    Random overextrusion after 3+hours of printing FW 3.5.2
    Beta Firmware
    1.2k
    • charliedrumsundefined
      charliedrums
      I’m using a Duet 3 Mainboard 6HC v1.01, Tool board 1LC v1.2 in SBC mode with a Raspberry Pi 5 (64gb card) using the tool distribution board. The 1LC has the Z scanning probe attached and the Orthus Filament Monitor. The extruder is a first gen e3d hemera(Hermes branded)
      After I updated to firmware 3.5.2, every time I start a print about between 2 to 4 hours into the print it starts over extruding and a couple of layers into the over extrusion the filament monitor gets triggered because of not enough filament flow and the print stops. At this point I disable the filament monitor and try to continue the print but it keeps over extruding. While over extruding the retractions sound off (with a bit of a whine to them)
      When the print is paused, I can jog the extruder but when I try to extrude 100mm of filament at 10mm/s the motor kind of stalls intermittently. This does not happen when the printer is rebooted.
      • At first, I thought it was the filament so I changed the filament. Still over extrudes after a couple of hours.
      • Then I thought it might be the extruder so I took it apart and cleaned everything. Still happens a couple of hours into the print.
      • Reading in the forums I read something about pressure advance (can’t remember what it was) so I disabled it. Same thing.
      • I tried to go back and downgraded to 3.5.1 but after downgrading same thing happens 2+hours into the print.
      • At this point I upgraded again to 3.5.2, disassembled the hemera and replaced the motor (I have a spare hemera), thinking it could be a busted motor, same thing happened 4h 20m into the print.
      I am at a loss to what it could be. Can it be a busted 1LC board? I don’t want to buy another one if I don’t have to.
      The weird thing is, if I cancel the print and try different prints it continues with the weird extruder retraction sound and over extrusion right from the get go. I have to power the printer off and on again and the print starts fine until about the 2-to-4-hour mark.
      Here is some info:
      Diagnostic at the start of the print:
      RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V
      Used output buffers: 1 of 40 (40 max)
      Static ram: 155360
      Dynamic ram: 91716 of which 3224 recycled
      Never used RAM 92212, free system stack 117 words
      Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,rWait:,1.0%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,2.0%,211) CanReceiv(6,nWait 1,0.0%,771) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.7%,53) MAIN(2,running,87.2%,101) IDLE(0,ready,0.1%,29), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 01:13:06 ago, cause: power up
      Last software reset at 2024-06-25 22:42, reason: HardFault undefInstr, Gcodes spinning, available RAM 92500, slot 2
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00010000 ICSR 0x00400803 BFAR 0x00000000 SP 0x20419930 Task IDLE Freestk 38 ok
      Stack: 00000000 a5a5a5a5 a5a5a5a5 fffc0001 a5a5a5af 0049abe9 0049b4fa 61000000 4e49414d 00000000 00000000 00000001 00000002 0d16a016 00000000 2d080000 20380209 00000000 003ffad4 00000000 00000000 00000000 00000000 00000000 003ffff0 20419818 00000002
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU temperature: min 35.5, current 52.6, max 52.7
      Supply voltage: min 23.8, current 23.9, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/152/152, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min 0, mspos 577, reads 35131, writes 29 timeouts 0
      Driver 1: ok, SG min 0, mspos 624, reads 35131, writes 29 timeouts 0
      Driver 2: ok, SG min 0, mspos 135, reads 35131, writes 29 timeouts 0
      Driver 3: ok, SG min 0, mspos 969, reads 35131, writes 29 timeouts 0
      Driver 4: ok, SG min 0, mspos 889, reads 35131, writes 29 timeouts 0
      Driver 5: ok, SG min 0, mspos 439, reads 35131, writes 29 timeouts 0
      Date/time: 2024-06-25 23:55:56
      Slowest loop: 93.76ms; fastest: 0.04ms
      === Storage ===
      Free file entries: 20
      DMs created 125, segments created 26, maxWait 190546ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 9 ticks, disabled
      Moves shaped first try 3990, on retry 2328, too short 2031, wrong shape 48235, maybepossible 587
      === DDARing 0 ===
      Scheduled moves 61489, completed 61429, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state 3
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.1
      Heater 1 is on, I-accum = 0.0
      HTTP* is doing "M122" in state(s) 0 0, running macro
      Telnet is idle in state(s) 0
      File* is doing "G1 X326.306000 Y332.777008 E0.085130" in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 1, axes/extruders owned 0x80000007
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 0
      Extruder 0 sensor: no data received
      === CAN ===
      Messages queued 98980, received 127427, lost 0, errs 1, boc 0
      Longest wait 2ms for reply type 6031, peak Tx sync delay 380, free buffers 50 (min 48), ts 21935/21934/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 41142/41142
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc
      Buffer RX/TX: 1520/3088-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit)
      HTTP+Executed:
      > Executing M122
      File 0:/gcodes/Guiros/Guiro 12in_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing
      HTTP:
      >> Doing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics"
      File:
      Buffered code: G1 X326.306 Y332.777 E.08513
      Buffered code: G1 X325.021 Y332.512 E.09104
      Buffered code: G1 X324.798 Y332.419 E.01677
      Buffered code: G1 X324.384 Y332.123 E.03531
      Buffered code: G1 X324.228 Y331.99 E.01422
      Buffered code: G1 X323.882 Y331.632 E.03455
      Buffered code: G1 X323.712 Y331.551 E.01307
      Buffered code: G1 X323.637 Y331.372 E.01347
      Buffered code: G1 X323.653 Y331.182 E.01323
      Buffered code: G1 X323.487 Y330.548 E.04548
      Buffered code: G1 X323.381 Y329.878 E.04707
      Buffered code: G1 X323.342 Y329.089 E.05482
      Buffered code: G1 X323.387 Y328.112 E.06787
      Buffered code: G1 X323.5 Y327.355 E.05311
      Buffered code: G1 X323.673 Y326.613 E.05287
