    TRONXY VEHO 100 2E
    421
    • kmjr20undefined
      kmjr20 @jumpedwithbothfeet
      @jumpedwithbothfeet
      I am having the same problem. The machine worked before, but after installing the duet board and following the directions from duet and reprap, the motor vibrate and do not move. I also have 2 independent Z axis motors that have to optical stop/limit switches. I also installed the BL Touch, but it will not let me use the IO for both motor z motors. And the wiring for the steppers is the same as it was before. I am ready to can this board and go with something else. How can I fix this problem
      jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 0
      • kmjr20undefined
        kmjr20 @oliof
        @oliof
        Thanks,
        I will do that
        • jumpedwithbothfeetundefined
          jumpedwithbothfeet @kmjr20
          @kmjr20 It`s best to start a new thread, attach your config and M122 to it, it does sound like you have a wiring issue with your motors check A+,A-,B+,B- match at both ends using the board and motor schematics.
          6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
          kmjr20undefined 1 Reply Last reply Reply Quote 1
          • bug2k22undefined
            bug2k22 @kmjr20
            @kmjr20 I have a printer with 2 independent z motors and a bl touch as the z probe/endstop here is my homez.g which probes at the middle of the bed first, then levels the bed by checking each side of the bed where the z leadscrews are and then finally does another z height check in the middle of the bed once the left and right z motors have levelled.
            M561       ; Cancel any currently active mesh compensation
            ; increase Z
            G91                                    ; relative positioning
            G1 H2 Z5                               ; move Z relative to current position to avoid dragging nozzle over the bed
            G90                                    ; absolute positioning
            ; home Z
            ; NOTE: The following XY position is determined from the probe grid defined in the next section
            var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
            var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
            G1 X{var.xCenter} Y{var.yCenter} F6000 ; go to bed centre
            G30                                    ; probe the bed
            while true
                G30 P0 X0 Y150 Z-99999 ; probe near a leadscrew, half way along Y axis
                G30 P1 X252 Y150 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                if abs(move.calibration.initial.deviation) < 0.01 || iterations > 4
                    break
            ; Probe the height again after syncing the z motors
            G30                                    ; probe the bed
            • kmjr20undefined
              kmjr20 @oliof
              @oliof
              This is the config that reprap generated. The x/y move slightly then stop, the 2 z axis motor just hum and vibrate. I checked the wiring according to the manual, but they worked on the tronxy board. The bed is 1000mm by 1000mm in the XY and 1000mm in the z axis. What am I doing wrong?
              ; Smart Drivers
              M569 P0.0 S1 D2 ; driver 0.0 goes forwards (X axis)
              M569 P0.1 S1 D2 ; driver 0.1 goes forwards (Y axis)
              M569 P0.2 S0 D2 ; driver 0.2 goes backwards (Z axis)
              M569 P0.3 S0 D2 ; driver 0.3 goes backwards (w axis)
              M569 P0.4 S1 D2 ; driver 0.4 goes forwards (extruder 0)
              M569 P0.5 S1 D2 ; driver 0.5 goes forwards (extruder 1)
              ; Motor Idle Current Reduction
              M906 I30 ; set motor current idle factor
              M84 S30 ; set motor current idle timeout
              ; Axes
              M584 X0.0 Y0.1 Z0.2 'w0.3 ; set axis mapping
              M350 X16 Y16 Z16 'w16 I1 ; configure microstepping with interpolation
              M906 X800 Y800 Z800 'w800 ; set axis driver currents
              M92 X80 Y80 Z400 'w400 ; configure steps per mm
              M208 X0:990 Y0:990 Z0:990 'w0:990 ; set minimum and maximum axis limits
              M566 X900 Y900 Z12 'w12 ; set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z180 'w180 ; set maximum speeds (mm/min)
              M201 X500 Y500 Z20 'w20 ; set accelerations (mm/s^2)
              M584 X0 Y1 Z2:3 E4:5 ; Driver 0 controls the X motor, 1 controls Y, 2 and 3 control Z motors, 4 5 and 6 control E motors
              M671 X-15.0:100.0:215.0 Y220.0:-20.0:220.0 ; Z pivot points are at (-15,220), (100,-20) and (215,220)
              M208 X-5:990 Y0:990 ; X carriage moves from -5 to 990, Y bed goes from 0 to 990
              ; Extruders
