    Random overextrusion after 3+hours of printing FW 3.5.2
    Beta Firmware
    1.2k
    • charliedrumsundefined
      charliedrums
      Small update. While waiting for the new 1LCv1.3 to get here I decided to remake all the cable harnesses that connect to the 1LC board I got the correct crimper and crimped everything correctly with new JST-PH connectors (trying to get these perfect is not that easy). After this I tried again but same thing After a couple of hours the extruder randomly starts over extruding. So this eliminates any bad crimps or harness connections.
      I also took the board off the extruder and inspected everything to see if there was any visible damage. But there was nothing that I could see. Is there any test to see if the board is busted in any way?
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @charliedrums
        @charliedrums
        Have you scanned the Gcode at that area?
        I once had a similar issue that was doing my head in.
        It turned out that in one of the settings in PrusaSlicer, I had a value entered as a percentage when it should have been an 1 based factor.
        So instead of be 75% of the extrusion value, it was 75X the value.
        I never figured out if I made an error, or there was a change in the software (unlikely), or if it was me caopying configs between prusa slicer and super slicer.
        I think it was in overhangs.
        In any case, maybe check for sudden increases in the E values for moves in that area.
        charliedrumsundefined 1 Reply Last reply Reply Quote 0
          deckingman
          I haven't read this entire thread so I might have missed something but another option/thing to check is if the Z axis is moving properly. If the Z axis has some "stiction" or other movement related issue which prevents it from moving the full layer height, then this can seem like over extrusion. i.e. if you extrude enough filament for (say) 0.3mm layer height but the Z axis has only moved (say) 0.1mm, then this can seem like over extrusion.
            charliedrums @OwenD
            @OwenD I have printed the gcode before. Probably like 30 t50 times and it has always worked. Still gave it a look but found nothing out of the ordinary.
              charliedrums
              Ok, so the new 1LC (v1.3) board came in today. I decided to start everything with a new install on a Pi5. using
              image_2024-04-19-DuetPi-arm64. Once I built the image and assembled everything I updated all the boards thought putty. Interesting that when I do a toolboard diagnostics it says that the toolboard is version 1.1 not 1.3.
              Now whoever I'm having a new problem. After updating everything on FW3.5.2, I go to start the print everything looks good and is heating up as it should but once heating up finishes and it starts to move to the the homing routine a couple of things happen. *Edit Before I start any print or anything I can probe and scan the bed without any problems.
              Error: Expansion board 120 reconnected
              Error: Expansion board 121 reconnected
              then the scanning z probe starts scanning the bed and in every pass I get this error.
              Error: Board 120 does not have input handle 3040
              and in DWC this is how the teperature is reported after this happens
              I have no Idea whats going on now. All I did is change the 1LC board.
              Here are the diagnostics. of all boards.
              RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (SBC mode)
              Board ID: 08DJM-956BA-NA3TN-6JTD0-3SJ6S-1V82V
              Used output buffers: 11 of 40 (40 max)
              Static ram: 155360
              Dynamic ram: 91860 of which 3080 recycled
              Never used RAM 92188, free system stack 136 words
              Tasks: LASER(5,nWait 7,0.0%,169) SBC(2,rWait:,0.9%,801) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,1.8%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.6%,53) MAIN(2,running,87.4%,101) IDLE(0,ready,0.2%,29), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 00:23:03 ago, cause: power up
              Last software reset at 2024-07-01 18:02, reason: MemoryProtectionFault mmarValid daccViol, Platform spinning, available RAM 92476, slot 1
              Software reset code 0x4160 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0440f804 BFAR 0x00000000 SP 0x204198e8 Task IDLE Freestk 20 ok
