundefined 1 Reply Last reply Reply Quote 0
          • omtekundefined
            omtek @droftarts
            @droftarts I'm using the 4-pin Molex KK cable. The original cable length was ~711mm long but I spent the morning re-crimping and shortening the length to ~400mm. I also updated the M575 line in my config.g per your suggestion. However, I'm still getting the single 'Error: Pop(): stack underflow on Aux' when performing the troubleshooting steps I outlined here.
              @omtek is there anyway you could setup in standalone mode (no RPi/SBC) and test if you have the same behaviour? That might help point out if it’s a firmware issue, or DSF. Is there anything else unique about your setup?
              • omtekundefined
                omtek @droftarts
                @droftarts My setup is nothing too exotic I hope: Duet 3 Mini 5+, Raspberry Pi 4b+ 4GB with external M.2 SSD (no SD card), RRF36 toolboard and a CannedERCF board (sitting on the canbus as passthrough, but no gcode configuration sent during this); all boards are running v3.5.1. I do have 5VEXT connected via an external power supply for a servo-powered filament cutter and the jumper set to disable the internal 5V.
                • I removed the jumper that disables the internal 5V power supply, but received the same error.
                • I copied my /sys folder to a microSD card flashed with image_2024-04-19-DuetPi-lite.zip, and I no longer get the Error: Pop(): stack underflow on Aux error using my troubleshooting steps. Several attempts over the last half-hour and the error has not occurred once.
                My current setup was running the older JessieBuster image, and the only additional software I was running on the Pi was a uStreamer instance for the webcam (this was before Spyglass came out).
                Is it worth trying out the new Bookworm image for troubleshooting now that it appears the error is specific to SBC mode?
                  @omtek said in 3.5.1 - 'Error: Pop(): stack underflow on Aux':
                  You can certainly give it a go, if you want! As it seems to be related to SBC mode, I'll ask @chrishamm to look at this.
                  • omtekundefined
                    omtek @droftarts
                    @droftarts I used the same microSD card that I tested standalone mode to boot the raspberry pi and moved my configuration files over, however I still receive the Error: Pop(): stack underflow on Aux error when performing the troubleshooting steps.
                    Additionally, and probably out of the scope of this post, but I had issues booting my external M.2 drive when flashed with image_2024-04-19-DuetPi-lite.zip. The pi runs headless, but the green LED would flash 3x (missing start.elf iirc), and the M.2 drive activity would flash for a time, and then stop. I didn't feel like troubleshooting past that, but I was able to boot from the official Raspberry Pi OS (64-bit, lite) using the same drive and enclosure and following the instructions here I was able to get the repos added and DWC, DSF, et al installed. Unfortunately, the Error: Pop(): stack underflow on Aux error occurred using the official Raspberry Pi OS image and performing the troubleshooting steps.
                    • chrishammundefined
                      chrishamm administrators @omtek
                      @omtek I've got a bug fix ready for v3.5.2 which we will release sometime soon.
                      Duet software engineer
                      • gloomyandyundefined gloomyandy referenced this topic
                      • gnydickundefined
                        gnydick @chrishamm
                        This post is deleted!
                        • omtekundefined
                          omtek
                          This appears to be fixed with v3.5.2. I'm no longer getting the error message using the above steps. Additionally the 3 macros in the upper right corner of the 'Control' page have returned.
                          Marking as solved.
                          • omtekundefined omtek has marked this topic as solved