              M584 E0.4:0.5 ; set extruder mapping
              M350 E16:16 I1 ; configure microstepping with interpolation
              M906 E1000:1000 ; set extruder driver currents
              M92 E420:420 ; configure steps per mm
              M566 E120:120 ; set maximum instantaneous speed changes (mm/min)
              M203 E3600:3600 ; set maximum speeds (mm/min)
              M201 E250:250 ; set accelerations (mm/s^2)
              ; Kinematics
              M669 K0 ; configure Cartesian kinematics
              ; Probes
              M558 K0 P9 C"io7.in" H5 F120 T6000 ; configure BLTouch probe via slot #0
              G31 P500 X0 Y0 Z0.7 ; set Z probe trigger value, offset and trigger height
              M950 S0 C"io7.out" ; create servo #0 for BLtouch
              M574 X1 P"io3.in" S1 ; configure X axis endstop
              M574 Y1 P"io4.in" S1 ; configure Y axis endstop
              M574 Z2 S2 ; configure Z axis endstop
              M574 'w1 S2 ; configure w axis endstop
              ; Mesh Bed Compensation
              M557 X25:175 Y25:175 S40:40 ; define grid for mesh bed compensation
              ; Sensors
              M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0
              M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1
              M950 H0 C"out0" T0 ; create heater #0
              M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0
              M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0
              M950 H1 C"out1" T1 ; create heater #1
              M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1
              M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1
              ; Heated beds
              M140 P0 H0 ; configure heated bed #0
              M950 F0 C"out7" ; create fan #0
              M106 P0 C"Cooling Fan" S0 L0 X1 B0.1 ; configure fan #0
              M950 F1 C"out8" ; create fan #1
              M106 P1 C"Hot End Fan" S0 B0.1 H1 T45 ; configure fan #1
              M563 P0 S"Extruder 1" D0 H1 F0 ; create tool #0
              M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
              M563 P1 S"Extruder 2" D1 H1 F0 ; create tool #1
              M568 P1 R0 S0 ; set initial tool #1 active and standby temperatures to 0C
              Phaedruxundefined kmjr20undefined 2 Replies Last reply Reply Quote 0
              • kmjr20undefined
                kmjr20 @bug2k22
                @bug2k22
                thank you I will give it a try
                  Phaedrux Moderator @kmjr20
                  Please send M98 P"config.g" and post any messages you get.
                  @kmjr20 said in TRONXY VEHO 100 2E:
                  ; Axes
                  Why do you have 'w entries here? If you're intending to comment them out, you must use a semi colon.
                  For your motor wiring, have you verified that you have the phases paired correctly for the Duet?
                  https://docs.duet3d.com/en/User_manual/Connecting_hardware/Motors_connecting#identifying-the-stepper-motor-phases
                  • kmjr20undefined
                    kmjr20
                    Thank you for the suggestions. I started with a TRONXY printer that was broken out of the box. They would not exchange or fix, so I decided to try and update the power supply and computer. I also added BL Touch. After following all the directions and watching endless videos, I am frustrated that it is not easier to fix. The motor for the Z axis just hum and sometimes move a little, the x & Y movement but never complete the homing, so I am stuck. I have tried everyry thing that I m told, but I am getting ready to bring it to the dump. I thought I could find some dites that teach what the parameter mean after the code, but I am have found anything.
                    • kmjr20undefined
                      kmjr20
                      This is the config file. As I said I get an error that it can't home, or it didn't home, and you can't manually do it either. I am not a programmer for printers and am lost with all the codes and no explanation of what all the parameters mean.
                      ; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC
                      ; generated by RepRapFirmware Configuration Tool v3.5.1 on Mon Jun 24 2024 18:43:06 GMT-0400 (Eastern Daylight Time)
                      ; General
                      M575 P1 S0 B57600 ; configure PanelDue support
                      G90 ; absolute coordinates
                      M83 ; relative extruder moves
                      M550 P"TRONXY" ; set hostname
                      ; Accessories
                      M552 I1 S0
                      M552 I1 S1
                      M587 S"Comstat-1QVR3" P:art7206row2unnamed!"