              Stack: 20419968 00000000 2041999c 20419960 a5a5a5a5 0049a485 0049a0e0 61000000 61000000 a5a5a5a5 2041999c fffc0000 20425daf 20419958 2041995c 43f8e92d 20419960 00000000 ffffffff 004999a9 43f8e92d 00000000 20419960 00000000 00000001 204199e0 4e49414d
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU temperature: min 33.6, current 42.0, max 42.1
              Supply voltage: min 23.7, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
              Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/72/72, gc cycles 0
              Events: 2 queued, 2 completed
              Driver 0: ok, SG min 0, mspos 628, reads 55863, writes 17 timeouts 0
              Driver 1: ok, SG min 0, mspos 913, reads 55863, writes 17 timeouts 0
              Driver 2: standstill, SG min 0, mspos 520, reads 55863, writes 17 timeouts 0
              Driver 3: standstill, SG min 0, mspos 936, reads 55863, writes 17 timeouts 0
              Driver 4: standstill, SG min 0, mspos 952, reads 55863, writes 17 timeouts 0
              Driver 5: standstill, SG min 0, mspos 104, reads 55864, writes 17 timeouts 0
              Date/time: 2024-07-01 18:25:49
              Slowest loop: 77.42ms; fastest: 0.04ms
              === Storage ===
              Free file entries: 20
              DMs created 125, segments created 27, maxWait 199391ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
              next step interrupt due in 1 ticks, disabled
              Moves shaped first try 1321, on retry 722, too short 604, wrong shape 12745, maybepossible 120
              === DDARing 0 ===
              Scheduled moves 17499, completed 17443, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
              === DDARing 1 ===
              Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Heater 0 is on, I-accum = 0.1
              HTTP* is doing "M122" in state(s) 0 0, running macro
              Telnet is idle in state(s) 0
              File* is doing "G1 X336.225006 Y327.441986 E0.046660" in state(s) 0
              USB is idle in state(s) 0
              Aux is idle in state(s) 0
              Queue* is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 1, axes/extruders owned 0x80000007
              Code queue 0 is empty
              Code queue 1 is empty
              === Filament sensors ===
              check 0 clear 0
              Extruder 0 sensor: no data received
              === CAN ===
              Messages queued 28613, received 21465, lost 0, errs 641, boc 0
              Longest wait 6ms for reply type 6024, peak Tx sync delay 250, free buffers 50 (min 48), ts 6920/6919/0
              Tx timeouts 0,0,0,0,0,0
              === SBC interface ===
              Transfer state: 5, failed transfers: 0, checksum errors: 0
              RX/TX seq numbers: 53966/53966
              SPI underruns 0, overruns 0
              State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x24cfc
              Buffer RX/TX: 3248/48-4096, open files: 0
              === Duet Control Server ===
              Duet Control Server version 3.5.2 (2024-06-12 07:12:47, 64-bit)
              HTTP+Executed:
              > Executing M122
              File 0:/gcodes/Guiro 12in_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing
              HTTP:
              >> Doing macro 0:/macros/Diagnostics, started by M98 P"0:/macros/Diagnostics"
              File:
              Buffered code: G1 X336.225 Y327.442 E.04666
              Buffered code: G1 X336.573 Y327.959 E.05293
              Buffered code: G1 X336.881 Y328.464 E.05023
              Buffered code: G1 X337.357 Y329.369 E.08267
              Buffered code: G1 X337.635 Y329.988 E.05459
              Buffered code: G1 X337.85 Y330.524 E.04646
              Buffered code: G1 X338.183 Y331.522 E.08229
              Buffered code: G1 X338.49 Y332.75 E.09722
              Buffered code: G1 X338.669 Y333.816 E.08108
              Buffered code: G1 X338.748 Y334.521 E.05168
              Buffered code: G1 X338.797 Y335.606 E.07913
              Buffered code: G1 X338.763 Y336.843 E.08942
              Buffered code: G1 X338.686 Y337.585 E.05172
              Buffered code: G1 X338.569 Y338.329 E.0515
              Buffered code: G1 X338.414 Y339.049 E.04953
              Buffered code: G1 X338.163 Y339.93 E.06047
              Buffered code: G1 X337.864 Y340.77 E.05791
              Buffered code: G1 X337.827 Y340.861 E.00612
              Buffered codes: 864 bytes total
              Code buffer space: 3200
              Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
              Full transfers per second: 38.34, max time between full transfers: 64.4ms, max pin wait times: 34.9ms/3.8ms
