DUET 2 MAIN v1.06 Solder bridge problem
Hello
I have DUET 2 Mainboard v1.06. It's a new board. While using with PT100 temperature sensor daughterboard a problem appears with one channel not working. I saw two pins solder bridged on the back of the pcb. There is pin CS2 bridged to GND.
@wmdeveloper is this the same board that was posted about here? https://forum.duet3d.com/topic/35934/duet-2-hardware-problem-not-reading-temp-from-daughterboard?_=1719301930805
When and where did you purchase the board? -
@jay_s_uk Yes. Sorry we misunderstood with coworker and now the problem has been duplicated. Should i delete this discussion or close it in this case?
@wmdeveloper i can lock the other post and we can continue here.
when and where did you purchase the board? -
@wmdeveloper @developerOI Yes, that's a solder bridge, and no, it shouldn't be there. Sorry for the inconvenience.
If you have a soldering iron I'm happy if you want to melt the excess solder to remove the solder bridge, which will be quicker for you to get the card working, and we'll still honour the warranty.
I'm also happy to authorise a warranty replacement, if you prefer. You said it's a new board, can you let me know where and when you bought it?
@droftarts
I did successfully melt the solder bridge and now board works fine. We bought this board directly from you on 05.04.2024. Thanks for your support! -
@wmdeveloper Great, glad you were able to fix it. Let us know if you have any other issues.