      Buffered code: G1 X323.904 Y325.887 E.05287
      Buffered code: G1 X324.157 Y325.271 E.04621
      Buffered code: G1 X324.549 Y324.489 E.0607
      Buffered code: G1 X324.97 Y323.823 E.05467
      Buffered code: G1 X325.368 Y323.304 E.04538
      Buffered code: G1 X325.805 Y322.826 E.04494
      Buffered code: G1 X326.355 Y322.35 E.05047
      Buffered code: G1 X326.933 Y321.926 E.04974
      Buffered code: G1 X327.926 Y321.432 E.07696
      Buffered code: G1 X328.861 Y321.166 E.06745
      Buffered code: G1 X329.761 Y321.067 E.06283
      Buffered code: G1 X330.017 Y321.11 E.01801
      Buffered code: G1 X330.524 Y321.078 E.03525
      Buffered code: G1 X331.067 Y321.151 E.03802
      Buffered code: G1 X331.607 Y321.277 E.03848
      Buffered code: G1 X332.515 Y321.621 E.06738
      Buffered code: G1 X333.275 Y322.06 E.0609
      Buffered codes: 1536 bytes total
      Code buffer space: 1520
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
      Full transfers per second: 38.73, max time between full transfers: 41.8ms, max pin wait times: 41.5ms/36.7ms
      Codes per second: 14.15
      Maximum length of RX/TX data transfers: 6892/1304
      1LC diagnostics at the start of the print:
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.5.2 (2024-06-10 13:24:04)
      Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
      All averaging filters OK
      Never used RAM 3220, free system stack 71 words
      Tasks: Move(3,nWait 7,0.2%,84) HEAT(2,nWait 6,0.4%,94) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,delaying,3.7%,52) MAIN(1,running,90.8%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0%
      Owned mutexes:
      Last reset 01:13:09 ago, cause: power up
      Last software reset data not available
      Driver 0: pos 0, 405.0 steps/mm, ok, SG min 0, read errors 1, write errors 0, ifcnt 17, reads 28909, writes 17, timeouts 4, DMA errors 0, CC errors 0, failedOp 0x71, steps req 0 done 3093220
      Moves scheduled 57525, completed 57520, in progress 1, hiccups 0, segs 26, step errors 0, maxLate 0 maxPrep 346, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
      Peak sync jitter 0/8, peak Rx sync delay 243, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 17.5, current 23.6, max 24.6
      MCU temperature: min 39.5C, current 55.4C, max 57.5C
      Last sensors broadcast 0x00000002 found 1 26 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 89842, send timeouts 0, received 114519, lost 0, errs 1, boc 0, free buffers 18, min 17, error reg 20000
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 365, adv 36211/74681
      Accelerometer: LIS3DH, status: 00
      I2C bus errors 0, naks 3, contentions 0, other errors 0
      Interrupt 1 to 42us, poll 2 to 1757us
      Driver 0: ok
      At the beginning of the print, I started a log with M929 S2 but the info is beyond my understanding. I’ll attach it here if it is of any use.
      Any idea or recommendation of what to try next?
      Thanks in advance.
      edit: I had to separate the post because of to many words. See below for diagnostics at the moment of print pausing due to over extrusion.
      charliedrumsundefined 1 Reply Last reply Reply Quote 0
        charliedrums @charliedrums
        Diagnostics at the moment the print is paused due to over extrusion:
        Used output buffers: 12 of 40 (40 max)
        Static ram: 155360
        Dynamic ram: 91852 of which 3088 recycled
        Never used RAM 92164, free system stack 117 words
        Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,rWait:,1.0%,821) HEAT(3,nWait 6,0.0%,321) Move(4,nWait 6,2.7%,211) CanReceiv(6,nWait 1,0.0%,771) CanSender(5,nWait 7,0.0%,325) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.7%,53) MAIN(2,running,86.5%,101) IDLE(0,ready,0.0%,29), total 100.0%
        Last reset 04:51:37 ago, cause: power up
        Stack: 00000000 a5a5a5a5 a5a5a5a5 fffc0001 a5a5a5af 0049abe9 0049b4fa 61000000 4e49414d 00000000 00000000 00000001 00000002 0d16a016 00000000 2d880000 0038221b 20000000 003ffbf0 00000000 00000000 00000000 00000000 00000000 003ffff0 20419818 00000002
        Error status: 0x04
        Aux0 errors 0,0,0
        MCU temperature: min 51.4, current 51.6, max 53.6
        Supply voltage: min 23.7, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/216/216, gc cycles 0
        Events: 1 queued, 1 completed
        Driver 0: standstill, SG min 0, mspos 632, reads 51389, writes 0 timeouts 0
        Driver 1: standstill, SG min 0, mspos 824, reads 51389, writes 0 timeouts 0
        Driver 2: standstill, SG min 0, mspos 632, reads 51389, writes 0 timeouts 0
        Driver 3: standstill, SG min 0, mspos 472, reads 51389, writes 0 timeouts 0
        Driver 4: standstill, SG min 0, mspos 392, reads 51389, writes 0 timeouts 0
        Driver 5: standstill, SG min 0, mspos 936, reads 51388, writes 0 timeouts 0
        Date/time: 2024-06-26 03:34:27
        Slowest loop: 51.20ms; fastest: 0.04ms
        === Storage ===
        DMs created 125, segments created 28, maxWait 1240ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
        no step interrupt scheduled
        Moves shaped first try 2936, on retry 3506, too short 5601, wrong shape 228938, maybepossible 1103
        === DDARing 0 ===
        Scheduled moves 311800, completed 311800, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        === DDARing 1 ===
        File* is idle in state(s) 0
        Autopause* is idle in state(s) 0
        Q0 segments left 0, axes/extruders owned 0x80000007
        check 0 clear 0
        === CAN ===
        Messages queued 361199, received 373710, lost 0, errs 0, boc 0
        Longest wait 5ms for reply type 6024, peak Tx sync delay 381, free buffers 50 (min 48), ts 65555/65555/0
        RX/TX seq numbers: 31182/31182
        Buffer RX/TX: 0/0-0, open files: 0
        HTTP+Executed:
        > Executing M122
        File 0:/gcodes/Guiros/Guiro 12in_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, paused
        HTTP:
        Code buffer space: 4096
        Full transfers per second: 39.23, max time between full transfers: 68.1ms, max pin wait times: 62.9ms/13.3ms
        Codes per second: 19.64
        1LC diagnostics at the moment of the print paused due to over extrusion:
        Never used RAM 3196, free system stack 71 words