              Codes per second: 12.04
              Maximum length of RX/TX data transfers: 8176/1140
              1LC
              Diagnostics for board 121:
              Duet TOOL1LC rev 1.1 or later firmware version 3.5.2 (2024-06-10 13:24:04)
              Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
              All averaging filters OK
              Never used RAM 3832, free system stack 71 words
              Tasks: Move(3,nWait 7,0.2%,90) HEAT(2,nWait 6,0.1%,126) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,91.3%,412) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.5%,112), total 100.0%
              Owned mutexes:
              Last reset 00:18:59 ago, cause: power up
              Last software reset data not available
              Driver 0: pos 0, 80.0 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 55, reads 21490, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 660061
              Moves scheduled 15214, completed 15210, in progress 1, hiccups 0, segs 26, step errors 0, maxLate 0 maxPrep 210, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
              Peak sync jitter 1/6, peak Rx sync delay 245, resyncs 0/0, no timer interrupt scheduled
              VIN voltage: min 11.9, current 24.6, max 24.6
              MCU temperature: min 36.0C, current 38.5C, max 38.8C
              Last sensors broadcast 0x00000000 found 0 137 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 6671, send timeouts 0, received 20102, lost 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 369, adv 36213/74673
              Accelerometer: LIS3DH, status: 00
              I2C bus errors 0, naks 0, contentions 0, other errors 0
              Zprobe
              M122 B120
              Diagnostics for board 120:
              Duet SZP firmware version 3.5.2 (2024-06-10 13:23:26)
              Bootloader ID: SAMC21 bootloader version 2.10 (2023-11-16)
              Never used RAM 14188, free system stack 110 words
              Tasks: HEAT(2,nWait 6,0.1%,132) CanAsync(5,nWait 4,0.0%,54) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) MAIN(1,running,64.7%,430) IDLE(0,ready,0.0%,26) AIN(2,nWait 4,35.1%,72), total 100.0%
              Owned mutexes: I2C(AIN)
              Last reset 00:19:13 ago, cause: power up
              Last software reset at 2024-03-12 06:08, reason: StackOverflow, available RAM 14136, slot 0
              Software reset code 0x0100 ICSR 0x0041a00e SP 0x20007f34 Task ACCE Freestk 5138 ok
              Stack: 20002e70 20002ea4 00014913 200029a4 20002ac0 20002998 000139f1 20002ac0 fffffffd 0000002a 00000000 20007f8c 00000000 20007f8c 00014677 00000000 200010a4 20001028 00013eb7 20001028 200010a4 00000032 454c4449 00019000 00012683 200011c0 200011c0
              Peak sync jitter 1/6, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
              VIN voltage: min 4.4, current 5.0, max 5.0
              MCU temperature: min 27.5C, current 30.1C, max 30.2C
              Last sensors broadcast 0x00000000 found 0 165 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 5518, send timeouts 0, received 11275, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
              Accelerometer: LIS2DW, status: 00
              Inductive sensor: raw value 39288477, frequency 3.66MHz, current setting 13, ok
              I2C bus errors 0, naks 3, contentions 0, other errors 0
              any help would be greatly appreciated.
                charliedrums @charliedrums
                Ok so I narrowed down the tool Expansion board 121 reconnected error to the harness connection between the scanning z probe and the tool board harness. I mystically did not plug it in all the way. Having plugged it in correctly I started a new test print with the new 1LC board but still I’m having the same over extrusion problem at random times. Sometimes is at the start of the print, sometimes is at layer 5, sometimes its 3+ hours into the print.
                So I decided to go back to the basics I disconnected the scanning z probe and the filament sensor and updated the config.g file to comment out the scanning z probe and the filament sensor. So the only things that are plugged in to the 1LC are the extruder & cooling fan, the extruder heater, thermistor, motor, vin power and the can connection. With this configuration I started a test print to see if I keep getting the over extrusion issue. Hopefully I have a successful print on this one I really don’t want to ditch duet for Klipper and a Chinese board.