                      M552 P0.0.0.0 S1 ; configure Ethernet adapter
                      M586 P0 S1 ; configure HTTP
                      ; Smart Drivers
                      M569 P0.2 S0 D2 ; driver 0.2 goes Backwards (Z axis)
                      M569 P0.3 S0 D2 ; driver 0.3 goes Backwards (w axis)
                      ; Axes
                      M584 X0 Y1 Z2:3 E3; two Z motors connected to driver 2 (left motor) and driver 3 (right motor)
                      M671 X-20:990 Y0:0 S0.5 ; position of leadscrew/bed pivot point at left and right of X axis
                      M208 X-5:990 Y0:990 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200
                      M208 X990 Y990 S0 Z990 w990 S1 ; set axis maxima and high homing switch positions (adjust to suit your machine)
                      M208 X-8 Y0 Z0.5 S0 ; set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
                      ; home Z
                      G30 ; probe the bed
                      while true
                      break
                      M950 S0 C"io7.out" ; create servo pin 0 for BLTouch (use IO_4/5/7 for 6HC, IO_1/2/3 for Mini 5+)
                      M558 P9 C"io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                      G31 P500 X25 Y0 Z2.5 'w2.5 ; set Z probe trigger value, offset and trigger height
                      G30 ; probe the bed
                      ; Extruders
                      ; Kinematics
                      ; Probes
                      G31 P500 X0 Y0 Z0.7 'w0.7 ; set Z probe trigger value, offset and trigger height
                      M574 'w2 S2 ; configure w axis endstop
                      ; Sensors
                      M143 H0 S120
                      M308 S1 P"temp1" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin temp1
                      M308 S2 P"temp2" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 2 as thermistor on pin temp2
                      M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
                      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                      M143 H2 S280 ; set temperature limit for heater 2 to 280C ; set temperature limit for heater 0 to 120C
                      ; Heated beds
                      • oliofundefined
                        oliof @kmjr20
                        @kmjr20 you can find a description of all the parameters in the documentation at https://docs.duet3d.com/
                        There is a search bar at the top which has the secret that you must not hit enter after typing your search term for it to work.
                        • oliofundefined
                          oliof
                          Can you tell me what the W axis is supposed to be? I don't see an extra axis on the images I can find of the printer.
                          Also, please share the contents of homex.g, homey.g, homez.g, homeall.g (and homew.g), as well as a verbatim copy of the error you get.
                          • kmjr20undefined
                            kmjr20 @kmjr20
                            @kmjr20
                            I have looked everywhere for some videos on programming. I am new to this.
                            I have a TRONXY Veho 1000 and it was defective out of the box. With no warranty from the company I put a duet 3 6hc board in it. I can not get the thing to home or do anything. When I try to home it says g1 error, no axis homed. I finally tried a new configuration of (below), when I hit the hom, the x axis motor goes in the opposite direction of the end stop, moves very slow for about 50mm then stops, the Y axis does the same thing. I can not find any information on why or how this happens. When I go to the paneldue control and press the move button it moves much faster but does not go all the way and then says there are no end stops when I run the M119 command. I keep getting such helpfullinfo as look at the duet manual, check out the duet web forum. I have and can't find anything but specs.