        Tasks: Move(3,nWait 7,0.2%,84) HEAT(2,nWait 6,0.4%,90) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.2%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,90.7%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0%
        Owned mutexes:
        Last reset 04:51:40 ago, cause: power up
        Driver 0: pos 0, 405.0 steps/mm, standstill, SG min 0, read errors 4, write errors 1, ifcnt 235, reads 31529, writes 60650, timeouts 5, DMA errors 0, CC errors 60650, failedOp 0x6f, steps req 0 done 9962542
        Moves scheduled 300627, completed 300627, in progress 0, hiccups 0, segs 27, step errors 0, maxLate 0 maxPrep 365, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
        Peak sync jitter 1/9, peak Rx sync delay 264, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 20.3, current 24.4, max 24.4
        MCU temperature: min 39.5C, current 52.6C, max 57.5C
        Last sensors broadcast 0x00000002 found 1 144 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 268805, send timeouts 0, received 413549, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 395, adv 36111/74679
        I2C bus errors 0, naks 0, contentions 0, other errors 0
        Interrupt 1 to 84us, poll 4 to 1841us
        Driver 0: ok
        Here is my config.g:
        ; Configuration file for Duet 3 (firmware version 3.3)
        ; generated by RepRapFirmware Configuration Tool v3.3.10 on Wed Feb 16 2022 21:57:55 GMT-0500 (Eastern Standard Time)
        M575 P1 S1 B57600                                         ; enable support for PanelDue
        G90                                                       ; send absolute coordinates...
        M83                                                       ; ...but relative extruder moves
        M550 P"duet3"                                             ; set printer name
        M669 K1                                                   ; select CoreXY mode
        M929 P"eventlog.txt" S1                                   ; start logging warnings to file eventlog.txt
        ; Wait a moment for the CAN expansion boards to start
        G4 S2
        ;M552 P0.0.0.0 S1                                          ; enable network and acquire dynamic address via DHCP
        ;M586 P0 S1                                                ; enable HTTP
        ;M586 P1 S0                                                ; disable FTP
        ;M586 P2 S0                                                ; disable Telnet
        M569 P0.0 S1 ;D3 H30 V30                                          ; physical drive 0.0 goes forwards (X-Y)
        M569 P0.1 S1 ;D3 H30 V30                                          ; physical drive 0.1 goes forwards (X-Y)
        M569 P0.2 S0                                              ; physical drive 0.2 goes forwards
        M569 P0.3 S1                                              ; physical drive 0.3 goes forwards
        M569 P0.4 S1                                              ; physical drive 0.4 goes forwards
        M569 P0.5 S0                                              ; physical drive 0.5 goes forwards
        M569 P121.0 S0                                            ; physical drive 121.0 goes forwards
        M584 X0.0 Y0.1 Z0.2:0.3:0.4:0.5 E121.0                    ; set drive mapping
        M671 X35:790:100:780 Y-105:-105:665:665 S10	           	  ; set Z belt positions, max error 5mm
        M92 X80.00 Y80.00 Z800.00 E405.00                         ; set steps per mm
        M350 X16 Y16 Z16 E16 I1                                 ; configure microstepping with interpolation
        M566 X420.00 Y420.00 Z60.00 E960.00                       ; set maximum instantaneous speed changes (Jerk)(mm/min)
        M203 X24000.00 Y24000.00 Z1200 E7200                      ; 120 set maximum speeds (mm/min) - 400, 400, 20, 120 (mm/s)
        M201 X1500.00 Y1500.00 Z300.00 E5000.00                   ; set accelerations (mm/s^2)
        ; M204 P1500 T2000                                        ; Set printing acceleration and travel accelerations
        M906 X1441 Y1441 Z1441 E1179 I30                          ; set motor currents (mA) and motor idle factor in per cent
        M84 S30                                                   ; Set idle timeout
        M208 X0 Y0 Z0 S1                                          ; set axis minima
        M208 X670 Y650 Z645 S0                                    ; set axis maxima
        M574 X1 S1 P"!^io3.in"                                    ; configure switch-type (e.g. microswitch) endstop for low end on X via pin !^io3.in
        M574 Y2 S1 P"!^io1.in"                                    ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin !^io1.in
        M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
        ; M950 S0 C"121.io0.out"                                    ; create servo pin 0 for BLTouch
        ; M558 P9 C"121.io0.in" H5 F300:120 T15000 A1 S0.05         ; set Z probe type to bltouch and the dive height + speeds
        ; G31 P500 X-31.27 Y-36.64 Z2.820                           ; set Z probe trigger value, offset and trigger height
        M558 K0 P5 C"!io5.in" H3 F900:120 T15000                    ; set Z probe type to EZABL Pro and the dive height + speeds
        G31 K0 P500 X-31.27 Y-46.64 Z1.70                            ; set Z probe trigger value, offset and trigger height
        M557 X29:609 Y40:603 P30:30                                 ; define mesh grid
        ; Scanning Z probe
        M558 K1 P11 C"120.i2c.ldc1612" F24000 T24000 B1             ; configure SZP as probe 1, type 11, on CAN address 120
        M308 A"SZP coil" S10 Y"thermistor" P"120.temp0"             ; thermistor on SZP coil
        G31 K1 X-25 Y0 Z1.40                                         ; define probe 1 offsets and trigger height
        M558.2 K1 S13 R147095                                       ; set drive current and reading offset
        ;M558.1 K1 S1
        M557 X29:609 Y40:603 P30:30                                 ; Define mesh grid for probe 1 (overwrites probe 0 mesh grid)
        ; Filament Sensor
        ; M591 D0 P3 C"121.io1.in" S1 L24.84 R35:130 E5           ; Duet3D Rotating Magnet Filament Monitor connected to Toolboard 1LC io1
        ; M591 D0 P1 C"121.io2.in" S1                             ; Dyze Design SENTINEL Filament Detector connected to Toolboard 1LC io2