                Here are my diagnostics:
                MB6HC
                Used output buffers: 11 of 40 (29 max)
                Static ram: 155360
                Dynamic ram: 89888 of which 5072 recycled
                Never used RAM 92192, free system stack 136 words
                Tasks: SBC(2,rWait:,0.9%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,1.9%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,9.7%,53) MAIN(2,running,87.1%,101) IDLE(0,ready,0.3%,29), total 100.0%
                Last reset 00:19:02 ago, cause: software
                Last software reset at 2024-07-01 22:29, reason: User, Gcodes spinning, available RAM 95744, slot 0
                Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 37.2, current 42.1, max 42.2
                Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/48/48, gc cycles 0
                Events: 1 queued, 1 completed
                Driver 0: ok, SG min 0, mspos 366, reads 41818, writes 17 timeouts 0
                Driver 1: ok, SG min 0, mspos 1010, reads 41818, writes 17 timeouts 0
                Driver 2: ok, SG min 0, mspos 277, reads 41818, writes 17 timeouts 0
                Driver 3: ok, SG min 0, mspos 59, reads 41818, writes 17 timeouts 0
                Driver 4: ok, SG min 0, mspos 859, reads 41818, writes 17 timeouts 0
                Driver 5: ok, SG min 0, mspos 229, reads 41818, writes 17 timeouts 0
                Date/time: 2024-07-01 22:48:14
                Slowest loop: 1369.34ms; fastest: 0.05ms
                === Storage ===
                DMs created 125, segments created 26, maxWait 99861ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                next step interrupt due in 383 ticks, disabled
                Moves shaped first try 1182, on retry 654, too short 544, wrong shape 10891, maybepossible 117
                === DDARing 0 ===
                Scheduled moves 15092, completed 15032, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                === DDARing 1 ===
                Heater 0 is on, I-accum = 0.2
                Heater 1 is on, I-accum = 0.0
                File* is doing "G1 X329.549988 Y341.337006 E0.083270" in state(s) 0
                === CAN ===
                Messages queued 24111, received 22784, lost 0, errs 1, boc 0
                Longest wait 2ms for reply type 6026, peak Tx sync delay 323, free buffers 50 (min 49), ts 5711/5710/0
                RX/TX seq numbers: 45007/45007
                Buffer RX/TX: 3264/752-4080, open files: 0
                HTTP+Executed:
                > Executing M122
                File 0:/gcodes/Guiro 12in_3.4.6Test_0.6n_0.3mm_PLA_EXOCUBE_8h39m.gcode is selected, processing
                HTTP:
                File:
                Buffered code: G1 X329.55 Y341.337 E.08327
                Buffered code: G1 X328.919 Y341.965 E.06177
                Buffered code: G1 X328.509 Y342.594 E.0521
                Buffered code: G1 X328.222 Y343.222 E.04791
                Buffered code: G1 X328.016 Y343.85 E.04586
                Buffered code: G1 X327.906 Y344.479 E.04431
                Buffered code: G1 X327.95 Y344.793 E.022
                Buffered code: G1 X328.205 Y345.107 E.02807
                Buffered code: G1 X329.428 Y345.735 E.0954
                Buffered code: G1 X330.45 Y346.364 E.08327
                Buffered code: G1 X330.63 Y346.543 E.01761
                Buffered code: G1 X331.455 Y346.422 E.05786
                Buffered code: G1 X331.908 Y346.306 E.03245
                Buffered code: G1 X332.359 Y346.157 E.03296
                Buffered code: G1 X333.06 Y345.853 E.05302
                Buffered code: G1 X333.762 Y345.466 E.05562
                Buffered code: G1 X334.184 Y345.184 E.03522
                Buffered code: G1 X334.598 Y344.867 E.03618
                Buffered code: G1 X335.255 Y344.267 E.06174
                Buffered code: G1 X334.577 Y343.85 E.05523
                Buffered code: G1 X333.945 Y343.222 E.06182
                Buffered code: G1 X333.536 Y342.594 E.052
                Buffered code: G1 X333.249 Y341.965 E.04797
                Buffered code: G1 X333.042 Y341.337 E.04588
                Buffered code: G1 X332.933 Y340.708 E.0443
                Buffered code: G1 X332.976 Y340.394 E.02199
                Buffered code: G1 X333.232 Y340.08 E.02811
                Buffered code: G1 X334.455 Y339.452 E.0954
                Buffered code: G1 X335.476 Y338.823 E.08321
                Buffered code: G1 X336.108 Y338.195 E.06182
                Buffered code: G1 X336.518 Y337.567 E.05204