                            M552 I1 S0
                            M552 I1 S1
                            ; Smart Drivers
                            M569 P0.0 S0 D2 ; driver 0.0 goes backwards (X axis)
                            M569 P0.1 S1 D2 ; driver 0.1 goes backwards (Y axis)
                            M569 P0.2 S0 D2 ; driver 0.2 goes forwards (Z axis)
                            M569 P0.3 S0 D2 ; driver 0.3 goes forwards (Z axis)
                            M569 P0.4 S0 D2 ; driver 0.4 goes backwards (extruder 0)
                            M569 P0.5 S0 D2 ; driver 0.5 goes backwards (extruder 1)
                            ; Axes
                            M584 X0.0 Y0.1 Z0.2:0.3 ; set axis mapping
                            M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                            M906 X1000 Y1000 Z1200 ; set axis driver currents
                            M92 X80 Y80 Z400 ; configure steps per mm
                            M208 X0:1000 Y0:1000 Z0:1000 ; set minimum and maximum axis limits
                            M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min)
                            M201 X500 Y500 Z20 ; set accelerations (mm/s^2)
                            M950 S0 C"121.io7.out"                           ; create servo pin 0 for BLTouch
                            M558 P9 C"121.io7.in" H-5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
                            G31 P500 X0 Y0 Z-2.5                              ; set Z probe trigger value, offset and trigger height
                            M557 X15:990 Y15:990 S20                         ; define mesh grid
                            ; Extruders
                            M591 D0 P1 C"e0_stop" S1  ; filament monitor connected to E0_stop
                            M591 D0 ; display filament sensor parameters for extruder drive 0
                            M591 D1 P1 C"e1_stop" S1  ; filament monitor connected to E0_stop
                            M591 D1 ; display filament sensor parameters for extruder drive 0
                            ; Kinematics
                            ; Probes
                            M574 X1 S1 P"!io0.in"  ; configure X axis endstop
                            M574 Y2 S1 P"!io1.in"  ; configure Y axis endstop
                            M574 Z1 S2 P"io2.in"  ; configure Z axis endstop
                            M574 Z1 S2 P"io3.in"  ; configure Z axis endstop
                            M557 X50:975 Y50:975 S40:40 ; define grid for mesh bed compensation
                            ; Sensors
                            M307 H0 R2.43 D5.5 E1.35 K0.56 B1 ; configure model of heater #0
                            ; Heated beds
                            M563 P0 S"Extruder 0" D0 H1 F0 ; create tool #0
                            M563 P1 S"Extruder 1" D1 H1 F0 ; create tool #1
                              droftarts administrators @kmjr20
                              @kmjr20 Please send M119 in the console, and post the output. Also do this for M122, so we can see what firmware version you are using.
                              Errors in your config.g:
                              M552 I1 S0
                              M552 I1 S1
                              You only need these lines if you have a WiFi adapter for your 6HC. Otherwise, delete them. M587 should not be in config.g at all.
                              You have set the Z probe to be on a CAN-connected toolboard, but I can't see any other other device connected this way. Where is the BLTouch connected? Do you have a CAN toolboard? If the BLTouch is connected to io7 on the 6HC, remove the '121.' from the pin assignments.
                              These are Duet 2 pin assignments, not Duet 3 6HC. Where have you connected the filament monitors?
                              This endstop configuration is saying that the X endstop is at the low end (ie where X=0), and the Y endstop is at the high end (ie where Y=1000). Is that correct?
                              S2 means 'use probe'. You don't need to define the pin here, as it is already defined for the probe. Delete these two lines. If you do have an endstop for each Z motor, the command should be something like M574 Z1 S1 P"io2.in+io3.in".
                              Finally, documentation for testing and checking:
                              • It would be good to read all of this page: https://docs.duet3d.com/en/How_to_guides/Commissioning
                              • Test endstops: https://docs.duet3d.com/en/How_to_guides/Commissioning#h-8-check-endstops
                              • Check motors go the right direction, test homing: https://docs.duet3d.com/en/How_to_guides/Commissioning#h-10-check-stepper-motors
                              • kmjr20undefined
                                @jumpedwithbothfeet
                                i GUESS THAT WOULD WORK IF i KNEW PROGRAMMING. i CANT EVEN FIND A VIDEO OF WHAT THESE COMMAND DO OR WHAT THE PARAMETERS STAND FOR AFTER THEM. iTS JUST "p" XX, AND ITS DIFFERENT DEPENDING ON THE m OR g COMMAND AND WHICH ONE. aLL THE RESPONSES i GET ARE LINKS TO THE DUET WEBSITE. i KNOW HOW TO READ AND FOLLOWED THE DIRECTIONS TO A T.
                                i AM GOING TO GO THE THE bigtree tech board. I called them and they actually answer the phone and have information. I have posted 11 times now and still can't get an answer yer other than send me the code, which I have or a message with a link to DUET Manual. It would be nice to have a response other than what I am getting. I feel like I am getting an AI and not a person, because its the same response.
                                  @kmjr20 You get the links because all the information is already written down for you, did you check the connections like I suggested?
                                    I've moved the messages from the 2-year-old thread (https://forum.duet3d.com/topic/27374/duet-3-mainboard-6hc-motors-not-working/) to this one.