        M591 D0 P7 C"121.io2.in" S1 L1.246 R50:200 E40            ; Dyze Design SENTINEL Filament Detector connected to Toolboard 1LC io2
        M308 S0 P"temp0" Y"thermistor" T100000 B4138              ; configure sensor 0 as thermistor on pin temp0
        M950 H0 C"out0" T0                                        ; create bed heater output on out0 and map it to sensor 0
        M307 H0 B0 R0.391 C260.7 D2.75 S1.00                      ; enable bang-bang mode for the bed heater and set PWM limit
        M140 H0                                                   ; map heated bed to heater 0
        M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
        M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
        M950 H1 C"121.out0" T1                                    ; create nozzle heater output on 121.out0 and map it to sensor 1
        M307 H1 R2.135 K0.524:0.000 D2.62 E1.35 S1.00 B0 V24.1    ;M307 H1 B0 R1.891 C265.1 D5.94 S1.00 V24.2; disable bang-bang mode for heater  and set PWM limit
        M143 H1 S280                                              ; set temperature limit for heater 1 to 280C
        M950 F0 C"121.out1" Q500                                  ; create fan 0 on pin 121.out1 and set its frequency
        M106 P0 S0 H-1                                            ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"121.out2" Q500                                  ; create fan 1 on pin 121.out2 and set its frequency
        M106 P1 S1 H1 T45                                         ; set fan 1 value. Thermostatic control is turned on
        ; LED Extrude Lights
        ; M950 E0 C"121.io1.in" T1 U10 Q3000000
        ; Accelerometer
        M955 P121.0 I54 ; specify orientation of accelerometer on Toolboard 1LC with CAN address 121
        M955 P120.0 I45 ; Add accelerometer on SZP with CAN address 120 and specify orientation
        ; Low power automatic pause and save
        M911 S22.5 R23.3 P"M913 X0 Y0 M104 S0 M140 S0 M107 G91 M83 G1 Z3 E-5 F1000"; G91 M83 G1 Z1"
        M563 P0 D0 H1 F0:1                                        ; define tool 0
        G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
        G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
        ; Firmware Retraction
        ;M207 S0.6 F2400 Z0.4
        ; M572 D0 S0.018						                          ; pressure advance
        M593 P"zvd" F27.7				                              ; input shaping
        • charliedrumsundefined charliedrums marked this topic as a question
          I updated to a raspberry PI 5 when there was an update to include the Pi 5 not to long ago. So, I decided to do a new install on a Pi 4 with a new 64gb card. For the pi 4 I used the image 2024-04-19-DuetPi-arm64.img. Once I booted with the new pi image, I updated everything through Putty so that I’m on 3.5.2 but this time around on a raspberry pi 4. I started the same 8 hour print to see how it goes.
          Here is the diagnostic of the board and the 1lc right after I started the print. So far it has been an hour into the print. I’ll update accordingly.
          Static ram: 155360
          Never used RAM 92212, free system stack 143 words
          Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,nWait 7,0.9%,819) HEAT(3,nWait 6,0.0%,321) Move(4,nWait 6,1.2%,211) CanReceiv(6,nWait 1,0.0%,792) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.6%,53) MAIN(2,running,87.9%,101) IDLE(0,ready,0.3%,29), total 100.0%
          Last reset 00:18:39 ago, cause: software
          Last software reset at 2024-06-26 18:23, reason: User, Platform spinning, available RAM 95692, slot 2
          Software reset code 0x6000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU temperature: min 37.9, current 41.6, max 41.7
          Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/88/88, gc cycles 0
          Driver 0: ok, SG min 0, mspos 283, reads 12251, writes 21 timeouts 0
          Driver 1: ok, SG min 0, mspos 796, reads 12251, writes 21 timeouts 0
          Driver 2: ok, SG min 0, mspos 43, reads 12251, writes 21 timeouts 0
          Driver 3: ok, SG min 0, mspos 949, reads 12251, writes 21 timeouts 0
          Driver 4: ok, SG min 0, mspos 757, reads 12251, writes 21 timeouts 0
          Driver 5: ok, SG min 0, mspos 187, reads 12251, writes 21 timeouts 0
          Date/time: 2024-06-26 18:41:48
          Slowest loop: 101.55ms; fastest: 0.04ms
          === Storage ===
          DMs created 125, segments created 26, maxWait 232121ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 94 ticks, disabled
          Moves shaped first try 687, on retry 298, too short 380, wrong shape 6976, maybepossible 58
          === DDARing 0 ===
          Scheduled moves 9303, completed 9280, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 40], CDDA state 3
          === DDARing 1 ===
          Heater 0 is on, I-accum = 0.2
          File* is doing "G1 X320.627014 Y339.914001 E0.037090" in state(s) 0
          check 0 clear 0
          === CAN ===
          Messages queued 18737, received 33044, lost 0, errs 1, boc 0
          Longest wait 3ms for reply type 6013, peak Tx sync delay 243, free buffers 50 (min 48), ts 5596/5595/0
          RX/TX seq numbers: 43540/43540
          Buffer RX/TX: 1824/3032-0, open files: 0
          HTTP+Executed:
          > Executing M122
          File 0:/gcodes/Guiro 12in_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing
          HTTP:
          File:
          Buffered code: G1 X320.627 Y339.914 E.03709
          Buffered code: G1 X312.601 Y339.914 E.46182
          Buffered code: G1 E-.6 F2400
          Buffered code: G1 F12000
          Buffered code: G1 X315.759 Y339.914 E-.6
          Buffered code: G1 Z3.8 F720
          Buffered code: G1 X322.543 Y347.759 F15000
          Buffered code: G1 Z3.2 F720
          Buffered code: G1 E1.2 F2400
          Buffered code: G1 F3000
          Buffered code: G1 X322.543 Y349.856 E.12066
          Buffered code: G1 X337.457 Y349.856 E.85816
          Buffered code: G1 X337.457 Y347.759 E.12066
          Buffered code: G1 X347.399 Y314.669 F15000
          Buffered code: G1 X347.399 Y312.572 E.12066
          Buffered code: G1 X312.601 Y312.572 E2.0023
          Buffered code: G1 X312.601 Y314.669 E.12066
          Buffered code: G1 X312.601 Y312.572 E-.39843
          Buffered code: G1 X313.662 Y312.572 E-.20157