                Buffered code: G1 X336.805 Y336.938 E.04797
                Buffered codes: 1536 bytes total
                Code buffer space: 2512
                Full transfers per second: 39.60, max time between full transfers: 50.4ms, max pin wait times: 35.8ms/5.4ms
                Codes per second: 13.53
                Maximum length of RX/TX data transfers: 4436/1124
                1LC
                Never used RAM 3372, free system stack 71 words
                Tasks: Move(3,nWait 7,0.2%,90) HEAT(2,nWait 6,0.3%,98) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,90.8%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.8%,112), total 100.0%
                Owned mutexes:
                Last reset 00:19:06 ago, cause: software
                Driver 0: pos 0, 405.0 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 26, reads 48051, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 850185
                Moves scheduled 13946, completed 13943, in progress 1, hiccups 27, segs 26, step errors 0, maxLate 0 maxPrep 335, maxOverdue 102, maxInc 37, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                Peak sync jitter 0/5, peak Rx sync delay 228, resyncs 0/0, no timer interrupt scheduled
                VIN voltage: min 19.7, current 23.7, max 24.6
                MCU temperature: min 34.6C, current 45.0C, max 46.0C
                Last sensors broadcast 0x00000002 found 1 205 ticks ago, 0 ordering errs, loop time 0
                CAN messages queued 22882, send timeouts 0, received 24273, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 403, adv 36312/74663
                  charliedrums
                  Ok this time it was 1h 1m 28s when the over extrusion started. Any Ideas of what I could try next? Would making a new RJ11 cable from the tool distribution board help? Or re cabling the whole thing? At this point I’ll try anything.
                  Diagnostics:
                  MB6HC
                  Used output buffers: 1 of 40 (29 max)
                  Static ram: 155360
                  Dynamic ram: 89912 of which 5048 recycled
                  Tasks: SBC(2,nWait 7,0.9%,821) HEAT(3,nWait 6,0.0%,323) Move(4,nWait 6,2.5%,211) CanReceiv(6,nWait 1,0.0%,794) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,346) TMC(4,nWait 6,9.7%,53) MAIN(2,running,86.7%,101) IDLE(0,ready,0.0%,29), total 100.0%
                  Last reset 01:00:13 ago, cause: software
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU temperature: min 41.9, current 44.6, max 44.7
                  Supply voltage: min 23.7, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                  Driver 0: ok, SG min 0, mspos 444, reads 10183, writes 0 timeouts 0
                  Driver 1: ok, SG min 0, mspos 867, reads 10184, writes 0 timeouts 0
                  Driver 2: ok, SG min 0, mspos 508, reads 10184, writes 0 timeouts 0
                  Driver 3: ok, SG min 0, mspos 852, reads 10184, writes 0 timeouts 0
                  Driver 4: ok, SG min 0, mspos 628, reads 10184, writes 0 timeouts 0
                  Driver 5: ok, SG min 0, mspos 460, reads 10184, writes 0 timeouts 0
                  Date/time: 2024-07-01 23:29:26
                  Slowest loop: 31.88ms; fastest: 0.05ms
                  === Storage ===
                  DMs created 125, segments created 26, maxWait 991ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                  next step interrupt due in 166 ticks, disabled
                  Moves shaped first try 2755, on retry 1709, too short 1471, wrong shape 35430, maybepossible 500
                  === DDARing 0 ===
                  Scheduled moves 61679, completed 61619, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                  === DDARing 1 ===
                  File* is doing "G1 X337.981995 Y325.506012 E0.063910" in state(s) 0
                  === CAN ===
                  Messages queued 65895, received 49465, lost 0, errs 0, boc 0
                  Longest wait 6ms for reply type 6024, peak Tx sync delay 254, free buffers 50 (min 48), ts 12359/12359/0
                  RX/TX seq numbers: 11409/11409
                  Buffer RX/TX: 1920/3424-0, open files: 0
                  HTTP+Executed:
                  > Executing M122
                  HTTP:
                  File:
                  Buffered code: G1 X337.982 Y325.506 E.06391
                  Buffered code: G1 X338.172 Y326.122 E.04473
                  Buffered code: G1 X338.373 Y326.988 E.06169
                  Buffered code: G1 X338.475 Y327.605 E.04339
                  Buffered code: G1 X338.532 Y328.208 E.04203