          Buffered code: G1 X310.115 Y315.058 F15000
          Buffered code: G1 X349.885 Y315.058 E2.28839
          Buffered codes: 1200 bytes total
          Code buffer space: 1824
          Full transfers per second: 39.48, max time between full transfers: 155.5ms, max pin wait times: 57.1ms/6.5ms
          Codes per second: 7.94
          Maximum length of RX/TX data transfers: 4420/1140
          1LC diagnostic
          Tasks: Move(3,nWait 7,0.1%,90) HEAT(2,nWait 6,0.3%,90) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,delaying,3.7%,52) MAIN(1,running,91.0%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0%
          Owned mutexes:
          Last reset 00:18:41 ago, cause: software
          Driver 0: pos 0, 405.0 steps/mm, ok, SG min 0, read errors 0, write errors 3, ifcnt 11, reads 32054, writes 2584, timeouts 3, DMA errors 0, CC errors 2562, failedOp 0x72, steps req 0 done 468382
          Moves scheduled 7701, completed 7700, in progress 1, hiccups 0, segs 26, step errors 0, maxLate 0 maxPrep 335, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
          Peak sync jitter 0/5, peak Rx sync delay 240, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 4.4, current 23.5, max 24.6
          MCU temperature: min 40.0C, current 55.6C, max 55.6C
          CAN messages queued 22784, send timeouts 0, received 22157, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 362, adv 36231/74671
          Interrupt 1 to 32us, poll 2 to 1421us
          Driver 0: ok
            Well, it happened again at around 3 hour and 12 minutes in it started over extruding again. This time I have not stopped the print. I just disabled the filament sensor and am going to let it print a couple of hours to have a visual on where exactly it goes wrong.
            Here are the diagnostics of as of now, after it started over extruding.
            Static ram: 155360
            Never used RAM 92212, free system stack 134 words
            Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,nWait 7,1.0%,819) HEAT(3,nWait 6,0.0%,321) Move(4,nWait 6,2.7%,211) CanReceiv(6,nWait 1,0.0%,771) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.7%,53) MAIN(2,running,86.5%,101) IDLE(0,ready,0.0%,29), total 100.0%
            Last reset 03:26:07 ago, cause: software
            Error status: 0x04
            Aux0 errors 0,0,0
            MCU temperature: min 40.9, current 43.2, max 43.2
            Supply voltage: min 23.8, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Driver 0: ok, SG min 0, mspos 447, reads 34871, writes 0 timeouts 0
            Driver 1: ok, SG min 0, mspos 358, reads 34871, writes 0 timeouts 0
            Driver 2: ok, SG min 0, mspos 337, reads 34871, writes 0 timeouts 0
            Driver 3: ok, SG min 0, mspos 655, reads 34871, writes 0 timeouts 0
            Driver 4: ok, SG min 0, mspos 463, reads 34871, writes 0 timeouts 0
            Driver 5: ok, SG min 0, mspos 481, reads 34871, writes 0 timeouts 0
            Date/time: 2024-06-26 21:49:16
            Slowest loop: 51.41ms; fastest: 0.05ms
            === Storage ===
            DMs created 125, segments created 26, maxWait 189738ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
            next step interrupt due in 106 ticks, disabled
            Moves shaped first try 5639, on retry 5272, too short 6461, wrong shape 194305, maybepossible 1481
            === DDARing 0 ===
            Scheduled moves 235144, completed 235107, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
            === DDARing 1 ===
            File* is doing "G1 X354.319000 Y309.311005 E0.101450" in state(s) 0
            check 0 clear 0
            === CAN ===
            Messages queued 317673, received 320618, lost 0, errs 0, boc 0
            Longest wait 6ms for reply type 6024, peak Tx sync delay 379, free buffers 50 (min 49), ts 56240/56240/0
            RX/TX seq numbers: 25733/25733
            Buffer RX/TX: 3024/512-4080, open files: 0
            HTTP+Executed:
            > Executing M122
            HTTP:
            File:
            Buffered code: G1 X354.319 Y309.311 E.10145
            Buffered code: G1 X355.033 Y311.045 E.13012
            Buffered code: G1 X355.661 Y312.813 E.13019
            Buffered code: G1 X356.205 Y314.607 E.13008
            Buffered code: G1 X356.666 Y316.421 E.12987
            Buffered code: G1 X357.045 Y318.247 E.12941
            Buffered code: G1 X357.397 Y320.497 E.15803
            Buffered code: G1 X357.563 Y321.95 E.10148
            Buffered code: G1 X357.699 Y323.815 E.12976
            Buffered code: G1 X357.75 Y325.703 E.13106
            Buffered code: G1 X357.713 Y327.535 E.12715
            Buffered code: G1 X357.541 Y329.761 E.15492
            Buffered code: G1 X357.368 Y331.11 E.09437
            Buffered code: G1 X357.015 Y333.005 E.13376
            Buffered code: G1 X356.656 Y334.436 E.10237
            Buffered code: G1 X356.222 Y335.812 E.10012
            Buffered code: G1 X355.764 Y337.028 E.09016
            Buffered code: G1 X355.384 Y337.898 E.06588
            Buffered code: G1 X354.879 Y338.912 E.0786
            Buffered code: G1 X353.981 Y340.442 E.1231
            Buffered code: G1 X353.31 Y341.42 E.0823
            Buffered code: G1 X352.698 Y342.217 E.06973
            Buffered code: G1 X352.042 Y342.991 E.0704
            Buffered code: G1 X351.344 Y343.741 E.07109
            Buffered code: G1 X350.607 Y344.462 E.07154
            Buffered code: G1 X349.22 Y345.659 E.12713
            Buffered code: G1 X348.202 Y346.428 E.08853
            Buffered code: G1 X347.349 Y347.011 E.07169
            Buffered code: G1 X345.778 Y347.961 E.12739
            Buffered code: G1 X344.865 Y348.446 E.07174
            Buffered code: G1 X343.71 Y348.995 E.08874
            Buffered code: G1 X342.01 Y349.696 E.1276
            Code buffer space: 2512
            Full transfers per second: 39.20, max time between full transfers: 56.5ms, max pin wait times: 51.8ms/21.5ms
            Codes per second: 20.63
            Maximum length of RX/TX data transfers: 4440/1140
            1LC
            Tasks: Move(3,nWait 7,0.3%,84) HEAT(2,nWait 6,0.4%,90) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.2%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,delaying,3.7%,52) MAIN(1,running,90.7%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.9%,112), total 100.0%