                  Buffered code: G1 X338.576 Y329.165 E.06648
                  Buffered code: G1 X338.54 Y329.812 E.04496
                  Buffered code: G1 X338.477 Y330.421 E.04248
                  Buffered code: G1 X338.404 Y330.875 E.03191
                  Buffered code: G1 X338.17 Y331.76 E.06352
                  Buffered code: G1 X337.971 Y332.224 E.03503
                  Buffered code: G1 X337.819 Y332.486 E.02102
                  Buffered code: G1 X337.248 Y333.118 E.0591
                  Buffered code: G1 X336.888 Y333.48 E.03543
                  Buffered code: G1 X336.109 Y334.03 E.06617
                  Buffered code: G1 X335.767 Y334.23 E.02749
                  Buffered code: G1 X335.59 Y333.679 F15000
                  Buffered code: G1 F1500
                  Buffered code: G1 X334.92 Y333.853 E.04803
                  Buffered code: G1 X334.282 Y333.984 E.04519
                  Buffered code: G1 X333.634 Y334.091 E.04557
                  Buffered code: G1 X332.588 Y334.206 E.07302
                  Buffered code: G1 X331.473 Y334.279 E.07753
                  Buffered code: G1 X328.705 Y334.286 E.19207
                  Buffered code: G1 X327.414 Y334.206 E.08975
                  Buffered code: G1 X326.38 Y334.093 E.07218
                  Buffered code: G1 X325.719 Y333.984 E.04649
                  Buffered code: G1 X324.531 Y333.728 E.08433
                  Buffered code: G1 X324.202 Y333.548 E.02602
                  Buffered code: G1 X323.572 Y333.103 E.05352
                  Buffered code: G1 X322.915 Y332.457 E.06394
                  Buffered codes: 1472 bytes total
                  Code buffer space: 1920
                  Full transfers per second: 39.44, max time between full transfers: 54.9ms, max pin wait times: 54.5ms/4.6ms
                  Codes per second: 19.17
                  1LC
                  Tasks: Move(3,nWait 7,0.3%,88) HEAT(2,nWait 6,0.3%,90) CanAsync(5,nWait 4,0.0%,52) CanRecv(3,nWait 1,0.1%,70) CanClock(5,nWait 1,0.0%,58) ACCEL(3,nWait 6,0.0%,52) TMC(2,nWait 6,3.7%,52) MAIN(1,running,90.7%,314) IDLE(0,ready,0.0%,26) AIN(2,delaying,4.9%,112), total 100.0%
                  Owned mutexes:
                  Last reset 01:00:15 ago, cause: software
                  Driver 0: pos 0, 405.0 steps/mm, ok, SG min 0, read errors 0, write errors 2, ifcnt 168, reads 27122, writes 16826, timeouts 4, DMA errors 0, CC errors 16827, failedOp 0x71, steps req 0 done 2205650
                  Moves scheduled 57511, completed 57507, in progress 1, hiccups 80, segs 26, step errors 0, maxLate 0 maxPrep 354, maxOverdue 106, maxInc 52, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                  Peak sync jitter 0/6, peak Rx sync delay 252, resyncs 0/0, no timer interrupt scheduled
                  VIN voltage: min 11.6, current 24.2, max 24.5
                  MCU temperature: min 34.6C, current 45.2C, max 46.0C
                  Last sensors broadcast 0x00000002 found 1 143 ticks ago, 0 ordering errs, loop time 0
                  CAN messages queued 49415, send timeouts 0, received 65795, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                  dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 398, adv 36262/74666
                    deckingman @charliedrums
                    @charliedrums Looking at this logically, any print move looks like this. G1 Xnn Ynn Enn. Which means move a certain distance in X and/or Y while extruding a certain amount of filament. What you are saying is that at random times, when printing a gcode that you have printed many times before, that Enn becomes something greater. I.e, the fimant moving through the extruder randomly moves further or faster than it should do. There are many reasons why it might move less (partial blockage, temperature too low, motor or wring issue, missed steps, etc), but none that I can think of that would make the filament move further than it should. So the only logical conclusion is that something else is happening which gives the appearance of over extrusion when in fact it isn't. My best guess, as I've stated before, is that your Z axis isn't moving the full layer height.
                      charliedrums @deckingman
                      @deckingman @deckingman
                      I would have guessed the same but I have checked all 4 Z motors and their harnesses. Here is what leads me to determine it is over extrusion. First once the issue begins, I remove the print from under the extruder and let it print in air for a while and visibly one can tell the more amount of plastic is being forces through the nozzle.