            Owned mutexes:
            Last reset 03:26:10 ago, cause: software
            Driver 0: pos 0, 405.0 steps/mm, ok, SG min 0, read errors 1, write errors 1, ifcnt 35, reads 48266, writes 40994, timeouts 4, DMA errors 0, CC errors 40994, failedOp 0x72, steps req 0 done 9378961
            Moves scheduled 224153, completed 224150, in progress 1, hiccups 0, segs 27, step errors 0, maxLate 0 maxPrep 367, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
            Peak sync jitter 0/8, peak Rx sync delay 260, resyncs 0/0, no timer interrupt scheduled
            VIN voltage: min 19.7, current 23.3, max 24.4
            MCU temperature: min 40.0C, current 54.6C, max 56.1C
            Last sensors broadcast 0x00000002 found 1 29 ticks ago, 0 ordering errs, loop time 0
            CAN messages queued 230643, send timeouts 0, received 362699, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 390, adv 36112/109819
            Interrupt 1 to 105us, poll 2 to 1701us
            Driver 0: ok
            I don't really understand it. The last thing that comes to mind is changing the 1LC board? I'm at a loss here. At this point it feels like I'm punching in the dark. If anybody has any info or what to try next I appreciate it.
            *edit: The print separated from the build plate so I'm including some pictures of the how the print looks after the over extrusion. Also uploaded two videos. one at the start of the print and the other when it starts over extruding. Notice the sound of the retractions. It sounds off.
            video_2024-06-26_22-01-48.mp4 video_2024-06-26_22-01-39.mp4
            gloomyandyundefined 1 Reply Last reply Reply Quote 0
            • gloomyandyundefined
              gloomyandy @charliedrums
              @charliedrums If you think this may be a problem with 3.5.2 then perhaps try going back to whatever version of RRF you had installed before and see if the problem goes away?
                charliedrums @gloomyandy
                @gloomyandy
                Right now, I went back to DuetPi 2023-09-06 (buster) on a pi 4, from there I updated to RepRapFirmware 3.5.0 RC4. I would stay in 3.4.6 but I have the Zscaning probe and If I recall correctly that one is not usable in 3.4.6.
                For some reason Duet web control doesn’t update to 3.5.0RC4 and stays on 3.4.6 or I might be updating it wrong. Either way I’m on another test print 2h 13m 51s in so far.
                gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                  @charliedrums What version of RRF where you using before you started having these problems? Ideally you want to go back to that (especially if you still have a problem with RC4). You probably do not need the scanning probe to be working to run a test print, you can use a previously saved mesh.
                    @gloomyandy
                    I was using 3.5.0 and I ran 8 to 20 hour prints without any problem. The print I was running just had the same issue at the 2 hour 40 mark it started over extruding. It has been printing fine for a about two months. Could it be a busted 1LC board. My 1LC is the 1.2 not the 1.2a. I can get the 1.3 from fillastruder and try it out to see.
                      droftarts administrators @charliedrums
                      @charliedrums Sorry you're having problems. @dc42 needs to look at your M122 reports to see if there's anything in there. I can see a few things that may help troubleshooting:
                      The 1LC has not reset, according to the M122 B121 report. Nor has the steps per mm on the extruder driver changed, it's still 405. The board doesn't seem to have overheated, and there's no CAN or I2C errors, either. You could update the bootloader on the 1LC, current version is 2.8, you're on 2.3. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_bootloader
                      I can't see any other errors in the M122 report for the 6HC, either. I think as far as RRF is concerned, nothing happened.
                      When it starts printing with double the extrusion, does the motor sound the same? I'm wondering if something is causing the microstepping mode to change to x8 rather than x16 (you say there's a 'weird extruder retraction sound'). It could be a heat related effect on the 1LC, but without running a test print on a previous RRF version that was working for you, it's hard to say why this would happen at the same time as updating to RRF 3.5.2. If it happens again, can you send M350 and check the microstepping in use is still x16, as per your config.g?
                      I can see from your video that some of the wiring is exposed where it is crimped into the connector:
                      Check for potential shorts of those. Can you post a sharp, hi resolution image of the 1LC?
                      Is the hot end metal work grounded in some way? We advise this to minimise the chances of static shocks. See https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#wiring-notes
                      We recommend connecting the hot end metalwork to ground on the toolboard via a resistor (10k to 1M Ohm), if it is not grounded through its mounting system. This will prevent the hot end building up static charge, which might otherwise occur as filament is extruded and may then flash over to the tool board thermistor input, causing damage.
                      Again, these don't really explain why it started happening when you updated to 3.5.2, though.
                      charliedrumsundefined 1 Reply Last reply Reply Quote 1
                        @charliedrums Just to be clear, did the test with RC.4 also start to over extrude? If that was the case then it seems unlikely that it is anything in 3.5.2 that is causing the problems, especially if you were able to print ok with 3.5.0. Why did you choose to go back to 3.5-rc4 rather than 3.5.0? You might want to try 3.5.0 just to be sure, that the problem is not related to the firmware.
                          charliedrums @droftarts
                          @droftarts said in Random overextrusion after 3+hours of printing FW 3.5.2:
                          Ok, so I went back to 3.4.6 and ran the file again and the same thing happened at around 2-3 hours in, so that takes out the possibility of being software related. I think?
                          Here is the diagnostics:
                          RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.01 (SBC mode)
                          Static ram: 153252
                          Dynamic ram: 67620 of which 0 recycled
                          Never used RAM 126272, free system stack 128 words
                          Tasks: SBC(resourceWait:,0.8%,446) HEAT(notifyWait,0.0%,321) Move(notifyWait,2.5%,214) CanReceiv(notifyWait,0.0%,773) CanSender(notifyWait,0.0%,327) CanClock(delaying,0.0%,347) TMC(notifyWait,8.1%,56) MAIN(running,88.5%,923) IDLE(ready,0.0%,30), total 100.0%
                          Last reset 04:20:10 ago, cause: power up
                          Last software reset details not available
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          Step timer max interval 131
                          MCU temperature: min 41.5, current 42.5, max 42.5
                          Supply voltage: min 23.8, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/64/64, gc cycles 0
                          Driver 0: ok, SG min 0, mspos 917, reads 44703, writes 0 timeouts 0
                          Driver 1: ok, SG min 0, mspos 860, reads 44703, writes 0 timeouts 0
                          Driver 2: standstill, SG min 0, mspos 792, reads 44703, writes 0 timeouts 0
                          Driver 3: standstill, SG min 0, mspos 168, reads 44703, writes 0 timeouts 0
                          Driver 4: standstill, SG min 0, mspos 488, reads 44703, writes 0 timeouts 0
                          Driver 5: standstill, SG min 0, mspos 408, reads 44703, writes 0 timeouts 0
                          Date/time: 2024-06-27 16:15:47
                          Slowest loop: 29.62ms; fastest: 0.04ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, segments created 28, maxWait 204ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          Scheduled moves 224744, completed 224704, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                          === AuxDDARing ===
                          Segments left: 1
                          Movement lock held by null
                          File* is doing "G1 X340.993011 Y297.888000 E0.105450" in state(s) 0
                          Code queue is empty
                          === CAN ===
                          Messages queued 10186, received 8489, lost 0, boc 0
                          Longest wait 5ms for reply type 6024, peak Tx sync delay 372, free buffers 50 (min 49), ts 1726/1726/0
                          RX/TX seq numbers: 19094/19094
                          State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2ab5c
                          Buffer RX/TX: 1392/2864-0, open files: 0
                          Duet Control Server v3.4.6
                          File /opt/dsf/sd/gcodes/Guiro 12in_3.4.6Test_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing
                          HTTP:
                          Executing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics"
                          > Next stack level
                          File:
                          Buffered code: G1 X340.993 Y297.888 E.10545
                          Buffered code: G1 X342.308 Y298.665 E.10599
                          Buffered code: G1 X343.57 Y299.538 E.10648
                          Buffered code: G1 X344.154 Y300.008 E.05202
                          Buffered code: G1 X344.773 Y300.507 E.05517
                          Buffered code: G1 X345.912 Y301.567 E.10797
                          Buffered code: G1 X346.982 Y302.707 E.10849
                          Buffered code: G1 X347.988 Y303.921 E.1094
                          Buffered code: G1 X348.928 Y305.199 E.11008
                          Buffered code: G1 X349.801 Y306.533 E.11063
                          Buffered code: G1 X350.614 Y307.927 E.11198
                          Buffered code: G1 X351.353 Y309.347 E.11108
                          Buffered code: G1 X352.021 Y310.789 E.11027
                          Buffered code: G1 X352.628 Y312.265 E.11074
                          Buffered code: G1 X353.165 Y313.751 E.10964
                          Buffered code: G1 X353.636 Y315.246 E.10876
                          Buffered code: G1 X354.039 Y316.739 E.10731
                          Buffered code: G1 X354.375 Y318.223 E.10558
                          Buffered code: G1 X354.641 Y319.687 E.10325
                          Buffered code: G1 X354.846 Y321.122 E.10058
                          Buffered code: G1 X354.995 Y322.53 E.09825
                          Buffered code: G1 X355.09 Y323.879 E.09384
                          Buffered code: G1 X355.137 Y325.313 E.09956
                          Buffered code: G1 X355.137 Y326.466 E.08001
                          Buffered code: G1 X355.088 Y327.775 E.09089
                          Buffered code: G1 X355.005 Y328.922 E.0798
                          Buffered code: G1 X354.754 Y330.938 E.14097
                          Buffered code: G1 X354.577 Y331.92 E.06924
                          Buffered code: G1 X354.355 Y332.922 E.07121
                          Buffered code: G1 X354.128 Y333.784 E.06185
                          Buffered code: G1 X353.652 Y335.265 E.10794
                          Buffered code: G1 X353.182 Y336.446 E.0882
                          ==> 1536 bytes
                          Code buffer space: 1272
                          Full transfers per second: 38.87, max time between full transfers: 43.7ms, max pin wait times: 56.7ms/1.0ms
                          Codes per second: 21.21
                          Maximum length of RX/TX data transfers: 3672/1664
                          1LC
                          Duet TOOL1LC rev 1.1 or later firmware version 3.4.6 (2023-07-21 14:17:33)
                          Never used RAM 2484, free system stack 25 words
                          Tasks: Move(notifyWait,0.6%,99) HEAT(notifyWait,0.5%,75) CanAsync(notifyWait,0.0%,65) CanRecv(notifyWait,0.1%,74) CanClock(notifyWait,0.0%,65) ACCEL(notifyWait,0.0%,61) TMC(delaying,2.9%,57) MAIN(running,90.9%,351) IDLE(ready,0.0%,26) AIN(delaying,5.0%,142), total 100.0%
                          Last reset 04:20:12 ago, cause: power up
                          Driver 0: pos 7425929, 405.0 steps/mm,ok, SG min 0, read errors 0, write errors 1, ifcnt 238, reads 13513, writes 18073, timeouts 1, DMA errors 0, CC errors 18073, failedOp 0xec, steps req 281499 done 281503
                          Moves scheduled 215982, completed 215979, in progress 1, hiccups 0, step errors 0, maxPrep 584, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                          Peak sync jitter 1/5, peak Rx sync delay 210, resyncs 0/0, next step interrupt due in 134 ticks, enabled
                          VIN voltage: min 20.9, current 23.7, max 24.3
                          MCU temperature: min 44.2C, current 53.7C, max 57.6C
                          Last sensors broadcast 0x00000002 found 1 152 ticks ago, 0 ordering errs, loop time 1
                          CAN messages queued 7108, send timeouts 0, received 10187, lost 0, free buffers 37, min 36, error reg 0
                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 424, adv 36414/74668
                          I2C bus errors 0, naks 0, other errors 0
                          Interrupt 5 to 24us, poll 24 to 1733us
                          Driver 0: ok
                          I also ran M350 while printing with the over extrusion and it still says everything is a x16.