                      Second, I am using the Orthus Filament Monitor. The orthus has a light that flashes intermittently when filament is running through it. The faster the blink of the light the faster the filament if passing through the sensor, when the problem begins the light flashes faster as in filament is passing faster trough the sensor/extruder. I can move the printer to the max height(365mm) and home without any problems.
                      I’m going one thing at a time right now I eliminated the z scanning probe and the filament sensor. Still happening. This time around I re did the harness that powers the tool distribution board (two cables 24v Vin ground) and am currently running the print to see if the problem continues after this, I’ll re do the RJ11 cable. Then continue from there.
                      deckingmanundefined 2 Replies Last reply Reply Quote 0
                        @charliedrums If you are certain that it is genuine over extrusion after some seemingly random period of time, then the only explanation I can think of is that somehow, something is changing the G1 Xnn Ynn Enn commands that exist in the gcode file to something like G1 Xnn Ynn E(some other value that is always higher). I note that you are using a SBC. Is there any chance that you could run stand alone mode and print directly form an SD card?
                        charliedrumsundefined 1 Reply Last reply Reply Quote 1
                          @charliedrums One other suggestion - try a print without input shaping. I can't offhand think why it should make a difference but who knows?
                            @deckingman
                            Yes, I can I don’t see why not. The only reason I have SBC is so I could get WIFI. Looking through the documentation I see that I can connect to the board directly with an ethernet cable. Next thing Ill do is that go Direct an eliminate the SBC and see. Thanks for the idea.
                            gloomyandyundefined 1 Reply Last reply Reply Quote 0
                            • OwenDundefined
                              OwenD @charliedrums
                              @charliedrums said in Random overextrusion after 3+hours of printing FW 3.5.2:
                              Good that you're keeping an open mind.
                              Having printed the code before may not prove anything.
                              For example in my case the Gcode extrusion values were far above the capabilities of the extruder, but I wasn't getting skipped steps because my maximum extruder speed values were limiting it to achievable amounts (albeit way over extruded).
                              If in the interim you had for example increased your max extruder speeds then a problem that wasn't obvious before may now appear.
                              Loading the code into Prusa Slicer and viewing it by volumetric flow rate would show up any odd areas most likely a lot more than just scanning the code by eye.
                              Have you tried swapping the drivers around that the extruder is on?
                              That should rule out a hardware fault on the board at least.
                              EDIT: Just saw that you're using a tool board and have swapped it.
                              • OwenDundefined
                                OwenD
                                Just noticed a similar post also using a toolboard
                                https://forum.duet3d.com/topic/35869/overextrusion-out-of-nowhere
                                One for @DC42 I think
                                • gloomyandyundefined
                                  gloomyandy @charliedrums
                                  @charliedrums One other thing to try, I think you said that once it gets into this "over extrusion mode" then it stays in it even when starting a new print? If that is the case can you try checking the extruder calibration when in this state see: https://docs.duet3d.com/en/How_to_guides/Calibration#h-3-calibrating-extruder-e-steps-per-mm and then do a reboot and perform the same task again and see if there is any difference.
                                  • Phaedruxundefined Phaedrux moved this topic from General Discussion
                                    charliedrums
                                    After many weeks of testing, I figured out the problem. I started re-wiring every cable to eliminate any problem with the harnesses. Once I got to the power from the Mainboard 6HC to the tool distribution board. I measured the power from this cable with a multimeter and everything was reading normal. For some reason once I rewired this harness everything seems to be working now.
                                    I’ve done dozens of 20–50-hour prints with no problem so far. Updating this post in case someone is having the same issue. Check the power from the main board to the tool distribution board.
                                    dc42undefined 1 Reply Last reply Reply Quote 3
                                    • chrishammundefined chrishamm has marked this topic as solved
                                      dc42 administrators @charliedrums
                                      @charliedrums I'm glad you solved it! Thanks for the update.