                          	M350
                          Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on)
                          As for the wire I tested all connections with multimeter and there doesn’t seem to be any shorts I could find. I however did not ground the hot end metal work, never did since I put it together around 2022 and it is mounted directly on the Hermes/Hemera which is mounted on a 0.25in SS bracket. While in the over extrusion face of the print I touched everything in the 1LC and nothing feels hot to the touch.
                          Completely missed that in the documentation. I’ve tried 3.4.6, 3.5.0RC4,3.5.1 and 3.5.2 and the same thing keeps happening. And up to this point everything was working fine even when jumping to unstable releases. I'm leaning towards a faulty 1LC unless there is something that I'm missing.
                          Here are the pictures requested:
                          *Edit:
                          Also, I live in Tampa Florida and these past couple of weeks we’ve seen some thunder storms for about two weeks straight. Don’t know if it is relevant but might as well mention it. I do not have the printer on an UPS.
                            @gloomyandy
                            Yes, so far I’ve tried 3.4.6, 3.5.0RC4,3.5.1 and 3.5.2 and the same thing keeps happening. I'm leaning towards a faulty 1LC unless there is something that I'm missing .
                              @charliedrums said in Random overextrusion after 3+hours of printing FW 3.5.2:
                              Is the SS bracket grounded? If not, I don't think it would hurt to try, or make sure the motor is grounded, particularly if the alternative is replacing the 1LC. May be the hot, humid, thundery weather, and a particular filament is enough to make it more susceptible to static discharge. I'd imagine it's discharging through the motor wires, into the driver, and messing that up. To reiterate our advice:
                                @charliedrums Is there any chance this could be related to temperature of your extruder or extruder motor? I wonder if after a long time your are getting "heat creep" that impacts the ability for the extruder to perform a retract, perhaps the filament is softened and so the extruder fails to grip it? You mentioned earlier that you needed to reboot for the problem to go away. Couple of tests you could try....
                                1. Wait for the problem to happen, reboot the computer and start the print again (do not allow any time for things to cool down).
                                2. Wait for the problem to happen, do not reboot, but allow the printer to cool down completely, then start the print again.
                                If in case 1 the problem does not happen for a few hours we can probably ignore heat. If in case 2 it takes a couple of hours for the problem to appear, then maybe heat is involved.
                                When you fitted the SZP, did you make any other changes? Is there any chance that the way the SZP is fitted that the airflow around the extruder has been reduced/changed?
                                  @droftarts
                                  It was not grounded but it is now. Since it takes a couple of days to get here I went and ordered a 1LC v1.3 board to see if that changes anything.
                                  I updated the bootloader on the 1LC and I have grounded the bracket and now the screws and the hemera are grounded. This time I started a print and it started over extruding right from the start. Maybe now with the updated bootloader and grounded everything, updaye everything to 3.5.2 and see what happens? I'll keep trying stuff until the new 1LC gets here. I'll keep the thread updated to my findings.
                                    @gloomyandy
                                    I don't think it is heat related. I do a lot of hueforge, so the way I have the pause script is to turn off the extruder and park the extruder. So at least twice of the tests have been, set the print and go to bed, when I wake up it has been paused for a couple of hours letting the extruder cool down. I proceed to bring it up to temperature remove filament, trim it, and finally purge filament before resuming the print. After this the problem persists. But I'll give ot a try.
                                    I bought a new 1lcv1.3 from filastruder so I have a couple of days before it gets here where I can keep investigating to see if I can pinpoint the problem.
                                      charliedrums
                                      Small update. While waiting for the new 1LCv1.3 to get here I decided to remake all the cable harnesses that connect to the 1LC board I got the correct crimper and crimped everything correctly with new JST-PH connectors (trying to get these perfect is not that easy). After this I tried again but same thing After a couple of hours the extruder randomly starts over extruding. So this eliminates any bad crimps or harness connections.
                                      I also took the board off the extruder and inspected everything to see if there was any visible damage. But there was nothing that I could see. Is there any test to see if the board is busted in any way?
                                      OwenDundefined 1 Reply Last reply Reply Quote 0
                                      • OwenDundefined
                                        OwenD @charliedrums
                                        @charliedrums
                                        Have you scanned the Gcode at that area?
                                        I once had a similar issue that was doing my head in.
                                        It turned out that in one of the settings in PrusaSlicer, I had a value entered as a percentage when it should have been an 1 based factor.
                                        So instead of be 75% of the extrusion value, it was 75X the value.
                                        I never figured out if I made an error, or there was a change in the software (unlikely), or if it was me caopying configs between prusa slicer and super slicer.
                                        I think it was in overhangs.
                                        In any case, maybe check for sudden increases in the E values for moves in that area.
                                          deckingman
                                          I haven't read this entire thread so I might have missed something but another option/thing to check is if the Z axis is moving properly. If the Z axis has some "stiction" or other movement related issue which prevents it from moving the full layer height, then this can seem like over extrusion. i.e. if you extrude enough filament for (say) 0.3mm layer height but the Z axis has only moved (say) 0.1mm, then this can seem like over extrusion.
                                            charliedrums @OwenD
                                            @OwenD I have printed the gcode before. Probably like 30 t50 times and it has always worked. Still gave it a look but found nothing out of the ordinary.
